PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. all motor gsr stroked
  2. 81mm HG on a 81.5mm Bore? yes/no
  3. im looking to get a h22 head ported any advice where i should sent it?
  4. GSR Head on B16 Block ?! - ANY COMMENTS ?
  5. VTEC Problem
  6. h2b All motor
  7. header fitment question
  8. All motor B18C question
  9. b16a/ b18b1
  10. Tri Y problems...
  11. questions on buddy club 3 cams for b16
  12. Best tranny for b20 block...
  13. what should i do?
  14. TUNE B16 p28
  15. P2R thermal Throttle body power gain
  16. what injector size?
  17. all motor nonVtec builds
  18. oem gsr girdle on ls block
  19. b16b questions
  20. valve seals... ?
  21. Battle of the MiniMe (d16y7 vs. d15b7)
  22. Cam Gears?
  23. can you degree cams with the motor in the car?
  24. 200whp???
  25. Rev limit in a b16
  26. Noob B20v Build
  27. Gsr block/Ls crank... Looking for 12s
  28. ITR NA Build
  29. just wanna break 200-210whp on my itr
  30. anyone know a good motor building place
  31. need help fast H2B evolution kit ek
  32. Taped for LSV B16 head. still usable?
  33. Rebuilding B18C(JDM ITR) with P30's
  34. Need Help From a Skunk2 Dealer
  35. My b20 vtec build
  36. b20b pistons to b20z pistons
  37. H22a NA build
  38. GSR IM swap on LS......yes ive searched
  39. First dyno session. Anything i should know?
  40. b series dizzy
  41. HONDA GOS STOCK CAR RACING
  42. LS/VTEC Smokes when in VTEC. New Valve stem seals. Great compression. What else???
  43. h22a in 2000 teg
  44. Need help on my build !!!
  45. compression?
  46. Spoon head gaskets?
  47. what is the best option?
  48. K20A2 Pistons..forged rods?
  49. best all motor header?
  50. lsvtec fresh-built, ready for starting...computer question
  51. H22 Bisimoto Camshaft they work?
  52. Shaved block and head.. is it safe to use high performance camshafts?
  53. piston ring gap.?
  54. New Build... Compression question
  55. need help on what intake&filter to use
  56. B20V Problem :/..
  57. Jenvey ITBs for 2008 S2000 with DBW
  58. MSD Injectors
  59. 300hp out of an All motor LS/Vtec setup?
  60. V2V Clearance: H22 w/ Skunk2 Pro 3's
  61. b16 block itr head?
  62. Calling ALL BC5 Cammed Motors
  63. HELP HELP NO SPARK NO SPARK HELP ME PLEASEE...
  64. ELECTRIC WATER PUMP= HORSEPOWER?
  65. Pro1 to Pro2, bolt on and drive?
  66. Performer X or Victor X
  67. accel coil for honda
  68. Looking for advice on N/A H22 Build
  69. Bosch 900cc injectors Vs RC 550cc
  70. ITR CAM INSTALLED VERY HAPPY!!
  71. will i make it into the 12's?
  72. Help Me Settle the debate..
  73. Factory bearing clearances?
  74. help whats in this motor? h22a
  75. pr4/b20b
  76. **Velocity Stack Pics And Write-Ups Request**
  77. Quick Question befor work, b20z ecu, Researched.
  78. help wit my motor build
  79. Need help on my motor
  80. 70mm bbk tb how to adjust idle
  81. K series on F series Block
  82. Head studs
  83. F20B Injectors size?
  84. what valve springs to run
  85. V8-swapped Civic?
  86. jg engine dynamics?
  87. Header
  88. spark plug gap?
  89. What happen to RM?
  90. Best Cams for my setup
  91. how to degree my b-series motor?
  92. What rod bearings to run? math ?
  93. Iceman intakes
  94. WHAT SIZE FUEL PUMP IS GOOD???
  95. No oil on the dipstick after adding oil
  96. High compression 2&3 cylinders VERY lean
  97. need some questions answered
  98. Want to build NA B16A, where to start?
  99. B20 vtec results inside, finally happy
  100. Valve springs???
  101. choosing an oil pump for LS-Vtec engine...
  102. Building a F23/F22 hybrid, advice needed.
  103. need help want to bulid all motor b series
  104. What kinda power should im be making?
  105. why sae over uncorrected?
  106. My first motor build...
  107. H series Skunk pro series vs bisimoto camshafts
  108. non-v b20b build ?
  109. Re-built LS still smoking.
  110. Critique my build, b20/v
  111. Need Help Calculating Ideal Intake runner length
  112. are there any tuners in 417/missouri area?
  113. blox c vs. s2pro2
  114. another b16 cam??
  115. Is there a reason, why people do not use Skunk2 stage 3 camshafts very often?
  116. suggestions on more whp
  117. GSR Ticking after instaling ITR replica cam
  118. Timing is off and i cannot get it right.
  119. lsvtec vs gsr stroke
  120. b16b head on b16a bottom end which pistons to use?
  121. PrecisionAutoCanada.com Pro1 VS Pro2 Dynotest
  122. How to contact Sparks racing???
  123. B20 ITR with Pro1s..
  124. Building 82mm ls/vtec few concerns?
  125. to run carbs
  126. B18B3 redline at 8000, B18B1??
  127. crank pulley interchangeable? Help!
  128. CTR exhaust
  129. piston to valve cyn3
  130. changing my head on my civic
  131. Is getting a tune worth it at this point?
  132. How to calculate effective compression ratio?
  133. Recommendations for a new swap
  134. A 1.9Lt B16b?
  135. sk2 pro manifold, modifications? anti-reversion step?
  136. Nippon CTR Pistons In B16a
  137. cam journal Question
  138. Is a -8AN fuel feed line too big for Walbro 255 inline?
  139. RS Machine Pistons
  140. B18c1 all motor help
  141. GSR build questions
  142. B20v How much Hp tq with my setup: stock b16a1 head & stock b20 bottom (locomp)
  143. 95 Civic Built Head, wont start!
  144. 220hp stock bottom h22
  145. Build what I have or buy another motor?
  146. B20 build.....Few questions
  147. wanting to build 85mm sleeved b18 to get into 11's?
  148. H22a: 11.5:1 comp, Jun Cams - Pump Gas dyno tune
  149. stroker crankshafts?
  150. "plain jane" ls/vtec build ?'s
  151. BLOX Dual Valve Springs N Retainers any GOOD?
  152. blox intake mani gasket fitment on gsr
  153. JUN3 Intake cam w/ STOCK GSR Exhuast Cam?
  154. skunk2 pro springs
  155. quick noob question!!
  156. How is the valve regulation for a B16a2 when CTR cams installed?
  157. Anyone know how to??
  158. K-Series bearings in a B-Series?
  159. Something for all you high reving guys to think about
  160. b18c1 bearings.!?!?! help.??
  161. ls b20 cranks an rods?
  162. I built an LS-Vtec, i just have 1 or 2 specific questions before i run it...
  163. need help with b16 head reassmble.
  164. B16A1 into EG 4 door
  165. Engine “Over Balancing” ?
  166. Head Milling, Cam Gear adjustment
  167. Has anyone tried out these camshafts?
  168. CTR intake cam gsr ehxuast cam cam gears?
  169. callin all b20 builders
  170. d16z6 n/a build, help with pistons
  171. rmf replica ITR dyno
  172. 142whp d16z6 e85 how to adjust ignition timing for a 75 shot of nitrous
  173. best cr for jun3's
  174. need some insight...headers, manifold.
  175. Vision technica feedback request
  176. Vision techica feedback request
  177. JUN PARTS FAKE or Real?
  178. Dyno Results: ITR Spec Pistons 85mm w/ Blox Type-C Cams
  179. H2B EK4 . 250whp "on a budget"
  180. Stock b16 + E85 - need opinions
  181. oversized valves + blox type a's clearence issues?
  182. b18 build
  183. 3in or 2.5in
  184. Ordering a chip for my ecu. Have some questions
  185. F20B Bearings?
  186. Modding the head oil control orifice for more oil...
  187. GREAT NEWS!!!! went to dyno again b16a2 bolt ons!!!
  188. Some motor questions. Help
  189. b18b and b16 head?
  190. 3 inch axhaughst sound clips or vids
  191. Is oil consumption common with Honda???
  192. are buddy club 3s good for this b20vtec set up?
  193. K20z3??
  194. D16Y7 Build
  195. Valves
  196. PLEASE PLEASE FAST HELP NEEDED.... D series
  197. D15b7 Need rings or faulty compress test?
  198. valve train question? need help
  199. 293hp 193tq. B-vtec looking a little more!!
  200. Finally time to finish my engine, Pistons?
  201. Went to dyno again, NOT HAPPY WITH RESULTS B16a2
  202. D16Z6 CR ~11.8:1? Detonation?
  203. LS vtec with CTR pistons
  204. rsx muffler flow ?
  205. gsr bore question?
  206. Type-R
  207. B16: I/H/E GSR Cam Dyno tune
  208. B16: All Stock - E85 Dyno Tune
  209. what should I do to a h22a4
  210. how come my vtec is weak?
  211. ALL MOTOR VS BOOST ???
  212. head gasket help.!??!
  213. ALL MOTOR CR VTEC HELP
  214. tell me what you guys think...
  215. 323 WHP 2.4L H SERIES THANKS TO RLZ ENGINEERING
  216. H22A & S2P2 Skunk 2 Pro 2
  217. knocking on drivers side of H22a in a 93 accord
  218. D15 Mini Me? Please chime in!!!
  219. High compression
  220. Crower Stage 1 camshaft for a d16 power gain
  221. Stock GSR w/ Toda Spec A2 cams
  222. b18c jdm gsr aiming at 200whp
  223. timing question...
  224. question on porting intake ports on cylider head?
  225. b16a2 MAIN Bearing Diameter?
  226. d15b into a 1996 civic ex
  227. Porting H22A Intake Mani (searched, read, confused)
  228. h22 in. plenum noob q'
  229. B16 Valve cover breather block-off?
  230. 2000 ITR with PCT pistons
  231. B18A1 build Questions
  232. B20Z/B20B into EG 4door
  233. piston to valve clearance. semi built h22 mahle???
  234. Opinions on AEM Short Ram for CIVIC SI 99 b16a2 dyno gain?
  235. B20z2 vtec motor build help
  236. better stage 1 cams?
  237. b18a1 fresh build not making SH!T for compression HELP
  238. RSX-S: Toruku Cams & Bolt on's - Pump Gas Dyno Tune
  239. Building Ls/VTEC
  240. Which Brand for a Header and an Echaust?
  241. AGNMOTORSPORTS 1.8 all motor project
  242. VETC won't work
  243. Tapping head for B20v
  244. header theroy?
  245. NEED HELP FAST WITH B20Z2 BLOCK
  246. Anyone run Motol oil?
  247. 3" exhaust with 2.5" collector
  248. new h22 all motor dyno 252 horse power
  249. Piston design
  250. h22 swap for ek
