- Slower after cams! HELP!!!!
- +++Bisimoto '94 Del Sol: STOLEN; HELP!!+++
- B18c1 with CTR crank pulley which belt to use for the ALT?
- BIg Tube HYTECH
- post your engine bay pics
- oversized vavles
- Rod Bearings and Honing Question for LSVTEC help
- Rocker arm/valve clearence
- Custom Intake Setup Using 304 Stainless
- Prelude injector color?
- skunk 2 stage pro series vs blox stage 2 cams
- built c5 wont start.
- WILL THIS MOTOR SETUP BE RELIABLE/DAILY DRIVABLE?
- opinions please
- Exhaust Question
- 93 EG with Type R motor; Which CAI model to purchase, LS/RS or EG?
- head build
- Which Axles for a 93 Civic Hatch with an LSV?
- Is a 68mm Throttle Body Optimum for an 89 x 84.5 Build?
- dyno DAY! b18c-R
- Lame Question: Overbore, need pistons first?
- camp1320 header fit in a ek?
- Help me ID these bearingsfrom picture
- ~~Stock GSR..Pretty Impressive~~
- Would a jdm d15b pass emissions
- need help #3 cylinder has no compression
- Important question about oem oil pumps PLEASE HELP
- Skunk Pro series cam gears
- startinline
- B18B teardown
- crower products
- Anybody tuning for good fuel economy in the lower columns?
- Anyone use the Blue Point or Snap on valve keeper tool?
- too rich, washing out the piston rings, too lean, melt the piston?
- Got the Ls Vtec Tuned and Dyno'd
- vibrant or spin tech muffler
- K series ITB units from Kinsler: DONE!
- wiring!god i hate wiring!
- Parts for SELL
- Professional products gsr & itr throttle body differece?
- noob question: h2b vs complete h22
- car running bad has no power
- Will a obd1 jdm d15b be a direct replace motor for a 96-98 ek ex?
- how do I know what size acl race bearings to get for na build
- sign of spun bearings? rings?
- Whats the difference??
- ls/vtec
- bigger injectors?
- URGENT HELP!!!!! how do you take of the starter from the s2k? im sure im in the wrong forum. i apolo
- valve calibration
- To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup
- chich flywheel would be better to use for 1/8 mile drag racing
- Supertech valve stem seals or oem honda???
- b18c5
- Hondata S200 questions - How to use?
- which is better rc saturated or peak and hold injectors for itr compression
- b18a injector size
- b16 head on gsr bottom end question
- Are M24x any good. Vs JUN #3 cams
- b18 block with b16 head how much better is it than just leavening it a b18 or a b16
- Jun 3 cams with stock retainers?
- Can bad rings cause misfire?
- k20 in 1989 civic hatch?
- Maximum compression with stock ecu
- civic idling problems
- velocity stack
- THIS IS RIDICULOUS
- rings or valve seals? I SEARCHED!!
- need ideas quick!!!!
- BRIAN CROWER VALVETRAIN:: Experience / Thoughts?
- Tuning questions
- Are Block Guards removable once installed?
- Dumb Quick Question about ACL Bearings
- Toda Spec C's Or Jun 3's on mildy high comp b16???
- BluePrint MFG. prototype K-series intake manifold PICS!!!!
- hi folks does anyone have the number to zdyne my computer is acting up
- compression question
- Skunk2 Proseries manifold for B16
- can I run Blox hsl cams with my setup
- Piston MM rules??? 81mm-84mm???
- H22 with B-series tranny
- Fitment?
- identify skunk 2 cams?
- 11.6 compression.
- GMS Motorsport CRX D15 Vtec build
- Just bought a 94 4 Door... building time.
- B18C1 WITH ITR CAMS QUESTION
- cold start problem
- ITR valves be alright?
- wat do i need for a lsv swap into a ef
- Thoughts on Omni Power head package
- Open header= too rich to keep running?
- B20Z nonVTEC w/Performer X
- K20z3 dyno, thought this was impressive!!!
- Question Regarding the Third Lobe - Swirl Inducer
- Dyno'd my GSR last night.. Unexpectedly low #'s. Look please.
- what do you guys think of rs machines oem spec itr pistons 82mm
- Velocity stack on my front bumper LOTS more top end!!!! and CHEAP!
- cams lowering compression
- back fire with flame HELP!
- Just got my head back from Combustion Contraption...
- ITR head.. does this look normal to you?
- My fuel pressure reading slightly high.
- Headgasket fitment
- toda springs with spec A's or not with stock (been seaching for days)
- ls question
- Proper order to build GSR? Please help.
- Part throttle VTEC "Hiccup"
- more beneficial: upgraded valve springs/retainers :: upgraded valves?
- Do those throttle body spacers do anything?
- GSR with P30 Piston??
- Lightest Valve material?
- Aftermarket rocker arms....
- JHPUSA B series stage 2 cams?
- N/A and A/F meters
- Trouble with Pro2 cams from ebay
- fitment issues with b16 block gsr head..
- B18c build help...
- b18c7 build plan
- Bore size
- Dyno test of Vibrant 4-2-1 2.5" collector header
- Life expectancy aftermarket valves/spring/retainers??
- ctr pistons
- vTEC
- Just installed an ACT organic clutch, now problems!
- integra mid pipe
- skunk2 stage 2 vs. pro 1's
- valvetrain?
- Just street tuned my motor
- Good Machine shop around Phoenix AZ or area?
- B18c1 with B16B pistons??
- help need smog!
- b17 motor witha type r head
- New to HT just finished my gsr build
- skunk2 stage 3 or pro 2's??
- Which parts for my H22a4
- ITB Guru's , your thought's please
- sohc f23 vtec
- arp rod bolts
- built gsr head.. itr headers?
- B18C4 tuning
- B18C5 Long Runner Intake Manifold??
- b16 turbo need help
- My NHRA street stock build!
- ATI or FLUID DAMPER????
- about to do my first build
- E85 B TYPE R???
- anyone here dealt with p2r
- ls head to gsr
- b18c5 pistons into a b18c1 block
- got the h22 tuned. is this right?
- ? about bearing clearances
- Startinline.
- New to HT. First B-series Build
- Comparison between two similar setup engines.
- question about wiseco second ring
- Compression
- CamShaft ID
- B20 vtec pump gas graph/ intake manifold test pg.2
- JUN 3 cam gear degreed???
- noise in my head
- all motor ls rod bolt question
- B16a dyno with bolt-ons
- Boring LS
- what h22 cams to use?
- HELP! Engine misfires, stalls out on highway or at idle, no one knows why!!
- Skunk 2 Pro 1
- need a shop that only specialises on honda /acura
- help identifying valvesprings/retainers....
- Questions????
- Modified Mag K24/K20 motor build
- 1996 prelude NA build cam ???
- DH Racing
- header question
- buddy club III and smog
- gsr with tapped b16 head
- Help with bottem end build.
- Spun bearing help
- Ls Vtec Build Disscusion!
- help, wath is going on with this engine???
- Noob. needs help with Build
- high comp. B18C1
- type r stroker motor?
- HELP..... EXTREMELY HIGH RPM AT IDLE
- New 2.0L B16b build plan.."Welcome for Discuss"
- **B16 Pistons on ITR Rods??**
- quick rod bearing ?
- pct wrist pins/ls eagle rods
- itb vacuum setup?
- crazy high idle after cleaning throttle body HELP
- ls vtec compression ratio?
- ***Show Your 11:5 84mm Builds***
- 1.85L set-up blown...what's next?
- gas milage
- Camshaft ?
- B series valve spring comparison
- oil catch can for all motor car
- Projected HP?whp?trq?compression? poor mans type r/gsr. Looking for comments and useful info!
- stock block? bad idea?
- evo h2b half moon adapter ?
- LS Econo Billet Rods with P30 Pistons???
- Header questions(yes I searched for you search nazis)
- My First Big Build Im only 14
- intake diameter question
- gsr crank/rods w/ b16 pistons in ls block
- HELP with my build what next????????????????/
- 70mm tb, hmmmm???
- Q's on building a poor man type R
- ITR flywheel or Exedy Flywheel???
- ls vtec build for 90 ef si
- Tuning Questions
- on the dyno
- 80MM Apexi WS2 Turbo Muffler or othewise for my 2.0 vtec all moto' project? *your thoughts pls*
- Simple question: can VAFC be used to tune a nonVTEC motor?
- Piston damage pic - funny
- valvetrain? what to do? supertech? ferrea? bc? skunk2? cowler? rev, RM
- ANYONE KNOW A SHOP IN SOCAL HAS A D16Y8 OR A SOHC VTEC MOTOR FOR SELL?
- vtec problems please help!!!!
- K20 swap
- about to start a b20 build need help
- Al Season Coolant?
- b-20 / ls cams
- B18c1: thinking about putting JDM ITR pistons and CTR cams in.. any clearance issues?
- b16 HELP!
- head gasket question
- When taking of the head
- need help with an all motor SOHC that im going to be building
- I need a p&p...
- B16a rebuild... advice/opinions please!
- ls vtec swap
- ITR motor/m22x cams/check this dyno graph
- which way are the pistons supposed to face?
- $45 Honda/Acura Dyno Day! Sponsored by Phearable.net
- Actual bottom-end build
- Injector #1 and #4 not flowing as much as 2 and 3
- integra test pipe
- ctr pistons in a b18c-r
- ls vtec need help with vafc tunning
- need help? Boring a b20 to 86Mm All MotoR SafE?
- question about AN- fitting
- Woah! Did I do damage at Laguna Seca?
- 'Official' Poormans R Setups
- 4-2-1 or 4-1 header
- Where to buy parts in the PA??
- P30 pistons in GSR
- bad numbers
- Check engine light flashes
- new to N/A b18c1 build questions
- Nopi Comp 4 What would make you want to compete?
