- WHY WAS THIS DONE !?!?!?!?!?!
- Help on swapping engine
- what is the compassity of my coolant system d15b
- Are Omnipower and blox valvesprings the same?
- cam settings for buddy club spec 3's.
- Friend bet me his car that I couldn't build a 200whp B16 with $1500
- Oil cooler sandwitch plate question?
- LS-vtec want some input
- asking a ricer question what would yo think my car will run
- blocks
- Poor man's TYPE R; What route for more power?
- help with torque specs...
- Building a d16a6 block + d16y8 head...need some suggestions
- NEW PERSONAL BEST 11.2@120 at NOPI vids inside
- do i need a tune?
- RBC intake mani and throttle body questions/info. k20 k24 RAA
- ***Some Good News***
- ls vtec b18b jdm buget built
- to coat or not to coat?
- highest D16 hp
- need specs on skunk2 pro1s
- power fc problem
- Edelbrock d16 header
- b18b1 W/404's
- p29 Pistons in a D16Z6
- type r swap question???
- Getting vtec in only 3 cylinders?
- Project underway are my clearances good?
- Need help identifying cams!
- How to STOKE a B18C1..
- b20 build
- anyone use this combo... (ctr pistons, gsr block,b16 head, jun3's)
- Midrange cams?
- my motor stutters at 4000 rpm
- Stroke a b16
- tranny question
- ls/vtec compression.....stock honda pistons?????
- p28 ECU/Hondata S200 problem
- Looking for a machine shop to fit my CTR Pistons onto my 2nd Gen B16 Rods (SoCal)
- RMF Street vs Narrow Header
- blox b's or crower stage 2
- what rear engine mount do i use?
- TWM throttle body question....
- B20Z stock revlimit
- need help deciding on a 2.5 inch muffler
- Suggestions on old b18c build
- gasporting OEM pistons for a street motor.
- B20 VTEC
- Do GSR rods fit P30 pistons?????
- advantage of 2 piece header?
- portflow standard honda work!
- new ECU...feel's weird????
- Do you need washers for your Prelude LMA's?
- H22 vs. K20-24, a stokc car aint a race car
- compression question
- good idea to do internal bottom end work on a JDM Euro R motor?
- Need help.....More Detonation........AGAIN!!
- ported Euro R IM expected numbers
- GSR headgasket on LS/vtec
- b20/vtec..........what head bolts do i use?????????????
- B18 vs B16/B17 - Head Potential!!
- crank case allen plug !
- best place for custom pistons
- Help with VTEC controller
- anyone know a good dyno around sacramento norcal area?
- Headers for B20
- how to build & stay ca street legal?
- all i want is torque!
- all motor tune-up
- Want anwsers on B20/B18ls block with B16 head
- Hondata intake manifold plastic gasket???
- supertrapp muffler?
- more bore=more rev=more stroke=more torque
- ported head from ERE???
- Anyone using the golden eagle LS/VTEC sandwich kit?
- Gsr Head with a b16b block ...has anyone here tried this combo before Results ???
- Honda Engine. High Revving. How to make it higher?
- Slowest B18C EG
- J's Racing Japan 4-2-1 Header
- One or two cams?
- Sometimes engine-building is such a pain in the ass...
- > IB Spec pistons (SUPER DUPERS?)
- What exactly is a stroker?
- TUNING CAMS ON VAFC
- stripped spark plugs
- Dyno shop?
- B16 HEAD-B18 HEADERS
- can you use ctr pistons and ctr rods and ls crank in a b18a1 block?
- BUDDY CLUB 3 CAMS
- two ?'s
- bc4 or blox b?
- supertech nitride valves or JG ??
- dynamic autosports cams vs blox HSL cams
- Piston pins
- supertech valve springs retainers / toda c2 cams
- D16A6 block work
- B16 build up...pics
- compression check
- comptech icebox
- rod lengths
- f/s skunk pro2s
- Venom Intake Manifold
- QUESTIONS ABOUT MY LS/VTEC
- Need help i got a motor mount ?
- Stroker setup
- Negative effects of stroking?
- compression test on the b18c
- gsr faster then a lsvtec
- built ls head
- b16A block + (0.6mm) Head Gasket = ?(COMPRESSION)??? need help????
- TEam HYPer 16
- F20 pistions in an H22?
- TWM ITB's
- poormans type r power
- re-using rod bearings?
- home made header tips..
- new best 11.18 with new Hytech cams
- 81.4mm stroke with longer rods???
- Is any one using R/M gen 1 spring/retain package with stock valves?
- removing valve guides?? help!!
- valve job?
- custom piston question
- HELP-B16-NO POWER
- Last parts of LS...
- motor build question
- BC4's in 96 gsr motor(tried search)
- ~~~>What kind of cam is this?????
- typre r crank question....
- stoker kit went to shit pics inside
- Toda v.s. Rage header
- ls/vtec rebuild which pistons???
- building motor
- 11:1 or higer cr on poormans type r ????dat good
- oil cooler?
- header question....
- K24A2
- My 1.8l dyno graph
- THE LIMITS OF STOCK INJECTORS
- Rods, Pistons, Compression= HP or TQ
- max power with buddy club 3+
- Rage header on b20
- today's limits on pump gas with NA tuned honda whp/liter
- F20B piston specifications?
- need to rebuild?b18c block swap?heeeeelp!!!
- Question?
- Ebay Intake Manifold
- R/S Ratio.
- lsvtec with a milled b16 head
- b18a rod
- VTEC not activating!!!!!! Need Help!!!
- K20A2: K20Z/Euro R manifold or RCREW P.I.M.P?
- can i use stock gsr valves w/ stage 3 cams
- p8r head question
- PCTs in B18C.... help b4 build !!!
- Fuel pressure at idle is different B&M FPR !!!!!NEED HELP!!!!!!!
- can any one help me with this issue
- gsr intake manifold on b16 head, can it be done?
- k20a2 bone stock
- B18C conrod weight??
- Who has RM M25x cams?
- Fuel questions
- 200whp goal (gsr)
- 2000cc's of theory
- ALL MOTOR B18C TYPE R
- having problem adjusting valves
- my engine quest
- my rods are a little blue
- k20a3? any good?
- LSVTEC COMPRESSION
- quick 2 part header question, please no poop flinging
- Skunk2 Pro2 for B18C-R
- h22 rod bolts
- what pistons to use to raise compression in JDM B16A?
- I NEW TO THE ENGINES AND WOULD LIKE TO KNOW A FEW THINGS
- High Compression Engine = OEM Starter Question?
- OEM LS vtec reliability for a daily driver
- All motor B16 or LS turbo?
- Skunk2 Intake Manifold
- Tb question
- K20 VS any B series
- Spray with a B16a
- RLZ Stage III Camshafts...
- help!rebuild or block swap/limited budget?
- Bc3's or Bc4's
- 82mm piston on B18C1
- which k motor belongs to which car?
- d16a9 pips
- b16a oil pump enough for ls/vtec?
- will an oem headgasket work on a 81.5mm bore?
- Which ring compressor to use for B16/B18 purposes
- Intake manifold IACV to later model swap?
- Is it common for a deck to warp ????
- Edelbrock header b-pipe
- if u had to choose...
- B16a headers
- Things that would fail the emission test.
- ZEX 59300 cam in a D15b, will the timing be off?
- good setup?
- B20Vtec...would this head work...
- Trouble with smog in Southern Calif.!
- pro 3 camshaft vs. compression
- please explain this to me
- RMF header or not?
- Cylinder #3 low???
- how to built my B16A?
- hondata s200? anyone have? or recommend?
- high power
- emissions help
- lsvtec o type r
- Safe rev limit on build H22
- spark plug?
- blox type c
- Building A B18C1, need advice.
- blown or not blown
- What cams should i go with? Yes i searched.
- lsvtec tranny ?
- Header gasket. Re-use or replace?
- new personal best 11.19@123.7 all motor street IDRC AZ
- ITR question
- Ok Break it down.. Skunk 2 IM or Blox IM
- Is thi a good deal?
- no tuning with an lsvtec
- Poorman's R went to the dyno yesterday. How does my graph look?
- ITB question
- NEED HELP ASAP!!
- "Confused" LS heads
- HEADERPURCHASE HELP
- is this similiar?
- camshafts
- b17 gsr IM question
- upgraded d16y7 valve-train?
- best header for itr.....................
- How's this setup?
- bc3+ cam users, what torque setting for the camshaft bolt?
- Is this a decent time for this setup?
- Found my old Dyno.....2.0L LsVtec
- What's a good leak down tester brand and where can I buy one?
- Having some idleing problems
- what are main problems u face with LS vtec
- if you were me, what would you do? TODA Cams or Generic Skunk2, BLOX, BC3+ copy?
- timing belt broke going under 20mph....replaced it and have a problem
- boosting up my h22a
- Heat wrapping headers?
- Exhaust Bore flow question, pics inside
- RAGE HEADER OWNERS GOT QUESTIONS FOR YOU...????
- please help with c/r
- Help, why is my car backfiring???
- ctr pistons or itr pistons?
- My Project Build
- d16z6 or b15bvtec cam witch one
