PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 [109] 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. thin head gasket blowing out? valve clearance? b16b
  2. All Motor K Series Hatch...
  3. anyone using COMP CAMS???
  4. ARP head studs
  5. NEED HELP!!!!!!!...on my B16A
  6. 96 d16y8 injector problem
  7. compression question / skunk2 valves
  8. Beat again by a trueno bzg
  9. Simple question... for the all motor tech
  10. Do I have to hone for CTR pistons in my B16?
  11. 12.67 @ 106.9!!
  12. new build in the works! opinions and help wanted!
  13. whats a mean n/a cam for a d16y8?
  14. all-motor build over 200whp (need your help)
  15. Hondata installation info
  16. rocket motorsports m23x camshafts.. and itbs
  17. Buddy Club Cams Spec 5 vs Spec 6
  18. Dyno-ed my VTEC in my DA today.....
  19. Can you identify this valvetrain? skunk2? dohc vtec
  20. Reputable Machine Shops in Seattle, WA area..
  21. Where to get cast P73-00 pistons? (NON OEM)
  22. question on head differences...
  23. i need help
  24. P72 vs Pr3 heads
  25. WTB 3.25" Silencer
  26. alternator faulty?
  27. valves for all motor
  28. help a homeslice out
  29. Question about b17 gsr Intake Manifold
  30. piston installed on rod backwards
  31. trimming oil ring?
  32. Optimal Coolant Pressure.
  33. honda of japan.. hamp products
  34. Electrical issue??
  35. Difference in headers for a gsr / b16?
  36. idle drainage with battery drainage ?????
  37. ALL MOTOR BUILD clearances question..need help!!
  38. Piston compression help
  39. Degreeing cams
  40. smsp vs rmf... help me decide
  41. car loses power in vtec.
  42. SOMEONE PLEASE HELP ME
  43. how will this hold up?
  44. blox stage 2 cams GOOD or BAD?
  45. Engine Rebuild
  46. HOOK-UP HEADERS
  47. ...thermostat....
  48. D series: GX pistons, what rings to use? Anyone use this setup yet?
  49. what setup for my crx and 4 door?
  50. obd1 or obd2 dizzy
  51. Dynoed some ITB's with filters
  52. b16, GSR, and ITR valve springs all the same?
  53. b16 cams VS b18 cams
  54. Setting ring gaps?
  55. Accord: Honda clutch or aftermarket clutch kit for same price?
  56. need milled after head removal ?
  57. post some pics of your custom race headers for b series
  58. TRYING TO IDENTIFY WHICH CAMS I HAVE...THEY ARE AFTERMARKET FOR SURE
  59. B16 11:1 CR Pistons with GSR head....Too Much Compression???
  60. rm22x or rm22xx on a b16
  61. AN-R or TODA HEADER?
  62. Thinkin of doin all motor on a b18c5 (type R UDSM)
  63. Calculating C/R on B18C1 N/A build...help???
  64. what does it mean by milling a head???
  65. Skunk2 manifold
  66. im new , i need help PLEASE
  67. Concerns about Ti retainers....
  68. Correct procedure when tuning cam gears
  69. Header ground clearances and decisions
  70. Greddy header
  71. mugen head gasket stock motor?
  72. spoon cams??????????
  73. Calico Coating ?
  74. b20 extremely rough idle
  75. Tsx Piston Rings?
  76. H23/Vtec Piston to Valve Clearance...
  77. Low compression + Skunk2 Stage 2 = ?
  78. Quick piston ring placement question
  79. Compression loss?
  80. JDM B18C Build - 200whp to 220whp - Opinions Appreciated
  81. Porting throttle?
  82. MY POORMANS R BUILD & QUESTIONS
  83. Crower Cams :|
  84. crank binding problems
  85. roller rockers that dont elimintate vtec?
  86. would this be a good build?
  87. Seals and keepers in head ?
  88. connecting rod difference
  89. stage2 cams on a stock block GSR???
  90. Which Cat. to use on edelbrock 2.5 mod for 97 gsr?
  91. axles?
  92. Couple options: Looking for insight, NA LS nonvtec
  93. Which pistons? OEM or Wiseco
  94. buddy club spec III
  95. PoorMans Type R question- Skunk2 Stage2's good header ?
  96. 1.8L... 4-2-1 vs. 4-1
  97. how much whp would my setup be???
  98. F22 potential?
  99. h22 lightweight flywheel
  100. Big Tube 4-1 makes more power across the board vs small tube 4-2-1
  101. B16 piston size
  102. Lightened crank ??
  103. Clearances for PERFORMANCE engines
  104. itb's..........
  105. too aggressive
  106. b20/b18 stroker kit
  107. random thought about cam pricing
  108. DART tall deck question
  109. port and polish (done the search)
  110. flex pipe or test pipe?
  111. Machine shop process..?
  112. skunk2 throttle and manifold
  113. Cometic head gasket is junk!!!!
  114. All motor B18C mods?
  115. Ideal size of exhaust piping/header collector size for all motor setup? 2.5 or 3 inch? Exhaust/heade
  116. are Cams reliable?
  117. b16a help
  118. Weight of DA Integra compared to EG Hatch?
  119. Trying to replace the valve seals on my D15B7
  120. H22 Cylinder Head Rebuilt
  121. cams for a stroked gsr
  122. b16 broke a valve (IS IT REPAIRABLE)?????????PICS INSIDE!!!!!!!!!!!!!!!!!!!
  123. chipped ecus
  124. All motor honda vs. srt-4
  125. lsvtec future 1/4 mile times??
  126. Hondata/ NepTune ?
  127. guess what chewed up my timing belt
  128. B20VTEC
  129. IS B&M fpr good ?
  130. Ground clearence "Race header"
  131. my b18c5 build up, aebs, buddy club 3+, pct pistons
  132. any guesses before dyno?
  133. injectors
  134. just got my new parts in 106mm billet k crank
  135. D16A6 vs ZC
  136. PR 3 PISTONS ?
  137. dissapoiting and scary
  138. H22 Cams: Skunk PRO 2+ vs JUN
  139. Any dyno number differences if car was lowered?
  140. Which intake and exhaust mani are big power allmotors running?
  141. Ti vs Oem retainers
  142. rmf header? how can i get one?
  143. how much would it cost around to build a stock d16y8 motor?
  144. Tanabe SMH exhaust
  145. Quench area
  146. Ls-vtec ready!!!
  147. Driving around with ECU throwing TPS sensor code?
  148. Finally Tuned right ~~ Results....
  149. Piston question for my build.
  150. Would ITBs benefit my all motor setup???
  151. How to identify skunk2 Stage 3 cams? (yes, searched)
  152. throttle body size issues....
  153. Crower 403s on a Stock b20z
  154. endyn crank breather
  155. engine noise-2002 accord 4 cyl vTec
  156. WHAT ARE THESE SENSORS
  157. ls-v-tec head studs
  158. are snap gauges "acceptable"?
  159. connecting rod
  160. B16 Vtec solenoid in B18C6?
  161. ALL MOTOR STROKER B16 DRAG VIDEO
  162. Need help with b18c5 build
  163. Quick Question
  164. wtb stock fpr for b16b type r
  165. ***CR/VTEC Questions***
  166. Couple questions on a Poor mans type R
  167. JUN ultra lightweight flywheel
  168. putting bevel on top of cylinder bore
  169. Just got tuned @ Whitfield Racing!
  170. Help, what kind of camshafts are these? D-series pictures inside
  171. HP Question
  172. notching block for Eagle and other fat rods
  173. I need a ls motor
  174. ls-vtec all-motor is it worth it?
  175. Portflow B-Series VTEC Inner Valve Springs
  176. My d16y8 build
  177. wat problem am i facing?????
  178. wiseco b16 piston help.....
  179. vafc II
  180. CTR Intake Cam in a JDM B16 XSi worth the money?
  181. Fully Built H22 rev cuts out at 6500rpms HELP!!!!
  182. GSR Head, B20 Block Q's
  183. ZC DOHC timing.
  184. Difference between JDM ITR 96-98 and 99-00 tranny?
  185. **Would this setup work..B20vtec**
  186. NEED TO KNOW WHAT SIZE INJECTERS TO USE PLEASE HELP
  187. 1997 usdm type r swap
  188. Stock ls rod bolt torqe specs??
  189. anyone using USDM itr pitsons in your ls vtec setup post up whp/1/4 times
  190. Built motor and SMog
  191. coolant on radiator... does rob need a new radiator?
  192. who has made DIY ITBs??? need help
  193. Intake manifold
  194. cam question
  195. Milling pistons?
  196. Skunk Pro 2's vs Skunk Pro 3's vs Toda C's-street driven 11.5:1 b-series.
  197. cold air intake gains over stock? no other mods.
  198. 1st gen b16a help
  199. choice in a well-rounded cam setup
  200. having hard time starting car
  201. Buttoned up before bed...
  202. TOP-END GASKET SET>WHERE TO BUY>>>>?
  203. TOP-END GASKET SET>WHERE TO BUY>>>>?
  204. MILLED HEAD W/ FLAT TOPPED PISTON vs. HIGH DOMED PISTONS
  205. Oil Pump
  206. ITB Design
  207. **Removed Valve Cover and found sum things-PICS**
  208. Supertech valves and my experience.
  209. all motor h22
  210. GSR Burning Oil what causes this..
  211. Could be Getting a b16 Head
  212. home cookin!!
  213. my setup
  214. Skunk 2 Valvetrain yay or nay?
  215. WHP numbers
  216. JDM B16a Head
  217. Whats the difference?? GSR v. ITR CAMSHAFTS
  218. sleeving companies
  219. impoissible to find oem spec 75.25mm rings. can i use 75.5?
  220. help me here
  221. can this sohc setup run around 14's ???
  222. next new motor?
  223. Valve spring compressor?
  224. b16- yes i need help
  225. Campulley Adjustment
  226. Proper injector size?
  227. crower head n'stall
  228. Pct (b16b) pistons in a B16a
  229. 87mm pistons for a B20-sleeved block?
  230. need answers for crankshaft fittings
  231. found ls block. what pistons, rods should i use? on a budget.
  232. Some questions.
  233. Another Reason to visually inspect Ti Retainers often
  234. extrude hone port or port and polish??
  235. b18c1: differences in stock oil coolers among years?
  236. b20 vtec question
  237. ARP Rod Bolts!
  238. ITR intake manifold on a GSR head...
  239. purchasing first set of engine building tools....
  240. Will I need to switch out the valves also?
  241. Valvtrain parts for F22B1 SOHC Vtec head?
  242. b20vtec head gasket
  243. Finally DYNOED JDM H22 hatch...it's been a long time comming!
  244. 250 WHP out of a B18C1...is it possible....????
  245. AEBS MANIFOLD FOR 2.0 SET-UP??
  246. Jet Hot Coating
  247. cam torque spec
  248. b17 cams on b16 head
  249. A6 PISTON QUESTION
  250. h22 overbore.??
