- re-using ARP head studs?
- endyn catch can
- Black spot in driveway from exhaust, Is this normal?
- Rebuilt Motor Won't Start...
- Need b20b eg swap help
- throttle body gasket issue with Skunk2 intake manifold
- Cnc head.. What do you think?
- GSR with a noob question about IM
- handicapped by TB size?
- B16A motor
- 84x89 Pro3 Intake Pro2 Exhaust
- mild built gsr, needing advice for a header
- Benefits from 3" exhaust on b18c5?
- Oil Catch Can overfilled
- 92mm B-series Cranks
- 86x89 N/A need advise on manifold options etc..
- Strange high pitch whining sound from 95 b18c?
- Help: My integra boggs on acceleration..?
- camshaft Question
- bore question
- old school JG header edelbrock mod?
- need help, b16b swap!
- Misfire/Wrx sound
- 98 spec Type R, MORE HORSEPOWER!?
- IACV issues on fresh build
- What pistons, lsvtec? b18a1/itr combo
- 14:1 LS/VTEC B16A2 HEAD W/ ITB's
- hytech replica big tube or regular?
- B18C Type R help
- Jap spec engine vs. US spec engine
- Toda B ValveTrain in conjuction with? Oem vs. Aftermarket.
- School me on the b18
- Identify Retainer
- which b series transmission do i have
- has anyone bought a long block from japanese motor services in seattle area washingto
- School me some on H22's
- Most HP on FRM H22 all motor?
- Converting D16A9 PFI to D15B Dual Carb?
- cracked valve seat straigt from the machine shop
- F20b build. any info would be most appreciated
- CEL
- which smsp header is this
- HOW TO TELL IF TITANIUM RETAINERS ARE WORN???
- j32a2 questions
- Timing belt cover - Cam gears
- B20 Vtec safe for road course?
- the bottom end
- Can someone help me ID these CP pistons
- Itb or performance x ported
- Engine balancing...did you do it or not?
- Custom Bike ITBs - a list of diameters, makes and models.
- 92 civic won't shift into overdrive
- Is this way too much for an filter rel and oil cooler?
- Car cranks but won't start.
- 60mm vs 70mm exhaust on a b18c?
- aebs intake manifold or skunk2 on 2.0 build
- eagle rods???
- b18b1/a1 mini-me swap noob
- need help.tuners advice.cam choice gsr?
- 84mm b16 itbs going for 230whp and 0ftlbs
- All motor setup help
- JUN auto b16 header
- Website to buy motors in TX?
- ls vtec in da9 help
- new exhaust suggestions
- A few questions for LSVtec
- Just bought my first prelude, 1991 Prelude Si 4ws. Little help?
- so let me get this straight
- Charcoal canister catch can
- Problem with F22B2 dizzy
- I have no idea what it called??? PLZ HELP ASAP!!
- help w/ obd1 swap in obd2 integra
- 96 Teggy with smoking problem
- Super Quiet 3in exhaust on CRX
- b20vtec skunk2 pro2 losing power at 8rpm?
- JE pistons question
- another catch can question
- Project inquiry: 210+whp f20B NA engine build. Is it possible?
- School me about helmholtz resonators
- Will this work for my head?
- Retanging LS/b20 rods for GSR bearings
- b20 vtec swaps and list mods
- are all honda keepers the same? b d h?
- cylinder head damage
- g23 n/a break down needed!!! using h22a head and f23a4 block
- DIY Camshafts
- Rebuild my H22A7
- B16 crank pulley question
- g23 build.....f23a4 crank in 95 h22a?
- h22a head decking and compression ratio
- Do I need to line bore my cam journals?
- B16 head bolt question
- Jdm 98 Spec ITR Question
- Best way to keep shavings out of intake manifold?
- Where should I buy a JDM motor online?
- Old style LMAs on 94 B16A3 head?
- B20Z2 Questions
- b18b in 93 da9!!!!
- Diamond pistion rings??
- Running rich with Hondata S300 on H22 Accord
- Biggest Diameter Exh. w/ stock Cat?
- GSR main cap question
- Need Help, all motor B16
- b18c1 sounds like a wrx
- Underhood temperatures
- how much torque do i have?
- Help with b20v NA 280hp build!
- Ported Gsr Intake
- cranking the engine on a stand
- clutch question
- b20 vtec build question
- B series all motor gas mileage fuel efficiency.
- Won't start d15b2 engine d16y7 head
- B16a SiR II NA Build
- nippon p73 slugs, PWC for decent ring gap?
- B16a2 IHE making 168whp!
- 2000 Si dyno testing!
- D16y7
- ctr crank pulley question
- Engine dies after reaching Rev limit!
- b series cam question
- bore and resleeve b18b1
- anyone used a 4.92FD on a b16 tranny gears??
- HOW TO: B16 intake manifold on a B20 w/ pics!!!
- Sunrise Motors
- Msd6al-2
- Almost done with my h2b build
- NEED OPINIONS ON MY GSR BUILD
- Intake theory discussion(not the typical noob intake discussion lol)
- Combustion chamber volume-GSR
- My Mild B20 Daily Driver Setup Thread w/lots'o pics!
- Slow process, H22A rebuild
- manifold and throttle body questions
- Headgasket Confusion
- skunk2 pro intake mani ??
- idle issues w/TWM's, ID1000's on B20V
- B series questions
- Spark plug Question: Denso IK22 or IK22G ?
- p30 vs p73
- Time to rebuild my B16A3
- cant decide on what motor
- Hytech replica + Burns Megaphone
- Problem with installing Web Cams
- How about some D series love?
- Has My Engine Been Swapped? How Do I Check?
- Need advice for B18C swap into a 00' LS
- JDM B18C SiR vs. B16B swap
- ls/v high compression help
- need help with civic hatch swap!!
- Thoughts about H22A4
- Stock Block USDM GSR DC2 Into The 12s!
- b16a2 block with b18b ls head
- DD-tech cams
- Running tighter valve lash on stock cams
- do i need a performer x or victor x?
- First n/a build, I turn to h/t for help!
- stock bore/stroke GSR 205whp 139tq
- Are these b16a2 cams or 95 GSR CAM?
- IAT's does their placment really matter?
- GSR CAI Intake AEM Hybrid 3" or GSR 2.75"?
- vtec swap
- F20/22C piston specs for H22 Build
- b20 question
- High Comp Pistons w/ Stock Sleeves?
- RBB VS RBC DD K24A2
- ECU p28 question
- B17 dyno
- just read it. and what can you tell me
- help with b18c build
- Fuel injection problem!!!!!! Need helpp pleaseeee!!!!!!!!!!!!!!
- Need Help with Injectors
- B20vtec in ek HELP!!!
- lightweight guts in b16 worth it
- Deciding on an engine
- ►► March - April | All Motor Classifieds | FS & WTB ◄◄
- LSV OPTIONS
- Somender Singh: "Grooves"
- Preludethan Block fitting question
- Are BC cams any good????b20vtec build
- RMF drag headers
- ENDYNE
- Valve clearance
- B20z Making Cackle sound..
- camshafts for b20 vtec phk
- Can anyone tell if this portwork is decent?
- Simple B20vtec build - 257hp 162tq
- Nah2b DRAG Header
- F22 with h22 pistons HELPPP!! asap
- tapered ring compressor specs
- RS Machine piston rings
- Vtec Problem PLEASE HELP
- hondata s300 on b16
- eagle rod ?help asap
- what is the highest Compression ratio that is safe without tune?
- P&P B20 Head. Worth it?
- CTR cams.
- Weird performance issue after SWAP to a D15b HELP!
- HAMP, Honda OEM, Mobil 1, Wix
- LSV setups: who have kept stock GSR IM for setup..
- b18c5 unknown cams (Name the cam)
- Timing belt issue
- im exhausted
- H23A/H22A vtec engine dimensions
- understanding n/a 1/4 mile time slips
- Blown engine!! R16 to R18 swap!! What parts are needed??
- LS vtec questions
- Best way to lower compression?
- B18b1 performance opinions.
- what valves are these
- b series lightweight crank pulley
- D16 rebuild
- Ls cam in sohc?
- stillen fuel pressure riser
- Ls/vtec compression question?
- My B18C1 Stock Block, Head Build
- B18C6 question/help needed
- 94 GSR motor cooling issues
- h2b or b20v need help..
- b20block b16 or gsr head?
- Need bearing help please
- 94 civic ex d16y5 idle problem
- K series retainers
- twm tps plug help!!!!!!
- need help on gsr build
- extrude hone or PnP intake manifold?
- Are my sleeves messed up
- b16 block
- JDM ITR Longblock Worth?
- h22 head f20 block accord build questions and ideas
- Pro Series Centerlines
- Six Sigma Racing
- Stock piston question???????
- does EW3 = DB15A3?
- All motor build
- Help with CAM choice
- B18c1 bolt ons, id1000's,walbro 255,ported oil pump need advice
- All motor now - boost later
- Noise from timing belt area after warmed up & low idle...cause?
- stuck between oils for break in
- noob question, but I did search. ls vtec stock style rod
- B16b and Skunk2 Stage 2 cams help!
- Jdm b18cr with itbs
- Gsr block with ls crank help!!
- Timing question
- jdm b16a problem!!
- building b18c for high comp
- JDM b18c bolt on dyno tune
- At the risk of looking like a total idiot...
