PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. B20 Rod Question
  2. Exhaust Question Reguarding piping
  3. p30 bearings... help...!!
  4. whats safe
  5. H22 Hatches in the Atlanta/South East Area- Dyno Testing need test cars!
  6. Dyno Results Mild B18c5.
  7. H22 oil prime
  8. tps question
  9. Expanded Break-In and Building Advice
  10. Low dyno results What is wrong? 150/106
  11. Boring question
  12. poor mans type r ?
  13. Walbro Pump glitch?
  14. throttle body
  15. 85x89 dyno tuned
  16. what is wrong with the engine!?
  17. Help me make up my mind...
  18. Need advise (ima noob) For a built LS
  19. D15B frank Q's
  20. DSM injectors
  21. Looking for advice on reliable n/a build
  22. Vacuum help.
  23. need help with piston question
  24. injector options
  25. ecu not working
  26. Need Help to decide on my piston setup. Stock or 12:1cr???
  27. 14.7 consistant on ls motor
  28. 85x89 build parts combo/general advice/input?
  29. Time for a rebuild!! Engine gurus look!!
  30. Cam Timing
  31. ls with some b20 internals?
  32. type r manifold, obd0
  33. stock rods
  34. H22a Swap in ek Hatch
  35. b18c1 with b16a head build questions?? nippon parts???????
  36. ls v-tec air/fuel ratios?
  37. Car is running to RICH (ECU question)
  38. LS VTEC Lack of Power, Motor issues
  39. Good set of rods for the ultimate LSVTEC build?
  40. Could you me calculate my setup?
  41. which head is better B16A2 vs. B18C1 on a B18C1 block w/ plans to build NA?
  42. shop made itbs...intake too...is it any good?
  43. KMS or Rev Valvetrain???
  44. valve to piston d16a6/y8head, stage 2 cams, possibly have to mill head
  45. Euro R manifold question
  46. 13.95@96mph With a stock blocked 1.5
  47. Intake Manifold
  48. recommendations b16
  49. ls/vtec handling stress?9,500rpm?told it could safely...
  50. What to do...What to do?....
  51. recommended spark plugs???
  52. ITR build need advice!
  53. velocity stacks??? help on running them...
  54. 09 fast and the furious to show off some all motor
  55. Show me some S2k dyno vs 2l B dyno
  56. b17 with CTR pistons Compression ratio?
  57. Whats wrong w/ my h22 I/M? Noise!!! Video
  58. 13.1 piston Compression
  59. what 2 expect of an ls/vtec built motor?I LOVE ALL MOTOR!!!
  60. skunk2 high compression valves on a stock k20
  61. Performance B18c1 Rocker Arms?
  62. Hondata gasket worth it?
  63. 12.5+ comp b16a? all motor !
  64. cams ?
  65. 90 da wire tuck/bay shave.. have a few questions and lots of answers
  66. Two New Forums at HT
  67. bet all 16 valves? need quick help
  68. 84mm pistons
  69. cooling disadvantages
  70. best b16 all motor 7500rpm - 9500rpm intake ?
  71. k20 valve spring retainer
  72. jdm b16a ?
  73. Intake Manifold / Runner / CAI Sizing Theory, need some insight
  74. idle goes up and down between 1500rpm and 1100rpm on cold start.
  75. i would like to no
  76. passwordjdmintake vs full coldair
  77. Gsr bottom end Price check
  78. b16 na
  79. Small tube or big tube header on LS/VTEC. Which one?
  80. clearances???
  81. 350z exhaust question
  82. running rich?
  83. 370 injectors to big for this setup?
  84. j's racing 60rs exhaust?
  85. Already Searched, TPS Plug connector pinout
  86. Too much cam..... or more power??????
  87. Hp with Skunk2 Stage2
  88. Rare Honda Acura GSR B17 Cranshaft - B16 Stoker!
  89. Smoke in deep vaccum
  90. Engine builders please enlighten me. Rod Question, brands, etc.
  91. Will an LS B18 head fit onto a B16a Block?
  92. BC K26 Crank...what do you guys think of it? Should I go with it? Yes or no?
  93. Anyone have pics of the Performer X?
  94. Does this look right?? (camshaft TDC)
  95. best setup for gsr all motor? help please
  96. What injectors to recommand?
  97. Compression >> HP
  98. motor idles like it has cams after tune
  99. 228whp and looking for more
  100. i need help
  101. need help
  102. Bearing Clearances Plastiguage Question
  103. ***********IDLING PROBLEM************
  104. Where Can I find Built GSR's?
  105. B20 Vtec Fuel Pressure reg
  106. What GSR Bolt-ons to get ?
  107. Any high CR 87 octane experience? D16 specific, but general knowledge appreciated.
  108. What pistons in ls vtec with boost
  109. sohc 11.1:1 from oem parts
  110. need intake manifold and throttle body upgrade!!!
  111. Honda Bearings
  112. rebuilding my motor to stock specs have a fw questions (k20)
  113. ls vtec rod bolts
  114. I need help setting the timing on my H23 Prelude motor!!!! HELP!!!
  115. B series Thrust Washer question (1st engine build)
  116. JG crankshaft vs B18C5 crankshaft?
  117. Dyno'd a toda cammed 91 octane K20 today...
  118. s2 pro2 issue. clearance maybe?
  119. Which p/s pump bracket to get for ls/vtec?
  120. k20. not sure what i want to do.
  121. 2001 gsr whp?
  122. is this a reliable or even possible setup?
  123. dissapointment with tunning
  124. .03" milled head...when do I adjust valves?
  125. All Motor K24 Honda Day B2 Champ Videos
  126. What cams should i use
  127. B16a w/ bolt on's - gearset or tune
  128. polar bear tuning
  129. Ported head or not?? Pics inside
  130. light weight windows..... worth it????
  131. B20vtec build need advice and help
  132. Driveability problems after OBD1 conversion <---------HELP!
  133. B2o vtec head
  134. WHAT TO EXPECT FROM THE "B" ????
  135. JDM All Motor B18C
  136. Intake manifold and TB question
  137. itr vs gsr cams
  138. Most Bulletproof Drivetrain?
  139. Qs : Allmotor Guru, Don F, Tbone, Bisimoto, etc... please... Intake Piping Diameter for 2.2L Skunk2
  140. Is a ITB set up practical.....
  141. opinions on h22 cams rocket motorsports vs skunk2 pro series
  142. Tuning for best MPG
  143. H22 Header???
  144. Will a stock clutch hold up to a CrVTEC
  145. 62405A-2 in a B20
  146. Need Help on my First build
  147. BLOX CAM Question, Stage 1 VS Type A
  148. dropped my block off for machining ??????????
  149. Cam/cam gear question!!!
  150. JDM B16 Cam VS USDM B16 Cam
  151. 2.5 inch (internal diameter) exhaust
  152. 69mm TB vs ITB - Which would you go for?
  153. 74 mm T/B to big?
  154. JGE SS valves
  155. JDM b18c vs USDM b18c1.. why the 10hp power difference?
  156. B Series road race cams???
  157. poor r wont start
  158. ring gapping
  159. Header Comparison dyno tests...
  160. Valve tick need advice
  161. h22 civic iacv
  162. LS-VTEC problem HELP!!
  163. Need some help on golden eagle head studs torque specs
  164. B16A2, CEL 61...need a little input
  165. Before / After ITBs dyno graphs
  166. what spec torque wrench do i need?
  167. Got a question
  168. look at the intake
  169. broken down! Clutch/Tranny problem
  170. questions fellaz...hey which 1 is better b20 vtech ot b16?
  171. Question about All Motor FP
  172. ctr pistons in my b16
  173. What degree timing you running, 218whp?
  174. WHERE TO BUY FACTORY PARTS.....CHEAP?
  175. Rocket Motorsport H22 cams. Non-Vtec Profil??
  176. Question about Over advance timing
  177. ALL MOTOR, breakin in the b-series the right way.
  178. B18C1 With Bolt-Ons Dyno + Questions
  179. OIL LEAKING IN SPARK PLUG!!!! HELP!!!!!!!
  180. Oversize Valves +0.5mm or 1.0mm?
  181. JUn type 3 cams or Skunk2 pro2 or 3?
  182. h2b low numbers
  183. Ls vtec into 91 crx
  184. about how many ponies (hp) will this little setup have? just curious.
  185. noob question with gsr tranny hydro/cable
  186. some ?'s regarding non-vtec ls building.
  187. can u use b16b pistons in a d16a2
  188. so machine shop says my ls rods dont fit my ls crank...
  189. Possible Blown Head Gasket? Need Help! <Searched>
  190. ls vtec/poor man r?
  191. Wanna change and minimize exhaust
  192. debating...need help
  193. 2595cc F20c motor
  194. Just a Simple Question
  195. 84.5mm in b20 block will they fit
  196. does ls vtec last
  197. tuff decision...
  198. headgasket question
  199. 1.8 LS-V dyno sheet
  200. JDM GSR Crower Stage2 Cams
  201. jr_deleon's F20b build (2141cc 12.2:1 compression 1.69 r/s ratio)
  202. itb's
  203. are evo 540 injectors to big for a b20vtech??
  204. quick ? do you need to take out motor for new pistons/rods install
  205. APEXI WS2 VS SKUNK2 VS TENABE MEDALLION VS HKS HI POWER TI VS BUDDY CLUB PRO SPEC
  206. k series build price
  207. New headgasket, still smokes.
  208. code 9- cylinder position sensor. i know its been covered but i cant find an answer!
  209. Are cams worth it?
  210. LS with GSR pistons... anyone done it?
  211. best rpm to launch at
  212. VERY bad Idle after camshaft degreed right.
  213. Installed Toda valvetrain/cams --- need advice please
  214. The new H22 build up kicks off
  215. machine shop problem, this cant be ok?
  216. APEXI noir exhaust
  217. How to fix code 43
  218. b16a rod bolts vs gsr rod bolts
  219. how much does this b16 sirII head
  220. 96 or 98 Spec transmission for B18c ?
  221. omni power vs. JG vs. skunk2 vs. buddy club titanium retainers
  222. 95mm crank from b20a1 in b20b
  223. Nippon 82mm p30 piston specs?
  224. LS VTEC with bone stock B16A head. Safe redline?
  225. B20VTEC For My DB2
  226. 196whp... i want more
  227. My All Motor B20/VTEC build
  228. h22 type s pistons in a darton sleeved motor?
  229. Timing belt question
  230. Cylinder bore surface finish
  231. Motor noise no clue what it is.
  232. B20 vtec camshaft timing
  233. Need help..2 Step??
  234. best B16 cams for my $
  235. What size exhaust for All motor + Nitrous?
  236. Question about what tranny on my b16b
  237. Building a B18c1 GSR: need some opinions. BC3+, Hytech Replica, Spoon HG, Skunk2
  238. Ctr and Itr cams questions.
  239. Engine breaking up past 7K RPM please help ASAP
  240. best power from intakes?
  241. help!!!! crower 404 cams
  242. ls vtec swap
  243. timing help ,code 4
  244. Slowly building a 2000 honda prelude any and all help will be happily taken!
  245. tanabe or rsr exhaust?
  246. B16 high comp pistons. which ones?
  247. h22 knock sensor
  248. melted a piston on 11.7-1 comp all motor b20vtec need some opinions
  249. melted a piston on 11.7-1 comp all motor b20vtec need some opinions
  250. Ferrea Roller Setup Streetable??
