- help me find a 3 inch. intake pipe!!!
- Lubrication...
- Got the 2000 model H22a4 lma's, but which .040" washer?
- All Motor "Street Car"
- I need help with my engine
- Which header has a 3" flange.
- K series engine specialists?
- Theory, How much HP can 2.5" exhaust support
- type r trans or gsr
- Head swap on an F22
- header with 2.25" collector
- where to find b20z??
- b17 head on b20vtec setup practical?
- Header help
- would a exhuast cut benifit na setup
- does gsr girdle fit b20
- Restrictor design for optimum power
- H22 cam questions/concerns
- Max Lift on Skunk2 Pro2's
- Wtb piston
- can i run blox valve spring wit Itr retainer?
- Fuel Pump question
- g23 build question
- ecu
- Where to purchase (Testpipe/highflow)
- Catalytic Converter question
- Basic Build help....GSR
- Please help-head? And crankshaft?
- ideas for a b16 header
- just finished my b20vtec build....
- ANR compact or hytech Tri-Y Replica
- oil pump ?
- help piston ring!!!!
- stock rubber intake arm ek9
- b17 crank in b16a2 worth it
- Help w/ vtec & idle
- GSR Build...
- all motor sohc
- all motor build plus nitrous ?
- RS machine pistons?
- ls/vtec oil line
- valve seal????
- This has something to do with CC Cylinder heas success
- cam question
- itr retainers with crower dual valve springs?
- Camshaft timing
- The right parts
- what ya think
- Suggestions on building a all motor LS
- ls/vtec ????'s
- b16/b18c1/b18c5 oil pumps (usdm) Lets discuss part #'s
- CCcylinderheads!!!
- head codes
- RS machine 84/84.5mm pistons discontinued?
- oem outer valvespring colors?
- B16 Cam Caps the same as B18C1?
- 87 Accord - Broken cam - why?
- H22 final drive for all motor set up?
- stock ported h22 intake manifold advantages
- 2.1gsr dart tall block
- ACL Vs. Honda Bearings
- 1st startup, lots o smoke:( code 72/73
- bisimoto header question.
- lsvtec stroke good or bad?
- My B16a Dyno, what do you think?
- B20 vtec or g23
- question about donut fit for a header..
- ls vtec
- B18C1 based "B20VTEC" questions
- Advice: Header or Headwork?
- valve lash question
- Can I run PCT/CTR pistons with a P72/GSR Head?
- For those with mini-me setups, would you recommend it?
- B16b + ls crank and rods?
- My custom experimental ITB setup on my D14
- Hondata s200 and s300 question
- Ls stage 2 crower cams idle
- GSR w/ LS crank and pr3s - Cam??
- Need ideas for a build 99sir/b18c
- Any suggestions?
- ls crower stage 2
- most power with exedy organic clutch?
- LS Rod Measurements
- B20Vtec top end conflict
- Tuning on e85
- First B20V build about to start
- What is REQUIRED for a motor rebuild?
- B18C Type R
- D13C mods
- pro+1 cam timing settings?
- want to know how fast my N/A run
- How would flowmasters sound?
- All motor Ls build Questions
- Bad injector driver?
- H22 VTEC disenguagement issue
- b16b ctr??
- 95 Civic D16z6 or JDM D15B V-Tec-E?!?!
- throttle body size
- spark plugs for a B16a???
- Building LSVtec
- Fuel Recommendations
- Few Questions/Camshafts & setup
- flanged/t sleeves
- LS VTEC w/ ITB Idle Issues
- H22 Type S Cams
- skunk2 b16 i/m on gsr head?
- Need help on budgte build from experienced builders
- Broken Magnets
- GSR in ej1 piston and power concerns
- Exposing your air filter??
- Building info and valve tool question !
- Piston side-load and the affects of bore size
- rpm limit of stock ls retainers?
- goal 200whp gsr block type r head?
- B20 VTEC Instructions
- B18c with CTR pistons ***!!HELP**!!
- help with b16a
- Spun bearing damage
- Honing block???
- Help on pro 2s
- -->All motor Daily LS Build!<--
- Bearing Question?
- Header Ground Clearance
- Ls crank in a gsr block...oil jets???
- Help** installed hondata intake manifold gasket now smoke out exhaust
- fastest b-series N/A
- Need input on cams for lsvtec
- ls w/ CTR crank pully & gsr water/oil pump
- be carefull on ebay
- d16z6 vs ls vs b20
- spoon throttle boby question
- d15b in a 1997 civic ex
- B20b with a b18 head or gsr head?
- B20vtec Build
- b16 crankshaft end play?
- ls/vtec dowel?
- K20a2 Rocker Arm Assembly Question
- Simple swap question
- h22 type s cams measured
- B18c HEADER
- ls motor questions
- H22 Header question??!?! can it be done?
- buddy club Spec 4 cams
- MSD Pro billet users.
- ls rod bearings
- Toda B Cam
- 13:1 CR B18A with Type R internals
- blox type a on stock b16 valvetrain
- Tuners chime in. So you rented dyno time...
- What Tires Are you running
- questions about B20 in 95 ej1
- Bseries Intake manifold Adapt to a H22
- Stroke Question
- Critique my GS-r build
- intake and exhaust valve clearances
- collision problems?? ls vtec
- Fuel pump Issues
- Stumped on my build. High compressions pistons..
- I'm locking VTEC: I need some experience tips.
- Help, car won't start
- H24X cam specs?
- needed mods to cam an ap1 s2000
- possible new b18c1 build to come need support and advice
- header design discussion
- floating and pressed pins>>help
- Post Your Nitrous Set Up's
- what else?
- Piston rings?
- timing belt TOO tight?
- Nitrous Install
- reliable fun built motor?
- need help with my slick size...
- p28 a52 ecu question
- AEBS IM vs B16a Stock IM?
- Poor's Man Type-R HELP NEEDED! ASAP!
- All motor spark plugs?
- Piston Identification request
- Main bearing clearances
- H22A Crower 3 Setup Help
- Need Help: New Built B...Smoking
- h22 rebuild
- D VS B weight!
- questions about b20...help please
- ignition setups
- B20z2/VTEC Build !
- B18c Type R
- Race fuel
- Performer X Manifold overkill with ITR cams?
- fresh built ls vtec and wont go over 3000 rpm...need some input!
- Kinsler ITBs for H22 lovers...
- Need some input on measuring p2v clearance.
- can i squeeeze more power...wit lil money..B20Z-V
- b16 oil pan gasket work on a gsr motor?
- ls vtec idel prob
- n/a 3 piece front end???
- noob question
- Blowby?? need help
- affect of tune on new header
- Build spec sheet of my 12:8:1 comp motor.
- AEBS and Professional Products Whirlwind Intake Manifold
- not degreeing cams...
- YCP Pistons or RS Machine Pistons on B20/vtec
- ITR Brian Crower Stg2s
- d15b8 block w/ d16a6 head
- Head Flow and Cams question
- 1st Post/B20VTEC build questions
- How can I tell if my 98 honda civic EX has an AT engine or MT?
- Need cam help please
- Wondering how much power ...
- $50 B16a block..What should I build
- Stamp on head?
- what igintion setup's is everyone using on n/a b16
- B20Vtec Basic Allmotor Build *Australia 12.9@108mph *4/2/09
- want to hit 230whp
- poor mans type r b18c1 block with b16a head
- No Start After Xenocron Fuel Pump Install
- Stock B18B Cams vs. Upgrade
- Keys to making power
- Anybody else ever use the CBR1000 carbs? Keihin I think.
- nitrous on an ls
- H22 camshaft Crower3 or Pro2
- flat and dish valve combo question.
- Are 370cc injectors ok for my set up
- bolt-on or lightweight
- how do i tell if i have GSR cam?
- Custom h series intake manifold plenum
- Does this sound like ticking LMA's? Video included...
- Help!!!!!!!! H22 in 99 si
- gsr manifold
- P30 Pistons/LS Rods
- Did Comptech ever make a 4-1 B-series header?
- Noob throttle body question
- Crank alignment sensor problem in OBD2 car
- does this work?
- cam choice question.
- Spoon block blade/ Function 7 5-Cap Block Girdle
- some header tests
- 2.0l gsr build??
- Non-vtec b20z headgasket & cams question
- NastIE Built B20V on a budget....212whp & 160TQ
- AC compressor + AC bracket
- ***********b20vtec build and dyno graph*************
- B18C1 issues...
- b16a built top end
- not gettign oil pressure to vtec solenoid port
- em1 4.9 finale drive
- Oil hole on ls rods?
- Project Heat Insulation
- GSR build
- LS Vtec build OBD0 to OBD1
