PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 [205] 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Which would you pick? ITBS and alaniz head or Alaniz Head/Cams/Header????
  2. Is it safe to go for CR 12.8:1 on 94 octain fuel with 16° settin of ignition
  3. DTR/SMSP header clearnace on B18C-R
  4. lsvtec bottom end build
  5. Need help on engine swap
  6. Clutch Help Please
  7. b18c1 setup!!!! project229
  8. Valve clearance question on K series
  9. CARB legal header?
  10. New to forums, Ill share my "all motor", and a few questions
  11. Is Emanage compatible with OBD2??
  12. I have a b16, but I want more, Cali ref legal necesary
  13. Piston Rings: OEM vs Aftermarket
  14. comp cams
  15. d15b2 block, d16y7 head, high compression. With FPR, should I lean it out? or would it detonate?
  16. oil filter relocation?? good or bad
  17. difference between merge and street?
  18. fastest race crew in central cali!!!
  19. ITR bottom Si head and Si ecu
  20. BUDGET header question b16 street car
  21. new muffler?
  22. Valvetrain info help!!
  23. Who has the fastest all motor in here in honda-tech?!!
  24. Another B20 CR ?
  25. injector placement ITBs
  26. Need help IDing GSR intake and exhaust valve springs
  27. For 96-00 civics with b18b all motor...
  28. 1/8 , 1/4 mile times on B18 crx i/h/e//cams
  29. Machine shop messed up need to lower comp PLEASE HELP
  30. Setting your VAFC Controller
  31. Race fuel?
  32. For all you sporting a b16b- LQQK INSIDE!
  33. K-series Header dyno results
  34. Need piston advice
  35. Are these good DYNO NUMBERS for my LS?
  36. shaving head?
  37. help with wiring vtec to ecu
  38. Performance gains from open header valve on street car?
  39. how 2 make my gears shorter
  40. sorry to ask this but do you'll think i can get 180 or 190 whp poor mans r ?
  41. What do you think about these?
  42. H22A all-motor build : Knock Sensor - A good or bad thing?
  43. Here's my new setup.
  44. header wrap an intake?
  45. does 84mm LS =resleeve block???
  46. I put an intake and a 74mm tb on and don't see results $1000 investment ?
  47. LS bore 2.0 headgasket question?
  48. think i spun a bearing
  49. Best Platfor to Start an All Motor Project???
  50. stock C5/toda C
  51. just wondering about vavle springs
  52. WTF?gsr runs slower then before after bigger cams?
  53. What is the best header for an all motor car?!!!
  54. VALVE SPRINGS
  55. best cams for high comp
  56. ot: anybody have a bling bling display b-series block/head?
  57. Wich springs to use with ITR Cams?
  58. Equal Length Manifold...A/C Compatible....*Searched*
  59. I'm having serious issuse with my crank pulley, please help me!
  60. crane external coil w/ modified dizzy cap, HELP!!!!
  61. ctr pistons in b18c1??
  62. ******compression gurus look!!*******
  63. P29 - D16A1 Integra Piston Pics
  64. need some help from the Dyno Guru's.. tuned but still low WHP
  65. 210whp type r project
  66. Greddy E-Manage??
  67. Insane in the Membrane: AN-R Header is Crazy!!!
  68. Looking for JDM wholesalers
  69. race gas? mix it or just full strength
  70. where can i get a helm manual?
  71. Ran my stock B20B tonight
  72. What bore can you go with a H22???
  73. Need Help With Compression in FL
  74. PLEASE HELP PLEASE NEED ADVICE! PLEASE
  75. Finally, gonna start my build-up (big pics)
  76. hondata or chip p28 ecu for all motor or turbo
  77. do you need to buy springs and retainers with cams??
  78. Comp Cams---
  79. tips on bottom end assembly
  80. just installed my fpr...what to set it to?
  81. Emissions
  82. Valves and Retainers
  83. H22 Drag Civic Any Tips?????
  84. CHECK OUT THIS HEAD (EBAY)
  85. Please post good pics of out weisco 84.5mm 2&4cc domes side view of domes
  86. Need help with piston sizes and other misc crap!
  87. Need a mentor...any volenteers?!
  88. I broke a Rocker arm in my LS!!!!
  89. Skunk2 Stage 2 cam geat settings
  90. What cc injectors should I get???
  91. ctr pistons in b16??
  92. Motor question
  93. Fuel tunning
  94. what cams should i run for my n/a setup?
  95. Clearances Question on Comp Cams. Can i run these?
  96. Proper Setup for Skunk2 Stage 2 Cams
  97. PISTON DAMAGE (ok to use?)56k beware!
  98. PISTONS FOR LS/VTEC ALL MOTOR??
  99. how do you get pistons off of rods without destroying the pistons?
  100. Check out these Air/Fuel numbers
  101. good b18c cams?
  102. Are PR4 LS rods Weaker or stronger than stock a6 rods?
  103. GSR cam question
  104. B18 Knowledge needed...
  105. ls vtec timing
  106. pistons hitting head?!? b17a/pct combo
  107. Dyno poeple, thoughts please.
  108. GSR cams
  109. problems w/ skunk2 and str tb install
  110. new aebs gsr intake manifold?
  111. might go back to all motor... possibly B20
  112. Generic intake filters
  113. Any recommended shops to install pistons in so cal?
  114. ctr rods in ls
  115. having second thoughts on motor build
  116. ITR springs, yellow paint goes where?
  117. Bad Business
  118. ITBS
  119. Should i run the Hondata obd1 pr3 or what help!!!!!
  120. I need Help!!!
  121. Pistons question
  122. FT: 96 JDM B18CR (ITR) for b18c1
  123. downside to torque
  124. ITR-tranny-internals in EG2-tranny-housing ?
  125. T1R header
  126. CRVTEC setup help
  127. ever seen this? h22 w/ b16 intake manifold
  128. GSR/LS question???
  129. honda civic HB
  130. camshafts
  131. Quick headgasket question...
  132. ECU Chip for H22 P28
  133. Which plugs do I need for my set up
  134. cams
  135. Cam question for D15B7
  136. springs and retainers yes or no???
  137. f22a1 cams vs f22a6 cams is there a difference.
  138. Is it easy to get 12's out of a B16???
  139. Suspension problems... (cant post on suspension forum for some reason...)
  140. Which pistons in a gsr w/ skunk stage 2s ?
  141. Im concidering a buildup on my b18c1. Could i get some honest advice?
  142. Lighter flywheel
  143. n/a is best sticker
  144. B18c5 All motor or LS/VTEC hmmm ??
  145. Comp Cams Stage 2 anyone vs. 403's vs RS machine. (another BS vs thread!)
  146. would anyone buy my motor?
  147. Probe pistons anyone using them?
  148. LSVTEC Build Part listing.. How much would you pay?
  149. piston question...help!!!
  150. rev potential of K24 frank motor
  151. help on stroke and bore
  152. d16y8 what should i do???
  153. NAR-spec header?
  154. Has anyone seen Toda Spec C make more than 215whp on 81-82mm bore?
  155. good local machine shop??????
  156. LS/VTEC alternative article on HS
  157. 2.0 bore set-up ineed of some info?
  158. 1st run results of my ls/vtec
  159. is a gsr and b16 head gasket the same
  160. Bought a GSR from a dealer, after a few weeks I relized it had a bit more done then I thought.
  161. Whats a afforable "B" series?
  162. quick question dowel location w/ pic
  163. any tips for "purchasing" a smog paper?
  164. my new motor setup in eg hatch....
  165. Somewhat new to Honda N/A ....what do you techies think of this setup?
  166. pics of my lsvtec..
  167. Noisy Toda A's with .2mm lash? Can I try stock/other options?
  168. h22a vs b18c r/s ratio
  169. Is my head warped?
  170. tips for building an all motor street car for low 13s , high 12s or better
  171. camshafts for a d16a1
  172. b16 head or gsr head
  173. Eagle Rod question.....
  174. will this setup work?
  175. Hybrid: exhaust/cat/piping question????
  176. Question about STR 68mm Bseries T/B
  177. Just got my LS/VTEC bottom end back from the shop! *BiG PICS*
  178. skunk 2 intake manifold
  179. Backpressure issue...
  180. what style intake do you prefer...
  181. header info!!!!
  182. need help building b20 block w b18c1 head
  183. K series VS B series
  184. Tranny casing question..
  185. Individual Throtle Bodies?? does anybody have this setup?
  186. 1995 dx auto- b16a compatible with tranny?
  187. high whp na ls setups?
  188. sohc camshaft N/A!!!????????????????????
  189. been turbocharged, now all motor. whoa....
  190. Reducing the bank role...
  191. Highest CR for 91 octane?
  192. Since Im going All Motor, so I figured I would post this here.
  193. itb's vs d16z6/y8????????
  194. p29 pistons with d16z6 piston rings and pins?
  195. gauge question.
  196. UPDATE: exact CFM results from headwork. What do you think.
  197. Keep the all motor d16a1 or go b16?
  198. Anyone use exospeed slevees sleeves?
  199. what cams for me?
  200. B16 Stroker Kit
  201. Hi Everyone...
  202. Flat top Valve Weight (grams) Comparison
  203. What bearing clearance should I be looking for???
  204. RS cam VS Skunk2 stage2
  205. Bosch 4227 spark plugs
  206. Overheating!!!!!!!!!!!!
  207. What my compression???
  208. PLEASE HELP ME!!!!!
  209. 9:1 vs 10:1 c/r d16a6
  210. Skunk 2 cam gears, what are the markings they use for TDC?
  211. Question about hp and compression...Did search but not much luck.
  212. Dynoed My LS/VTEC w/ Hondata... #'s Inside...
  213. Best oil and plugs for Hi Comp?
  214. QUESTION ABOUT SKUNK2 STAGE II CAMS
  215. Mircotech Mt-8
  216. 2.25 to 2.5
  217. How would you tune a honda civic EX
  218. Any ideas on tunning a 2003 civic ex
  219. Fuel PSI
  220. Crower valve springs
  221. honda tuning's 4 door integra
  222. Flow Bench readings, headflow gains questions.
  223. Just got back from the dyno with my h22
  224. People with built motors how long has your lasted?
  225. break in tech
  226. overbore and milling d16z6
  227. H22 build advice needed
  228. s2s2 cams w/ SiR2 valve springs/retainers
  229. true life "im a street racer" guy are you a H-T member?
  230. Supercharged Automatic Integra? Opinions?
  231. poormans R or gsr head.......
  232. Fidanza 7.5lb flywheel
  233. sumthin
  234. My Setup What will it run??
  235. Good price for Alaniz Ported head???
  236. modded B16a dyno
  237. Who's Knife-Edged???
  238. how much HP?
  239. Just got my head on...water temp gauge problem
  240. header tech or fake sms?
  241. WHATS WRONG HERE
  242. how much does a b18c with tranny weigh?
  243. Wiesco vs. Arias vs. Ross vs. JE vs. CP pistons. Who's the best?
  244. Nitride coated ITR valvetrain
  245. Compression In excess of 14:1
  246. Limits of stock 240cc injectors
  247. What Pistons to use in my ALL motor project?!
  248. HEAD PORTERS!!! Valve job!!! P&P guru's lend a hand HELP!!!
  249. Piston Question?
  250. b16a all motor PROBLEMS???
