- my allmotor build w/ dyno chart...want to rebuild to reach 200whp
- do i need valve seals?
- professional product Harmonic Balancer ?
- Anybody playing with an L15 motor yet?
- are itb's my solution? (caution contains actual tech...all motor gurus???)
- rod bolts
- ls vtec build
- Motor building question??
- Setting Vtec?
- smsp knockoff vs. hytech knockoff
- p75-10 casting number on head????what is it???
- best intake manifold
- going to degree in cams, a quick question?
- how to install a 2 step??????????
- B20 VTEC w/ B16 head... what to use / replace?
- Questions about Tuning
- how to swap a 91 prelude head to vtec
- Bang for the BUcks?
- 98 spec JDM ITR motor, what cams can i toss in without changing valvetrain?
- HELP!!! Just put in crower 402's in B16 now its knocking...
- pr3 or p30 pistons?
- RS Machine Headwork
- Nyce1s.com... Video Unlimited Performance Breaks into the 10's
- hissing noise, and rpm's messing up
- Help! Problems with F20B Swap Install
- experience needed h22 cams?
- APEXI neo
- i got b20 vtek
- Weird problem occured today some help?
- help me
- Camshaft?
- Dart block or sleeve block
- How many WHP can i get out of this set up???
- My 98 GSR build, looking for opinions and suggestions!
- cam cap torque spec for b18c1 ASAP
- ***Another are these CTR cams thread.....help!***
- DC HEADERS
- detonation upon decelaration?
- where to get decent mods in south africa
- New to Honda's Cams intake manifolds please skool me
- S200 help
- JUN manifold
- torque specs on cam bolts
- EKJavi LSVTEC build/ lots of pics
- M22x vs Blox HSL vs Blueprint 2 cams
- type r build
- maxbore on sleeves
- Help me choose a H22 N/A race cam!!!
- headers?
- b20 vtec question.
- Tranny for drag application
- best camshaft gear?
- So i took the head off my H22 today.. PICS!!!!NEED ADVISE
- Victor X H22
- scored cylinder wall...overhoning single cylinder an option?
- Fuel Filter relocation
- Fuel Filter
- Oil cooler question Ls/v
- Intake project coming soon...
- how to tell OBD2
- max reving with p72 rods
- How did you decide??
- HELP PLEASE!!!!
- DOHC ZC running lean ....<help needed>
- What compression should i be at to optimize crower stage 3's?
- Double check my rebuild parts list b18c1
- DART BLOCK ON A B20!!!!!!
- R Rods w/ GSR Crank Bearing ?
- Nyce1s.com... Honda Day Drag Racing Videos - Round By Round Footage!!
- Six Sigma Racing Might Mouse K-20
- blox A cams right now, upgrade to blox B or other stage 2 cam?
- looking for some more power
- Forged pistons in lsv???
- cant figure out problem, fuel cut(ish) feeling
- golden eagle ls/vtec????
- Reading Cam specs
- machine shop MD NOVA
- help me identify these cams!
- slicks fs/ft
- What's the best camshatft for stock b18c5
- -------->H22 stroker<--------
- 1997 civic engine light
- b16a2 with light flywheel
- Intake Manifold Selection, B20Z non-vtec w/403’s
- Which VTEC Head Is Better??
- priming a h22 for initial startup after sittin up for a while???
- Thrust bearings shot on a B-series???????
- Question on runner length, homemade ITB'd LS/vtec
- BDL FUEL RAIL need help!!!!
- identify camshafts?
- ITR pistons in LS B18a motor
- B18C1 to B16A2 Need your input
- first car..........lsvtec w/ b16 head
- review on the slim fans
- twm help
- D15B7 cam?
- vacum pumps
- my motor is dead!!!
- Wrong forum? Exhaust
- lsvtec compression ?
- Midnight Performance
- Who sells harnesses?
- Place to find leakdown tester?
- LSV with P73 Pistons
- Compression Question!?!?
- Hot Air Intake
- Is this set up worth buying?
- all motor ek
- bent valve question
- installeda a fully built head now the car runs funny.
- Heagasket question 85x92mm p2v problems.!
- kodys motorsports
- will B16 trans syncros work on GSR trans
- Integra All Motor | B20Vtec Stock Sleeves | 240whp SAE
- how do i tell skunk2 cams from others?
- Looking for big SOHC Dyno Numbers and Setups
- replacing piston rings and the might as well syndrome...
- Storing my engine in my garage???
- gsr crank...ls rods...
- Breaking in new motor... I have questions.
- Girdle for LSVTEC
- Prostreetonline Intake Mani Gasket???
- Air/Fuel, Tuning, And other Question's
- Spoon B16B stroker kit
- CTR IM = ITR IM?
- swaping internals with blocks????
- head questions...align bore?
- Best Cams for daily driving!
- running rich on C5 ...what now?
- LSvtec w/ block girdle? yay or nay?
- What oil and oil filter do you guys recommend for my D16Y8?
- Parts and services to make the most reliable b20/vtec
- ____SOHC dyno numbers and or builds
- What cams are you guys running?
- ARP Head Bolt Question
- ls-vtec in 2000 civic si questions
- a/f meter needed for n/a?
- $39.16 Shipped for Brand New ACL Bearings?!!??!??
- OPINIONS B16a Build HELP!!!!!!!!!!!!!!!!!
- Valve to piston clearance specs?
- B20 VTEC Dyno Chart
- Critique my beginner porting(input greatly appreciated)
- Yes or No: Will retainers bottom out when I install CTR cams in PR3 head?
- fuel injection to carb kits for D-series??
- p 72 rods
- injector question
- LOOKING TO UPGRADE MY MOTOR
- Honda civic Hb - is my fuel pump going?
- views on LSV setup?
- Building B series head, need help selecting parts!!!
- **** EuroR IM H22 Dyno Testing Results*****
- Pistons Questions
- valvetrain kit for H22A
- Looking for The cheapest build, with the most potential
- Rebuilt GsR head......On the way to get my car tuned but it just couldnt happen!!
- just picked up a fully built JG type r head
- Test pipe size for 222whp B20/VTEC
- Help on this question!!!!
- lsd vs. non lsd
- NEED HELP!
- b18c1 All motor build Q/A
- rebuilding my c5 how exact is plastigauge
- idle problem with my poor mans type r
- skunk2 stage 2 or pro 1 pro 2???
- Ls Vtec over heating
- Full bottom end rebuild-Can any average Joe do it?
- 96 mm rods?
- ITBs on a B20..
- Crome Tuner in Wisconsin?
- Ran into a big problem: Which bearings for my if I don't go with Honda?
- Short ram or long ram intake?
- h22 si question
- K series decision
- H22A: Cam gears on stock cams
- Oil in intake tube, smoke from oil breather box
- Ingalls "Stiffy" engine Damper vs. Spoon Engine Damper
- MSD External Coil Versus Stock Distributor CAp and Rotor
- 66mm vs 68mm throttle body?
- b16a build
- help me identify this crank, b16b or b18c5
- how much better is a B20 compared to a B18?
- Fresh re-build not responding like it should, HELP!!!
- H22 rods
- Weird idling after 70mm throttle body install
- Help: Cams installation
- Im a noob and needed a little help...
- Engine Break-in Oil??
- misterious solid Cel7 (TPS) after distributor change
- Cast pistons?
- CAM ISSUE PLEASE HELP
- need help with cam choice
- LS cams?
- WTB AE111 ITBs.
- 2000 B16A2 BURNING OIL!!!
- H22 Cam question
- Need lsvtec help?
- Performer X vs. ITBs
- B20 vtec with M22 cams
- Shed light on the truth about Cast Pistons & Knock offs parts
- has anyone here done this...
- b20a crank help snout length
- Silicone hose, coolant hose and Radiator / Turbo hose kits manufacturer
- Calling ALL vtec specialists!! JDM H23A H2B!
- Overbore ?
- whats the best way for power
- Hastings Ring Gap Issues!!?!???!!?
- ls vtec help ???
- camshaft specs
- quick question about arp head studs..
- Test pipe install. Now ricey rasp!!
- Golden Eagle Vtec kit with a B20 Botton end?
- Ls motor - Swaping to CTR pistons and Aem Cam Questions..
- BBK intake manifold
- Non n00b questions on swapping ITR pistons in a GSR.. CR, balancing.. ect.
- B20 crank in LS "finding many different answers" (searched)
- Cams
- Success With Pro2's
- Slide vs butterfly throttle bodies
- b16b question
- question about building bottem end
- Valve lash specs for EF-1 M24 cams?
- anyone have "sluggish" acceleration problems w/ aftermarket gsr manny???
- Piston to wall clearence on poor mans type r
- ADVISE b18c5 or built b16a3!!
- b16 cam question
- header. help!
- gsr head on b16a
- exploring options for larger DIY t-bodies.
- 81.5 or 82mm overbore?
- cam degreeing and cam gears
- B16 or Ls/vtec?
- b18c5 crx ... looking for an avrage time in 1/4 and maybe 1/8
- NA / Engine builders
- LS/VTEC...what head?
- need some torque help
- is the vtec in the head of the engine
- All Motor guys with 3" exhaust- how to make it quiet!?? Resonators? Mufflers? HELP lol
- Hondata and what it can override
- just a quick timing belt question
- 6 Sigma 1/4 Sports two-point-three Liter Street All Motor HB part II
- sk2 st2
- should i be making more power??.. Please help!
- CTR crankshaft
- Headers
- Bad 1/4 mile times due to bad compression
- who make good EXTREMELY HIGH compresion piston?
- Eagle 95mm crank What Rod / Piston
- HELP Smokey B20 VTEC Build
- A brief tour of how to check clearances in your k-series.
