- start of my lsv
- Sign the E85 Petition!! convert to e85= exempt from smog
- What CR will a B16 run on stock cams
- B20 Vtec head gasket question
- WILL B18 INTAKE MANIFOLD FIT ONTO A B16A2 ENGINE?
- History - The JTCC/JACCS/MoonCraft H22A ACCORD
- b16 with ctr pistons what vales do i do
- Different flywheel and crank pulley change engine harmonics?
- E85 finally showed up at the pumps in town...
- H22 love from kaizenspeed
- all motor gsr build need advice and tips!!!
- Long oil pressure light at cold start
- Zerolift autolab experience......
- Blox intake manifold and Sk2 TB worth putting on Stock Gsr?
- Some injector Videos
- Lsvtec wont start
- valve guides & boss's
- how good or bad this works ?? Intake system
- Ammfab ported d16y8 head (you could call it race porting)
- 3 cylinders
- Another Exhaust Size Question
- head gasket question??
- Cold Air Intake
- power of main bearings SPOON
- How do the hot rodders achieve their "thumpy" idle?
- B20 non-Vtec build, questions and tech talk
- built g23 has very little too no oil prressure?
- Help lsv wont start/crank
- B20 vtec build problems
- Did I get the valve adjustment right?
- F22A1 to F22A6
- unorthobox cam gears ?
- ls vtec or b20
- B20 vtec build what should I change??
- best b16 set up
- 2000 Si......which swap....?
- top and bottom half of main bearings different?
- Need help!. B16a valves
- honda valve stem seals, all engines?
- Ammfab Race ported b18c1 head is finally done!
- repaired crank in N/a build, opinions needed
- Initial Crank Turn by hand difficult
- 230whp 82mm B18C1 Set-Up
- ITB's CTR hatch
- Difference between hi comp valves and standard?
- 1998 Honda Accord will not start
- First B-Series Build...
- SS Autoworks CRX
- 167.6 whp and 118 tq, what u think ??
- LS V Build questions
- LsVtec w/nitrous ideas for 300+ hp
- 200whp All-Motor Goal to be set.... Questions needing Answers!
- Loss in Power after swoping IM
- Opinions on my na b20v build bring it,.....
- 225whp h22
- Brian crower spring and retainers?
- need opinion on intake manifold
- GSR Cylinder Head Questions (LMA's & Retainers)
- H22A vs. H23A Blue Top
- B20 vtec quick block venting question?
- LMA talk
- What should i expect from a B20v
- F20b few q's
- H22A injector issue - electrical
- Honda engine builder in Ohio?
- Need ideas on best head to use w/ my setup
- b20v build
- Need help in identifying this ARIAS piston.
- Does anyone use the AEM distrutorless COP?
- B18C Water Pump Dowel Pins
- OBX ITB's? Need people who actually tried them reply
- Header and Exhaust?
- Break in advise!!!!!
- engine rebuild Q: piston/cylinder orientation
- 1992 Accord F22A6 Water in the Oil and Vice Versa Please Help
- NEED HELP!! Timing Belt job done- WRONG!!
- B18C head - crack between valves
- Stock B18C1 2.25 vs 2.5inch exhaust
- is the b20 crank weaker than a b18?
- Catchcan question
- D SERIES ADVICE?
- Reputable shops in Colorado?
- What does this Mean???
- Rocket M22x degree specifications
- anyone know a good shop to bring a civic in MA?
- 99 Civic 02 Sensor questions - Need advice
- H22A - check my timing pics, pls.
- 97 GSR BUILD ADVICE
- blueprint I-beam rods with wiseco piston
- h22 spring base removal, "stuck"
- whats wrong with my b16a
- What to do next to MAX out my B20Vtec?
- Bowman Crx B20B dyno
- Which fuel rails will work? Running CBR1100 ITBS
- Rocket Motorsports M25
- My totally full stock 200HP B16
- B16A Head With B18C5 Bottom End?
- goal: 200whp w/lsd trans budget: 4K$ halppp!
- Best Cam for Mildly built Sir-2 b16a
- help with custom intake piping for my s2k
- Tutorial: Engine Break-in with Joe Gibbs BR30 Break-In Oil
- Manual ECU Inside Of Automatic (OBD1)
- Throttle Response
- Low End Torque
- MT Gauge Cluster Replacing AT
- (Velocity Stack) Short Ram Intake
- D15B7/D16Z6 Head (Mini Me Swap)
- Moroso oil Pan and B18 Type-R round 2
- Oil Cooler?
- b series 95mm stroker pro's & cons
- PLM header question
- Crank pulley upgrade?
- 96 b18b1 is burning a lot of oil =/
- Help Identifiying These Cams?
- AEM FUEL RAIL QUESTION?????
- b18c1 ALL MOTOR (i need help!)
- İstanbul dan merhaba
- Skunk2 Tuner 2 cam dyno
- HKS Adjustable Cam Gears
- How can I find out if my B16 is stock???
- Returning turbo b16a2 back to stock
- H2B 89x95 Pro2s Build
- modded performer x dyno's
- B18C : Valve springs for OEM retainers
- I wish I could play the HP game
- valve spring questions
- whats my best bet for engine swap?
- b18c 1600cc
- MikeySpec re budget header test
- Need help on B20b Main Stud
- I Lost Power!! Need Help!!
- Questions about USDM1994 GSR Build
- Budget Header Showdown - Replica Headers vs. Skunk2 Alpha 1.8L Dyno Test
- GSR Block with PCT's and Pro3 Cams
- 12.1 or 12.5.1 piston
- lbs spring pressure at .500" lift specs for ITR/GSR/LS valve springs ?
- 300hp. Am I getting a good deal
- Semi built F20b head?
- k24a4 exhaust for 2005 accord lx
- anybody running blackworks stage 2 cams in gsr head?
- PROJECT BASTARD KING KLOS KOUPE
- King Motorsports Ported PX Manifold
- D15 build- Z6 and Z9 head - what's the difference?
- boring out stock intakemanifold
- <3 ARP
- Built LS/Vtec 81.50 mm Header choice?
- performer x choking my 1.8l??
- h2b all motor build help
- dc5-r exhaust question
- 4 Piston GSR Motor
- Which knockoff header for my setup?
- V-tech Engine/Tranny work- ATX Area
- Snapped timing belt-B18C1
- Does every header install require o2 wire to be extended?
- D16 ITB??
- Cam question
- built gsr leaking from HG
- ITB room vs stock manifold
- WHAT VALVETRAIN IS RECOMMENDED WITH SKUNK2 PRO SERIES STAGE 2???
- need a pro advice
- 20deg total timing at WOT?
- B20 vtec w/70m tb
- Wich tb gasket and im gasket to use
- BUILT lSVTEC oil leak...from headgasket...
- n/a b18c build
- LSVtec Questions CTR vs P30 vs ITR pistons....
- where can i find rocket cams at/from?
- 84mm flat top pistons sitting above deck surface
- Another B18 budget build...
- 0w30 Mobile 1 Racing Oil worth it?
- Need insight on b17 block/ Obd2 gsr head
- single crank pulley, whats out there?
- intake manifold help!
- Vtec cutting out in 4th gear at 8k
- B16 w/ GSR Intake Cam vs. B16 Cams
- B18B1-Just plastigaged my mains...this is what i got
- ITR rods surface rust removal?
- JDM type-R and Moroso oil pan
- about to buy a poor man's type r, am I getting a good deal?
- Oil filter relocation, cooler and pan
- what do you guys think?
- All Motor Build LS/VTEC 86x89
- h22 headers, which would you go for?
- Problems after dyno..help?
- Piston to valve clearance?
- Lsv vs b16 vs built z6
- need B16a torque specs
- JG 301 cam's, IDLE VIDEO
- all motor honda... meth injection
- B18b Help..
- skunk 2 pro 2's, RM M22XX or BC Spec 4's for all motor streetbuild
- Ls vtec all motor some miss understandings
- B18C4 doubt about cams
- mini me project! help!
- All motor 81.50 mm ls/vtec build! Many details and pics!
- Skunk2 flat valves
- ITR STREET BUILD?
- Need opinions on piston bore
- need help asap
- Spark Plug position
- 2003 Element Ticking Noise
- what bearings do you use?
- BEST B SERIES HEADER?
- Hytech big tube header on non-VTEC (too big?)
- Would you run this crank?
- Poor Mans TypeR swap all motor
- Rebuil B18c6 piston ring gaps.
- b20vtec feels slow
- E85 cranking fuel percentage
- what nexted?
- BC stage 2 cams with oversized valves
- looking for d16y7 block ! ? :P
- total ignition advance to run on a high comp b
- H22A starting problems
- Air intake? 04 Civic VP
- JDM B16 in CRX - ran, but now won't
- identify a gsr or ls crank
- Input on my H22a
- Car wont turn over
- Timing belt tensionir issue
- B20v build In the making
- Intake Manifold Test Needed
- how much does it usually cost to bore a b20 block to 84.5k 20
- best base for all motor build
- B16a vs b18b1
- rocker arm touching retainer caps?
- stuck on h22 na build NEED HELP!
- loud tapping that comes on and off!!!
- Brian Crower S2's w/S300? H22a1
- mini me CR question
- my b20vtec build. comments/suggestions
- problem revving past 5000rpm on B18C, like fuel cut off, tach bounces
- Another LSV or B20v thread.... Sigh.... -_-
- Stock b20 vtec: I has a disappoint
- Pics of installed wideband..
- Help with Cam upgrade choice or not for B18C5
- Has anyone used and tuned OBX ITB's for H22A
- Can RDX Injectors be used w/TWM fuel rail?
- 2000 Civic LX Engine Rebuild, Need Help!
- B16a build advice
- Rebuilding D for boost
- b20 non-vtec build ?s
- 82mm B16 help!
- skunk2 tb install ?? throttle stop??
- 2-step launch control w/ flames
- B20vtec....vtec not working
- 94 LS block is bad. What are my options?
- Car ran fine, then lost low end power
- Myth?
- THIS LS-VTEC Build?
