- Post your stock sleeve ls vtec builds
- Please help, Need advice on b18c5 n/a build
- itr retainers with crower dual valve springs?
- Do I need a retune if i decide to slap on my 2.5 inch exhast from ITR exhaust???
- ATTN Tuners, advice needed...
- Wht Do You Think I Should Do???
- Small NA build
- Type R valve train on my CTR cams
- What do you guys think about "performance" oil pumps - link inside
- Idle problem....
- how much hp will my mini setup HAVE?
- Who has installed JDM ITR 4-1 on a B18c (GSR) & lost power?
- s2000 injectors
- b18c with CTR pistons and TODA spec C cams idle issue!!
- timing belt problem
- Will these pistons work?
- Another what can i expect from my setup thread
- trade
- how to build lsvtec?
- what you guys think???
- what is a better setup for mini , d16y7 with z6 head or y8 head?
- B series stock regulators
- are all the vtec b series oil spray bars the same?
- Video of My Comp4/Street Stock car
- ITB
- Piston to wall clearance
- quick lsvtec question....
- In need of a d series / non-vtec throttle stop or itr one
- gsr pistons
- skunk2 pro2 on standar itr b18 motor??
- Hydro vs cable B16 trany - LSD?
- do i need a p72?
- c/r, gas octane and different elevations
- 70mmtb question
- oil cooler (needed/necessary?)
- crank shaft pulley needs to be replaced but which one and what will it effect ?
- d16z6 block/d15 head/d16a1 pistons comp?
- my cammed jdm itr dyno numbers inside, thoughts..
- good ls-vtec set up?
- h22 cams?? which one!!!
- Crower 404's or JG 303's
- B18C1 build - specs/opinions/suggestions?
- Which exhaust to go with for ~200whp b18c1 build?
- worth it to go all motor h22?
- high compression engine with itbs and a wet system question.
- Timing Belts
- H22 Motor build!!!
- Rs machine cams???
- type r compression question
- compression on stock b16a2 plz help
- b18 stroker vs b20vtec
- Fuel injectors and ignition control system, need help
- question about different rods??
- skunk 2 intake manifold on h22
- b18a all motor compression ?
- all motor sleeved OIL pan?
- Fuel pressure with AEM fuel rail?
- Skunk2 Pro 2 cams not skunk2?
- good compression ratio for E85??
- Another EK with a Performer X, with pics.
- big problem
- Just dynoed. spark plugs white as snow, help!
- PLugs ?
- What is stock fuel pressure?
- Gsr/Type R valve question
- Should I Deshroud my Cylinder Head for an 84.5mm Bore?
- b16a shift linkage?
- JG Dual Valve Springs & Ti-Retainers good for Pro-1 Cams or OEM ITR 200-400WHP
- itr(b18c5) builds
- RLZ headwork, prices and contact info
- F22 Build
- itr cams or skunk2 stage 2 cams
- B18c5 Import
- How much HP?
- dyno problems, motor wont rev past 8000rpm
- Been awhile since i ran a regular throttle body i have a question
- ITR Throttlebody
- blox tb with performer x
- Valve adjustment question
- GRINDING ON D16z6 BLOCK-Eagle rods
- B16 Head - Flow numbers after CNC portwork
- ITR oversized piston question..NEED HELP!
- Engine Coatings
- So Cal : Header Dent Repair?
- The never ending BC vs Skunk2
- Floating piston pin lubrication
- Time to upgrade 1st gen B16, I'm kind of lost, turbo would be to easy...
- Skunk2 cams
- DPR Racing - Portwork? Anyone have any input on them?
- ls vtec motor
- b18a all motor build ?'s
- B16A2 girdle usage...?
- low/slow oil pressure?
- I got stage 2 cams.. i don't know what to set my adjustable cam gears too....
- b18a betup
- B16a Oil
- cp piston question.
- b16 and gsr internals are the exchangable
- 1st gen b16 head for b20z question
- wiseco 85mm piston question
- b20 vtec
- Rod too narrow for journal?
- A ridiculous question
- header questions
- DOHC Vtec
- Where to buy OVERSIZED JDM B16 p30 pistons?
- Piston Compression rates
- Which of these 2 throttle bodies for my mild B16
- lsvtec Oil leak
- Which ECU Is For Me?!?
- DA - CRVtec - Fully Built - GE SKUNK2 EAGLE WISECO ACL ARP RC BOSCH CROME
- b20 vtec build?
- B20a1 Crank questions?
- forged ls build
- Eagle 90MM crank + 84mm bore = ?
- ALL MOTOR GODS - I need your help - # crunch
- ACT performance street disc and slicks
- Rebuild time.
- Stock ls/vtec? Hp numbers?
- head gasket question?
- ITB's on an ITR. TPS wiring and MAP sensor mounting help
- What is the difference on H22's (A) and (B)
- NA newb help!
- fully built gsr Bs or no Bs?
- Torco Premium Break-in Oil
- need some advice
- quick head question
- Higher revving B18c
- 1.5 DPI Engine ECU Code????
- throttle body question.. sticking
- D16a6/z6 Scat H beams
- cold weather intake problems ???
- ips k2 vs. ips kme cams.
- Question about my new build
- b20b
- Adjust valve gsr
- Thoughts on the article that Honda Tuning did with the stroked D16 with 100% OEM parts??? What do yo
- Pics of performerX install in EK chasis
- Help me choose
- Blox stage 2 cams, selling but need info....help
- Forged Pistons and Rods break in period?
- dry sump
- proper injector size 4 all motor
- When does the oem PCV system need to be upgraded?
- b16 heads and long blocks
- Ceramic Coat or Stainless Steel?
- Rev K series Valve Train.
- long ram + Blox velocity stack w/ Filter
- E85 - anyone? pros cons
- Building my GSR - just a few quick questions - ALL MOTOR FTW
- How much power possible with 11.5:1
- Aftermarket Valve Locks Keepers
- CRX b16 pcv black box leaking.......solution to eliminating it???????
- Can someone help me figure out the compression of this setup??
- best final drive and gearng for 24.5MT tyre with 300wheel hp 2.2L all motor??
- Anybody recognize these plug wires? What's their deal?
- spark plugs?
- GSR with cams?? How much torque??
- Exhaust Cutouts
- port and polish help
- crower cams
- Mild Performance Mod Discussion
- best intake manifold
- highest compression on k24 block?
- need help!
- Converting my DD 4wd CR-V into a vtec head
- are theese real Toda stage 1 cams?
- AllMotorRandy.....where are you and where is my intakeż!
- gasket matching an itr intake manifold
- d15 cam question
- D16Z6 High Output Street Build
- So what's the deal with Omni Power Individual Throttle Bodies (ITBs)?
- b18c5 crank
- Motor Build Recommendations To this setup
- ls/vtec
- b16a2 Daily driver
- B20 V-TEC Build (Suggestions, Comments, Advice, Whatever...)
- 02 sensor placement?
- Toda cam question
- SOHC 4-Door build
- GSR block with LS crank/rods compression ratio???
- which injectors size, and which one rc or precision?
- Planing to Build, and i've got some questions...
- Autolite Platinum Spark Plugs
- polyurethane engine mount inserts
- ITR intakes with aftermarket springs?
- did i get the wrong pistons???
- ls v-tec swap??
- JG Engine Dynamics D16A1/DOHC ZC intake manifold
- headgasket fitment
- Porting a B16a2 manifold ??
- non vtec to vtec?
- b18a1 hp
- 2.0l type r
- H22A7 vs H22A4 ??
- ls vtec smell like gas threw exh fumes help
- newbee question
- why are TODA & CRANE vtec killer cams so good?
- b18c5 what numbers for a be looking foward to
- SOCAL! - Help me find a shop for my rebuild!!
- D-Series STS engine...
- rev limit for b16a2 stock rods bolts?
- Header rubbing oil pan.......
- LSV: wats a good ls block setup on a stock gsr head
- lsvtec oil line from block
- susuki tps
- A Few ITB ?'s
- What's the Holy GRail of V-TEC Engines?
- all motor h22a build
- ls crank and rods in gsr block what pistons to run?
- good place for race parts
- 550 injectors on B16A.....
- ARP Head Stud Question
- vavle adjustment
- look that these rods
- cam gear torque spec for skunk2 cams
- B20 Block Pressure?
- piston ring issue or more of a question need help from expert builders
- Import Builders CNC intake manifold porting. Experience?
- honest help please!
- HeadGasket Q???
- torque in b20b and b18a
- My first SOHC port/polish (D16y8)
- WTB: TWM ITBS for H series! individual throttle bodies, ITB
- fuel injectors
- Need help installing my fuel setup
- Black crap all over the back of my hatch
- d15b7 question
- F-series hybrid theory N/A build
- Euro R/Type S H22A Red Top VS. JDM H22A Black Top (discussion dyno's inside)
- stock crank or not
- Removing LMA's
- My B20 Vtec Build
- some advice
- build questions
- wut can yall tell me about je pistons...
- all motor b16a question...
- Going LS Vtec w/ GSR head. Need a piston set to go with it.
- WD Distributor of Wiseco
- hey i need help bad
- Tanny final drive.
- Hypothetical/theoretical question: What would happen with the cams 180* out?
- check engine light?
- Trade B20 Eagle Rods for B18c Eagle rods
- All motor K24 (CRV block) in an EJ2. What tranny?
- Help with camshaft I.D.
- oil consumption
- soo i have
- GSR cams in a B16a2?
- Is this a good deal?
