PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 [145] 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. tuning program
  2. Tuning Questions
  3. Jg Engine Dynamics
  4. long block ?
  5. b18c block number?
  6. Is Jeremy Lookofsky using....
  7. B16A Dyno
  8. Camshaft Comparison
  9. Motor shut off, WTF COULD IT BE AGAIN?!?!
  10. buddy club spec IV valve lash?????
  11. b16 crank in gsr block???
  12. Whats the highest recommended comp for a daily driven on 91 octane?
  13. Outlaw Engineering thermobloc spacers gasket kit
  14. Florida Tuning Trip / Vacation: Nov. 4 - ???
  15. Shimmed Oil Pump, Cam Seals Leaking. Could there be to much oil pressure?
  16. NEED OPINION!!!!!!!!!!!
  17. Block Rebuild ?'s
  18. Dynoed the D16
  19. HELP! MAJOR OIL LEAK AFTER REBUILD!
  20. need help !!!!!
  21. All Motor Tuners (S300 users) Need your input here!!!
  22. I NEED HELP!!!!!
  23. which Rod bearinds for LS Vtec?
  24. Magnaflow cat?
  25. b20z block, gsr head, s2s2 cams. do i have to cut the valve reliefs?
  26. Built B18C5 Ohio-style: 201whp / 128ft-lbs MUSTANG :)
  27. p28 burnt? smells runs fine tho!?
  28. DYNO of my old N/A B16 setup.......
  29. h-motor/b-tranny????
  30. are endyn's bumpstix available for b20b?
  31. B18C Rebuild
  32. h22 NA build
  33. b20b ported head vs. p8r ported head, and difference?
  34. 12,143 Miles later....
  35. Chip p75 ecu???
  36. skunk2 stage 2 cam gear settings
  37. Why does my car smoke so bad in VTEC?
  38. Base fuel pressure and timing questions.
  39. Putting head back a few questions
  40. motor bracket
  41. All Motor Dseries guys, Who has 12's.
  42. B20z/vtec Header for under 600!!!!!!!
  43. Best mods for N/A to meet my goals? JDM B16 SiR-II w/ LSD.. Help!
  44. I know the K series is in but nothing like the b series
  45. what trany?
  46. skunk2 throttle body
  47. stock dynoes
  48. 2.0L gsr skunk/darton etc
  49. Cam application?
  50. washington local headwork?
  51. Flow charts
  52. PCT's, BC3+ and headwork.....Hmm?
  53. Anyone interested in a full drag all motor, H22 powered EG
  54. obd2 gsr TB will fit on the d16y8 skunk2 IM?
  55. Smoking on deceleration - new motor
  56. Maximizing power with cams?
  57. OT: Huge All Motor For Sale Post: Leaving Honda Scene
  58. Concerning SPEC Clutches
  59. 3" VS. 2.75" AEM Cold Air Intake Performance Difference
  60. My b16a dyno (vids/graph)
  61. B20Vtec Dyno
  62. Vigor oil pan removal
  63. URGENT!!! Will b18 b20 main bearings work with d16? might sound like a noob question
  64. An oil that my B series loves...
  65. Lack of info on the type s piston is really pissing me off...
  66. Need Fuel Pump
  67. lsvtec, out of the game for four years
  68. crower cranks...
  69. b16 or gsr...What head yeilds more compression in a b16?
  70. Bad trans leak!! Help!!
  71. QS: LSD Y1 HELP!!!
  72. ENGINE SWAP??????
  73. ALL-MOTOR action from Puerto Rico (VID)
  74. usdm or jdm
  75. Valvetrain question!
  76. b15 vtech or b16a
  77. New setup
  78. Jdm ITR One Piece on LS?
  79. b16 head, 2 bent valves, fixable or not?
  80. <<~**yet AnOtHER HOOK-UPS street car 223.67 HP/ 156.78 TQ pumpgas!!**~>>
  81. B20 Vtec build up
  82. ITR W/ ITB's
  83. Which cam to use??
  84. rod/stroke ratio questions about b16
  85. turbo or n/a
  86. custom head gasket...?
  87. N/A headgaskets what u got ?
  88. b16a with skunk 2 stage 1 cams .... slower
  89. H22A into eg swap pictures
  90. Newb and b16 build
  91. valve float???
  92. tensioner spring
  93. 85mm GE headgsket on a 84.5mm bore???
  94. Stroker Kit...Need Crank? Builder GURU'S needed...
  95. FINAL ANSWER: to reuse or not to reuse stock head bolts!
  96. ITB tunners: need your help
  97. help on cams
  98. COMPRESSION TEST ON JDM B18C ITR
  99. my new build me tbone rlz rmf rocket 2?? whp
  100. who has a skunk2 throttle body?
  101. Rocket M21 cams in B16?
  102. v-tec engagement on built gsr possible detonation???
  103. Port and Polish
  104. What you guys think?
  105. M22 Cams???
  106. GSXR-750 injectors in B series
  107. ticking noise in head??
  108. GSR - Intake Manifold Switch
  109. ENDYN BREATHER KIT / Z10 BREATHER PLUG "Where can I get one"
  110. FAQ: How to Change Headgasket , Timing belt, water pump On b16 / ITR / GSR
  111. Best Way to Clean Rust of Cams?
  112. code 1 cel, no vtec? *yes, searched*
  113. dual headers?
  114. Golden Eagle Cam gear
  115. which clutch for my gsr?
  116. Vtec Through VAFC
  117. can i just 8 inner portflow springs with bigger cams?
  118. check out the header i got...
  119. Neep help choosing motor.
  120. help w/ contacting AN-R......
  121. Help to identify, are these TypeR Cams and valvetrain?
  122. Modify B16B Issue Part 2
  123. Noob question about intake arm..
  124. 88-91 b16 vtec head question... what do u need to change to go with bigger cams?
  125. gsr intake mainfold.....performance gains?
  126. VTEC and synthetic oil...do they "mix"?
  127. Help in choosing 70mm throttlebody....
  128. 250whp 160tq 1750lb chassie. 1/4 times
  129. do i really need to hone after getting new rings?
  130. building d16y8 what next?
  131. p30 or p72 Ecu to run Ls vtec motor?
  132. How Much Does it cost to Install Pistons??
  133. 67 and 66 lsd ring gear difference?
  134. Engine rebuild for SCCA Club Racing
  135. Compression Ratio
  136. JUST BUILT A D16Z6 FULL INTERNALS AND HEAD WORK ALSO BOLT ON HOW SHOULD...
  137. Building up d-series NA using 89 integra rods/pistons
  138. what throttle body will work as a replacement
  139. I have 3 headers - which one should I use?
  140. timeslips built sohc vtec or on-vtec
  141. Best gain goin all motor?
  142. Removing stock pistons from stock rods
  143. skunk 2 valve train
  144. Nitrous + Big Cam ??
  145. Evo Fuel Pump in a Civic
  146. 2001 GSR USDM Spec
  147. oil presure sensor?
  148. pr4 head
  149. OMNI power valve springs..
  150. Alittle help with my All motor setup right now.
  151. B20/vtec Cams?????
  152. need some info
  153. which cam to choose?
  154. JDM ITR dyno charts
  155. B16 tranny or GSR????
  156. Will Toda C cams work with standard compression? 5 questions in need of answering
  157. m22 cams and valvesprings?
  158. buddy club short shifter
  159. WOOT I Finally HIT 200whp w/stock block 96 JDM ITR
  160. 1.8 liter buddyclub 3+ dyno
  161. Clearance for CTR Pistons???????
  162. sohc...
  163. b16b performance...
  164. What do u think of my setup
  165. OIL AND GAS IN MY CATCH CAN WHAT IS WRONG??? HELP PLEASE
  166. two questions?? timing advance and proper afr's
  167. I need a good engine rebuild shop in Orange County, any recommendations for an
  168. Thoughts on the new Greddy Ultimate Emanage for an All Motor setup
  169. Dyno ITR with Jun III cams
  170. Building A K20, need info!
  171. ITR cams intake or exhuast or will I need both to run on a gsr head?
  172. Best Cam and Heaader Choice ???
  173. where to get Crome and tuning equp.?
  174. Rocket Motorsports M22 advice.....HELP PLEASE
  175. B16b vs. LS-V??
  176. what cams with high compression....
  177. K-series: intake manifold tests - 2672cc vs simple build K24 (2381cc)
  178. are high compression pistons reliable ?
  179. Which cometic head gasket to use?
  180. H22A motor from HMOTORSONLINE.COM
  181. crate engines
  182. how many quarts
  183. bkr7e11 - ok for allmotor?
  184. Compression and timing
  185. AKMEE D16Z6 Type-S cam result - 6 whp peak, 19.5 whp @ 7700!
  186. Need Help choosing cams m22x, m24x, pro 1, pro 2 so many choices
  187. what to do to the block to put out more ?
  188. are these arias pistons?
  189. 1.8L Build Up
  190. automatic transmission shifting
  191. M22x's in my LS/Vtec EF.....Predictions?
  192. can a B16 with PCT pistons and S2S1 with hondata hit 200whp???
  193. ported itr intake manifold but want more whp.
  194. Help my indentify this JG cams
  195. Cam trade? Sk2 Stg2 for your BC4!!!????!?!?!?
  196. Can I use both type of valves?
  197. need some help or good advice!!!
  198. valves question
  199. Tuners: I need your 440cc idle maps!
  200. Bottle, how big of a shot should I run?
  201. Looking for a good company to build my single cam vtec.
  202. B16 or B18C1?? Wich should I get
  203. Dyno of a 254whp/176lb-ft
  204. few questions about engine rebuilding.
  205. Hondata
  206. K vs B --- What do you think?
  207. Oil pump ?'s
  208. Type R Bottom End.....B16 Head Shaved .030 Need Help Fast
  209. Check out my friends Porting work
  210. B20Vtec ohio style: 93 octane - 194hp / 134 ft-lbs on a mustang...
  211. h22 power curve question
  212. What do you set your rev limit rpm for 2 step MSD control in burnout box
  213. DAVE HICKMAN DHRACING CALLING YOU OUT.
  214. has any1 ever had something stuck in their cat converter?
  215. apexi vtec controller(black one)
  216. performance upgrade advice please.
  217. valve seat preassures? rocket gen's 1+2/ other aftermarket/ stock ?
  218. type r need more power
  219. Where to buy 84mm AEBS Sleeved B18C5 Block for good price?
  220. Autometer C2 Install
  221. Big Bore TB
  222. type-s vtec vs si v-tec
  223. Does the vacuum hose on the black canister matter? or top of throttle body?
  224. weird ass noise.. need help
  225. STP Octane Booster....
  226. I need the torqe spec for ARP head studs b16 block
  227. question about cams, cam gears, valve springs, retainers SEARCHED
  228. m22x vs skunk2 pro1 vs Buddyclub4
  229. Si tranny conversion...
  230. Idle issuse - stumble at idle - help
  231. Carb'd H22/H23 - anyone done it?
  232. Harder valve springs = more drag = less power, Correct????
  233. k20a3 adjustable cams gears?
  234. B20 vtec 12.5 comp what cams should i use any advice welcome =fast+reliable
  235. Aftermarket Cams -- Stock Cam Gears?
  236. Our H23 w/JDM cams - Dynojet numbers
  237. With higher comp motors, can you use colder plugs to prevent detonation
  238. aftermath of CMI
  239. Jun ITB H22 hp.......Sound right
  240. skunk pro1s vs BC4'?
  241. stock gsr compression, should I keep my buddy club spec 3+ cams
  242. OT: For Sale, Serious All-Motor Parts...You guys will appreciate some of this stuff.
  243. H22 Type S A's and B's Pistons and Rings
  244. who needs SKUNK2 PRO 1 cams??
  245. scat rods ?
  246. What pistons are these?
  247. b18-A all moter
  248. b18-a ls
  249. 00 ek with gsr track times
  250. Upgrading to Skunk2 S2, should I mill head or upgrade piston on gsr
