PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Single cam beast!??
  2. 5.1 h22 f/d . some ?'s
  3. rc injectors
  4. ITB HELP.
  5. All Motor Setup
  6. Another Idle Problem....
  7. Help with timming
  8. Need a lil help to finish my B20/VTEC build
  9. What kinda power with Toda Spec B an C's?
  10. intake upgrade comparision question
  11. high compression, wat gas?
  12. All motor K civic eg using rsx style radiator ?'s
  13. Exhaust
  14. GSR bottom end price??
  15. B18C
  16. Noob Question about F20b
  17. b18b help
  18. Tire squealing sound when going to first and sometimes 2nd??!?!
  19. HELP! Cracked CV boot? Whats the worst that can happen?
  20. finally got my gsr dyno tuned, graph inside
  21. skunk 2 valvetrain
  22. Need some help with my build. Been outta the B series thing for a while.
  23. Balancing (i searched)
  24. all motor setup
  25. Another Honing Thread
  26. help b20 all motor
  27. ls vtec, p30 part number
  28. VTEC or No
  29. 9" element 5" element
  30. Need machine work in SOCAL
  31. DCsports K swap header ????
  32. GSR B18C1 All Motor Build...Need help in Cam choice / Headgasket / etc.
  33. Best h22 cam for street build?
  34. tranny qeustions
  35. 15k to spend on 94 gsr
  36. just to see if anyone would do this trade.
  37. how to know when a motor is good or bad?
  38. Crank & rod question...
  39. Valve springs and retainers w/o removing head
  40. SOHC build 4 ef9
  41. 200-210whp ITR build - without bottom end work?
  42. Need input on my setup *k-series (cams/nitrous)*
  43. want to buy whats the best turbo pistons for ls
  44. aftermarket oil pressure sending unit.....
  45. toda,tri-y,profab, or itr for b16a
  46. ls vtec comp ratio?
  47. Crank Pulley Service (I Searched)
  48. Header - Paired Primary Tech.
  49. TODA SPEC A cams??
  50. My roadracing K24/K20 hybrid build thread
  51. JDM B16A or JDM H22A?
  52. smokey
  53. Please chime in if you know ... for my DD
  54. Del Sol B16A Sir2 revs dropping and sputtering around 3k
  55. NEED help quick k20 into ek crossmember ?
  56. 2.0 B18C
  57. help do my fist my b20v parts
  58. More benefit from Cams, Header, S100
  59. ITR valvesprings difference
  60. need help choosing headers
  61. jdm b16 probs.... helpp
  62. Strangest Problem !!!! Cant solve, NEED AS MUCH INPUT AS POSSIBLE
  63. Motor Ques Need Help
  64. b20 connecting pipe
  65. b20 eg from japan
  66. Engine Build Q?
  67. d series cam question
  68. Bearing Clearances too tight?
  69. stock valve springs and BC3's
  70. Searched! B18c and B20b deck height?
  71. Port & Polish?
  72. milling head
  73. AEM EMS guru's. Sensor question
  74. Need some help. Spark Plugs.
  75. lsv what cams r u using??
  76. TSX Header?
  77. all motor d series question.
  78. m22x... most power?
  79. Vitara Piston
  80. CTR cams
  81. My lil brother's n/a build
  82. B18c5 with b20 crank, what rods?
  83. NA Motor Build, Need Help/Advice!!!!
  84. sparkracing header?
  85. valvetrain????
  86. Guess this motor...
  87. B16A in EG - Best Mods
  88. NEED TO KNOW WHAT KIND OF CAMS I GOT!! I THINK JUN
  89. dome height???
  90. b16acam vs gsrcam in a gsr with b16 head.
  91. Skunk2 needs Civics for test fits! SoCal Civic owners step up!
  92. BREAK IN
  93. Opinions Wanted: LS Vtec Intake Selection
  94. Ring Quiz, How much u know about rings?
  95. my build...suggestions
  96. Gear-Based Fuel Correction
  97. Post your all-motor SOHC D videos
  98. Is this rod journal fixable?
  99. h2b
  100. Itr J's Air Duct w/ Ice Box...
  101. Clearance for S2 Pro 2 Cams on Stock block h22
  102. NEED ADVICE ON CAMS
  103. building my gsr
  104. skunk 2 stage 3 cams used with oversized valves??
  105. Aust. delivered k20z vs. US. delivered k20z internals..........
  106. Stage 1 BaZillion Cams? Old Skool
  107. half shaft problem
  108. crackling exhaust
  109. b20/B20 Vtec HELP
  110. WTB: OEM B-series Vtec rocker arms (complete or non-complete)
  111. **Anyone Dyno/Compare RMF Narrow vs Tri-Y?**
  112. head milled and 2layer HG
  113. flowbench setups. what are you using?
  114. Re-tap rod bolt threads?
  115. 450cc Injectors
  116. B16A+P72 PISTONS 81.5MM+ebay headgasket=blown head gasket???
  117. Catalytic Converter?
  118. Where are the ebay 3" intakes?
  119. which mod is more necessary?
  120. jg cams 296/300vt
  121. Engine Surge When Shift
  122. ALL MOTOR HELP
  123. TSX Topspeed > Final Drive change...?
  124. Got 12.54 @ 400M with this setup...
  125. all motor jdm b18c in theory
  126. Who has Installed Mahle Pistons In an H22
  127. Flat Top Valves For H22A
  128. The Future Is Here - CNC Valve Job
  129. all motor b20vtech
  130. Low comp B20 cams, please help
  131. im screwed!i stripped the threading on my block for my oil sending unit!!!!
  132. B18C1 setup - critique this n00bness
  133. Which Valve train for S2S2 cams
  134. cam question
  135. "HELP"Retainers, Rocker arms and Cam wear!! "HELP" "Lots of Pics"
  136. All Motor K20A(DC5) vs 4G63(EVO8) at the TRACK- VIDEO
  137. HELP! What cams to get for this setup?
  138. It's a good choice for my b16a2 Ek4
  139. Hats off to Bernardo Martinez
  140. Building a good ignition system for all motor
  141. LSVTEC tuned on California 91 octane pump gas!
  142. Performance shops.
  143. I found a bare integra GSR block and I NEED HELP!
  144. B20 VTEC: To sleeve or not to sleeve???
  145. How much does muffler size/volume affect flow?
  146. d16z6 cam
  147. Just another ls vtec
  148. 13 seconds b16 hatch?
  149. b20vtec block question
  150. gsr cams vs b16a2 cams
  151. My offset valve mod
  152. apexi gt spec vs N1
  153. BETTER IDLE OPEN HEADER
  154. Toda vs. Tri-y
  155. D15B Twin carb setup (91 jdm hatchback)
  156. will this pully mess up my crank
  157. what cams should i run with this set up??????
  158. GSR Build...Advice, Opinions, and Suggestions
  159. Block Guard question.
  160. Accel 32# injectors
  161. Another big thank you to Chris Whitfield
  162. I NEED HELP.
  163. gsr block with ls internals?
  164. Upgrade !?
  165. Greddy Evo exhaust + Hytech header??
  166. Need some help here
  167. port an polish or resleeved block
  168. help gsr!!!
  169. Skunk2 Pro 2 on stock B18C Type R head
  170. All Gsr professionals help me out
  171. type r oil pump on ls b18a1 (plastic timing belt cover not lining up)
  172. Just installed Mfactory gearset, having problems and need help asap!
  173. cusco cam gears OLD SKOOL!!!
  174. Are these b16 cams?
  175. B16A swap problemS!
  176. B16A2
  177. CP Pistons
  178. Does this look right?
  179. tranny or clutch problem?
  180. Eulogy for my 30k+ mile, 9,000+ RPM daily-'appreciated' LSVTEC
  181. mini me swap
  182. Finally decided my swap - H2B.. few questions though
  183. Skunk2 Stage 1s Still got it!
  184. KingMotorsports H23 Vtec ALL motor 282 WHP 196 WTQ!!!!!!
  185. Post you N/A builds and results
  186. ZC Pistons... HELP!
  187. broken rocker arm
  188. some help with choosing valves
  189. h22a
  190. Is it acceptable to shave the sides of CR small end to provide appropriate rod to piston clearance?
  191. Doe D15B2 have a EGR?
  192. poor man type r ??
  193. Dyno'd my gsr, 173whp.
  194. Redline of a K24
  195. Throttle Body Icing ?
  196. need my lsvtec crx smog in socal HELP!!!!!!
  197. WOW one OF my old motor build
  198. Wiring RDX injectors?
  199. check engine light..please help
  200. my b18b LS build up with 60k..wat should i do?
  201. header for all motor
  202. spark plug color question
  203. Anyone running high comp Poor mans r setup?
  204. question: f23+h2b (into eg hatch)
  205. B18B Pistons
  206. rmf replica
  207. B16B Plugs
  208. Slop in 1.5
  209. Custom Venturi Effect Intake?
  210. 98+ B18C Specs??
  211. engine break in, using an open header?
  212. Very high compression LS/Vtec
  213. another boring b16 stroker question what would be the best stroke 84.5mm,87mm or 89mm?
  214. Don Flores enterprise? Please share you experiences about this guy/company.
  215. Toda Racing header
  216. Cam gear settings with ctr camshaft
  217. tunned & dyno
  218. Installing Buddy Club Valve Springs
  219. just built ls/vtec and its throwing codes?
  220. D16Z6 build
  221. opinions on hogging out the stock gsr manifold !!!!!!!!!!!!
  222. Never Buy MSD Campaign!
  223. cams for k series
  224. manley valvetrain?
  225. Help Identify : 99-00 B16 Head Retainer / Valvespring OEM or Aftermarket?
  226. ANY MSD PRO Billet users?
  227. gs-r bogging/sputtering between 3-4K rpm
  228. B18a Motor build - 4000 - 6500rpm
  229. Looking for d series vtec cam specs, and int/exh port dimensions.
  230. 1st time build
  231. Need Suggestion on Type R mandifold...
  232. civic master cylinder
  233. b20vtec injectors?
  234. b16a stroker....jun/toda kit
  235. help me finish my setup. Long read ( forwaring)
  236. d16 opinions
  237. biggest cam for stock a2 valvetrain
  238. No fuel past 7500 rpm
  239. CAM-GEAR weights B16A's better response?
  240. BDL 70mm TB on ITR manifold b16a Sir2
  241. B18c1 build dyno Graph
  242. open atmosphere catch can
  243. port and polish
  244. how much power do the pro fabs make
  245. High Compression b18c1 build - Please offer any helpfull advice
  246. gsr pistons and rods in a ls/vtec
  247. b18c5 block+b16 tranny+b16 head any good??
  248. Mods that are safe, without rebuild
  249. ITB's v.s IM?
  250. 94 GSR All Motor Build UP
