- n00b question......
- Some advice for my new car...
- Anyone know H22 Wrist pin size??
- A few questions about the STR Throttle body
- Need help w/Engine problem.
- Need help with exhaust setup.
- Another B18C post-- experienced members needed for advice.
- which cams
- Check out my new header (SMSP bling blang!!!)
- Got a chipped p28 on my h22a and the vtec doesnt kick in till 6700 rpm
- Want To Go All Motor With My LS B18B1, Is This a Good Setup ? ? ? Don't Boost My LS?
- need advice!! on building b20-Vtec
- what plug wires everyone run nowadays?
- Buddy's b20vtec build up finally finished!
- SHORT SHIFTERS!!!! are they bad for your tranny
- where to get a good tranny (so cal)
- My LS All Motor Build...quick question
- ANR header and b16
- Can this setup handle a 50 shot safely?
- Crower 402 camshaft broke... Is it okay just to replace the camshaft?
- do i have a freak motor? B16a...
- d15b cam?
- (SEARCHED) B20Z W/B16 HEAD CTR CAMS
- skunk2 cam gears, timing belt walking..wtf
- 8mm or 9mm arp rod bolts???
- official build sticky?
- Oxygen sensor placement and it's effects?
- e-cutout on allmotor car...
- Convince me to go all motor!!
- Guys Tuned with Uberdata/crome/ ect. report here.
- Imitation!??!??
- rocket m22's vs. buddy club spec 4's?
- ITB's
- ACT Prolite or streetlite flywheel. Pistons????
- H22 without VTEC WTF?? Need help
- water and oil pump
- one crazy ass header???
- PCTs on Pr4 Rods Question.....
- Wondering about these sleeves...
- Need help with my b16 build!! Please Read!!
- how many mm in ctr pistons
- 1992 honda ex auto tranny
- 2.0L NA Integra Type R Video
- How Much Hp will you think ill get with this set up
- Bearing Color Code
- OEM builds
- b16 running 13's???
- Numbers for my JDM ITR motor...
- where to DL crome?
- need help with setup
- itr vs b20z
- type s pistons vs oem h22a(strength??)
- Crank pulley not turning while running?
- 91octane only need more Socal.
- BLOX intake manifold
- 1st gen B16a head port and polish?
- honda part numbers for jdm parts..need help!
- 97 H22 crank in H23a1?
- Hondata question
- pistons rings
- b16 cylinder bores and reboring
- pics of my new stroker b18c build
- aem fuel rail usefulle?
- smoking blue intermittently...need help please
- City-Speed B18C5 Heads....
- ls/vtec rev limiter
- Cam selection help
- What itb's will clear the hood in a k20 swapped EG!@!
- allmotor fuel set
- b16 All motor
- RPM Services....
- I need a Crome tuner! northern Indiana.
- help identify this ecu.....87 pm6????? zdyne chipped apparently??
- Opinions on GSR build...
- Header Wrap = Longer warm up time?
- Help me build my motor.
- all motor problem
- shot peened rods
- Itr stock oil pump on 12.5 comp. fine?
- Fully Built GSR in DB8 4 Door Integra Times?? Need feedback please...
- neptune+ ITB will it work?
- EXPERIENCES! Nippon Pistons & King Bearings
- ITB Kit Installed and tested makes 280hp(flywheel) on K20a2
- Which header for this setup?
- Will this exhaust setup pose any problems?
- K Series Header thread
- ITR rods on a GS-R crank what bearings to order??
- another p8r head question
- need help with springs and ret. Please help
- Accord Camshafts
- whcih valvetrain is better for a lsvtec not reving past 7200
- Broke as a Joke GSR ALL MOTOR BUILD.... NY Style...
- need help with cams...
- need to take motor apart....help decide
- San Diego Hondata tuners
- Throttle Boddy? Can you go too big?
- ITB in a GSR?
- '95 gsr into a '95 hatchback cx
- Cool, my header came in today! (AN-R)blingness!!!
- another LS/VTEC question
- d-series
- What would it take to hit 240 wheel in my ITR?
- How many cubic inches can U get from a B block?
- All motor lsvtec buildup
- f/hybrid
- ATTN: LS/VTEC GUYS!!! what's your valve lash?
- d16z6 cam install question
- was wondering how much bet how much better
- anyone using a E-cutout?
- GReddy Evo2 Catback......
- Dyno videos of 250whp all motor FROG
- what grit for a hone?
- the little header that could (no 56K)...
- Please post your Toda B or C Dyno's
- bearing may be going out........
- tell me what you all think
- B16 All Mota Build up
- How long is too long?
- B-Series Swapped CRX, will ITB's fit?
- 04' vs 05' K20A Cylinder Heads
- Q on ITBs and Injector sizes
- Strup
- Which is better Block Guard or Girdle?!?!
- OEM Valve weights?? Tried a search and found nothing...
- what gauges are you running?
- Took header off and exhaust runners are black!
- skunk2 stage 2 cams
- Tech 43 kit questions?
- b16 dowel pins
- b20 block with a b16 head?
- Pinging
- Air Horn????
- ls/vtec ?
- rough intake porting
- which cams for 98 gs-r??
- where to find abreviations page
- Prostreet tuning
- is toda 4-2-1 header a good deal for B20 vtec drag racing .. ???
- Rebuild engine, CTR pistons, Brand new ITR head, but no power....
- dual throttle bodies
- Help bringin up my Hp numbers...new to this...
- oil pressure gauge questions
- Plastigage measuring discrepancy
- Cam in a D16z6???
- Best pistons for this application?
- spot facing
- Full b16b head onto b16a sirII p30 bottom end.
- building a b16
- MSD Ignition w/ Engine Management
- apexi power fc help ?
- What kind of engine mounts are the All Motor guys having success with?
- Type R motor....
- b16 -> b22? possible?
- Compression height database?
- Hondata S100 vs. S200
- How Long the Engine need to break in?How Many Km?
- B16b pistons in a B16a?
- Header Decision!
- Good Chicago tuners?
- a few important fuel rail and afpr questions
- building the b16
- Jdm shit headers
- cam cap order problem
- D15b7 block questions.
- 93 b18a swap into 94 civic ?
- SOHC Vtec or LS
- intake cam is a hard to move
- ls nonvtec
- b17 crank and rods in b16???
- ANR header
- I dynod my b20zvtec last night. dyno sheet inside.
- DCR Intake Manilfold or Skunk
- How can I test my obd1 check engine light
- How to make my gsr a 2.0l??
- BC IV's or Toda C's
- tips for building up my sohc?. please help
- Auto VS Manual B16 head? help quick.
- Need Valve lash specs for Toda Spec A cams
- My D16Z6 N/A build plan... have I missed anything?
- Question about JDM motors
- >>>ITB VS HONDATA<<<
- b18a crank gsr?
- B20VTEC head gasket: OEM or Cometic??
- gsr vs b16__ which head is better for ls/vtec
- H22 AN-R header fitment problems help!!!
- usdm vs jdm
- Anyone know who makes K24 rods???
- throttle body seems to get stuck, b18c5 aebs manifold with jg tb into a gsr
- Pulling the most out of a Stock motor
- Can someone tell what compression a 1.185 dome height yeilds.....
- Any body use Supertech high compression valves?
- cam install help ASAP
- Which Throttle body
- ACT Xtreme PP, Organic disc for n/a setup + nitrous ?
- 82mm B16 safe?
- omniman 2.5 testpipe stupid question
- dilemma:swap pistons or build head
- B16A VTEC need help
- Any N/A EM1s in the 12s?
- Hondata s200
- 270 whp on a Stock BLOCK ALL MOTOR K20A
- M24 CAMS ON THE STREET
- k20a2 or k24a2?
- what cam do I choose?
- B20VTEC Build Q's
- for track use(auto cross) go with GSR? or Type R? or something else?
- b18c5 or h23a
- Mild GSR build pics
- need your help asap...
- WOOT! The brown clad Santa came by today!
- looking for recommendations on cam gear settings for GSR
- jun3 cams on b18c1 what valvesprings/retainer ?
- what cams should i use for a stock gsr
- Honda Acura K series parts that are needed for ALL MOTOR Projects
- anti reversion chambers in the header?
- What happened to Rev Valvetrain ???
- d15b7 Pistons and Rods
- p9r head question.
- RC engineering b18 Question
- anyone hear of eraceparts.com?
- Flywheel weight Question....
- Length of intake runners for a carb setup.(crvtec)
- A few ls/vtec Questions...
- Buddy Club Spec 3+ cams
- Running real rich after injector install.
- can anyone make me some itbs?
- *** searched FPR***
- Quick Cam Questions..
- 256whp all motor civic
- B20??
- b20 sleeves on b20-v NA motor
- ls/vtec questions....b16 cams with BC3/4 HElp
- Are low pressure valve springs adequate for big cams and high RPMs?
- itr pistons into ls
- b16 stroked stock what to use(searched)
- blox or skunk2 manifold??
- V-AFC question
- h22a4 piston rings
- is it safe to run ctr pistons w/ new oem stock headgasket?
- LS Vtec questions
- eagle rods & b16 pistons?
- What size throttle body for my setup?
- Buddy Club Stage 5 cams !!!!!!!!!!!!!!
- Sleeved blocks/forged pistons -- How many of you use the factory oil squirters?
- Skunk2 cs buddy club cams
- Sleeved B18C's -- Do you run oil squirters?
- question about vtec
- Choosing a intake
- ls head vs. b20 head
- 2nd gen IN cam and type r EX cam???
