PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. hi comp valves
  2. gsr is slower after being rebuilt with ctr pistons
  3. Harness wire colors for OBD2a integra gsr?
  4. Anybody using the Eagle ESP Armored crankshafts?
  5. Liquid to Air Intercooler on All Motor Car?
  6. whats your compression and specs?
  7. Best Powermaking Exhaust
  8. will this header fit?
  9. --Help with Build (cam choice)--
  10. Does anyone have...
  11. Buddy Club VI qs - any experience??
  12. k-series rear wheel drive conversion
  13. aebs vs. sk2 im
  14. Help identify these cams for me (Skunk2 Pro1's)?
  15. Upsizing displacement on H22A4, what to do?
  16. Help.,.,what engine do I have.,???
  17. Del Sol Swap questions..
  18. Skunk2 Pro2 vs Skunk2 Pro3
  19. b20b build cam questions
  20. Rs machine itr style pistons?
  21. 14+ compression question
  22. B18c4 build Opinions? type of camshafts?
  23. B20 windage tray and oil pick up.
  24. B16a2 Build suggestions please...
  25. decisions decisions
  26. Skunk2 Pro2
  27. =-what CR pistons can you run with 91 oct?=-
  28. Hydrolock help
  29. what size is the drain back on moroso oil pans?
  30. Installing ITR valvetrain in P72 head
  31. RMF DRAG HEADER
  32. Compression Ratio with Forged Internals
  33. Head Gasket for H23A DOHC VTEC Blue Top?
  34. Can't take off harmonic balancer bolt.
  35. PLEASE HELP GSR ????
  36. need some help...
  37. My CRX all-motor progress: full interior 91 HF w/ 1.8
  38. head milling question
  39. wanting to build a b16 head need advice
  40. need opinions on B16a build for autocross an light drag
  41. b18c5 all motor issue HELP PLEASE
  42. Are my valve seals bad?
  43. Help! V8Killers Build ??
  44. D16y7 head on D15b7
  45. RS Machines 84mm itr B20 pistons: Weight?
  46. anyone know how to get ahold of Rocket? (master of the universe)
  47. D16Y8 block with a D16Z6 Head *Couple Questions*
  48. GSR throttle body question
  49. HELP b16a2 NO vin# sais its JDM wtf
  50. Timing belt issue and question.
  51. Difference between B16A and B16B
  52. B16B swap into EG6
  53. B16 confusion?
  54. block guards
  55. CTR Cams
  56. Need some help deciding my next purchase
  57. Building a P8R head
  58. AVID ef b series mounts?? HYDRO or CABLE help
  59. HP gains from E85 stock gsr motor?
  60. K20A2 Head work vs Cams?
  61. help with gsr/skunk2 T2 cams, no degree wheel
  62. advice on my b20 build
  63. em1-b16a-cam/engine questions and rumors cleared up
  64. Price to have a shop rebuild my motor
  65. How to tell if my cams are Blox type C?
  66. header question
  67. 3" exhaust on gsr with bolt ons?
  68. D16a9 with webcam camshaft
  69. Help!!
  70. How do i pick the right springs?
  71. Is a 2.25" collector really a 2" collector?
  72. LSVTEC BUILD
  73. compact itb's for b series (air filter)
  74. Time to probe the all motor minds...tuning, ITB's, JUN3's...more
  75. cam gears
  76. itb's with out a brake booster
  77. 270hp/185tq Bseries
  78. d16y8 in 95 civic dx coupe ???
  79. D16Y8 Vtec Swap *What do I need?*
  80. head gasket choice...
  81. KiDDRacing Narrow Header on a b20vtec
  82. Help choosing pistons and rods (compression change)
  83. suggestions on 250+ b-series
  84. Are Buddy Club IV's too big for my setup?
  85. GSR Intake System Upgrade
  86. Cam replacement
  87. 142whp d16z6 all motor e85 will putting on a exospeed cam gear mess up my timing?
  88. Any AllMotor DA left?
  89. H22a oil question
  90. vented valve cover
  91. Which valve spring compressor did you use?
  92. Which valve spring compressor did you use?
  93. JDM Type-R parts to replace before it goes in?..
  94. F22B5 compatibility with F22A7
  95. dh racing single layer headgasket any good?
  96. FULLY BUILT LS/v...wat to expect?
  97. Help with valve choice plz!!!!!
  98. Victor X
  99. 1990 honda Civic Wiring Issues
  100. Passing aircare with high comp pistons and aftermarket cams
  101. B16 EACV
  102. What should be my next mod?
  103. h22a help!!
  104. Looking for a b16, sites ?
  105. To all b20v specialists!!!!Rod bolt question?
  106. D16z6 help
  107. fully built JDM D15B
  108. my new b20
  109. Rebuilt B18C1.Smoking and bubbling.
  110. b20v oil pressure issue help!?
  111. d16 crank pulley bolt
  112. b20v build
  113. A/F ratio drops to 10:1 when I hit a pothole?!
  114. d16 head with d15 block q's
  115. LsV-tec all motor (11 sec in 1/4)
  116. flywheel Q
  117. SA needs advice on a 180e High Comp build...
  118. moving up to a bigger motor!! help please
  119. bc ls cams good buy
  120. Engine jerks at low RPM
  121. At what point does a throttle body become restrictive?
  122. gsr cam centerline
  123. GSR helpppp pleasee
  124. What gear must a mine be dyno? mine was at 4th, is it ok?
  125. will a P75 out of a 94 teggy work with a 93 ls motor?
  126. The Better Cam for my setup.
  127. Built Poormans Type R compression questions.
  128. d16z6 stock rods
  129. Motor Mount Question
  130. LSD Engine
  131. JDM B18C Valve Adjustment
  132. finishing h22 swap in civic
  133. help with stroker and stuff
  134. OILing issues?
  135. Source of crankshaft wrench
  136. b18c gsr t run like b18c type r
  137. CANT GET RID OF IDLE PROBLEM DRIVING ME INSANE
  138. ignition problems.
  139. Low compression, bad rings?
  140. Ls/Vtec Power Problem!!!
  141. Port Flow inner valve spring question
  142. Distributer timing issues
  143. Itr all motor
  144. B20 vtec
  145. Engine Assembly, Rear Main Seal
  146. Engine rebuild question
  147. 1993 civic problem need help
  148. dhps heads, who has one?
  149. B20 head on B18 block?
  150. EK build? Help pls?
  151. TODA VTC KILLERS & a K20a2
  152. Need a Simple Answer
  153. bisimoto cam gear torque specs
  154. looking for tips on ITR build
  155. what cams are the bigest i can use on sk2 valve train
  156. Skunk2 proseries Intake Manifold vs Stock Type R manifold???
  157. d15b8 block with what head
  158. h2b all motor build suggestions
  159. DYNO B16a2 with Hytech replica, please help
  160. b17 build
  161. D-series advice wanted!
  162. Wiseco Piston to wall clearance for 81.50mm piston
  163. Question about d15b7 IM
  164. BC3 cams on stock 01 ITR valvetrain?
  165. IPG All Motor Car Project
  166. titanium retainers
  167. piston to deck problem
  168. Benson blocks , where r they located?
  169. should i tune my new exhuast set up?
  170. where to next??
  171. Help me understand Degreeing Cams plz
  172. can you identify this flywheel?
  173. Integra Questions
  174. questions on mini me swap
  175. Tuning Advice
  176. Need some tech help on a stock B20Z, cannot get cyl 3 to fire
  177. Milling f22b1 head
  178. How to tell the difference between 90-91 and 92-93 b18a1?
  179. Build Sequence on GSR IHE + cams
  180. GSR CAMS FOR A B16a2
  181. which recomendais me?
  182. LS/VTEC build bearing q
  183. How could I get more compression out of my ITR?
  184. GSR or upgrade to h22?
  185. New PB - 12.65 @ 106.43
  186. When is the step up in injectors/fuel pump needed?
  187. Need Help H22 EG Wont Start
  188. Dyno results some good #'S for gsr
  189. B18C1 2.3L Extreme BUILT - unexpected results?? :(
  190. mini me swap
  191. leak down test results.. need a little help..
  192. car running just not good
  193. need help street tuning
  194. LS-VTEC BUILD. HELP!!! opinions......
  195. B16a2 Tune on a DYNO with vafc-ii and fpr
  196. Aftermarket equipment hp
  197. Decided on BC5 cams....
  198. EF Type-R
  199. head rebuild question!!!
  200. b16
  201. going b20/vtec, what ya think about this??
  202. Breather Setup on a B18a1 Block (LS/VTEC)
  203. Any personal experiences with F1, xtd, act or exedy light flywheels???
  204. I HATE TO DO THIS!!!!!!CUSTOMER SERVICE ISSUES
  205. what are the best valves i can buy for high compression
  206. anyone running bisimoto B-series cams?
  207. A little Poll: Buying a new Project Motor
  208. octane fuel recommended
  209. fuel pump or fuel pressure regulator?
  210. GE ls vtec kit
  211. JUN TYPE 0 camshafts
  212. oem built b16 vtec is not working at all
  213. Panhandle of Texas Tuning shop
  214. Carillo and Wiesco
  215. Winter Build: B16a help!
  216. b18c piston ring gap do i need over size or can u use std
  217. Final Head Swap Questions..
  218. So about these pistons?
  219. Dont Buy FRom StreetImports.com
  220. Energy Suspension Motor Mount Inserts
  221. B18c5 All motor....Want more power... What else?
  222. Which Headgasket
  223. my b20 vtec dynoed
  224. HELP POOR MANS TYPE R BUILD PROBLEM
  225. B20b ....Want more power ...help need opinions
  226. Altitude correction factors when doing a compression test.
  227. b16a2 pistons questions
  228. using brake cleaner and compressed air to check valves
  229. b16a dohc vtec- vtec problems
  230. hastings
  231. d16z6 on e85 142whp 50-75 shot of nitrous ebay muffler internals broke from backfire
  232. BLOX FUEL PRESSURE REGULATOR
  233. BUILD CIVIC SI 1999 ARGENTINA 150/155whp goal HELP!!!! FROM ARGENTINA!!!
  234. Timing belt and valve question
  235. Cam gear adjustment
  236. D16Z6 build, for everyday riding ;)
  237. Removal of chip in a p72 obd1?
  238. allmotor build for b-series
  239. CRVTEC intake manifold Help which one ....
  240. jdm obd1 b16 = usdm b16a3/b16a2?
  241. 1991 Accord Erratic Idle
  242. ring end gap and valve lash numbers...
  243. B18c5 Stroker kit?
  244. B20 falls flat on its face at 8K..??
  245. Questions about my H22A1
  246. Why is their oil in my radiator overflow tank, d16z6 e85 142whp without 50-75 shot
  247. venting catchcan/crankcase into exhaust question
  248. my 81.5mm build
  249. Calling all motor guru's
  250. skunk 2 stage 1 tuner camshafts
