- (TSX)CT Engineering Header vs. PLM Header - *Dyno Results Inside
- buddy club spec III plus VS skunk2 tuner series camshafts stage 2
- Built LSV, Vtec sputtering?
- B16 internal qestions!
- B16a2 loss of power
- Sick ITB'd NSX tune- Trackforged
- Help on V-Tec
- Cold start up question
- where to go with my build (intake wise)
- b16 Camshaft holder plate bolts question
- High Compression Nitrous i got a couple of Q's
- B16 Del Sol VTEC is not engaging
- Any stock B20 cams benefit mpg and power?
- prelude 1990
- LS Intake Porting. Any point?
- B18c SIR-G fuel question
- Building my d16z6 worth it? Or is it better to invest in a B-series?
- Alternator noise
- Need urgent help please
- Possible to tell if you have cams without opening valve cover??
- mini me questions
- Upper dizzy bolt stripped out
- kelford 176 -B camshafts need helpwith info
- All 4 cylinders misfiring(code 71-74)! Tried everything! Need further help!!
- cam cap bolt broke help !
- do es tuning mufflers blow out?
- help on engine choice
- All motor B18b1 Stroker kit question
- Ideal Dynamic Compression Q's
- RDX Injectors onto AEM rail-- adapters required?
- B20 CRX Won't Start!
- Oil Leak Behind Crank Pulley
- how much is my block worth
- yes ive researched... toda vs highend header test
- best piston/piston kit to rebuild a b16a with?
- 97 gsr hatch not running strong?
- d15b non vtec to 3 stage, whats needed?
- whats a good set cams for a stock gsr?
- need opinions: best cam for pct piston/b16a build
- Hey B series builders Can this be done?
- Question about Cam vs Valve Springs
- HOW TO TELL IF I BLOWN UP MY MOTOR??
- VTC actuator replacement problem
- CEL comes on when VTEC engages - goes OFF when disengages?
- D15b7. 102->200hp?
- Gasket and filter identification
- I Smell Fuel from the Exhaust ... Balck Smoke
- b18c1 s2p2 (no vtec, rev limiter)
- mini swap or ls?
- building up type r
- What head can I use on a 1st gen B16A?
- Honda civic idle is to high help
- Compression Results
- Hear recommendations B18C JDM exhaust
- Planning a d series motor swap.. Best d series motor?
- ITB filters
- Issues with b18a1, unexplainable oil leak and rough idle
- GSR rebuild questions...
- My 86x89 LSV build
- B18 c2 main bearing clearances?
- Scat stroker crank
- shimmed valve springs for better rpm?
- Small oil leak running down passenger side of block
- Creamy oil. Fluid level way past "full" line on dipstick. Removed cylinder head.Help
- Tolerancing - Bearings/Rings/Pistons/Bore/Crank/Rods
- B16 head soot
- grank 95mm 50 main
- idle problems after head gasket
- B20b idle problem/Lean!
- Please HELP 93 civic coupe d16a
- newbie q's on built b series or built h2b
- Insanely stuck crankshaft pulley bolt
- b20 high comp p8r question
- Clutchmasters FX500 Clutch Disc Substitution.
- All Motor B20 Vtec BROKEN!! Please help
- help all motor gsr
- Should I hone or bore my cylinders?
- 97 B18 Hatch no heat
- B16A3 Engine Noise from Head, Possible LMAs?
- B18c1 upgrades
- 1994 LS Integra problems. Looking for LS motors
- need some help with 91 crx
- Is the PLM v2 header causing my midrange losses?
- fouuuund i guess a jdm engine asap
- spark plug color
- How many CC's lowered when head is milled
- victor x or type r intake manifold
- Ring Gap Help please
- D16Y8 engine swap
- type r need help???
- PLZ HLP!!! Very low throttle resp. & overheats in high altitudes!!
- d15b2
- 1993 civic 1.5 dx spits, sputters and backfires
- Mix match make me power!!!
- type r all motor or ls vtec?
- Honda Gurus Assemble
- jdm b20b throwing code 16 help???
- replacing piston rings on b16a
- Why is this H22 running so rich?
- What kinda springs this are?
- Help with Vtec /Weak engagement
- B18b won't rev past 3500rpm
- building a b20vtec should I upgrade my header?
- b series crank pulley qeustion
- H22a Stroker vs Rod Ratio
- D15b7 bogging issue
- Vtec not working :(
- LSV my first Bseries build
- d15b vtec 79x74.5 (1650cm3) EG8 civic sedan wants 200 whp
- need helllp.
- meth/water injection - anyone use or used it on an NA?
- B18C looser p2w clearance oem piston
- BWR half radiator and fan review
- ACL Race HX Bearing Thicknesses (Need confirmation on numbers I've found)
- Prelude 1990 heater hose
- Ef b series side exit header
- 95 Honda Civic DX Help and Questions
- Toda B camshaft help
- B18c4 bolt ons
- blox v3 intake manifold vs skunk2?
- P8R head - what intake manifold options? Modded b16 IM?
- Low comp NA!
- z6/b7 mini me help
- theory on if ill hit valves
- Barrier's Mundane Stock F20C Rebuild Thread
- anyone have the hook-up to a good porter? rlz,4 piston, ext
- EK B20 LSVTEC build
- what engine and tranny is this? how much is it worth?
- bad valve seals. NEED HELP
- 0bd0 b16a vs. 0bd1 b16a
- b vs. H pulley
- 1998 Honda Civic LX engine question!
- all motor b20vtec build. what intake manifold?
- Oil rings
- Cat cam question
- ZC motor
- Dyno results for f20b stroker
- Sleeve Removal
- ►► November - December | All Motor Classifieds | FS & WTB ◄◄
- All Motor EM1 help
- B20 non-vtec mods that don't sacrifice mpg
- Best oil filter for conventional oil
- b18c1 Build HELP
- Building a b18c4 block - need specs?!
- J30A1 Build Question
- speedfactory oil catch can question B18c-R
- J35A4
- h22a valve lift at TDC
- 95 honda civ engine shot
- What engine for off road?
- Questions about my B20z re/build & automatic tuning
- My All Motor Build Gone Bad Help
- ls vtec torque spec
- '94 Civic VX inconsistent idle / hesitation
- Ported GSR P72 head for a street all motor setup. 251Whp.
- My ep3 CTR
- What is the most horsepower from a JDM B18C N/A?
- All Motor D16z6 156whp
- Should I keep my ITR camshafts or go bigger...
- anyone have experience with obx h22 itb?
- Carbon fiber air horn/trumpet
- The terrible tale of the B18C
- eg coupe b18 swap, PCV valve discconnected
- Where can I find 85mm File to fit piston rings.
- Honda is sucking up too much gas!!!! HELPPPP
- is it worth getting a B16b?
- b16 cranks but no start (NEED INPUT!)
- ???? oil leaking ????
- Anyone recommend a site for complete rebuild kits? (F23A1)
- Identify these cams please
- D16Z6 BLOCK WITH A D16Y7 HEAD
- H2b Transmission choice
- valvetrain retain?
- F23 VTEC cam. Are there any options?
- J32A2 03 CL (Type S) Swap EJ1 *Help
- NEED HELP!!!!
- Type R cams in GSR head
- f20b stock stroke, cams daily abuser build for a friend :)
- Does this look like a Delta Camshaft 272 Re-grind to you?
- all motor "gsr" question
- K20z3 block stamp
- help
- EF full hydraulic conversion
- Stroked f20b compression test results
- Thinking about using this ITR crank in a rebuild ?
- Mugen NA Masterpiece
- FULLY BUILT ALL MOTOR B-SERIES
- will b16 spark plug wires work on gsr ?
- RMF B SERIES HEADER
- PLEASE HELP: B18a / B18b question
- My Review of RS-R's Ran Up Oil Additive
- d15b vtec e rev limiter at 5k.
- previous motor in new car running super rich in vtec
- Needing a little help
- Cool D series track video
- please help me B16b wont stay running
- rpms rev to only 7k, redline is 8k. NEED HELP!
- ammfab head porting pic thread....
- integra b20v sputtering, dying at idle
- Gsr/CTR piston warm-cold startup help needed
- 92 h22a 4200rpm cut out
- custom piping from www.mandrelexhaustsystems.com
- F20B stroker rod options
- I need help on deciding parts for my EK4 b18C
- Header swap on B16, need input!
- Skunk2 Tuner 2 / Supertech Springs
- factory pistons
- BHP with Block swap?
- b20v help
- High Comp Build on B17
- 1.8 All motor...
- b16a2 not running properly???
- mystery motor, whats the original car it belongs in.
- Tell me about Honda/Acura V6 engines.
- skunk2 pro2 cam settings for h22
- b18c1 tune?
- EGR Vacuum Solenoid Question
- Unpluged the spark plug wire from the distributor now the car wont start
- are these itr cams?
- B20 Nonvtec 208whp
- LS Intake Options
- HELP finding cam brand & spec
- TWM ITB START UP HELP!!
- bbk intake manifold help
- i call bullshit....
- Stock block b20v (b20z + pr3 head)
- b18c1 releases black smoke in high rpms?!?!? Opinions..
- HELP. Cams swapped but car isnt starting
- possable build
- B18C knocks when starting cold
- LS Auto to Manual swap isnt as easy as everybody thinks!!
- 750cc injectors
- Any All Motor D16Y8's Out There??
- bisimoto with gsr
- d15b vtec jdm
- Type r LMA's
- jdm b16a timing belt.....
- Need replacement header for built 2.0l type R
- B series flywheel
- K24a2 E85 light build with DYNO Chart
- B18c5 rebuild questions(searched and still stuck)
- f20b stroker (G23?) question
- HELP finding the best cams for my high comp b18c
- 95 f22b1
- stock cams?
- What Stroker Kit to use with JDM B18C
- wanted b18c1 block
- gsr head fitment
- D16z6 Boosted Motor Build
- b18b block with ctr internals?
