PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. d16 build idea.
  2. RC Injectors, Install Sucks
  3. 2.0 or larger B owners... intake recommendations
  4. good gasket for ls vtec??
  5. blox cams
  6. Civic engine blown
  7. 88 D15B1 C/R different?
  8. D16z6 Rev limit droped???
  9. d16a6 pistons and rods in d16y7 bloack??? need this info asap plz
  10. h22 4-1 header
  11. SK2 vs TODA
  12. how reliable is a stock b20vtec
  13. H22A melted piston/cracked ring land
  14. Eagle Rods wrong or not
  15. S2K valve angles?
  16. valves meet piston at 9000rpms
  17. b20 block
  18. CTR pistons in b16
  19. intake question
  20. TWM powered integra done for now :P
  21. n/a b18c5 build
  22. Microphone in Engine bay All motor LS/V
  23. Dual exhausts on my civic
  24. Rings for oil rings???
  25. Hamp Oil Filter same as Honda OEM.
  26. stroking for torque, destroking for high rpms F20B Tuning
  27. Buddy Club spec IV vs. Skunk2 pro2's cams
  28. HEEEEEELP!!! y8 mani on dm d15b please ASAP
  29. can i use 2 oem headgaskets to lower compression?
  30. Recommendations for a B18C-R
  31. 9000 RPM LSVTEC
  32. What should I do?!
  33. What's wrong with my engine?
  34. single layer head gaskett for b20v???
  35. injector calculator confusion
  36. a lil info/advice needed on an lsvtec
  37. Code 9 / 41 CANNOT FIGURE THIS OUT!!!
  38. AEM pulley kit making noise w/ ac
  39. itbs and hondata s200 can it work?
  40. Piston prep
  41. what pistons???
  42. D series build questions
  43. What FPR works with a stock fuel rail??
  44. What TB are you using for H22?
  45. ANYONE COMPARE PRO 3 & M25 ?????
  46. wideband o2 shootout
  47. Firing order
  48. My B18C build (another one) Input helpful.
  49. B17???
  50. all motor question
  51. LMA's ... what are they
  52. post your high comp stock bore/stroke b16 motors!!
  53. Cost to mill head? (searched)
  54. built b17 or b20 vtec?
  55. PVC breather system on b20/vtec after its built help please
  56. need help B18C5 valve adjustment with skunk 2 stage 3
  57. Type-R tranny problem (2nd gear is fussy)
  58. 97 LS 5th Gear
  59. pic of gsr cams tell me what yal think of them!
  60. D16 performance bearings ??which
  61. why block off oil squirters
  62. GSR swap question!!!!
  63. My dip stick is reading 9 inches of oil?
  64. need some help!!
  65. Egine Builder's, Polls on what lubricant to lub up Cylinder walls before Piston installation!
  66. Nippon vs. OEM Pistons
  67. jdm usdm upgradeing?
  68. Engine Builders. Whats happened to these bearings.
  69. need some help with cr/vtec please.
  70. The Importance of Valve Adjustment
  71. all motor b20/vtec
  72. Does anyone have pictures of wear for 92mm stroke
  73. Any idea how this happened? Sleeve damage
  74. What cams to go with in JDM b16a
  75. Summit Point August 25-26 (Track Weekend)
  76. Header for built all-motor LS
  77. catch can filling up
  78. some questions...
  79. video of integra with 190-200whp
  80. Sleeved Block Quick qusetion
  81. Stage 3 Jun Cams
  82. A/C belt alignment issues on LS/Vtec
  83. 2L B16 questions
  84. ported b16 head
  85. Early REV limiter??
  86. 200hp lsvtec....suggestions
  87. IM pressure at WOT
  88. DIY GSXR 1000 ITB Velocity Stacks?
  89. B20 fan switch
  90. picture request. bloxs Bs
  91. just got a great deal
  92. cracks in block casting?
  93. Throttle body tension adjustment, is it possible???
  94. bronze valve guides
  95. What's the idle Air/Fuel ratio supposed to be on a B16?
  96. Cheapest cam swap?
  97. b16 question
  98. Good or Bad: Crower Stage 2 cams? (B-series)
  99. Wheres a good place to buy Itr Cams from ?
  100. Tanabe concept g
  101. f20b h22a
  102. Dyno comparo of B16a2 and B18c with same bolt ons
  103. 2000 itr questions
  104. new passwordjdm retarded penis intake... critics?
  105. Just bought an Edelbrock Performer X Intake...
  106. b20 rod bearings.....
  107. GSR + skunk2 stage 2
  108. toda itb's + toda c's + hytech header +crome + blundar tuned = 190whp?
  109. which cams for setup
  110. Blox B cams with KMS valve springs..anyone have this?
  111. Obd 2 Clips with obd1 injector's info'
  112. what would u guys do????
  113. Compression Ratio's
  114. LOOKING TO BUY A B16A2
  115. Blox b's or S2S2?
  116. what r we missing trying to make 220 whp on a 1.8L?
  117. couple H22 questions.......... please bump if you look.
  118. B16 ignition timimg
  119. $500 2 spend on 2" 1/2 inch or 3" inch exaust i need help thanx ......
  120. question about my d15b motor?
  121. 85mm On Stock Sleeves, B20Z2 Block NA
  122. toothpaste for a light lap
  123. engine management
  124. race header for b16 crx
  125. blox flat valves + 2 layer HG on an otherwise stock 99-00 B16A2, what compression ratio?
  126. need info/help ASAP, Fuel line question
  127. h22 piston to wall clearances
  128. need some advice.
  129. LS w/ GSR crank
  130. will the gasket on b16 fit on 18a??
  131. Oversized valves and Skunk2 Pro 1's
  132. Time for a new timing belt?
  133. gsr with type r cams
  134. Plug index kit how to use ?
  135. Cooler intake air lowers RPM of peak torque ?
  136. GSR Block, GSR Rods, P30 Pistons, and B16 Head
  137. 95civic b20 swap?????????????????
  138. d15motor
  139. So Cal Transmission Shop Recomendations?
  140. h22 build
  141. mild gsr build
  142. a final word on skunk2 intake manifold
  143. Guess HP/TQ in this set up!
  144. Toda D or Skunk 2 Pro 3
  145. A little input on my Hybrid project please
  146. hytech vs rage headers
  147. b16 in crx what times have u run
  148. COMPUTER BLINK DIAGNOSIS
  149. about skunk 2 stage 2s????? tech answers please
  150. B16b pistons in B16a.... a few questions..
  151. all motor b20 bore question
  152. Bent Header does it matter?
  153. Toda Valvesprings - Egg Shaped..
  154. crvtec ecu
  155. help! i need to find 76mm p29's asap!!!!!
  156. Head stud thread lock?
  157. cp piston help
  158. What brand of header is this?
  159. torquing a head on to b18b
  160. itr cams in b16...
  161. b18b block help
  162. b18b1 injectors
  163. b16 head.... need advice.
  164. Gsr head rebuild-2 Q's
  165. Valve question
  166. p29 pistons plug and play with stock ecu?
  167. ctr pulley w/ balanced bottom end?
  168. plasti gauge bearing results.. need help
  169. Need advice on all-OEM "Poorman's Type R"
  170. high comp pistons?
  171. Retainers & springs for Type-S cams H22
  172. poor mans type r... some feed back plzzz
  173. Simple B20VTEC question?
  174. WHere can I get one of there?
  175. RMF drag style step header
  176. pwjdm vs aem-v2..i serached
  177. *BEST* ALLMOTOR intake, fuel rail, and fuel pump?????
  178. AO P73 Pistons????
  179. gsr piston help?
  180. b18b w/ b20 head?
  181. wiring knock sensor on b16a
  182. Know of a good swap shop or CRX mechanic in the Philly area?
  183. oil clearance question
  184. Burning oil, Did compression TEST...
  185. JDM D15B INjector O rings?
  186. Welded chambers or not? need help please
  187. Gunk on injectors ?
  188. gsr built 11.5-11.8 compression
  189. s300 With ITBs and VTEC Killers
  190. engine stalls when... (I've read all 34 search results)
  191. Velocity Stack k20
  192. 'Budget' LSVTEC CR-X dies!... 89x85 B20VTEC rises from the ashes! **PICS**
  193. Welding the slip-fit on a tri-y header
  194. Emission Problem
  195. oil burning really fast????
  196. what is a good rod and piston set up for my gsr build
  197. dose this sound right
  198. b20 block tock with b16a head with intake and exhaust
  199. fenders
  200. PCV valve dump tube
  201. computer
  202. Need Help!! Camshafts
  203. F20B Build
  204. Drilling Fuel rail?
  205. Searched...came up with nothing!!!
  206. Valve Spring Question?
  207. Would this setup work?
  208. AEBS lost me 8 Horsepower?? WTH
  209. i need some torque specs....
  210. some impt things to do when installin pro1s in an h22?
  211. good choice of valves?
  212. post your b18c5 ALL MOTOR setups
  213. is this a good buy? pistons and gasket kit
  214. what do you guys think of the Invidia n1 exhaust
  215. QUESTION I know alot of people are wondering
  216. flex hone vs tri stone hone
  217. B16b Dyno #'s
  218. b20 vtec problem
  219. stock rod strangth
  220. can somone prove me that miror polished intake ports are bad?
  221. White smoke, oil consumption and running bad.
  222. Aftermarket b17a parts (for b16a)
  223. blox velocity stack???
  224. Please tell me why my car is slow and gay
  225. B16A FOR SALE WITH EXTRAS
  226. Not picking up the -12 volts for my MSD
  227. Doin a k swap into and eg...any tips
  228. went to the track last night...should i be mad?
  229. most Whp for a b16
  230. Summer Project: DIY 954RR ITB B18C1
  231. Maybe Changing My Pistons, Would Like Some Input (Nippon Racing)
  232. ran my car in the 1/8th mile, b18c5 motor in a dc2
  233. new header
  234. royal purple...again
  235. help in a k20A
  236. Need help on SOHC V Y8 series problems
  237. Rod modification
  238. RS-R exhaust question
  239. 240cc injectors... 48psi vs. 55psi vs. xxpsi
  240. Adjustable CAM Gears what are good?
  241. Sheriff sending me to CHP inspection (stock exhaust) - intake mani question too
  242. i am building a 12.5 to 1 gsr motor what is the quietest hi flow muffler
  243. DynoJet numbers vs high altitude could be low???
  244. 4-2-1 vs 4-1 header?
  245. gsr build.... need help
  246. b18a w/crower 404's help! please.
  247. WTB
  248. Who makes theses cam gears?
  249. B-series head flow
  250. best way to remove stripped block cap'
