PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 [104] 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Magnaflow or es tuning muffler?
  2. fuel options for a 12:1 comp. motor
  3. Use Stock airbox w/ Aftermarket Intake
  4. BUILT LS BOTTOM END 4SALE,BOSTON AREA
  5. Noob-Type Question: Vtec Cams into B18b1?
  6. milled heads, adj. cam gears and timing
  7. 2.2L B18c5 Rebuild/Build up
  8. Looking for a tall FD for a b-series tranny...who makes one?
  9. looking for a new motor person, to help with a formula project.
  10. Anyone ever tried adjusting cam gears on a stock GSR??
  11. LS vtec Question
  12. web cams valve clearance?
  13. Is a stroker kit a good idea??? *need help**
  14. RPM gauge not reading correctly, what could it be?
  15. Supertech V-train w/Skunk2 Pro2 cams "Will it work??
  16. jdm zc pistons in d16y8
  17. whats it alla bout.
  18. drivieshaft shop stage 2
  19. easiest way to get 180-190whp from a b18c?
  20. does anyone know ????
  21. B20 250+ setup's
  22. b17 b16 pistons and type r cams
  23. Need Help finding a good shop to build my engine.
  24. PR3 versus PCT piston ring thickness?
  25. i need to find a performance DISTRIBUTOR for D16A6
  26. COMPRESSION TEST RESULTS---all motor built--- help!!!
  27. Need help finding oil line kit for lsvtec
  28. ITBs for h22a
  29. B16a with PCT pistons. I don't think I will need balancing. Or do I?
  30. piston ring gap spec????
  31. intake, headers, intake manifold... stock exhaust... bad for the motor?
  32. installing new valves
  33. TODA SPEC D CAMS !!!!
  34. Fitment of f23 crank h22a block
  35. Oil ?
  36. lsvtec
  37. CAI Question
  38. 13:1 compression
  39. gsr block rebuild ( poor man type r )
  40. TODA FLYWHEEL !! NEED SOME HELP !
  41. planning an all motor build
  42. 1992 JDM H22 Motor Question
  43. what size piping with my setup?
  44. 270 whp all motor!!
  45. A little video I made...
  46. Trying to decide tb size and injector size, I need knowledgeable people.
  47. whats the highest compression you can go on 89oct.?
  48. ls vtec T adapter
  49. Sport Comp2 tach jumps
  50. WHAT DO YOU GUYS THINK OF HONDA TECH SPONSOR JDM 4-1 HEADER REPLICA
  51. b18C Forged NOS?
  52. B-series people: What is your final timing on pump gas?
  53. distributor timing problem
  54. merry christmas everyone
  55. ITR head work: Toda VS Skunk 2?
  56. Looking for D16 Motor Combonation!
  57. JGE headers!!
  58. B.C. III cams, which valves springs?
  59. Full Race IM on a n/a B16 ?
  60. what is crome or neptune? need help
  61. What kind of power (if any) would I gain w/ an intake manifold?
  62. Cost to build a B18c1?
  63. Kinsler intake manifold itbs. Anyone have any info on it?
  64. d16z6 hybrid build...hepl if you can
  65. individual throttle bodies!!
  66. calculating dynamic compression
  67. Does anyone have any Dyno's of Rockets h24x cams?
  68. What is the biggest cam i can run on a stock gsr head reving to 8000 rpm ???
  69. LS and GSR Transmission Help?
  70. Blew My motor :( B20b with Buddy CLub Spec 4 cams
  71. SMS ITR Header(new)...
  72. drag header
  73. type r trottle body
  74. 91 octane, daily driven, Crome tuned, how high of a C/R is optimum?
  75. so should these valve be replaced?
  76. 2point6's final dyno... for now
  77. all motor LS, cam question
  78. lots of stuff for sale ef--eg---h22
  79. what exhaust would u guys use for all motor
  80. 3 grand?
  81. need help guyz!!!!
  82. What to do before DYNO run???
  83. switching my fluidampr to a stock pulley?
  84. Will hondata s100 be enough?
  85. If I start with and 89mm X 81mm B18 block, how much HP does each additional 1mm add?
  86. LS/VTEC Absolute Full Conversion
  87. Need Ideas With My LS/VTEC Build....all inputs Welcome!!
  88. What year range is PR3-1 from? anybody?
  89. Need help with these hoses *** WITH PICS***
  90. piston rings???
  91. too big for my setup?
  92. how much timing should I pull for a 100 shot?
  93. 86mm built type rw/ 1" deckpalte,should i buy?
  94. need help with built B16A into my crx
  95. adjustable fpr needed?
  96. GSR and B16a
  97. Blox B cams
  98. 200+ whp LS/VTEC?
  99. need engine help with rocker arms
  100. All motor H23 VTEC on ITBS and EMS
  101. spark plugs gap
  102. skunk2 pro 1 cam, crower valve train ok?
  103. whats the best sleeving service for an all motor/nitrous build
  104. b18c/b18a wiring
  105. SOHC N/A Piston Question
  106. How to Run Vacuum to the Brake Booster when usiung ITB's??
  107. lookin for some springs and retainers for h22 seen some kms ones for cheap does anyone know if they
  108. Cam installation question. Concerned about crower cams.
  109. Problem setting b20vtec timing
  110. V6 ENGINE ON ODYSSEY EXL
  111. Any input on still stroket kit.
  112. Tuning a TSX
  113. quick question help asap
  114. B20:Sleeve or Not to Sleeve??
  115. oem retainers, will this work?
  116. Portflow inner springs?
  117. cbr 900rr for itbs?
  118. cams
  119. OT: Christmas Special.
  120. jg edelbrock pro-flo header Model: #6752
  121. Intake manifold question?
  122. timing marks for ls v-tec
  123. High Compression B18c1 build.
  124. Automatic???
  125. How do I know If I have a bent Valve?
  126. Crank Pulley ?
  127. Shot-peening OEM rods....is there any advantage to it?
  128. bogging out?????
  129. Best Bang for the Buck All-Motor Setup!?
  130. head gasket
  131. complet gsr swap for sale
  132. b16b pistons in b16a2?>>
  133. b16 oil pan in a b18c4 block??/
  134. blox b tuner series on b16a2??
  135. lsvtec build
  136. Hondata Romeditor v4 for s100/s200 is now out.
  137. 4-1 DC Header on Stock Block= Loss of power, right???
  138. ATTN: All Motor Guru's......I need your help =)
  139. BuddyClub Spec 2 On 1996-2000 civic coupe!??????
  140. 12 sec all motor
  141. Buddy Club Spec III?
  142. Which is better for Torque?
  143. timing belt advice
  144. installing valves springs need help
  145. skunk stage 2 with current valvetrain?
  146. Piston to wall clearance
  147. Which brand of retainers would YOU choose?
  148. which dual valvesprings would you choose?
  149. Need help with new header/exhaust combo! SMSP?
  150. camshaft poll
  151. Some oem H22A intake manifold tests
  152. Stock Fuel Injectors on H22 Build??
  153. which rods for K24/K20
  154. Need help choosing axles!!!
  155. Golden eagle gasket?????
  156. scratched pistons, reusable?
  157. knock off type R ls vtec rods ????
  158. Main Studs???
  159. Avarage Cost of a shop to teardown and completly build a short block???
  160. B16A2 W/CTR
  161. tuning hondata s200 p28 with chrome?
  162. bend valves ??? pic request
  163. CTR CAMS WORN OUT?
  164. What to get?
  165. 86mm type r w/ 1inch dechplate,what timing belt do i run?
  166. Looking for piston advice
  167. head swap on ls, to vtec, oil line help?
  168. Valve to Valve clearance.?
  169. 01 Civic Ex
  170. theory i heard somewhere
  171. would this be a good set up??
  172. where do you get a good price on factory pistons?
  173. Thickness of headgasket when raising compression.
  174. LS V TEC VS. B20 V TEC
  175. block guard how neccesary for N/A
  176. Poll: Breaking in a new motor: Drive it hard or Take it Easy!!!
  177. Help! My B18c feels like its hitting Rev Limiter @ 5,000rpms?
  178. HELP PLEASEE!!!! im stumped...
  179. .040 Overbore on stock d16a6 sleaves will the walls be ok?
  180. What exhausts/mufflers are you guys rocking? Will an Apexi WS Sport really hurt my HP?
  181. Someone help me please!!!!!!
  182. My planned allmotor setup B20
  183. supertech valve stem seals?
  184. what are some good plugs for allmotor?
  185. all motor setup
  186. new set up
  187. buddy club 4 cams , skunk 2 cam gears , aem cam gears
  188. Choosing cams for for lsvtec
  189. Average price for a b-series build?
  190. 86 mm darton sleeved LS
  191. Anyone done any writeups, on converting over to natural gas?
  192. AEBS Racing still exist?
  193. FPR off AEM fuel rail.
  194. Fuel injector and Hondata question
  195. what cam gear to go with??
  196. what header to use?
  197. 94 gsr head into 00 gsr?
  198. Hytech reweld
  199. Why doesnt this work....
  200. my 1600cc setup. dynosheet inside.
  201. Pro Fab header install...
  202. stroker kit questions
  203. 1st build and have questions
  204. No oil pressure?
  205. valve clearance questions?
  206. high compression valves?
  207. all motor set up
  208. Tuning help!
  209. Picked up Skunk2 Stage2 cams retainer and valve springs. ANyone have their #'s?
  210. Decking block .060?
  211. how many miles per gallon to you guys get on your all motor setups ???
  212. OmniPower valves R they any good ! ???
  213. all motor setup help
  214. part throttle hiccup
  215. stock JDM b16a longblock...192whp sae
  216. hondata, crome or neptune? witch is better?
  217. Which cam seals are you guys using?
  218. headers
  219. bad spark plugs
  220. Individual throttle body
  221. Manley Pistons w/ Stock H22 Sleeves???
  222. SWAP del sol 8k budget
  223. H22 dyno chart skunk2 intake manifold with s300
  224. f20b valvetrain upgrade or not?
  225. Timing Belt Upgrade ? Worth it ?
  226. WHITFIELD.RAGE.RYWIRE.SKUNK2.SNAPON...etc CHARITY RAFFLE
  227. 24.5x8x13 inch Mickey Thompson Slicks
  228. Spark Plug Wires
  229. Engine Swaps??
  230. Compression check before break in ????
  231. PLEASE HELP!!!!!!!
  232. buy b20 or sleeve b18c1
  233. Engine compression 160psi?? WTF?
  234. b18c1 all motor build y0!
  235. itr cams or something bigger?
  236. b16 IM vs ITR IM
  237. LS crank and rods in a GSR Block? Is it possible?
  238. Rage headers - 2.5" donut flange, help needed
  239. Can you take a look at my bearings and crank? is it toast?
  240. sent wrong injectors?!?!?!
  241. Opinions of combustion chamber damage please?
  242. h22 rod weight? stock oem rods weigh h22a1 h22a4
  243. Gates "Sport" timing belt?
  244. Edelbrock Parts
  245. Anyone using stock retainers with dual springs?
  246. retorque head bolts?????
  247. Header Question
  248. 240cc vs 440cc injectors
  249. Mild gsr build na hitting dyno tonight
  250. whats the difference between saturated vs peak and hold injectors
