PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 [191] 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. exhaust for a b18c1 in an eh2
  2. Whats a good piston for high compression for a low money marketing??? D-series
  3. My new setup is up and running....Check it out.
  4. ls or gsr block
  5. What cams and valvetrain are u allmotor H22 guys using?????
  6. Port and Polish
  7. where to buy 3"-4" mic?cheap So. Cal.
  8. skunk2 cam identification...
  9. venom intake manifold
  10. motor swap 88 civic sedan
  11. is running a header/exhaust combo w/o flex pipe ok?
  12. What kind of mods would it take for a d16z6 into an EF Civic?
  13. new setup in 90 DA
  14. prelude motor experience
  15. ********* RS MACHINE ***********
  16. Motor swap questions
  17. clutch and flywheel combo for s1 tranny
  18. Ceramic or stainless steel headers?
  19. usdm b18c1 in a del sol
  20. need help with engine rebuild..
  21. Getting type r cam
  22. Coil Packs?
  23. help not getting spark or gas
  24. Need to find a good machine shop on the EAST coast.
  25. 12 Sec Hatch
  26. dynos of skunk2 stage 2
  27. JDM B18C5 Motor Q's
  28. 12:1 CR on an h22... it will be done, but i have a few questions
  29. code p1163 98 hx
  30. B20 or B18b???
  31. Sparkplug Wires?
  32. 8500 Rev limit safe on stock b16 head?
  33. Question on ls/vtec build
  34. baseline Fuel pressure
  35. uk civic hatch,
  36. toda b's daily driven
  37. LSVTEC BOTTOM END
  38. I have a quick oil pump question
  39. Cam Gear Design
  40. LSVTEC HELP!!!!!!!!!
  41. Which ferrea valve are you rocking?
  42. Already posted but I'm trying in this forum now :)
  43. GSR GIRDLE, OIL PICK UP, AND WINDAGE TRAY "?'S"
  44. anyone know AMR RACING?
  45. Benefits of new valves?
  46. smoking issues
  47. rev cap. for stoked B16
  48. What set up for 13's
  49. B20A5 What to do.
  50. Best Exhaust Option
  51. Prefered Method of Tuning
  52. need a block....suggestions or advice needed!
  53. building all motor gsr need help....
  54. looking to get clutch/flywheel
  55. skunk2 valve spring quality
  56. are titanium retainers a must have
  57. Is there really a perfect r/s Ratio?
  58. omniman's b16a w/ TECH43 82mm stroker piston kit.
  59. Words from HondaHans' family!!!
  60. GSR B16 head differences
  61. what happens if your ports are to big?
  62. Suggestions on B16A n/a mods...
  63. HELP! My idle in my b18C sits at 2000 RPM's!!! HELP!
  64. crx d15b
  65. collector size of dc headers?
  66. Drag race your all motor car?
  67. crank Qs
  68. What size Throttle Body
  69. f22b wiring in civic
  70. Newb question
  71. Cam gear settings
  72. Shorty header w/ hf versus race header w/ hf
  73. inlinefour.com valvesprings
  74. vtec solenoid broke!!!!
  75. anyone have info on lma's
  76. crankshaft question.
  77. Porting tips???
  78. jun stage 3 vs toda spec c camshafts
  79. Bisimoto, ANR, or what I already have???
  80. engine honing?
  81. h22a accord with itb short vids
  82. project car.
  83. itr /gsr rods?
  84. PCT Piston in B18b...
  85. 2000 gsr with k20 vs crx with gsr
  86. Too Lean or not???
  87. is my car running rich or is it burning oil?
  88. Can a b16 handle LS rods/Crank?
  89. Stock B18C1 & B20b
  90. is there a such thing as a JDM B16 AUTO ECU?
  91. my all motor project
  92. need rs machine phone number
  93. hg leak lsvtec
  94. Having a problem, need some help
  95. b16 pistons
  96. kinda built block
  97. Espelir Exhaust
  98. OEM K series cams
  99. ignition boxes wroth it
  100. Motor building basic questions
  101. ls/vtec problem
  102. F20 in my eg.
  103. skunk2 cam questions
  104. home made itbs
  105. b18b Dyno Numbers
  106. bkr6e or bkr7e
  107. Budget B16
  108. wow! ls teg with type r trans
  109. NEED ADVICE ON SETTING UP CROWER STAGE 3 CAMS
  110. what size slicks? already searched
  111. Smoke when I start the car?????? HELP!!!!
  112. b16 all motor went to the track tonight!!
  113. lift and duration on jun3's?
  114. My alternator in my 94 Civic makes some weird noises!
  115. Jun Stage 3 Camshafts
  116. Es sport question muffler???
  117. Mr. Hyde or Smooth like water: How do you prefer your vtec transition
  118. Plugs burning yellowish side
  119. JDM B18C
  120. best oil filter?
  121. Problems with GEM block
  122. Prelude limited edition
  123. My idle is jumping.................
  124. most popular cams for track
  125. Difference in feel between lsv & gsr???
  126. Velocity stacks
  127. Need info for an All-motor LS
  128. where can i get full engine assembly for reasonable pice "SO CAL"
  129. Anybody??? Buddy Club Spec IV cams
  130. ITB question
  131. exospeed
  132. YS1 Tranny Gearing
  133. Air Filter for intake
  134. Why go all motor??
  135. ls mtx rebuild kit in a gsr trans?
  136. Looking to buy an adapter harness for APEXI POWER FC for 92-95 civic
  137. Buddy Clubb Cams
  138. In think I blew a Cometic Head Gasket
  139. 11.96 with itr cams!
  140. head bolts... is this normal?
  141. my DIY cbr 954 ITB project for a jdm ITR (dial-up beware)
  142. I love eBay...1000 GSXR ITB's on the way...?'s...
  143. rpm limit?
  144. LS/VTEC oil line size?
  145. I really want ITB's
  146. What type of diff is this???
  147. injector size
  148. stroke...
  149. b18b pulleys
  150. Looking for a 85mm headgasket??
  151. WTB: z6 engine harness and z6 dizzy
  152. Fake J's Intake....CHEAP!!
  153. b20vtec, problem..
  154. over heating
  155. 10.5:1....can i get away with 87 octane?
  156. Ferrea valve 6000 series.
  157. Scratch in cyliner walls...LS
  158. MY clutch pedal seem to sink......................
  159. what cams for my street set up?
  160. All-motor LS Question!
  161. any fast sohc's?
  162. B16a head with GSR b18C block: which head bolts, which timing belt?
  163. CTR cams on lsvtec??
  164. Burning oil from block or head?
  165. b20 85mm high compression pistons WANTED!
  166. AN-R headers any good?
  167. skunk2 stage 3... ?
  168. what else can i do to help my h22
  169. Need Advice: PR3 head
  170. pros & cons of overbore
  171. intake systems... crx
  172. jdm itr dyno
  173. identify these cams
  174. how to chip p30 to not detect knock?
  175. velocity stacks
  176. difference????
  177. Idling at 2300-3000
  178. Hondata
  179. Looking for help/advice on LS/VTEC build...
  180. B20Z Sleeves?
  181. Dyno Results B16b swap in a 98 ek hatch
  182. all motor h22?????
  183. Need advice on what to do next!
  184. My car is lacking power and I'm not sure of the cause.
  185. got a newb question...
  186. will my stock lsvtec rod bolts be reliable @ 7.5k rpm
  187. MOTORVATION thorttle body spacer
  188. question
  189. Keeping your knock sensor while chipping the ECU?
  190. ITB Uberdata tuning
  191. ITB's...Hmm
  192. d16z6 head fit d15?
  193. VTC1000C Shadow Spirit
  194. Need info...Skunk2 cams
  195. All Motor H22 Q's
  196. Help Me build a Simple Ls/vtec Setup
  197. porting p72 head, can they port it to optimize the skunk2 manifold?
  198. DIY ITB's, Any Real gains????
  199. ctr pistons in a b16a question
  200. Just joined the 1.8 liter stock piston 210+ WHP club!! AYE!!!
  201. PCT pistons in b18c-r w/ jun3's
  202. RLZ Engineering Head Porting
  203. new tires less rpms???? help
  204. H22A
  205. How do engine builders keep the engine clean while building it?
  206. I need all motor tuning help
  207. head torque 3.5 L 1999 odessy
  208. H22 Tb on a B18B???
  209. are crane cams good?
  210. best motor???
  211. A quick question
  212. Is it bad to stroke an engine and run a turbo?
  213. any one dynoed with a lovefab header?
  214. whats better comp. for all motor build 10.1 or 10.6
  215. running a ctr intake cam with gsr exhaust cam
  216. toda b's for sale
  217. Hayame catback, anyone used it?
  218. A REALLY weird starter problem! (please read)
  219. What kinda cams... Enlighten me, I know nothing.
  220. ls crank and gsr crank
  221. good daily driver n/a setup
  222. 97 jdm b20b oil pump do i need ot replace for vtec. SEARCHED>
  223. 97 jdm b20b oil pump do i need ot replace for vtec. SEARCHED>
  224. compresion ratio question
  225. what is the best intake and header out there right now?
  226. PLEASE SIGN THIS PETITION TO SAVE NHRA DRAGSTRIP "ENGLISHTOWN"!!!
  227. DIY All Motor JDM Piston install.............................:P
  228. CTR ITR SI Head
  229. pwer loss after switching to Skunk2 IM and 64 mm TB
  230. can you ID this cam? jdm itr maybe?(huge pic)
  231. any dyno compairisons of cams out there???????
  232. 00 B16a2 cyl head. still good or not?
  233. I want a hatch bad
  234. CTR pistons, what rods.
  235. fuel pump problem???
  236. USDM B16 Piston Dome Height
  237. stock block gsr, how high can you rev?
  238. jdm b16 - which clutch/flywheel combo are you rocking?
  239. jdm b16 motor, si b16 tranny, which clutch?
  240. We all lost a good friend tonight.(Hondahans)
  241. Turn around time on an An-r header?
  242. slow to rev
  243. what comp are ctr pistons good for in 1998 gsr?
  244. need help fast impatient about motor swap
  245. B16a valvetrain and compression question
  246. Upped fuel pressure means more rich?
  247. import tuner b series shoot out. need info on tool
  248. Petition for Englishtown Raceway Park
  249. zc sohc block d16z6 head ?
  250. 3 Old pistons w/ 1 new piston??
