- Skunk2 Tuner Series Valvesprings enough for JUN3 cams?
- stroker on a b16
- b20vtec timing issue
- What engine oil viscosity to use in a vehicle with rare usage
- My Dyno Numbers
- Question. Upgrading D16z6 Throttle body?
- TB/IM question for 2.0L ITR build
- Fastest OEM stroke B-Series in US???
- dipstick reads no oil. LS VTEC ... help
- -Poor man Type R motor build up?-
- Question! B18C - B18A1 Crankshaft
- Weird "purring" sound, with loss of power
- H22 - Serious issue with balancer shaft!
- I got a question
- Timing Belt & Water Pump OEM vs Aftermarket
- Our B20Vtec build
- B20 VTEC ARP HEAD STUDS
- how to remove crankshaft rear main seal housing ?
- Looking to do some Internal work. B20vtec.
- 3 in chambered muffler vs 2.5 in Straight thru
- omni man spark plug trick help
- Pistons destroyed....what causes this?
- Cam Shaft Failure
- Car won't let me go in any gears
- How far can i rev my block???
- SHort ram intake or AEM ITR?
- quick question about b20 crank
- Oil on spark plugs, car sluggish?
- Skunk2 Header doesnt clear B18c
- Distributer cap obd0 / obd1 b16
- Burns stainless 2 stage
- 3inch thermal on allmotr lsvtec?
- a grrreat idea...maybe?
- Forged Valves needed?
- B16 head work and piston rings, build up process expecting 170whp!!
- Supertech H1002D with Skunk Pro 3 cams
- Is a 8.5LB flywheel okay to run
- help identify these injectors...
- crank wont turn on gsr!!
- I need a setup for B20 Vtech ALL MOTOR
- Valvetrain for skunk tuner stage2 cams?
- B20 with v-tech Head
- New tranny, car feels sluggish????
- Intakes / All the same?
- timesert? best place to buy?
- Adjustible Cam Gears....what do u guys run.
- Replace timing belt or not?
- All motor setup injector size
- engine smokes on deceleration b20vtec
- best cams for stroked b20vtec
- Everything there is to know about fully built and compression?? HELP
- Idling oddities and a limping car (D16- auto) any help?
- RMF Narrow Rep w/ 2 1/5 Collector?
- No fuel cyl #4.
- need help with tuner for my b16a, s200
- Dry spark plugs.. valve guides not piston rings ?
- Opinions on all motor b16
- crower 404's or 405's
- ARP head studs question
- b18b1 vs b20?
- Y8 cam in D16z6?
- anyone running TWM itbs?!
- Fitting Toda B18C ITB on a K20a?
- LS/Vtec Problem-o's
- Help for building engine (Pistons & Cams)
- fj distributors and acl company product reviews
- degreeing blox C cams
- I have an LS motor what else should there be for make it a fun ride?
- rsx type s retainers in b series? the valve springs?
- b16a crank in b18a1 block?
- mysterious engine problem .....
- How to fix a seized motor (I need help!)
- 200whp..Stock Injectors Enough?
- b18c5 with 99 b16 head with blox b cams, spring, retainers dyno?
- MY EXPERIANCE WITH EBAY ERISTIC HEAD GASKET
- Header help. Which one to choose
- Fitting cast pistons on eagle h beams
- b18c1 leaking oil
- DIAGNOSTIC PLUG?
- SHOULD I GET ADJ. CAM GEARS???
- Stupid mistake made during rebuild....
- Buddy club race header questions
- Building motor.Is Balancing needed?
- DO IT DYNO
- Crower Stage II Cam=ROUGH IDLING??
- b18c high compression & nitrous
- high compression.
- I'm at my wit's end with my car: Idle problems <-- Help
- ITR Mugen 4-1 header VS RMF Narrow Rep Header Flow Theory
- Piston to Valve Clearance with Skunk2 cams
- probllem after rebuild sorta need guru's
- H22A4 Build help
- Highest hp stock block h22 ever!!!
- 95 Teg w/ B16a
- skunk2 stage 2's = 220 whp?
- Whats rods to buy?? and crank help??
- B20VTEC broke an axle :( (Dyno & Timeslips)
- valve springs bind
- Compatible HEAD??? engine missing.
- questions about n/a ls
- Which Header ???
- another ls vtec build :)
- A'pexi WS2 muffler core?
- can you re-use main bolts?
- Headers for B17a1
- time to retire the ITR rod/piston 1.8 bottom v. B20VTEC
- EK hatch w/ LS swap accelerating/engine surging problem
- its safe use Pro3 Cams with Skunk Tuner valvel spring
- b18cR build...cams/valve-train
- Fresh b18c1 build no oil pressure help
- Engine restore fix rings that wont seat ?
- Y8 Cam>Z6 Head
- help head coolant leak
- breather vent setup
- jdm b18c build
- ek b16 axle comes out
- WHP FOR B18c BUILD
- Megan racing B series header? Test pipe?
- d17a2
- cam advice
- C Clips for Rs Machine Pistons
- easy timing belt question......
- not getting accurate readings from my 3 TPS sensors!! wtf??
- Input needed on NA F22B2 build
- 200-210 possible on stock ITR cam
- high flow
- 81.5mm Poor man R build/Dyno
- VTEC oil pressure switch obd2b
- *TRYING TO REACH 200+WHP ON MY ITR* HELP ASAP
- need help testing dizzy
- Whats your idea of a 250hp n/a build B18c1
- Skunk2 torque specs??
- cilck here..need help on my daily drive build up poors man type r
- Machining depth limit tabs
- differences between honda obd1 injectors??
- D16 burnin oil like there no 2mm!! Help
- N/A B16A Buildup
- poorman type r loosing compression!
- N/A LS Build - 94 Dx hatch
- B16 put together and runs like ass
- itr pistons and rings question...
- What should I be expecting???
- fuel injector Q's
- Pros and cons of running CrMoV retainers vs TI retainers.
- 2010 All Motor Header Test- Gauging Interest.....
- Knocking h23a vtec
- skunk2 cams
- can i use a 84mm hg ona 84.5mm bore
- Piston ring Material.
- need some help with adjusting cams
- H2b
- safe bore size for stock sleeve? b16a
- i want to make 200 whp and raise my tq
- b20vtec
- ...about B20F
- B17a1 All Motor Help
- building my spare b16. racepak's first NA project :)
- ATI Street Damper install
- D16 engine build questions
- How to tell if my valvetrain is Omnipower?
- 211 HP WWWWAAAAACCCCCKKKK
- stroker kit?
- Can you find the problem in this picture?
- What headgasket??
- DIFFERENCE IN CRANKS
- Gsr feels worse than a b16
- any one can tell me what this is?
- so what cams
- crankshaft question? please help...
- Carnage pics, what caused it?
- Aem ITR vs Injen ITR? Cold air intake
- V-TEC swap piston question
- b16a2 headgasket choices?
- ?automatic jdm gsr valve springs
- b16? what you guys think of it????
- WEAPON R HEADER QUESTION
- Cams Choice RM M24X ; PRO2; PRO3
- timing b16a ctr pistons
- VTEC
- HELP, BEST INJECTOR SIZE FOR A B16 NA
- where to get replacement Skunk2 cam gear screws?
- Fake Skunk2 Pro intake manifold alert
- Head Gasket Question
- ls vtec n/a need ur advise
- B18c1 block, B16 head, ctr pistons
- h2b dead injector help?!?!?
- Looking for advice thats it
- 500hp all motor b16
- Quick B16 question
- valve guide clearance
- what assembly lube?
- Building NA F22B2
- M22x Exhaust cam
- b16 rev surge?
- LS VTEC bogging out of VTEC! Help!!
- 94 gsr swap
- RSX-S: Cams & Spring & Exhaust Install / + Kpro Tune
- GSR build advice...
- need outer diameter for type R Throttle body
- Need help picking a clutch
- N/A H22 build help
- Heat wrapping Intake
- Reliable east coast engine supplier?
- B16A JDM rev limit
- aem hybrid intake vs Aem Itr intake
- 95 gsr in 95 civic (ej1)
- Anyone using Ferrea 5000 Series Valves
- Fuel pump failure question
- My b20v future build!!help?
- In need of some assistance
- Main causes of dropped valves?
- all-motor LS
- B20 Vtec Or B20 Cammed?
- compression test wet and dry.
- B18C5 question?
- harmonic balancer question?
- performer x or victor x for my setup
- What year tsx chromoly retainers to order for b16 head and where...?
- What cams for my all motor H2B Build
- RS machines type r pistons
- what engine would be better
- Explain to me what a valve guide seal is
- endyn girdle installation
- Overheat opinion track car. please chime in
- Carrillo Pro-A rod question
- ITR B20 VTEC
- idling high wit 70mm throttle body..need help
- B18c1 or K20a
- b16a build questions
- Need more torque!!!
- B18a1 build
- b16a starter/ alternator
- Engine Management
- B18C2 Build
- Engine rebuild and feels slower/worse
- Loose oil clearances?
- prelude SH motor ---> EK chasiss
- knocking noise, cant figure it out!! help!
- all motor b16a build
- Big engine block problem.Need help. 91 ex sedan.
- 95 gsr putting
- bore spec confusion
- B16a drag motor Help
- Identify this cams
- Valve Train Upgrade Questions
- Cam cap torque and valve lash questions?
- Conrod And Piston Weight
- switching over to b20vtec build!!!! advice plz
- smog hook up
