- B16 Build
- Need some help front the ls/vtec pros
- D15B(3Stage VTEC) Vs D16
- Tell me what you thing!
- Which one is the best?
- how to reach a hp goal 230-250 with a gsr
- b20 ef
- Why do this!
- Who has the fastest SS/AM H-series in the USA
- Magnaflow vs Vibrant Hi-Flow Cat
- [B]Magnaflow vs Vibrant Hi-Flow Cat[/B]
- Are aftermarket b-series valves even worth the money?
- how can i check to see if my block/head has been milled?
- Cam Question
- How to fit KiddRacing's header into my current setup,please help
- EGT temp
- del sol b16 piston...need input!!
- F***ing block stipped out
- Best B Series Motor for Spcial Project
- can someone please help me?
- b20vtec pistons and rod bolts?
- D16Y8 and D16Z6 main girdle and caps interchangeable?
- poorman type r ...which headgasket and timing belt?
- B18c motor build. Where to?
- New to the Honda scene
- why arent aftermarket cams made with offset
- What retainers for a 100,000 mile motor?
- 12's n/a???
- any one running a 4" intake on h22?
- head setup
- 2 more ported non honda heads, yes!
- H2B crank pulley options
- Start of n/a b18c1
- B16A 60mm or 70mm exhaust???HELP???
- d16 rods
- d16a1 help!
- timing belt..
- How unsafe overbore is for a B18C JDM ?
- Catastrophic Failures on 'Built' all motor - Help us learn from your expiriences!
- Engine Upgrade
- Not Another one of Those ' Think for ME ' Threads!
- h23 blue top swap
- j series into a delol ?
- I picked up a CRX w/ an unknown LS-VTEC setup. How do I figure out what I have?
- GSR motor with BCIII cams
- My Gsr Build! Needs Help
- B20vtec main cap questions
- Help Teg Wont Start!?!?
- Z6 head/A6 block/11:1 pistons???
- vteckidd header worth upgrading from DC 4-2-1?
- Are These REAL Skunk2 Pro 1s?
- which head gasket?
- Your All motor builds...
- What cams are these ??
- DMH e cutout = AWESOME
- question about compression and cam choice
- LS vtec question
- Spark plugs pulled from fresh build gsr
- Supertech retainer failure
- 94 GSR into a 2000 Si?
- engne rebuild/break in questions
- B18C4 rod bolts
- Stock rubber Vs. Metal intake arm
- blox b cams and blox valve springs power and reving
- Running a blend of c14+ on almost stock motor?
- B20Vtec for Road Racing, Sleeves an Issue?
- Blow by?
- looking for a similar set up. jdm type r with stage 3 cams
- My B20/Vtec build...........Am I being excessive?
- Difference between Blox Type B and Blox Tuner Stage 2?
- LS/V....how much hp and torque??
- Find TDC on crank without taking crank pulley off?
- h22?
- B20V 250hp target, intake mani question/poll. Which is better?
- Piston and Main Cap damage
- D16 Build help
- Skunk 2 B series header worth it?
- LSV Questions - Bout to start the build
- Valve spring Question i need help
- JDM ITR 98 CATYLITIC CONVERTER VS HIGH FLOW
- crower cams vs. skunk2 cams for h22????
- opinions please??? k20 trade or not?
- Is this CTR intake cam useable?
- B16A exhaust info
- Whats wrong with this engine???
- best poor man's type-r setup
- Slight B16 Confusion
- stock crank pulley or aftermarket???
- D series to JDM B16a lots of questions.
- Couple fuel questions
- Crankshaft Pulley Bolt coming loose?
- the next BIG thing for Honda's...
- Standard B16B head with 12.5 2.0L itr block?
- Question about ERL Superdeck 1 for All motor
- Engine jerking upon deacceleration.. stumped
- 95 honda civic GSR swap help
- ITB + Nitrous
- Another Homemade 43mm ITB project
- sleeve material on B18b1
- Skunk2 Pro series ~ retainer wear
- HELP!! LOOK IN HERE!!!!
- Need Help Identifying B series All motor race cams.
- B16 build for track car swap (Noob will probably need guidance)
- h22a stock bottomend 230whp/168tq
- supertrapp add-on mufflers?
- new to the honda world need some help
- Building a DD B20vtec
- H2b vs j32
- My project B16A2 NA
- b18c gsr /jdm itr pistons help please.
- b16 head or GSR head??
- BARing questions
- B16a Non-Vtec (P-75) Winter beater
- Is this normal camshaft wear?
- B18b motor... whats the different in proformance if you use a obd1 pr4 or pbd1 p75 ec
- Dynoed my car good or bad #'s??
- N/A Mini Me Piston help!!
- Robertson racing Crx sets landspeed record
- DC sports DAC intake for 95 civic si
- B17 crankshaft
- 200whp stock block b20b?
- help! h22 swap in eg need help!
- b16 high compression pistons
- Buddy Club Spec III+ cams Any GOOD?
- Which intake manifold?
- Oil Leak [ with photo ]
- Motor dies after 2000 rpm
- b16a stock block max rev?
- A question or two about a future build.
- few d series questions
- Anyone know the specs of the blox valvesprings?
- Supertech Springs + Skunk 2 Pro2 ..Yes or NO
- ported my first honda head (warning its only a d15 head)
- h22 stock dual valve springs?
- Oil Coooler
- bog at low rpm... Yes Ive searched! Please HELP!!!!
- Sleeved or not?
- Poll: Monthly classified sticky for the all motor section?
- honda-tech choice b20 with wat internals??
- ~*Toda Spec C camshafts and SKUNK2 valvesprings question?*~
- Simple GSR Build, Graph inside!
- My All Motor Build
- any stock ls/vtec dyno charts??i've only seen stock b20vtec charts
- D16Y7 knock
- hone or not to hone?
- went to the dyno today!! need in put please!!
- rewiring the fuel injector harness, one SIMPLE question :)
- ported another stupid neon head
- my current b20 vtec ef setup not performing??
- quick Q about skunk2 pro 2's
- skunk2 68mm throttle body gasket NEED PICTURE OR DIAGRAM!!!!!
- Civic B16 crank sensor
- ? on B16 block with B17 crank and rods
- tunning ign and afr
- mini me build help pls!
- anyone make their own intakes??
- porting out skunk2 manifold??
- Port and Polish work
- JDM B16A indivual throttle bodies help, suggestions...anything
- custom gsr manifold?!?!?!
- can i use those light damaged head gasket????
- CTR piston in B16A
- Need Input on my B20VTEC build
- AEM dyno plot on 99 Si - not V2
- ctr gsr
- aem v1 or aem v2
- i know im not supposed to ask this!!!
- Maybe going to the dark side.........K series questions lol
- b20vtec in a 92 cx problems
- Had my day at the dyno!! I think my money was well spent..
- itb question
- B20VTEC ARP HEAD STUDS #?
- b16 header help
- these rods look weird
- h22 injectors and pump maximums
- JDM Type R OBD2 engine in EK
- 99 B18c build suggestions/ideas?
- timing or something idk?? HELPPPP
- OBD1 to OBD2 Wiring Conversion
- B20B SLEEVED
- b16 help
- SP fab header test
- Cracked Valve, Scratched Crank....Help!!!
- Slight chip on cam lobe still okay?
- cold air intake b18c6
- Quick way to check valve to piston?
- b16 cam gear adjustment
- Will my clutch do????
- rod caps not fitting after arp bolt intsall
- GSR with BLOX tuner stg 2 cam
- Please recommend Head Gasket for 89 Civic
- gsr cams and type r pistons usdm what specs when adjusting valves?
- oil in distributor!!!! bad inside seal!!!
- Best Replica Header
- blox valvetrain......
- cam gear adjustment recomendations
- 208WHP b16a2 "shelf parts"
- b18c1 ctr pistons
- apr rod bolts
- help :[
- header
- B16.. where to start?
- Wear in the head where the cam sits fixable?
- HELP!!!!!!!
- BONE STOCK b20vtec setup
- high mileage gsr ...doing simple rebuild
- PCV trouble
- jg edelbrock victor x what intake system?
- 2.5" donut gasket and B-pipe 3-bolt gasket
- wrist pin help??
- Radiator for B18C-R Build in EG
- tools required for all motor build
- beraring?
- h22 vtec engagement
- 350whp all motor ??
- itr cams with stock b16 springs and retainers
- Piston/rod help for my build
- JDM B18C Type R Trouble...
- what header for my set-up
- Screwed have to test only B.A.R certified smog station
- LSV Build Cam Opinions- Need feedbakc please!!!
- rocker arm/cam wear on part of the VTEC lobe...
- step by step idiots guide for timing?
- what cams do i have??
- 120 whp on D15b7?
- Need Help installing 92 acura integra DOHC 1800 in a 96 Civic EX
- GSR B18C1 Build Questions
- timing belt cover and rain???
- msd 6al ignition
- Cometic vs. GE head gasket: which one is better??
- How much HP?
- Aem pulley kit for integra
- 300+Hp all motor set ups?
- Injector opinions
- Full float pistons stock rods
- Can a Head Gasket be reused if it hasn't been heat cycled?
- 200whp B18a1
- what are most common mistakes of first time engine build?
- My teggy type r help
- QSD h2b headers
- Question about Poor Mans R, pretty much stock internals.
- Before i throw my motor in..
- b16b1 or sohc 1.5 v-tech
- E85
- such a thing as a "quiet" 3 inch muffler?
- sohc timing help!!
- ==all motor build help ===
- Mugen headers and exhaust
- K20A6 Coil on plug problem
- itr pistons on ls block?
