PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 [182] 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. GSR RODs on GSR Pistons Removal Question
  2. 12:1 comp, what size injectors will be good?
  3. f22 convert to VTEC
  4. Alternator Help
  5. ctr piston & eagle rods will it work 2gether?
  6. Good springs and retainers
  7. LS/VTEC allmotor?
  8. Buddy Club Stage 4?
  9. b20 w/pr3 head vs. b18c5 (trade in mind)
  10. Mad by Rage Design? headers? where can i find them?
  11. compression wacked?
  12. Ls Vtec Problem can Some one help me
  13. When is 2.5" piping necessary ?
  14. non vtech f22 conversion to vtech
  15. Big throttle bodys
  16. Catalytic Convertors!
  17. ATS!!! make something for the Prelude!!! (final drive)
  18. ARP head studs and stock bolts. Searched.
  19. which injectors have a better spray pattern..rc or dsm
  20. Prelude Injector Size?
  21. d16y8 hang with gsr's?
  22. what's best b16 or b18 to all motor
  23. b18c gsr dyno results
  24. Has Anyone In BAY AREA had DNR Performance do headwork?
  25. Repeated question <----- ANNOYED
  26. Repeated question <----- ANNOYED
  27. honda pistons
  28. Exospeed Race cam...love it and hate it....
  29. hondata
  30. what parts for the ls vs gsr
  31. b16 head and block milling will timing belt tensioner take out the rest of slack?
  32. test bin file for ITBs using Crome for OBD0 and OBD1
  33. ls swap to civic
  34. need suggestions on my NA B16a
  35. im and fuel rail good for setup, which ones?
  36. WHAT CAMS?? BC3 vs. S2S2
  37. 2.75 inch exhaust piping for CRVTEC?
  38. Whats so good about high compression?
  39. any downside of boring stock GSR TB?
  40. Oil filter too heavy???
  41. Up the displacement then destroke it, uumm... will it even work?
  42. Forged Crank? Worth it?
  43. Boostfed built Forced Induction Motor but NA??? WTF?
  44. obd1 and obd2 gsr cams...?? the same...
  45. SIRG B18C Pictures
  46. Engine Harness
  47. pgm-fi vs. itbs
  48. Engine builder in the Pacific Northwest
  49. I felt left out, new dyno #'s
  50. crower s2 cams? guys with these let me know experiences
  51. valve lash...crower stage II's?
  52. Skunk 2 stage 3 cams
  53. Ls/Vtec questions
  54. Will ls stock air box and intake tube fit b18c5?
  55. done researching...just help me decide
  56. Compression Test: B16A2 motor, bolt-ons, p&p, etc
  57. What would I need to get in order to hit 11's in my car with street tires?
  58. which crank to use with 2.0l?
  59. b20 high compresion or low
  60. b20 crankshaft pulley
  61. Ls/vtec at 500miles...tuning, compression, ect need input
  62. b20 crankshaft
  63. Can anyone tell me what chip this is?
  64. b20 crank in gsr blocK (searched)
  65. b16 or b20 a CRX? What would you do and why.
  66. OBD I Dyno?
  67. b16 swap fuel pressure?
  68. weaponr race header... weapon r b16a
  69. My Buddys ITR NA Setup
  70. Car only moves at high rpm!?!?!?
  71. Toda Spec B's & Dual Valve Springs
  72. ITB's on a b16a1
  73. CTR crank pulley need some info with pepz who have this on thur Bseries engine
  74. After so long in waiting, my project is about to be done...
  75. ctr cams..quick no0b ass question
  76. what are the best cams, cam gears, valves, retainers ect.....Head for b16b
  77. Ignition timing???
  78. no0b question......
  79. Oil Squirter Question
  80. jdm d15b????? need help!!!!
  81. 250whp + = what exhaust?
  82. Are these Cunningham rods???
  83. b16 SiR2 buildup help
  84. Hondata in stock GSR
  85. what happened to my valves...
  86. I need some advice... so I'm turning to HT experts.
  87. aftermarket pistons worth the money?
  88. USDM B16 VS JDM B16
  89. yes or no
  90. What Cams are you running in your daily driver?
  91. help in engine swap
  92. Proper ways to P/S removal please help
  93. Valve Spring Rates
  94. B16 failing emissions......
  95. Your opion
  96. Engine Dyno Location in So. Cal???
  97. help!! with my valvetrain debate on cams
  98. HeLP me With My Motor b18c1
  99. SOHC vtec head questions
  100. How much compression with Toda B
  101. ITB's vs ported intake manifolds? Gains just not there or what?
  102. how much can you go over on a b18a1?
  103. fuel pump
  104. Buddy Club 3+ vs. Skunk2 Stage 1
  105. Question about girdles,align honing and sleeves
  106. Take a look at this...
  107. es oval muffler!
  108. 86mm ok for daily driver??
  109. Wiring Help on a 94 GSR in a 88 CRX
  110. disadvantages & advantages of replacing O2 sensor are?
  111. AEM 400hp All motor H22a STOCK INTERNALS
  112. ls/vtec with air conditioning? anyone still have it?
  113. best headers for civic type R
  114. Motor Building Question...
  115. Jdm B20b ? cams, header, exhaust
  116. Anyone ever succeeded in creating a quiet custom exhaust?
  117. Nitrous on High Compression?
  118. h23a buildup
  119. help where to find small red nos button like on steering wheel.
  120. break in on b16
  121. B18C1 Setup
  122. compression test ls/vtec
  123. lsvtec build ctr/arp/honda oem parts w/ crazy header
  124. Installing cam anything I'm missing???
  125. which throttle body?
  126. Type R Final Drive -- Ls Tranny???
  127. injectors....
  128. b16 with 62mm throttle body?
  129. biggest bore on b18c1 sleeved??
  130. MY NEW SETUP
  131. *Help* Pulled my CEL, need to know which code this is!
  132. 1994 Civic motor running problem ?
  133. Any Silencer dynos?
  134. bc stage iv
  135. b20 vtec build up ?
  136. Chipped ecu + hondata
  137. my all motor ls/vtec setup
  138. sohc non-vtech wants to go sohc vtech
  139. ls/vtec running like shit
  140. Does anyone know how to change the master/slave cylinder?
  141. milling head on b16 how much?
  142. B16 mods!!! help
  143. Daily driver upgrade- ZC cams?
  144. Finally into the 11's..... 1.8l on 91 octane...
  145. WTF: I Give The Car Gas and it drops in rpms like a big gulp then recovers but sputters.HELP
  146. Could MSD SCI + external coil hurt my dyno #s?
  147. power mods for the moeny HELP
  148. stroked 1.8
  149. why the hell cant i post in the classifieds?
  150. Sway bar and traction tech
  151. b20/vtec set up. please rate it and tell me what to change.
  152. are my itbs too long?
  153. civic type r CTR pistons O/s Oversized ???
  154. anyone have a sound clip of a ls lopey idle
  155. is it worth it to build my b16?
  156. Race gas necessary at some point?
  157. Pic's of Blown Motor.
  158. I want more RPMS.....
  159. skunk2 stg 1 valve lash?????
  160. Knuckle arm (passenger side) bended? wtf omg help
  161. Endyne crank girdle question
  162. Anyone dyno Buddy spec 4's on a mild compression application?
  163. K20 compression question
  164. good manifold is...
  165. b20 tuning
  166. ANR all motor header!
  167. best motor for a crx
  168. ITR Cams on Ls/Vtec
  169. emissions time!
  170. Frankenstein questoin. Need a straight answer.
  171. Revenge on sucky B16 1/4 :)
  172. espril exhaust? esperil exhaust? WHAT"S THE NAME!!!
  173. ? about setting up release for crankcase vapor
  174. Do yall think that this ECU is hurting my engines performance?
  175. Sputtering Question.......need some advice asap ......
  176. tunning question.....air temp vs fuel
  177. megan 4-1 header or jdm dc sport 4 to 1
  178. b18a1 head on b20b
  179. Grindin 3rd and 5th
  180. a little help
  181. i'm new ..need some help
  182. Which cams?
  183. Where to buy K24?
  184. idle problem
  185. Need opinion on my h22a4 swap
  186. B20 With LS Intake Manifold Problems. (Injector Related)
  187. advantages and disadvantages of converting from obd0 to obd1
  188. clearance
  189. Help with low Hp numbers
  190. think this can hit 240 hp????
  191. pr4 ecu upgrades
  192. poor man's type r emissions
  193. hmm i port my SOHC myself and match port
  194. Skunk2 IM: CFM???
  195. are these b16a cams ?
  196. planned lsvtec setup
  197. broke into the 12's
  198. b16 build bottom end or just the head
  199. Need help with Piston to valve clearance with Toda Spec C
  200. Portflow inners Redline??
  201. Toda Spec A cams....opinions?
  202. Urgent why wont my crower cams turn.??? H22a question.
  203. B16A1?
  204. DH racing??
  205. Aftermarket rockarms?
  206. Stupid underdrive pulley, no timing mark, how do I time?
  207. airmass thunder muff cat back exhaust system
  208. B20 bottom end + B16A2 head = ...?
  209. Buddy club stage 4 same as skunk stage 2's???
  210. jdm itr final drive and ls 5th gear
  211. Only have one cam.....
  212. Quick easy post, i need ot change my thermostat how i do it? and a quick thermostate problem...
  213. B18C5 w/ctr pistons, crane 2 cams dyno results
  214. can a fully built high compression motor run direct port nitrous or any form of nitrous?
  215. EIBACH VALVESPRING FEEDBACK?
  216. jdm b18c typer???
  217. Looking for a header.....used even for set-up
  218. NEED ADVICE ON ARP PRODUCTS
  219. More Hp
  220. bisimoto
  221. Baseline dyno for b16 and tuning b18c
  222. Skunk 2 vs BLOX intake manifold...
  223. HELP! Need to know about valve seals
  224. Wicked cams stage 1-3 specs!
  225. whp discussion...
  226. P30 Pistons in B18C5
  227. JDM ITR motor in Civic Si DYNO Sheet
  228. how does the oem windage tray work?
  229. problems with a VTEC head, used in a ls/vtec setup
  230. anyone putting up good numbers without the port and polish?
  231. VTEC--limp mode with stock ecu, sputters before engaging with Hondata; CEL 3(MAP)
  232. Built GSR.. kinda new to this board..
  233. B20 pistons in B18b Block....?
  234. can i remove the stock block girdle on 9k b18c5?
  235. HIGH CR on stock cams
  236. 16 BROKEN Valve Springs
  237. Adjusting valve timing
  238. B16 Head w/GSR Cams
  239. B18C1 head Vs. B16A head
  240. h22 with 200 whp?
  241. What u guys think of this quick setup do my daily driver???
  242. can 200whp be achieve on 81mm bore?....
  243. a good Reliable machine shop in OC?
  244. Need Machine Shop in OC for my build? Help anyone.
  245. GSR Crank/B18A Block-motor heads please enter
  246. question about crower cams and ls/vtec
  247. new headgasket, when doing cam install?
  248. Custom H22 cams
  249. JDM Motor Swap wiring questions.......please help.........
  250. what to look for when buying a used big bore block?
