- LS/VTEC to 225 HP, HOW?
- F22B Head Porting Discussion
- bottomed out
- rebuilding engine, pistons?
- b18c to b20???
- Post your B16 Set Ups
- Calling All Emissions Specialists - high NOx, and yes I did my research
- built integra gsr
- identifying arias pistons
- JUN CAMS? OR RIPPED OFF?
- Highest Compression on Street Gas 93 octane with Skunk2pro1s
- Buy parts WHERE?INTERNALS
- valve seal question
- help me out
- Am I going overboard?
- ATTN: CTR pulley owners!!
- Injector and Cam Help
- rebuild of a b18c1
- What CAMS to run on H22? help!
- Gapping rings
- Camshaft - Flat Tappet
- ITR forum is no longer tech related, so I come to you guys... Camshafts...
- what valve guide seals on dual valve springs
- Help! Piston and sleeve problem.
- arp head studs
- Skunk2 Pro2 with 85mm CP 12.5:1 1977cc
- ZC 1.6
- Can I run this combo with stock ecu...
- b16 IM on b18b
- Golden Eagle dowel pins
- LS/VTEC OIL LEAK.
- When necessary to use Walbro 255LPH Fuel Pump ??????
- slow h22a civic
- crower cams
- GSR compression test results
- HP Guess
- Project B20 Non Vtec Revisited.
- so-cal smog???
- Looking for help on what I should do
- gsr block, ls crank . what main bearings to use??
- MS2A-My new header project.
- Project AM in the works (85.5x95) OutlawzPerformance
- How much Power u think i can make Everyone Welcomed here
- i got 3000 to spend. what would you do?
- B16 Power Potential/ Dyno/ Track Times Resource
- gsr build opinions
- Engine noise on deceleration ?
- question about the b20z valve lash specs
- Engine surging, HELP PLZZ!!!!
- CTR pistons in a B16A?
- LSVTEC build w/ no grinding down piston rings
- Name this intake manifold.. (A few big pictures, dial up beware)
- b20vtec reliable with stock internals?
- b17 block, b16 pistons, custom pistons?
- engine rebuilding
- anyone ever use crane stage 3 cams? part# 253-0014?
- questions about balancing a motor
- Cylinders 1 and 2 not firing! Please help ASAP!!
- quick con rod question
- Easiest Cam install for ITR
- Rebuilding a 240Hp H22a1
- junk yard find
- 310 RC injector or 370 RC injectors for N/A motor?
- Which mani - Performer X or IB Spec ITR?
- Which years/models of Integra's came with the B18C1?
- *Intake Manifold* oem machined or aftermarket? whats better??
- Stripped oil jet threads? Please HELP!!!
- whats better fully built lsv or fully built b20v
- Post your b20vtec setups over 200whp....
- gosh darn it, does anybody have the bearing color coding thingy?
- How much did omni mill off B16a head on his 200whp video?
- Compression test results..... bad news for me.
- BC4 center line numbers
- New Section for HT: ECU tuning
- cams for stock US h22
- how to do a h23 non vtec swap to h22 vtec
- What does it take to get all motor 200hp and higher?
- Header slightly damaged by UPS, who can fix this? (so cal)
- Timing Belt length for B18C5 Block with B18B GSR Head ?
- what 3inch intake for my built b20?
- Skunk 2 intake manifold
- built ls vtec ***wat pistons or cams***
- Help guys b16a2 skunk2 throttle body problems!!!!
- LS/Vtec initial dyno
- Skunk2 stg2 cams..need suggestions
- Break In Period: install pro1+ before or after?
- Stock K24 (crv) motor dyno
- JG Engine Dynamics headwork and other companies
- car sometimes wont rev over 3k
- Nyce1s.com Video - Tim Grey's Civic EG Early Season action @ Englishtown!!
- Comparison with plenty pics of the JG/BP Tri Y Header VS Hytech Replica BIG TUBE Header
- Lightened/Knife-edged crank, what can I expect from it?
- What header is this?
- b18 c5
- Velocity stack intakes... are they worth it?
- Need advice on d17 going "NA"
- skunk 2 or omni?
- machanical vacuum pump
- H22 Inlet Manifold Theory And Discussion
- Which cams and cam gears???
- JG Engine Dynamics/BP Header
- lets say you had a b18c4 block laying around
- why should stay all motor
- Problem contacting SMSP?
- B20 Head B18b Block????
- toda cams and supertech valvetrain?
- Blox TPS?
- "VTEC pressure valve" engine code
- need help picking a clutch...
- Crank Shaft question! please help..
- Aftermarket TB, what to do about Fast Idle Valve?
- Ctr pistons and Eagle rods?
- H22 performance issue's and tweaking?
- New at this, question for you guys!
- pro1's or pro2's on my build????
- need views and opinions on import auto pros dyno...
- g23 vtec what head gasket
- whistle with blox mani?
- gmg tri y header
- Pistons & Rods
- Anyone know where to get an ANR header from. I tried searching but had no luck
- 90/99 F23 V-tec swap
- CC Cylinder Heads announces its new B16 Racing Head
- broken spring retainers
- Well i be able to compete?
- lsvtec to Achieve 200whp
- 99-00 jdm b20b with P8R head questions...
- just wondering what my numbers will be
- ats 4.9 ITR tranny makes weird noise today..hrmm..
- bigger valves
- can't get the right compression????????wtf
- B16 noob conversion help needed
- New sparkplugs out by "pulse" in super street. Discuss
- RE: R.I.P. LSVTEC, Hello K20
- Head stud question?
- suggestion for my B16a2
- Big tube or not? Specs Inside.
- I'm having a problem with the block !!!!
- What is the best cam/ignition timing on a D16Z6?
- B16 cams vs. B17, adaptable?
- need B series parts
- skunk 2 pro 2s with ctr pistons in ls vtec?
- differential question
- Is this Sump ok for a B18c4?
- car sitting 2-3months ?maintance?
- Bigger valves on b16 head
- tuning ?
- e85 question(i did search found nothing)
- k20 type r vs k20 type s internal specs please help
- what is the best header?
- Running open header
- who has the MOST accounted miles on their LS/VTEC or B20/VTEC
- hey can any one tell me
- Highest nitrous dyno / mph anyone I'm very curious.
- b18c1 crank girdle on a 81.4mm b17a crank?
- Skunk 2 Stage 2 on ls vtech
- BAD ASS RACE MOTOR REBUILD!!
- B20/VTEC using ITR Girdle, Windage Tray, Pick Up. DO I need to use a ITR Oil Pan?
- Help me choose an exhaust according to my setup.
- she's finally back from the dead... along with some friends. =)
- TRANNY HELP
- single layer SOHC vtec headgasket?
- rebulid questions if anyone can help thanks!
- simple question about tranny/lsd
- Flame suit on... budget build?
- simple question about exhaust piping
- JDM ITR + SMSP + ROCKET + PERFORMERX... dyno!!!
- Nyce1s.com Video - Tim Grey Civic EG Early Season action @ Englishtown!!
- DTR/SSR header street sweeper Vs SMSP B20/VTEC
- Type S pistons with H22 A1 rods
- Calling all 240+ whp stock sleeves b20vtec owners
- GSR Rebuild, what to replace?
- supertech pistons
- P30 pistons in a B17
- B16 in a 95 Integra LS
- Compression
- Non Vtec b20 on ITBS
- ls/VTEC HeadGasket Question
- Help with Crank Pulley Question...
- gsr Eagle rod ?
- GE sandwich plate oil leak. Anyone else?
- Ported Head w/ stock Ported GSR Intake Manifold
- looking for ppl with ctrs in gsr block
- Ls Vtec.. Oil Pickup..?
- S80 "E3E" Tranny
- 94-95 and 96+ b18b1 block difference
- 11.4:1 gsr
- b16-type r
- Crank scrapers ...who is running them ?
- Blox velocity stack
- GSR Motor Question?????
- B16a or GSR Tranny, What is better
- Crank Questions
- k20 swap! how much TOTAL? or just keep type r motor? HELP ME OUT!
- Peak Performance Cam Gears for B18C?????? should i pass or pick them up?
- Where can I buy Wiseco pistons individually?
- Hondata Thermal Intake Gasket doesn't match intake port?
- What should I do? Transmission issue
- Rpms drop to zero IACV problem
- light weight or stock crank
- Just a couple of quesions
- Pro1's, Blox duals and Ti retainers w/ gsr valves.
- CTR pistons w/ls rods in a B18c1?
- Tranny assembly.
- turbo help
- Tuning questions.
- H2b swap
- To the guys running a f23 crank in a h22
- b18a reliable
- N/A
- b20vtec need help on it
- poor man's type r
- rods and pistons
- CAMS
- RHD JDM DB8 Integra Type R Race B18 Build
- opinions on this motor setup
- Hondata s200 question
- Side Exit Drag Header....Anyone??
- Will kms valve spring retainers work with crower stage 2 cam NON/ Vtec B18B1
- got my build done but a few problems
- if you paint your engine block will it have heating and cooling issues?????
- b20 engine (non vtech)....b16 head
- Brian Crower Valvetrain with Skunk2 Stage 2 cams?
- balls out EK
- D16Z6 ITB's, headwork... what redline?
- Im about to go by my H22 today for my H2B but friends are begging me to buy a H23vtec Bluetop
- mugen headgasket...
- I want MORE POWER.... but.....
- Quick question about media blasting a block
- valve seals and valve guides
- Just clayed motor got a question
- gas mileage on all motor build?
- (Money Shifted)
- Calling All users of NGK wide band OR PLX-M300 Click here
- Built all motors are noisy?
- Ls/v setup inside:
- calling all engine builders
- Deck height on B-series motors?
- DNR Head-work???
- b20 vtec.....why?
- Hondata S300 USB Plug Issue
- type s vs euro r manifold.....which is better?
- F20b manifold
- LS/VTEC question
- What compression am i running?? Good for boost?? LS/Vtec
- d16y8/zc mini me
- motor setup
- ITB questions
