PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 [184] 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. is my fuel pressure okay?
  2. vavletrain noise
  3. How good of a setup is this?
  4. bearing questions! already did a search
  5. http://www.raretrick.com/index.asp?cat=515&Page=1&Display=Yes&Back=Listings&ProductsID=6280
  6. B18C1 In A B16
  7. TODA valvetrain?
  8. anyone recomend a nice after market head???
  9. do TB and IM have to replace at the same time for ?
  10. What came would suit me better.
  11. skunk2 intake not good for PCT cams?
  12. CAM OPINIONS please...
  13. hondata
  14. How much am I ristricting?
  15. MY GSR REDLINES AT 7500?????? HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  16. need some help with oil pans????
  17. best cam for me to run?
  18. Need help on LS/VTEC build...
  19. northern minn machine prices
  20. CTR cams stock valvesprings.
  21. 98-96ITR VS 95-01 GSR CAMS APPERANCE?
  22. 1 Ply Head Gastket for H22?
  23. need help with valvetrain
  24. people using skunk2 stage 3's...inside
  25. ls crank
  26. do port and polish good for turbo after NA
  27. AN-R headers
  28. Destroked B20v??
  29. B16 with ctr internals... few questions
  30. Cylinder head switch messed with dyno numbers.
  31. CTR pistons...
  32. My setup
  33. Help me decide...
  34. B20B/B18B Pistons...What should I use?
  35. first n/a build
  36. buddy club vs. Skunk 2 camshafts
  37. Searching for answers from D-Series experts/owners
  38. *SMOG CHECK FACTS NEEDED*
  39. ITB adapter plates--- for u DIYs
  40. Who makes gold/bronze cam gears
  41. blox vs. skunk2 intake manifold?
  42. Integra 1/4 times full interior
  43. b18c5 on the highway?
  44. b16 IM on b18b
  45. cleareance issues?
  46. It's nearing completion! h22/hb allmotor
  47. Valve to Piston Clearance (searched)
  48. anyone self bored out their TB
  49. Catalytic converter
  50. CTR / lsvtec ?
  51. Will jdm itr pistons fit on 99 usdm gsr?
  52. Just a few questions need help?
  53. BuddyClub stage 4 vs Skunk Stage 3 DYNO'S INSIDE WWW.BRISTOLDYNO.COM
  54. how to set proper ign timing with timing gun
  55. ITB set up...Homemade...Throttle body set ups??
  56. $250 for a complete B16a shortblock a good deal?
  57. OEM Piston Rings. OK for LS/Vtec??
  58. Anyone have a 88-91 CRX DX or SI Tranny? or maby a ZC motor?
  59. b16a swap question?
  60. Throttle Surging
  61. Lsvtec with 95mm scat crankshaft?
  62. will OBD2's ECU reset Advance Timing of the Distributor?
  63. Any suggestions?
  64. b18 or b20 (i know its been answered!)
  65. b-series degree wheel?
  66. to bore or not to bore?
  67. Questions about an engine rebuild...
  68. lightweight aftermarket rockerarms?
  69. Which makes more power?
  70. N/A tuning
  71. Anyone have a Tech43 B16/Ls stroker motor
  72. Beginning either LSVTEC or CRVTEC
  73. I know this is totally off subject but I didnt know where else to post. What does CTR mean?
  74. Nar-Spec.com Headwork?
  75. Ls Vtec ?
  76. SuperTech or Portflow Dual Valve Springs and why?
  77. comparison LS CRANK vs ITR CRANK
  78. Absolutely Necessary to sleev B20 block??
  79. BRAND NEW ITR HEAD GOOD ENOUGH???
  80. all motor b20
  81. Velocity stack "street setup"
  82. Snoflake EG's 2.0 lsvtec buildup!!!!!!!!!
  83. d16y7 block with a y8 vtec head
  84. what exhaust setup do you all recomend
  85. Does ANYONE have any allmotor sohc setups they can post?
  86. are craftsman adjustable timing lights considered accurate?
  87. b16 falls on its face at crossover...
  88. AEBS or Type R?
  89. b20 head on a b18 block??
  90. Decided to do Advance Timing,,,need suggesitonsssssss
  91. GSR internals in LS Block?
  92. PROFAB HEADER
  93. motor build
  94. Intake Mani question
  95. ctr piston or toda piston?
  96. Will these tests tell me if a block is in good shape?
  97. Need some Help on my JDM GSR Motor.. Intake!!
  98. Starting an NA setup...
  99. little h22 parts i need to find?
  100. dry sump oil system??
  101. Exaust for 2000 Civic EX
  102. Stock H22 Retainers, Upgraded Cams and Springs?
  103. 250 whp... between 2 motors
  104. where to buy roller cams
  105. Built SOHC VTEC setups...looking for dynos/#s...
  106. B18a1 Swap Problem *HELP*
  107. 300whp H22?
  108. Adding MSD SCI ignition system... Quick Question...
  109. gsr in a civic swap problem
  110. CABLE OR HYDRO?
  111. just installed a CTR intake cam.......
  112. Engravings on Skunk2 Stage 2 Cams?
  113. Rm H22 Cam Specs from Kteller Inc
  114. Does anyone have this setup
  115. Opened Up Valve Releifs LS/B20 Vtec?
  116. GSR Motor Swap
  117. Has anyone passed emissions with an ITB setup?
  118. what to look for when buying a head(core)
  119. FAQ.... EK & Bseries swap (2 or 3 99si mounts)?
  120. What size bolts to place my h23 on an engine stand? 14mm?
  121. Another Intake manifold gasket question.
  122. help please!!
  123. p73pistons [jdm-itr] on ls/vtec
  124. dzminiz's D16 Engine Rebuild Kit
  125. Testing waters on b16....
  126. Rocket Motorsports Valvetrain?!?!? Good?!?!? Bad?!?!?
  127. help!
  128. Went to dyno yesterday check out my #'s and setup.....
  129. Love Fab Header
  130. Carsound vs the Challenger
  131. OB2 TO OBD1
  132. H22 stroker ???
  133. aebs + no iacv + winter = !
  134. b20 ealge rods w/ arp 2000 bolts, whats the torque spec?
  135. knock sensor in p28
  136. h22 with ITB's....what management?
  137. can someone help me, I NEED TO KNOW TORQUE SPEC'S
  138. best k24 hybrid
  139. tips on how to tune
  140. All Motor CTR(b16) CRX Questions
  141. Are gsr outer valve springs the same as ITR outer valve springs?
  142. Rod Recommendations??
  143. does anyone have a crower stroker kit???
  144. 88 ys1 tranny....which clutch?
  145. Good N/A Header
  146. will LS rods fit in d16y8
  147. Where to buy built motors?
  148. cheap fab.
  149. y8 intake manifold on the Z6
  150. b18b itb's .... has anyone tried this setup ?
  151. h22 head gasket?
  152. Honda Engine Rebuild
  153. Torque specs
  154. My results dyno CTR vs Sk2 over 200hp
  155. CBR 600 ITBs size
  156. Pistons, cams, Intake?
  157. Power of a fully built K20A Type-R
  158. ok looking to built a nasty b16 :) i already have a b16 darton block, crower econo rods.. need help!
  159. Looking for Forged Version of PCT pistons (ctr)
  160. how tuff is it do OBD2-OBD1 conversion by myself
  161. 12.5:1 84mm bore safe?
  162. Mugen Vavle Cover
  163. Are RS machines cams regrinds?
  164. question bout getting dyno tuned
  165. Built All Motor Ls Engine
  166. ls+vtec make 13's
  167. Compression on B20B/Vtec?
  168. I think this is what i want my setup to be.
  169. bent valves....should pistons be replaced?
  170. typr r pistons in gsr...
  171. h22 or b18c in a EK hatch
  172. took car to track horrible*cries* :*(
  173. do you all think a full hytech exhaust is worth it
  174. ls crank gsr block girdle?
  175. All motor B20 setup pics please
  176. 1300 degree exhaust temp. whats the problem
  177. not another itb question. sorry guys
  178. k20a2 valvesprings?
  179. anyone heard of profab header?!
  180. timing belt tensioner
  181. Which ARP Head Studs for ls/vtec?
  182. Suppliers of Pistons for an improved touring race car?
  183. No Catalytic Converter!!!!!
  184. would first gen b16a pistons give me more compresion on my ls block in my hatch
  185. Differences JDM Type R motor vs USDM Type R motor - How to identify Type R motor?
  186. need help with ls/vtec...
  187. going to the dyno help?
  188. cam bearings on head scored
  189. Headers question
  190. LS/Vtec Mains
  191. The delicate balance of streetable and non streetable all motor cars.
  192. rev limiter?
  193. VAFC causing CEL 3 (electrical MAP sensor failure)
  194. looking to build a B20. have ????
  195. WTF id this duuu!!!!!
  196. 99 B16B (CTR) Engine / 96-98 EX Engine Harness / into 96 EK Hatch Swap Question
  197. safe timing for my setup???
  198. CTR PISTONS WITH NITROUS...ANYONE???
  199. Any Uberdata tuners around San Diego?
  200. 3" or 2.5" exhaust
  201. is an integra fuel pump sufficient?
  202. Building a D16A6... Cost and changes?
  203. are all b-series distributors the same?
  204. gsr differential in a ls tranny?????
  205. Black smoke
  206. HELP - - - - - - -- - - I Want To Know
  207. 2005 b16 (ctr)build
  208. Do skunk2 stage 2 cams need more compression that I have?
  209. the correct way????
  210. b20b into 91 civic hb
  211. b17 crank, what rods
  212. RS Machine cams?
  213. LS cams
  214. Best cams and Pulley for B18B
  215. Transmission slop?
  216. 12.7:1CR do-able with 91 octane?
  217. modified GSR .. hp too low? dynod
  218. oversized or not?
  219. Is it worth it?
  220. Which route to ~210 whp?
  221. couple problems
  222. act flywheel
  223. Crower Valvetrain?
  224. Can you troubleshoot better than my Acura Tech??
  225. itb's + vafc tuning..... obd2? :o
  226. WTF is this peice ?
  227. bolting on aebs intake manifold
  228. will a crane hi-6 ignition fit on tegs
  229. Anybody had dealings with NIPPON produced pistons?
  230. my spark plugs quest pictures inside...
  231. >>>>critique this header design<<<<
  232. GSR engine + tranny curb weight?
  233. what is the AVERAGE gain of PORT&POLISH
  234. breaking in
  235. Dyno or not dyno my car
  236. built n/a ls or ls/vtec??
  237. ARP head studs on a Y8....
  238. What do all your N/A street cars weigh in at?
  239. Clutch Fork problems?
  240. accord h22/itb follow up
  241. Skunk stage 2 cams
  242. Another DIY ITB setup
  243. question on ls bottom end gsr head
  244. tuning question?
  245. who is using CTR cams on a STOCK motor
  246. shit rigged itb ????
  247. Copper spray on headgaskets???
  248. All Motor Setup
  249. custom exhaust setups
  250. CBR 954 throttle bodies, ITB's ON a GSR
