- Mitsubishi injectors on non-obd Honda?
- vtec head
- ti-retainers for TODA B
- I have a problem with my car someone help
- headwork/milling question.
- Hondata S200 vs AEM EMS for ITB's
- PR3 pistons, what rods????
- smoke when vtec hits?
- Check this out!! Mean deal or Crappy product!! [link]
- help needed on cunningham rods
- LS with CTR's......going with 404's in my next setup.
- problem bogging
- crower stage 2 cams h22 need help
- plans for the b18c5 build... input requested <link>
- California bar certifiying a car with a jdm civic type r motor
- Guess my static comp ratio please!!
- word!!! Ctr cams for my 97 gs-r
- asuming a quality built head, how much RPM can a stock D16 bottom end handle?
- Ignition timing
- spark plugs for jdm b16
- Crank Pulleys
- Hell Broke Loose ! Engine Trouble.
- pr3 ECU questions
- Has anyone run a 90mm bore on a daily driven H22?
- Need help/opinion with Pistons IB sent me.
- Stock b20/vtec cams?
- Exhaust tuning, flanges, collectors, etc.... Where can I buy with good selection?
- Who makes a good AC Compatible H22 Header?
- one of those next mod questions again
- Tunning
- Drag Radials - Tire set up in general
- what header its best for h22?? without head work
- oem pistons on aftermarket rods
- crower cams??
- ***Help me figure out what Aftermarket cams I Have!***
- help on frankinstien motor from b16a
- comptech headers/exhaust good
- 15.5 @ 94mph (EG B18C1)
- Any experience with TOGA bearings?
- Compression
- stupid question
- gsr head, b16 block, compression with ctr pistons?
- ELITE HEADER??!!!
- head gasket???
- how to put a Clutch on a 90 Hatch back
- Question about injectors
- Great basic info on turbo systems
- Good N/A Compression on 98 gas
- Cam Gears Settings
- Need help on next Mod choice?
- type R rods in b18b?
- costs on stock rods, pistons, & rings?
- Wiring ?
- Couple questions on my new toys I just put on (ls motor)
- What do I need to plug if I want to ron NO thermostat in my B18C5
- B18a/B16a LSVTEC /w GSR Cams help!
- Are these pistons any good??
- New Oil Pump???
- hellp
- D16a build up and need suugestions.
- bang for your buck? custom exhaust 2.25 or pre made brand name?
- Trading b18 head for b16 head, want opinions.
- how high is too high for pump gas (91 octane) CR????
- Will type R valves fit work in a B18B?
- B20Z Vtec VS. B18C
- ecu's vtec pin
- Where to Buy a Short Block
- Best Itb's for homemade itb setup?
- are ctr pistons the same as pr3 b16 pistons?
- New setup, Good or Bad
- B17 Crank???
- Need Help On injectors!
- b16 head and block milling ?
- c5 crank and c1 block
- lsvtec ??
- Installation of OEM oil cooler on B20 block
- Best motorcycle ITBs to use
- CaN Sum1 TeLL Me How 2 DeterMine How Big of Injectors NeedeD?!?!?
- Exhaust Piping Diameter suggestions??
- ARP rod bolts...Due rod clearance change?
- Thought it'd never happen to me [misshift 4th -> 2nd]
- is this a b series lsd
- ITR piston and rod in B18a
- motor mounts... question?
- port and polish...
- best camshaft for lsvtec 11:5:1
- obd question
- Skunk2 Stage 2 Clearances??
- mill A6 head with 272 cam
- Crankshaft Interchangeability
- c5 vs k20 vs ???, help me out here.
- Vibrant header input!
- Fault codes
- auto to manual
- Most efficient manifold for a 2.0 gsr?
- Cam timing question
- Did a compression test on my b18c1 not so good
- Allmotor Uberdata setup?
- would i have to get my head port/polished after building block?
- best size pipe for d16z6 intake and exhaust????
- B18c times?!?!?!?!?!?
- Differences of a 1.8L & 2.0L Header
- JUST WON DA HONDA ITB ON EBAY
- Need Help..... GSR block with b16 internals realted....
- Dyno Tune EGT Gauge???
- best ecu
- 3 layer OE headgasket.
- Air/Fuel Guage
- LS/VTEC in EF 4dr.??
- Question about valve adjustment + cam gears
- what fuel rail/fpr to use, fitment issues
- removing middle layer from OEM head gasket?
- Question for guys with the hondata IM gasket..
- help alternator question help
- JDM PW0 ECU on D15 Engine ?
- How big, is too big (catback pipping)?
- ITB Update.........Shes Done.
- NEED HELP TO FIND A 4-1 HEADER FOR MY PRELUDE ENGINE... THANKS
- Eagle rods with TODA pistons
- Differances between crower 402's and crower stage2's?
- chipping with hondata?
- How is gas mileage with ITB's?
- H22 Build idea - comments, suggestions and ideas welcome
- cam caps problem, help!
- help removing stock cam gear from camshaft.
- Power FC, 370 injectors, FOULING PLUGS???? why
- GSR rev limit
- im looking for 96 ex wiring harness
- Right size of TB for my B16?
- **Selling my 11.5:1 rollerwaves What 13+:1 piston you recco?**
- Best pistons and rods for b16????
- ?'s on engine/fuel management and 11:1 c.r. ..
- burning oil?
- 2.0L LS block resleeved or GSR with ctr pistons??
- D15b8 questions. (searched already)
- b18c mildly built head and wondering wat to do piston wise?
- Stainless Steel Valves or Type R valves???
- does the jdm dc header make decent power???
- Question for you all motor guys about intakes
- prelude injectors or RC 310s?
- JDM 4-1 R header on DA w/skidplate
- Anyone know torque specs for 3/8 Arp Rod bolts?
- Bumping up compression
- anyone know where i can get one of those....
- STOCK GSR HEAD...ITR CAMS OK?
- New header (DTR), slight hesitation after install.
- what is this thing on b16a manifold???
- 4 Sale B18B, J4D LSD (Type R tranny), ACT clutch, axles, ecu, harness, starter
- OEM b-series cam questions
- Cam problems! Help!
- Best pistons for B18c
- h22a accord 1994
- Not your typical Eagle Rod question.
- b20 vtec and lsvtec. I have some questions unheard of.
- WHAT IS V-TEC?
- Bisomoto header...any thoughts??
- BISOMOTO VS AN-R!!?
- DTR header in an EF9 hatch
- Rocket Motorsports - Gets a Flow Bench
- whats a better header?
- smoking question??
- D series valvetrain ?
- 2.0L N/A 220hp
- anyone with b16a ctr piston and ctr cams? need help
- Import builders.com
- How much is safe to mill off my GSR head?(wanting higher C/R)
- Stock B18C1 with ITR cams
- Daily Driver B20 VTEC w/all Honda parts questions...
- Stroked 1.8 b16a vs b18c1
- H22a Hondata Maps
- 2.0 GS-R, what parts are needed and what is all involved.
- hytech 2.3 litre k series
- What kinda timing with 11.5:1 ? What u running ?
- Bisomoto or AN-r????which one is better
- GSR 1/4 mile, 96 o boy fun night.
- 12s?
- Pistons for my B18B1
- need advise on which swap to do
- VTEC cam question? Why aren't there cams like this?
- whats the flaws and where to get a 2 layer head gasket for b16? in socal
- Another GSXR 1000 ITB Thread
- Help
- Head gasket on bored motor??
- b16a1 head with b18c block
- header. a lot of money for only a little power
- Fuel Pump and Stock PSI
- burning oil? spark plug covered in oil deposits????
- best midrange header???
- Port and Polished Heads
- PR3 pistons in P72 block???
- all motor tuning question, advance/retard?
- which injectors?
- b20 with ls head. what cams to get? need help deciding
- i got a couple dumb questions to ask
- 1.8 LS head or 1.6 VTEC head on B20B/Z block?
- B20A/B21A crank into B20B/Z block?
- Question for the pros
- Ia A Injen CAI too restrictive on a 2.0 liter 85mm B18C1 with 70 mm T/B ?
- Anyone running Crane cams stg III's, idle issuses?
- Skunk 2 Manifold or NOT
- Spoon Stroker Kit for the B16b worth it..??
- Balancing and Blueprinting
- lsvtec worth it?
- head gasket 11.8 compression help please!
- b20 outta what????
- Mad problems.
- Replacing rods and pistons
- motor almost done...what to do next?
- CALLING ALL ITB GURUs.....HELP ME PLEASE!
- Cam choices for a built motor
- rod question!!!
- best of the worst?
- help with head
- k20 into a 92 vx? is it possiable?
- valve springs
- H22 individual throttles
- Compression Question.....All input will help
- K series beast?
- Skunk 2 cams in b16a2
- rebuildable, metal chips off of block
- install cold air
- why arent more people out there using jun4 's?
- itr piston part #
- question with head.
- Building up B18c1.....need advice.
- Buildup Question
- I need help with an engine.......
- inconsistant smoke????gurus please help
- jun ecu?
- head salvageable?
- So...who's got the MOST HP n/a on a daily driver????
- AN-R Compact VS AN-R Standard Version
- Loose headbolts
- Carrillo A-spec rods, anyone use them??
- anyone running crower 63402s or 63403s
- Where can i buy some 2.5in exhaust flange..
- motor problem! need help.
- Best Cams for my NA setup
- horsepower vs quarter mile times
- whats the difference between a b18a1 an b18b1?
- Good #'s or not
- An-r header vs. Ericks racing header (which one can give you more horsepower thanks!)
- How much is a GsR Long Block, Head and Short Block Worth (B18C1)?
- Pushing the K24 to 8500rpm
- Boost guy going for big NA numbers
- Good Cam Gear for SOHC
- Someone, anyone, help me out here! backfire through intake on fresh motor
- are the CTR piston suppose to stick out??
- Which header for my DA6?
- My Dyno Video
