PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. f22a build
  2. F2b integra Q's
  3. Insight on choosing GSR Internals Plz!!
  4. Aaron's 190whp+ B16A Build
  5. Cams on all stock H22a4
  6. need advice and help
  7. TWM ITB Throttle problem
  8. b20 build questions.
  9. Honda Accord 2002
  10. b20vtec
  11. Rebuilding the bottom end of B16a2
  12. my gsr build
  13. B20/VTEC Build
  14. Gsr Compression
  15. Does anyone have measurements of the stock S2000/F20C/AP1 camshafts?
  16. Oil Change Guides for Hondas
  17. B18c type r block and B16b type r head car hit redline at 7000rpm????
  18. which retainers?
  19. why do my valve spring retainers keep cracking?
  20. HCA B18c(5) Revised Project Girlfriends Car...HighCompression Auto
  21. Gsxr or Hayabusa Throttle bodies
  22. b18c swap in 88 rex please help!
  23. Good and Bad about supertech pistons
  24. Gsr block damaged. Cheap alternatives
  25. Can I change rod bolts without changing anything else?
  26. D15 dual vtec aka 3stage d15 aka d15z* and my findings
  27. Skunk2/CTR cam LSA
  28. would a b16 all motor out perform a lsvtec all motor for drag?
  29. hall effect sensor tps on twm itb's
  30. Options of HP gain through n/a engine.
  31. Explanation of ITBs
  32. F22b1 head swap on f22a1
  33. ITR swap EK in 12's????
  34. D16y8 in my ej6 questions
  35. Good news for B series LMA's
  36. Semi build head??
  37. quick all motor ls build question
  38. weight and viscosity
  39. oil squirters on b20v, possible?
  40. Need opinins about Hondata map
  41. Flywheel Seal Issue
  42. Blox type b exhaust cam seems hard to turn
  43. camshaft refinishing/polish
  44. How can I make a reliable 12 second daily driver
  45. NEED HELP, think i blew it up
  46. Z6 Manifold issue!!
  47. Fresh Ls Vtec falling on its face
  48. car starts hard ...
  49. b16a problems need a little bit of help
  50. 85X89 ls-vtec
  51. LS supertech dual valve springs
  52. LS, b16 pistons. Need to rebalance?
  53. code 7 tps problem help!!!
  54. LsVtec Headstuds in a B16 ???
  55. LS vtec Timing
  56. How many times can you reuse main bolts?
  57. performer X , skunk2 pro series OR VICTOR X ???
  58. Looking to maybe buy a engine
  59. GSR header
  60. Pretty wild that this guy dropped a K-motor in a Lotus Exige S!
  61. "MINI ME" dizzy/tb QUESTION
  62. My G23
  63. What would of caused this failure ?
  64. best cam for Y7/Y8 mini-me
  65. ITR to B16 intake manifold problems...
  66. rebuild help!!??
  67. Fresh B18C1 Rebuild Weird VTEC Engagement Noise
  68. Do all American market J engines have exhaust manifolds cast into the heads?
  69. Want to get 180WHP+ with Stock Block B16A2
  70. Semi-built b15b turbo or stock gsr?
  71. Stock gsr swap
  72. b18b running at 1600rpm idle throwing cel 3 & 10
  73. Sry another CTR piston thread
  74. My cars confused, it's running like a WRX
  75. Cam and ecu question
  76. ej1 b16a2 swap help me please!!!
  77. Omni Power 68mm vs skunk2 alpha 66mm/70mm
  78. can my stock fuel pump handle this?
  79. Rpm issues.
  80. What causes cam/pad wear like this?
  81. Too much cam for this setup?
  82. frm liner pistons in a non frm block
  83. NPR Rings on Wiesco/CP pistons
  84. arp head studs interchangeability?
  85. who modifies k24 crank to fit h series block
  86. how many hp can u get from every mm over ??
  87. opinions? header, intake
  88. itr head upgrades?
  89. '94 Ignition Failure
  90. Does cranking pressure matter?
  91. b18c1 build question
  92. help with cam/headerselection for built b20
  93. ►► July - August | All Motor Classifieds | FS & WTB ◄◄
  94. What should I do? B20v
  95. B18CR - Cam suggestions, Blox Tuner vs Competition?
  96. B16 build Questions?
  97. B20/Vtec Camshaft question
  98. H22A4 main & rod bearing selection
  99. build imput on ITR or B20
  100. B16a pro1 or pro2s?
  101. T1R Test pipe ad exhaust question
  102. sheet metal diversion(?) plate thing to direct airflow
  103. k20 retainers itr springs & b16 vs b18 fuel rail
  104. K24A2 oil pump timing procedure???
  105. comptech exhaust
  106. camgear settings for obx stage1 cams
  107. B20Vtec Head Gasket Question
  108. Help on deciding my N/A GSR set up! pls
  109. db8 quarter mile?
  110. can thin head gaskets cause excessive pressure in cooling system?
  111. pcv????
  112. best way to cut out valve guides when porting a head?
  113. ** Tunned B20vtec Build **
  114. GSR Head/B16 Block.. Need info
  115. header?
  116. Race gas vs pump gas Question.
  117. need step bye step b20b with gsr head
  118. 1986 LXi 2.0 No Start
  119. ITB's or skunk2 intake???
  120. HELP!! LS bogging and running rich
  121. hondata throwing code 11(overheating) but temp gauge says its not
  122. B18B1
  123. INTERCHANGEABLE ? JUST KILLING TIME.
  124. Low Vacuum pressure when past 7.5k rpm
  125. Where to get pg6 pistons?
  126. Best muffler for a built B series
  127. ANYONE HERE USE JETHOT
  128. Price on used CP pistons with Eagle Rods
  129. b16 spring retainer identification
  130. [WTA] radiator
  131. Victor X or Skunk2 Manifold on my 188 whp Ls/vtec??
  132. Help me reach +200whp
  133. High comp NA D-series setups - What are you running?
  134. Custom 2-part exhaust?
  135. Endyn Bump Stix cams
  136. H22 crank pulley damper breaking up (2k miles)
  137. Need to find out what block I have please help
  138. LS/VTEC problem
  139. LS/VTEC or not???
  140. Tranny question for all motor
  141. most power out of b16 cams
  142. My Toda B20, to upgrade valve train or not..
  143. rrc manifold - what tb fits?
  144. gsr head & Si bottom.compatible?
  145. GSR with notchy shifting trans problem?
  146. what horse power do you stop losing traction in a gutted hatch
  147. Main clearance too loose???
  148. Mezeire water pump...and how does it work??
  149. how can i find out my real compression numbers?
  150. h22 iacv
  151. Am i OVERcamming motor?
  152. B18C1 Bearing Clearnace, I Need Technical Help
  153. Is there any difference between GSR and Type R rods?
  154. Eg w/B18c died and won't start back
  155. I or H beams, and which Pistons?
  156. Comptech Icebox with AEM SRI
  157. Best size Injector?
  158. the last step on my build ...what kind of cams???
  159. h22 main bearing ?
  160. injector o-ring for twm
  161. b18b1/b17a1 head build !!
  162. B18C5 Toda C Dyno results
  163. CTR VS Skunk2 Tuner 2 on JDM GSR
  164. Max Bore..?
  165. B18c-R timing issues
  166. all motor b20v with STR intake mani.. any input?
  167. JDM B20B help!!!
  168. B20Z auto into EG
  169. Guidance on F22a/b single cam.
  170. What intake manifold will bolt up to my skunk2 66 mm throttle body and my 91 hatch
  171. B16A2 Query
  172. Question: Building B18c1
  173. Which camshafts for B17A1 build?
  174. Ref/ Bar'd USDM ITR in a EK? can it be done?
  175. Maximum TB Size.
  176. Password JDM carbon fiber intake
  177. Runs distance::dieameter and relevant plum sizes
  178. Rebuild H22A4 vs getting new H23A VTEC?
  179. Inland Empire Help!!!!
  180. My B20vtec 13:5 CR Build
  181. Sticky Situtation
  182. k20 injectors on b20vtec
  183. Hytech replica big tube or Ib spec jg edelbrock header
  184. My 1st LSV build just about done and ready to go
  185. Questions after first start up
  186. B16A2, how to gain more power?
  187. Blew up my craiglist special! What should i put in it and where should i get it?
  188. B16A2 + Skunk2 Pro 1 camshafts
  189. Getting back in the game B18C1 build *input needed*
  190. header design cheapo vs good names
  191. 2002 Civic EX timing belt questions
  192. just looking for some advice
  193. Looking for B16B build advice
  194. B-series bogging/hesitation
  195. HTM, H7M, some sort of stamp on GSR head?
  196. FIRST TIME BUILD SUGGESTIONS PLEASE
  197. First time building a head suggestions please
  198. Which is a better build LS/VTEC OR B20/VTEC
  199. Possible P2V clearance problems.
  200. B16 Fully ported Vs GSR Fully ported
  201. d15 motor work ? or just a turbo or both?
  202. need help to put skunk2 manifold on gsr
  203. K20 fuel efficiency
  204. rods
  205. Why does everyone around here care about horsepower?
  206. B18 oil pump on B16A2 engine
  207. Catch can experts?
  208. H series: OE red main bearing?
  209. crank scrapper or knife edge?
  210. b20v
  211. B20-V All Motor Build.
  212. sleeved block boring
  213. 95 civic EG flooded spark plugs
  214. B18c1 block question
  215. Anywhere else to get the FJT Superkit?
  216. Buying a B16A2
  217. To retune or not?
  218. Which direction to go with my build? ls vtec.
  219. f22b1 vetc swap needs help asap
  220. Cam help
  221. ITR intake manifold question/re-assurance
  222. Help Recommend Exhaust Size
  223. NEW B18C1 Build what pistons should I use?????
  224. F20C piston compression height- someone prove 1.181"
  225. injector question....
  226. Arp head stud
  227. ls vtec build no budget!
  228. H22 with Xcessive intake manifold reviews and dyno.
  229. valve springs?
  230. What rpm should i set vtec engagement
  231. B7/Z6 Mini Me
  232. First Build Em1/Gsr Swap Lots of questions!!!
  233. H22 264whp / 185wtq
  234. Fresh B18C, no oil pressure??
  235. First Build-LS Vtec into a 99 SI (Pics!!)
  236. Which of these wires do I connect for O2 sensor?
  237. Can engine ID be any more confusing?
  238. pro2s w/ itr outer portflow inners
  239. 85x89 which pistons and compression?
  240. stupid question b18c1
  241. B18b1 stock rebuild
  242. What header to run on my b18c1
  243. ferrea valve locks
  244. 85x89 LSV which header?
  245. race fuel
  246. Opinions on NA B18c1 P&P
  247. oem or cometic hg?
  248. How do I find out how many degrees I can safely adjust my cam gears?
  249. Turbo'd B18b misfire ?
  250. exhaust question for my b18c1
