- Smoking need help gsr 1994 grey white smoke
- ls/vtec start up troubles..help
- junII cams with skunk 2 valve train..good idea? compatable?
- anyone have jun II's? how do u like them? what valvetrain r u using?
- b20 into all motor 2.2 liter
- Avrg. Amount of hours it takes to tune hondata
- head damage, what needs to be fixed? pic, 56k ok
- ef-1
- what head gasket to buy for
- pics of my block
- Best D-series motor
- zc swap
- 240+whp possible with my current setup
- gsr with ctr pistons? will it work?
- b16 with ctr piston
- Which is Better Radius Traction Arm System???
- What do LS and GSR motors cost ??
- whats the biggest bore u can get out of a 4 cylinder honda/acura motor?
- Has anyone built an all-motor non-vtec B18B that does good in the quarter?
- Compression Check
- Best cams/vavletrain setup for the buck?
- STR tb made by same company as Erick's Racing? Do either make power for the ITR? Worth it?
- how much power for .25 pistons
- Please look!! Are these skunk stg. 1's....thanx
- HOW MUCH hp IS THIS MOTOR PUSHING JUST WANT TO SEE IF MY FRIEND IS FUL OF SHIT
- skunk 2 stage 3 cams for B-series motors.
- Valve clearance?
- First dyno of my new LS/VTEC. Looking for opinions
- fuel problem? to rich or to lean??????
- 2.5" exhaust??
- Who runs a Comptech Race header here?
- Running Lean
- normal compression reading on a jdm itr motor? help
- BIG PROBLEM: adapter stuck in spark plug hole
- who here has made over 220 all- motor whp!?.......
- What CAI for b20?
- Compression
- Compression Ratio on LS/VTEC
- Header skid plate
- what does a stock 2000 honda civic ex make at the wheels?
- CAI for CRX with B20VTEC
- Just curious on some times that you guys with the all motor b18b's are running
- Which Piston Rings for CTR Pistons
- Toda C with CR of 11.2 or lower
- IS this the right part # for a GSR throttle body gasket?
- any downside to welding the differintal?
- who's got a mid 12sec daily driver?? or faster??
- anyone use the rlz house cams???
- Wodering about
- All Motor H22A
- 86mm bore and keeping all motor... is it possible?
- Posted in tech but not to many responces. Rod knock vs bad LMA
- no bullcrap help finding a block for a black sheep
- ALL Motor D is coming along...
- I want to get rid of my Tanabe..
- Hondata w/370cc
- B18a1+B16/ITR Head+CTR .20 Pistons=What Compression?
- anyone know anything about the 272 cam for d15b7 by deltacam?
- H22 trans issues...Question inside
- b16a 84mm
- skunk 2 stage 1 owners ..how do u like em?
- trying to decide on my compression ratio and bore size... please help
- Ti vs. Stock retainers: how much difference
- looking for a dyno chart
- spoon ecu
- ~ - ----> VOTE <---- - ~ FAVORITE BLOCK SLEEVING COMPANY
- Which ecu on a all motor gsr w/ skunk2 intake manifold
- CRVtec Hondata
- New Race Header for B-Series
- It's all about weight savings right??
- all motor
- pistons
- dtr header help
- CRvtec cam timing?
- arp head bolts for ls vtec
- burning oil.
- Question, Help...
- c-speedracing compression calculator accurate?
- Cylinder head work involved with boring out cylinders?
- CRV/VTEC QUESTIONS
- ECU for LS/VTEC
- LSD???
- Help me out fellow civic owners..
- Rod Knock Q's
- 2.0 time slip?
- Endyn's famous supercharged EF
- DH racing built longblock ....help
- injector filters do u need tehm ???
- max WHP gained by Skunk2 cams
- Fuel Pressure????
- What ECU chip for this? Who do you recommend?
- 85mm bore B-series people, piston options
- Some interesting VW ITB setups
- b20 vs b18, is the b20 worth it?
- GSR Crank in a B18B/A block
- how much compression on pump gas?
- time to build the head help me decide on the best cams please
- HONDATA
- erick's racing
- Alternator solenoid fuse keep popping?
- LS/VTEC near completion
- S21 OR Y21 Tranny?
- Ring gap location? HELP
- quick question
- Skunk stage2's with a thinner headgasket?
- Calculate Engine Size in Cubic Inches and CC's
- first dyno today!!
- Does Bisimoto Engineering have a website?
- is this a good set up?????
- engine rebuild?
- skunk2 stage 3 cams????
- NON ti aftermarket retainers
- Tuning
- B16 retainer P/N Q's
- test pipe problem help!!
- how much whp would i need to run 13's at high elevations like 6200 ft. high
- Building a B18C1???
- Running a LS ecu with a vtec setup?
- GSR Fuel Injectors
- would this be a good street/ auto-x setup?
- b18c1 with p30 pistons
- Aftermarket Cam spec question
- B16 Bearing clearances
- How do I know if CTR Cams are what seller says they are???
- Can someone post pics of the JUN B-series IM
- arp rod bolts
- wondering on my potential on my setup
- AN-R header just installed!!
- Question on set up?
- Type S pistons
- A bored out b16 the same as an ls?
- Hondata s100 OK for my setup?
- LS/Vtec v/s stroker kit (Crower, Spoon)
- Is a head porter a head porter??
- Timing Belt Question
- can someone help show me how to post pictures?
- cryo treating pistons/rods
- B18a1 engine failure : broke timing belt gear keyway. Pictures coming soon...
- Fuel injectors....
- b16 head for ls/vtec ported and polished -> check it
- will eagle rods be sufficient...?or should i switch to crowers?
- To stroke or not to stroke... that is the question (H23 VTEC)
- Who does the best block sleeving job?
- Getting a random Code 9 (Cylinder Postion TDC)
- FJO Wideband O2 problems
- d16a6 build up questions
- Quick Q for the GE vtec kit.
- My all motor setup. Let me know what you think
- Size Slicks on All-Motor H22A Honda Civic?
- b16 build up
- video of jdm gsr in 94 si hatch. whats wrong with my speedo?
- Ls Vtec with b17 head???
- Any all motor dohc non-vtec's around?
- Bomb, Bang, Gun shot!
- Crower street/race valve springs ok for toda spec b's?
- what "ecu" should i run for my setup? anh what kinda hp would i expect?
- calculating liters
- Skunk2 Valve Springs and Binding? Experts needed ASAP
- Sk2 Stg2 cams w/ CTR pistons in LS block? Clearance Issues?
- ITB's
- need cams that will pass deq
- quick question
- just dynoe'd my GSR with ITR cams "very impressed"
- 230-240whp: What Cams?
- Got a CTR piston question???
- Injector size....is stock enough?
- Would you buy....
- current setup. and what to do next
- Recent Updates to my allmotor drag car
- Specs for Web Cams Camshafts #452 for LS integra
- Function 7 block girdle
- what fuel pressure?
- Basic rebuild cost for B18C1
- Skunk2 valve train
- SMSP/AN-R/DTR/Headertech for S2000?
- port and polish myself?
- How big can a H22 get?
- First time LS/VTEC build
- DTR vs SMS
- Hondata?
- How do I Trim a B-Series Valve Cover for cam gears?
- 84mm piston???
- All Motor without forced induction? How?
- What are the better stainless valves??
- pictures, broken pressure plate and messed up flywheel and crank.
- WHOA.. whos running 86MM pistons in there B-SERIES??
- Guy from Toronto Canada wins englishtown dyno competition
- Compatibility of cams and valvetrain
- WTF do the honda tranny codes mean?
- 290 Prelude Injectors on B16 (or LsVtec)
- all motor potenial of a b17
- is the p08 ECU fully reprogramable??
- K20 2-layer head gasket?
- 1984 Porsche 911 SC/RS
- N/A and aftermarket rods
- Motor is bored what should I do?
- Link to new 95mm Crankshaft FS.
- d16 wit a1 pistons.....do i NEED to tune??
- CRVtec B20/Vtec Transmission tranny?
- GSR rods in LS block
- Toda C's in B16 Head mated with a GSR Block with CTR Pistons.....
- Springs+Retainers
- ? on making homemade ITB's
- B16 Help
- jenvey itbs, need more info
- Topfuel 1.8l stroker kit/Toda type C
- Need Help Valve Train Question
- how many miles will a honda engine give you?
- ITR 4-1 vs. DC JDM 4-1
- ECU problem
- cracked head??..blown gasket??
- k tell me if ive got it right yet
- GSR block/b16 head?
- which BFG's should i buy?
- SMS Header
- no oil pressure! oil light on!
- header turning gold?
- It's finally here.....
- roll call for all motor for nhra finals
- A6 vs. Z6
- will rc injectors for an obd1 92-96 prelude fit an obd1 gsr???
- Lsvtec question?
- 240-250whp possible
- need help with bearings
- About Z10 girdles?
- tuning crower 404's
- Spoon head gasket/ best pistons
- Tranny fd and lsd swap info
- might be a dumb question but...........
- S1 MANUAL TRANNY SWAP GOING IN AN 98 AUTO LS... HELP PLEASE!
- Bad things can happen if you don't check EVERYTHING!
- skunk2 manifold install help
- cr on an ls/vtec?
- Question about running a lower fuel pressure with my set up.
- vafc and all motor, with big injectors ???
- toda question for b16
- 82mm Pistons On B18C?
- newbie question about FPR and hondata
- I have no clue which stage cams to run on my mildly modded GSR swap????
- Added B-series cams, wont start. Any Idea?
- Which engine should i go with???!!!!
- All-motor gurus: how much to be gained from headwork
- 200 WHP possible?
- HELP! b16 with no vtec, why?
- Critique my setup please..
- modifying stock HG for higher compression
- Timing advance
- whats more worth it?
- my new set up
- 181 whp SOHC 1.6L
