PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 [181] 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Revolver Cams
  2. fluid damper
  3. Hytech 2.0L header on 1.8L block
  4. Engine Analyzer Pro or Dynosim software - anyone ever try?
  5. What HP do you think ill make with my new motor?
  6. Rod bearing tangs
  7. what is absolutely neccessary for ls/vtec?
  8. comp cams ?? had everyone run these ?
  9. Cam Test! Toda B vs Skunk2 stg 2
  10. georgians? atl
  11. SKUNK2 STG1 CAMS IN STOCK B18C1??
  12. aebs .....
  13. 1.6 2.2?
  14. What will it take to run all motor 12's
  15. Difference 10.2:1 ----> 11.5:1
  16. Buddy Club 3 or M22 cams?
  17. Question about sleeves bore size and new pistons installation
  18. ATS 4.9 FD for GSR Tranny
  19. ?'s about intake manifold
  20. HONDATA"??? PURPOSE AND COST???
  21. cams and valvtrain ?
  22. b16 what should i do next?
  23. some rod bolt pics that I got from sema
  24. this might be a nub question but i need help
  25. edelbrock 4730 street/strip cams? Opinions
  26. Getting an Itr to make 200+whp.......
  27. vtec swap into a 99 escort wagon
  28. Whats Wrong with my motor!?!?
  29. full b18 head
  30. Vibrates when moves off from stationary.
  31. Need some advice and opinions!
  32. ticking valves?
  33. Have you seen this before ?
  34. What's the most hp can you get off a b20 and k20/24 all motor setup and how much would that cost?
  35. dc jdm 4-1 specs
  36. fitv on aebs help pleaz!!!!!!!
  37. pistons with camshafts
  38. engine help please!!!
  39. Port Matching worth the $ and effort?
  40. b16a problem
  41. All those bored engines.....
  42. SO Fire up bennies old motor today....WTF!
  43. Car stickers question
  44. Dyno sheets with bc 4 cams
  45. vafc on my setup? worth doing?
  46. Sleeves
  47. Toda C's, Toda springs, OEM or TI retainer? Rocket spring/retainer? other?
  48. CAM GEAR ADJUSTING??
  49. COMP CAMS STAGE3 OR BUDDYCLUB SPECIII ON LS/VTEC????
  50. need help on what to do and what to build
  51. Is it possible to build a B16 with 200whp or close to that?
  52. quick quesiton! how many vacuum lines that go to IM
  53. need someone to help wrap this up, jdm h22 going type s piston. what piston to get a or b
  54. MY ITR IN MY CIVIC IS BACKFIRING!!
  55. Quick ARP rod bolt question
  56. Cam questions.....
  57. Valve spring compresor
  58. type r tranny on gsr...what kind of clutch????
  59. Help with buildup
  60. toda spec b's? keep or not . . .
  61. Engine management
  62. New MSD Pro-Billet Honda Distributor: Questions
  63. B20A5 hybrid?
  64. LOSING POWER ???? pls help !!!
  65. Spoon or Jun Cams?
  66. power potential - bore:stroke ratio and piston speeds
  67. No tec need help
  68. build: top or bottom first
  69. What Muffler?
  70. :ITBs on a B20Z???:
  71. for sale
  72. Lowest CR for S2S2 cams with 91 octane
  73. Poor mans R setup.....opinions?
  74. HELP motor falling apart!!!
  75. ITB'S and hondata
  76. beadblasting pistons?
  77. expected power ? 84mm bore 89mm stroke
  78. JDM 4-2-1 ITR header with 2.5" collector
  79. Does anyone sell a kit for doing an LS Vtec
  80. Piston ring gap
  81. Prelude LMA Pics. Are these the right ones?
  82. need some help
  83. oil pump...GSR or LS???..testing your expertise...
  84. Twm ItB's, and 84mm vs. 81.5
  85. ANYONE USING NIPPON RACING T-BLOCK SLEEVES????
  86. factory fuel pump with 440's
  87. Please tell me my GE block is ok???
  88. 86mm ok for GE sleves?
  89. LS CRANKSHAFT AND RODS ON B16 ENGINE???
  90. Track results from my M22 CRX
  91. Help me build my NA bottom end.
  92. Best flowing IM?
  93. CTR piston & connecting rod
  94. Help... Wheres Dan Benson??
  95. pics from the BOTI in joilet
  96. Whats Next on My ITR?
  97. total amount of $$$ for a k20a swap???
  98. BBK Intake Manifold???
  99. Forged equivalent of a P73 ?
  100. BEST CAMS FOR MY 11.3 COMP B18A1?
  101. Anyone use these with there 1.8
  102. which swap is best for high horsepower?
  103. On a Built LS/VTEC what cams would u choose between......
  104. Compression Ratio ? with mini me build
  105. jdm or usdm b16? how to tell
  106. STOCK crank pulley questions
  107. cams for h22a
  108. Header
  109. LS-V project, need idea's
  110. Pics Comparing " CTR cams Vs Skunk 2 Stage 2 cams "
  111. biggest bore on a b20 block
  112. What is the signifcance of ARP head studs?
  113. Z10 Block girdle...works?
  114. Those of you Running ITR/CTR CAMS:
  115. compression tested my b16
  116. Cheapest header to make over 230-240whp?
  117. Toda B cam........broke in half...:-(
  118. CAM GEAR QUESTION
  119. Anybody have this kit
  120. Stock sleeves 12:5:1 pistons b20 Vtec too high?
  121. Cable or hydro tranny
  122. ITB for f22
  123. IAC w/ITB's
  124. Passing Smog
  125. ALLMOTOR B18 ppl inside
  126. A/F ratio ??
  127. Aftermarket main caps?
  128. Need your help or ideas on an all motor project
  129. Engine dyno vs dynojet roller style ?'s
  130. exhaust piping question
  131. 84.5mm ls/vtec 11:4 compression expected power
  132. intake manifold for 1st gen b16.....need help
  133. ctr cams with ctr springs?
  134. sleeve ? what's the limit, is 13.1 to high for pump gas
  135. cam end seals??
  136. oversized valves and emissions!!! need help ASAP!
  137. Qns abt new engine.
  138. 12.5:1 JE Pistons in a LS/Vtec setup is it to high?
  139. B18C with CTR
  140. Need help with ls/vtec
  141. Emergency...installing BLOX IM in GSR-97 and get engine check etc
  142. my set up now what?
  143. my setup
  144. Which Cam Would be better
  145. D16A6 Build
  146. What needed for engine rebuild
  147. Dx injector questions::::::
  148. all motor ? with tb str
  149. Anyone Using JG's new B-Series "308/316" spec Billet Cams?
  150. help on upgrading my d16y8
  151. greddy
  152. TODA ITB ?
  153. Has anyone seen my power? plz
  154. Preferred cam mid-high rpm?
  155. Very Mild GSR Set up
  156. Jun Cams
  157. just swaped b16a, now what?
  158. What hoses need to be tee'd? AEBS typoon install.
  159. Hondata on a D-series................
  160. GSR oil squirters in LS bottomend...how much machining?
  161. Looking for rods
  162. Hasport Mounts?? Street, Race, Extreme Race???
  163. possible problem with d16z6 rebuild
  164. What cams with this setup??
  165. toda spec c camshafts and ctr pistons? Anybody clayed this?
  166. bottle neck somewhere?
  167. spoon vs skunk2 stage2
  168. problems with twm itb's
  169. London b20-vtec build
  170. Pocket Logger or similar product to log knock?
  171. TOPSPEED B16 +200HP
  172. New build, and it idles at 75-125rpm at WOT
  173. Skunk cams and CTR pistons
  174. GSR tranny to JDM B16 tranny
  175. turbo or no turbo
  176. best intake manifold
  177. Ls Vtec timing belt..
  178. Pistons and Compression, Please Educate Me
  179. H series adapter plate for b Series tranny
  180. LS throttle body bore limit?
  181. Does anyone have a list of motorcycle ITB sizes???
  182. portflow valvespring installation question (troubleshooting)
  183. LS motor having problems need help
  184. definitions of HALF-ASSED block and head upgrades?
  185. Stock head B20VTEC tuned
  186. with these mods i should should be running what in the 1/4 mile
  187. Difference between stock cams and aftermarket?
  188. with these mods what should my 1/4 mile be
  189. bREAKING IN MY LS/VTEC ?
  190. My RM m22s dyno
  191. D16z6 Piston-to-Deck Height
  192. to all my daily driven lsvtec'ers
  193. Import Builders, Wicked, Blox stage 2 cam specs, stage 2 cams Dyno soon
  194. Reputable Florida shop to do some head work???
  195. CAM ADJUSTING?
  196. So how many out there are succesfully running DIY ITB's???
  197. Is it possible to use stock honda 84mm rings with wiseco pistons?
  198. 98 EJ CIVIC LS SWAP FOR ALL MOTOR
  199. GoldenEagle Sleeves/girdles vs. ERL-Sleeves/girdles?
  200. NEW K SERIES INTAKE MANIFOLD
  201. Help on non Vt engine swap on 90 civic lx
  202. CP Pistons and rings?
  203. one coil per piston
  204. pics of my motor. SHES READY TO RUN!!!!!!
  205. water pumps, which ones to use
  206. Strut Bar for 86 Civic Wagon
  207. octane info and question
  208. d16z6 build up
  209. B20b with B16 head w/jun3camssprings/ret. VS. b16a2 w/jun2 camssprings/ret. with turbo ?????
  210. The Completion of my exhaust...T1R!!!!!!!!!!!
  211. Mine's Ecu?
  212. All motor build suggestions
  213. Canton racing oil pan, anyone use it?
  214. My ls/vtec setup
  215. Need help from people who have hit 12's in a DC2
  216. Tuneing assistance CRVtec Low Comp
  217. ITR Manifolds in B16A Head
  218. JG valvetrain???
  219. Good techs in LA?
  220. would a exhaust tip make your exhaust any quieter?
  221. crower cams and civics???
  222. All N/A street cars running 11.9s or better . . .
  223. b16a head parts in need of
  224. moroso oil pans and unoradox crank pulleys do they really work
  225. how much would it cost to swap my d16y8 for a b18b1
  226. B20 cam question
  227. How Much For a New Rebuilt b20
  228. what do your built all motor get for gas millage
  229. which is better
  230. Toda Bs on Skunk retainers and springs
  231. Decided to reun the car with the new build happy and sad at the same time.
  232. Finally broke 12's ALL MOTOR
  233. stroker kit
  234. valvetrain for buddyclub spec IV cams
  235. b20 crank and rods in ls block
  236. tried to install aebs....help
  237. CTR cams in B16A head
  238. im building a ls-vtec i have some questions
  239. sohc itb's
  240. GSR Build...200whp? with this setup
  241. What kind of power band with BC4's?
  242. ITR cams and AFter market cams
  243. so when are ya gonna talk about pumping & windage losses?
  244. Rewire Peak-hold inectors to run saturated injectors
  245. LS/VTEC needs...
  246. pauter rods for 10k rpm?
  247. For though who got BLOX-IM for B-series...
  248. How many miles does a honda vtec accord last???
  249. OK THis Shit just keeps getting better as we go.......HELP Please......
  250. Need information on where to buy a alternator belt? ASAP!!!!
