PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 [114] 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. LS/VTEC COMPRESSION WITH PR3 PISTONS
  2. 2 questions
  3. twin plate clutch ...blew 2 stainless braided clutch lines
  4. Smog issues
  5. Fuil filter
  6. Can anyone tell me what all is involved in swapping a 94 vtec into a 97 nonvtec?
  7. power and mpg
  8. 310 injectors
  9. CAM HELP
  10. crazy high oil pressure on a d15
  11. n2o on a na gsr
  12. help with h22 internals
  13. which gasket for d15b?
  14. SOMEONE HELP PLEASE
  15. rocket m24xx camshafts
  16. identify this head if you dare
  17. RS*R header dynos?
  18. Does antone know the rocker arm ratio of a b16 outer rocker arms not the middle one?
  19. overheating driving me nuts
  20. what are you using to tune ITBs
  21. Can someone help me understand intakes?
  22. header question
  23. How to test my spark plugs?
  24. best tranny for daily driven b20vtec
  25. Brakes fading after ITB install Woes...
  26. help going lean at vtec
  27. TYPE R QUESTION
  28. where can i get a OBD 2-A engine harness
  29. Dyno day for me at ProMotion Tuning
  30. Buddy Club SPec 3+ cam gear tuning
  31. JDM B16 rods,pistons, and crank in B18a1?
  32. B20vtec with a stock B20z bottom end
  33. GSR!
  34. WHAT SHOULD I DO???????????
  35. ctr cams
  36. Help w/aftermarket GSR H-beam Rods
  37. I can't get my RC 310ccs to fit into my intake manifold...
  38. My RMF 2-Piece Header
  39. supertech valvetrain and bc3+ cams in 2nd gen b16a, what redline can i run?
  40. Build rsx type s head vs built tsx head?
  41. MY LSVTEC
  42. blown headgasket??
  43. Anyone have itr motor's on just a tune? maybe some bolt ons??
  44. 89 accord.....
  45. How many 230-250whp H22's out there??? Polls Up...Keep it real!
  46. GSR intake manifold...price compared to performance
  47. engine harness gone bad?
  48. anywhere i can get a adjustable water pump?
  49. b18a
  50. whats next for my b16b??
  51. 440 cc's to big for my build
  52. Intake Manifold: D16A6 (CRX Si) suggestions?
  53. mad b16 vtak video
  54. K20A2 (RSX Type-S) vs H22A(97+ Preludes)
  55. Myth: thin K20a bearings don't work...BUSTED!!
  56. Added Header After Tune: Waste of Tuning Money?
  57. Great online racing game
  58. 250whp for the streets
  59. does this seem like a knock to you?
  60. Do you think all motor guys are stupid? lol
  61. 85mm bore, cylinder head prep?
  62. DYNAMIC VS STATIC COMPRESSION
  63. B18C, LS/VTEC or JDM B16A
  64. skunk2 build up
  65. motor won't start
  66. affordable power increase, besides i/h/e for b18b1
  67. mx22 or IB camshafts? rebuildin type R or?
  68. Bigger Exhaust = More Power & Torque, plus it's quieter too
  69. my b20vtec setup
  70. b16 vs. ls/vtec
  71. What Viscosity oil do ya use? And when?
  72. b20
  73. RS machine pistons
  74. mini me-hx in ek hatch
  75. Is the Fast Idle Valve necessary?
  76. Need Tuning Suggestions
  77. Problems setting timing belt and excessive belt slack
  78. Need help finding & deciding what header to go with?
  79. 2.0L ls vtec turbo...
  80. Valve seat width
  81. anyone running a JGE intake manifold on a d16?
  82. D16Z6 all-motor set-up
  83. vtec graph
  84. comments on my setup
  85. Tokyo Drag Video (The B20 build-up for DRAG story)
  86. Valves ?
  87. Machine shop in SC?
  88. skunk2 pro2
  89. after 3 yrs of boost, i wanna go NA
  90. Rev limiter on JDM Torneo F20B (DOHC VTEC, MT)
  91. My car bogs when quick shifting in HIGH rpms
  92. valve size
  93. What do you think of this?
  94. BC3+ Dyno: would cam gears help?
  95. give me some info on my b20vtec build
  96. Anyone know what d16z6 heads flow stock?
  97. jdm type r and california smog ???
  98. an-r header
  99. skunk2 vs. Toda cams
  100. Fuel ???
  101. B16B Rev Limit?
  102. exhaust
  103. bc3+ and standard valve train
  104. h22 dyno kteller/rage header
  105. catch can Q
  106. Integra type R valve springs ok with Crower stage 3's?
  107. b series build.. i need a rlz head. top notch
  108. to the ground
  109. high comp pistons
  110. setting up cams m22s
  111. A couple mini-me questions
  112. Head gasket suggestion Spoon, HKS, OE?
  113. Diffrence B/w h22 Auto and H22 Manual
  114. cams
  115. Getting rid of my turbo setup for NA
  116. need to know how stroked DART block will run with what I have
  117. dyno results
  118. LSVTEC with LS PISTONS
  119. does anyone got pics of a gsr harness and it says where each plug goes?
  120. MSD problem...I think. HELP PLEASE
  121. 252 hp skunk 2 b16a?
  122. h2b h22 all motor help!!!
  123. h22 stocker NA
  124. OK i need an answer about a header quick
  125. Couple of AEM EMS questions.
  126. B16a w/ Buddy club spec 3+ cams Dyno
  127. Motors for sale.....
  128. Throttle Body Shennanigans (need help quick)
  129. skunk2 camshaft casting marks?
  130. which parts for ls block
  131. JUN IM?
  132. Building my head
  133. Irregular Idling on 87 Accord Lxi
  134. oversized valve
  135. All motor B16 - dynoed at 151 w/110 torque
  136. CTR N1 crank pulley
  137. Would vacf be benificial to build
  138. Require opinions in reguards to my 96 VTI-R hatch with B16a2 obd2
  139. stupid easy question, where do my coolant/vacuum hoses go??
  140. knock sensor
  141. Help with sealing throttle body
  142. p30 or p72 on LSVTEC
  143. Dizzy Installation on a LSVTEC 2.0
  144. Thoughts/Opinions on Devcon filled stock sleeve B20??
  145. engine modification question
  146. HELP, HEADER TOPIC
  147. what is my compression?
  148. H22 VC evac setup for NA stroker, will this work?( big pic, fair warning)
  149. buying motors off ebay?
  150. where to find b18c5 oil squirters? need new squirters
  151. ls/vtec build... never ending
  152. b18c stroker kit
  153. highest compression on 100 octane?
  154. Cam Cap bolts
  155. A 13 Second All Motor Pizza Delivery Vehicle, Video Included!!
  156. ls motor
  157. FOR THE GUYS WITH 2.5 EXHAUST OR BIGGER
  158. i have a 92 civic hatchback with b16a with lsd any ideas of a good 1/4 mile time, est.
  159. b16y7 manafold swap to a b16y8
  160. Inlinepro Comp4 hatch runs 10.89@123
  161. P28 or P72??? to chip or not to chip?
  162. Lowering ZC piston compression by modification?
  163. lsvtec question
  164. acl or clevite bearings?
  165. what do you guys think?????
  166. Are OEM bearings always perfect if i match the numbers up?
  167. m22 head package in b18c5 with JDM ITR pistons
  168. AEM Type R Intake same as Civic intake?
  169. Stock 240s will suffice or go with my 440s? Mild ls build.
  170. 2 layer headgasket wit lsvtec
  171. Want to do a stock sleeve B20vtec (Help me!!)
  172. some more ideas for a b18a
  173. Anyone see anything wrong???
  174. 300whp H22 Dyno - NA
  175. Crome pro and ITBs
  176. Type R pistons
  177. b16 over 215wheel hp
  178. Opinions on not using a muffler....
  179. Are these Type R pistons???
  180. rebuild question
  181. Dryflow AEM air filter vs K&N air filter
  182. so i just installed my ITR cams etc
  183. what do you think of this setup?
  184. Crower 2.6L K24??
  185. B series Long Rod options
  186. Skunk2 Manifold Help Please
  187. Need Help Choosing Header and set of cams!!!
  188. Need advice. Mild B20 build starting soon.
  189. Are side allow in Idrc street class
  190. Cold Air Intakes
  191. Naturally Aspirated Engine Theory Discussion
  192. my ls vtec build
  193. ls crank/b16 pulley??
  194. vtec not kickin
  195. Car stall's out when low on gas??? HELP!!
  196. oil consumption but compression is great, not valve seals... help
  197. 93 and 100 octane at the pump in norcal
  198. bumping up b16 c/r
  199. Need help with idle- Pro2 cams-
  200. d16 rpm limit raising?
  201. D16A6 Header?
  202. 62 vs 65 vs 68
  203. how we do it .
  204. HELP!! with exhaust system
  205. Titanium retainers
  206. Highend try-y Header
  207. eagle rods
  208. fuel pressure with bigger injectors?
  209. Choosing pistons for ls/vtec build
  210. can this header be repaired?
  211. dynoed my gsr
  212. midrange vs. top end
  213. Extended intake manifold stud?
  214. Dynoed my mild H22 (SMSP + Crower cams), looking for advice
  215. Non-Vtec Teg to a Vtec?
  216. Need Opinions?
  217. building head: question(s) skunk2/itr
  218. Skunk2 Mani and TB Question
  219. wah kinda ECU should i go with???
  220. piston and rings question
  221. I NEED A HEADER FOR MY bseries 2.2L build!
  222. twm tps voltage.
  223. I finally found a header that beats the SMSP B19
  224. need help
  225. jmd b18c r motor
  226. Head Gaskets?
  227. lsvtec
  228. I'm putting a different motor in my non honda fwd car...how to I mount the motor in relation with th
  229. dyno tuned or chipped
  230. timing belt about 1/2 tooth off on crank, is that bad?
  231. b16 compression ratio
  232. what would you do?
  233. Problems with a friends fresh build and Crome Pro *VIDEO*
  234. Type r oil pump?
  235. LS/vtec set up. pictures,dyno coming soon...
  236. Are k20a3 and k20a2 intake ports the same??
  237. skunk2 pro vs regular cam gears?
  238. Why are na cars faster than turbo cars, same weight/whp
  239. ats close ratio gears
  240. jun vs 5zigen
  241. advice/ help on my b18a build
  242. Will a Type R crank with B18 rods work in my B17 block?
  243. Camshaft selection for 2.4 stroked H22
  244. Contact Rocket?
  245. Will K20a (type r) pistons fit in a k20a3 (EP3)?
  246. ecu
  247. what you think??
  248. '06 RSX valvetrain versus DC5R valvetrain? (stock single versus dual)
  249. JG 308/316 camshafts...anyone?
  250. Safe to Mill GSR head? & questions on my setup.
