- 13 Second GSR
- I think I hurt something....................
- where can i get new itr valvetrain?
- k20a allmotor what should i do?
- Orange Valves? PICS Inside
- stock ITR octane??
- AEBS B16 Dyno #'s/ comp. vs stock B16 IM??
- SOHC w/ diy ITB's ** 21.3whp gain *untuned*
- CTR Piston Qs already searched
- if you put type r pistons on your b16 how wide should the exaust pipe be?
- jumpy idle
- b16 stock bottom end dyno results!
- stupid head stud question
- where to get Hayabusa velocity stacks and filters for homemade ITBs?
- TRanny ?s hydro gears and shafts in a cable tranny
- Please review my h22 dyno graph i need suggestions..
- good b16 cam?
- Throttlebody upgrade
- B20B conrod?same height with after market conrod like eagle and crower?
- 12's all motor hp
- Air Filters
- Buddy Club Spec3+ idle
- 3" air intake?
- Buddy Club IVs too much cam?
- Need some help with my parts list for my CR/VTEC
- Do I need new valvesprings and retainers?? plz help
- gsr build up oem parts?your thoughts
- how much?
- what is a b16a stock bore?
- Just got back from the dyno. Results inside.... (56k warning)
- cylinder head repair?????
- line honing my mains ???
- spark plugs...
- motor mounts
- D16Z6 intake manifold VS D16Y8 Intake Manifold
- h22a dx coup
- b20vtec.. but no vtec...
- has anyone heard of oversized valve guides?
- J's racing replacement filters?
- anyone using greddy e-manage on n/a engine???
- 00si(b16) putting PCT pistons..do i need to shave off 1mm on each sides..
- Tuning the B16A2 JDM Sol SiR
- All motor 95 mm stroke Question
- line honing Cam caps?
- Higher RPM's
- B18C5 + Es tuning oval muffler..........
- when do an ALL-MOTOR car needed a new fuel system
- how much down time?
- B16A2 biuld Up
- i have a 95 civic with ENGINE SWAP2
- DYNO TIME, FULLY BUILT LS VTEC, WHAT YOU GUYS THINK******************
- 93' Civic Si, LS motor with Crane Cams 101-0012
- should i get rid of crower 402's?
- question about tunning
- what kind of clutch are YOU running!
- wheres the best place to buy oem honda rings / rod bearings?
- b16 motor need info
- STAYEN ALL MOTOR NEED SOME ADVICE
- H22 HESITATION PROBLEM BETWEEN 1-3 THOUSAND RPM?
- Winter weather causes motor to go LEAN?
- b16a intake mani versus itr mani. Ported.
- Is 13.1 CR ok with 100 octane for daily driving?
- b20 setup
- How high of compression can I go with a Gsr motor?
- How can I set-up VTEC to APEXI
- hesitation?
- LS/VTEC swap in so cal?
- N/A cars still with A/C and power steering?
- i need 2000 si motor mounts for a 96 hatch
- How much power it give Apexi vafc II
- high compression causing starter issues
- putting a 2k si engine on a 96 cx hatch
- B20VTEC vs. LSVTEC...which is the better and faster setup?
- B-series which gas?
- Buddy Club 3+ or Buddy club IV on a STOCK JDM ITR
- any one have any pic's of welded chambers
- ARP rod bolts and head studs question
- Skunk 2 valve springs, Are intake and exhaust springs the same?
- X-MAS GOODIES FOR ME!!!!
- calling experienced engine builders to help me
- new to the ls/vtec setup...
- Bolt On ?'s
- Motor build shops in New York/ New Jersey and...
- Wicked Stage2 vs BC4
- LS vs B16A
- best throttle body to use for ls/vtec motor with 195whp
- gsr engine rebuild
- where did you guys buy all of your motor parts?
- ls blox im... which throttle cable mount/bracket?
- Cams for ctr pistons in a b16
- endyn breather kit necessary for my lsvtec???
- Built Engine Break-In
- most all-motor whp from a h22
- Stock GSR block, ITR head milled .020, stock ITR IM/TB, GSR cams, how will it run?
- B20B-Vtec Valve Clearance (stock bottom end)? Cam options?
- any one with 85mm sleeves ?
- Uberdata shift light ???
- the good or bad
- Quick question about oversize CTR pistons and rings
- my n/a ls/vtec setup
- Rocket Martin M20 cams Worth it??
- Tough choice guys... what set of mods to get next?
- gsr Block blown
- apexi power fc comander....
- fuel rail/ skunk 2 IM question ..
- DC for integra GSR
- Calculating required octane number
- after markey crank pully realy wear out bearings?
- Can I use uberdata to modify my kenji chipped P28?
- Crespo cams...???
- d16a1 (zc) build up what pistons and crank to use.
- Putting Holiday money to Good Use?
- Toda "D" on Ebay??
- my street setup...
- STRIPPED HEADBOLT! What to do... Help!
- engine mods?
- Will I need Fuel management?
- by how much do port and polish effect
- AEM Tru-Power pulleys???
- A6 and Z6 quench to deck distances?
- Transmission help please.
- can i or cant i spray???
- higher compression?
- Copper Spray on OEM HG?
- Import Builders Piston question
- how much juice can I use
- HELP: Blox or SKunk2 IM with TB 67mm on GSR which CAI?
- Need help installing piston/rod, how do I install wrist pin?
- how much juice on a ls/vtec??
- catch can with itbs ??
- Is this set-up reliable and streetable??? - ON CA. PUMP GAS
- Is this setup good for 180whp
- Ls/Vtec overheating?
- quick question dealing with leaking oil!
- I need help ,,, Please give some advise
- header
- problem with tranny!need help!!(h22)
- CTR B16B All Motor Build (In progress)
- Best throttle body size ??
- Accord Injectors same as LS injectors?
- Opinions on OMNIPOWER valve train components
- Oil Sandwich fitting questions
- question, i tried searching
- which cams are better for my setup??
- vtec vs. no vtec
- 200HP+ Civic Type R Build-Up (OPINIONS PLEASE!)
- B18c1 N/A-Nitous pistons (Help me decide)
- crower valvespring assasinated my motor. : (
- Buying used ITR cams. Pics inside, help with condition...
- Which Rods?
- which ecu to use for b16b?
- what are your internals
- my ecu problem....couple questions
- h22 headwork yes no
- What kind of engine management can you use with ITB's?
- 6500 rpm rev limit on JDM H22a w/ P13...
- Identify this Exhaust Cam?? Maybe Skunk2???
- Tuning my all motor setup
- Whats with the new k20?
- OBD1 and ITB's
- check this out
- I installed a z10 breather tank today.
- question: on oversized valves and cams
- Building a LS VTEC / B20 VTEC
- type r valve train
- More pics of my Power Enterprise belt minus teeth
- d16z6 160 whp..all motor
- over rev do to miss
- Newbie B16 motor owner
- WTB: stock Type-R (B18C5) crankshaft
- Post pics, dynos, times, setups of any fast 4 doors?
- h22 balancer shaft belt help please quick question
- DON'T BUY EDELBROCK THROTTLE BODIES!!
- B18C1 with PCT pistons: Compression ratio??
- Eagle rods. Question on bearing clearances...
- crower cam valve lash...
- how do you tell the difference between a itr intake and exhaust valveaprings?
- 12,000 redline?
- Ignition timing question...
- H22 Question
- yellow h22 injectors? saturated?
- How much WHP do you think this will get me?
- how much is the labor installation of block
- New to honda's
- ITB's on a GSR,power diff.??????
- what is a good mild cam?
- breaking in motor problem?!?!?!
- BC spec 3+ .011/.013 lash? or .007/.008 lash?
- No idle after cam install
- How Accurate is a Dyno Jet?
- Experiences Wanted: getting 86mm bore to seal.
- i cant find a downpipe flange for my t3/t04e!
- question about cams and valve clearence
- Drop in Oil Pressure Saga
- k24/k20 tech questions (kind of long)
- Skunk2 Stage 3 or equivalent cams streetable?
- Has Anyone Recently Had PnP Headwork From JG Engine Dynamics? Checking To See If U Were Pleased????
- idling issue after cam/spring install
- Buddy Club 3 Cams Problem ? ! ?
- New to the Site not to the scene. Ls/Vtec set-up want input.
- Need advice for next move
- B16A6 and B18C1 Block Differences
- JDM H22A
- hyabusa DIY ITB runner length, need some advice!!!
- My LSVTEC Dyno
- how many of you REALLY run 3" exhaust?
- Anyone Running Skun2 Spec III with JDM ITR Pistions?
- Best mods on B18C5 to achieve 200whp NA
- B16a2 Woes
- Question about ECU's
- Which Exhuast Mugen, Comptech or Skunk for 210whp
- What would compression be?
- D Series mild build questions (long)
- Buddy Club 3's or 4's with C1 w/ ctr pistons???
- INJECTOR SELECTION HELP
- Arp Rod Bolts Question
- Cams cams cams... stock like small lobes + high rpm/power vtec lobes??
- What else is needed to start tuning?
- Whose got one of my old 1 piece B18VTEC headers?
- check out my b16a2 set up!!!!
- question from a newbie......
- 240whp, streetable and reliable - is it possible? (discuss)
- Golden Eagle or Valley Machine?????
- valve to piston clearance
- NA setup suggestions *H22 prelude*
- ideal compression for BC4's
- can i duplicate gains from a jrsc with a mild all motor set up?
- obx cams are good
- crower stroker kits?!?
- Exhaust Help
- B18c1 stroker
- skunk2 or blox?
- Anyone using SPARK RACING's Ultralite I-Beam All Motor rods?
- knock sensor
- ITR head on a b16a2 bottom end
- mmmm i wonder if it woold go boom ?????
- New Motor
- Can I use?
- is a vtech v16 good?
- Anyone have a motor built by ericks racing?
- B20 vtec
- Making my b16b a 1.8l
- Will this work with 550cc injectors??
- I NEED SOME HELP
- JDM B20 head(84mm) on B18b Block(81mm) Work? Yeh Nay
- alittle help please..on CAMS
- Anybody have pictures of the DCSports Race header?
- pyrometer readings
- would u dyno a fresh motor?
