- go with gsx itb or skunk manifold?
- official all motor street car pics and times)))))
- Wrist pin/rod alignment.
- ? Stock GSR head on GSR or Type R
- B18c1 build...whp #'s est...
- how do you take out the pully from the crank that the t-belt runs off?
- Please help me find the right cams!
- Cam question, read! :P
- help with sk2 throttle body
- RHS HONDA B-SERIES VTEC HEAD
- ITB's
- 223whp B20VTEC, 84.5mm, NO ITBs, pump gas....check it out
- Has anyone ported a Skunk 2 IM? p72 head..
- Reasonable price for the following motor??????
- Head Milling/Compression question
- ALL Motor B18C5
- Is all motor really powerful?!!
- M22 M22x cams in b18c1, gen1 or gen2 springs?
- can I hone a b18 block, and still run JDM ITR STD size pistons???
- help on gsr...
- Vtec head Question
- Distributor King Dizzy: Ignitor Replacement
- How much money have you sunk into your all-motor build?
- Stock LS/vtec times
- Gsr Block w/ 81.5 mm Bore. What size CTR pistons??
- HELP....high and rough idle at cold start...Y??? HELP
- H22 ALL MOTOR!! 243whp / 192tq custom manifold
- KMS Valve train?
- LSD Gear Oil...
- Jedi Training
- H22 Header Question
- need help with dyno results asap
- b20 build up gsr or si
- 200 whp b16 on stock revs possible ?
- Cams for b16a2
- Coupe of ?'s
- bout to start getting parts for my LS/VTEC... need to know if im missing anything.
- ITB's or B16 TB?
- Raised pin piston
- Trade: My b16 a swap for ITR Five Lug Setup with Wheels?
- u wanna see somethin hilarious?
- black exhaust crap??
- Jerry Built Or Bubba Tunned???
- how much power?
- h22 setups
- CTR pistons in a b16a3
- spoon headgasket with lsvtec setup valve clearance to close yes no?
- P29 Rods in d16z6
- Headertech 4-1 header...?
- have some noob questions on a deck plate
- EF9 noob...
- All Motor Build input is welcome
- B18a rods?
- What kind of numbers can i expect?
- if you're using racing gas what o2 sensor do you use?????
- Will it be safe to run B20Vtec like that?
- how much hp would i get out of a stock b20
- HOW do u read timing on h22a crank pulley?
- knocking noise from GSR head?
- Need help..low DYNO numbers
- Intake cam on exhaust side?
- help on allmotor build
- NEED HELP SELECTING B20 VTEC SETUP!
- S2000 Exhaust
- Extrude Honing IM...
- Will it be slow..?
- Ls/Vtec with chiped P28 ECU having fuel problems
- DOES ANYONE HAVE NA CUTIES #??
- bucking and surging PROBLEM code po502 honda passport 1999
- Which cams to use on LS-vtec?
- piston choice help (itr's or ctr's)
- K24a Fully built Dyno - k20a.org Spec
- JDM Integra Type R with B-18C5, wich cams???
- Is My Compression Fine for Skunk2 Stage 2 Cams ???
- Champion spark plugs
- AN-R Compact Header Question
- Ok, time to build by exhaust...
- Stock Bottom B18C1 All Motor Build
- vtec killer compression question
- how much is a b16 block worth?
- vtec cutting out
- which cams on this 1.8l ls/v?
- How Much Power!!!!!!
- IAT sensor
- Los Angeles or San Fernando Valley Builders ...
- b16 Build Sheet....I have a few questions....trying to reach 225 - 230 REALISTIC WHP
- Anyone heard of V-Bros headers?? Randy, Dave??
- Smoking, b18c1.. story inside. HELP please
- Broken spark plug, A few questions, Pic inside.
- why do i stop making power at 7200rpm 197whp 151tq
- Just got Rocket M22s Is this normal???
- phantom grip rocker arms,chewed up exhaust cam....HELP!
- Built ls-vtec 85mm, what cams to use?
- need help wit gsr
- need toda c specs
- Cam timing SoCal
- Toda valve spring for skunk pro2 ??
- Vtec Not Engaging Properly .... NEED HALP ASAP !!! Already searched with no luck
- B18c1 head rebuild
- crank weight question
- NEED HELP QUICK Arp gsr rod bolt torque spec!!?????
- my new setup
- max streetable comp. ratio for all motor B18C1?
- Timing belt issues
- Offset grinding an H22 crank: Discussion
- bore spacing for B18c5 ITR engine
- B16A1 vs B16A2 cams
- What cam to use that makes good power?
- what times should i be looking forward to in my eg hb with jdm b18c
- What else can I do to extract some more power
- THE VALVE TRAIN POLL
- Simple question about silicon connectors on air filters to T.B.
- Open exhaust vs through the muffler on the 240 HP 1.8 ITR-more graphs.
- new help in choosing engine build up
- mini me...kinda
- valvetrain breakin period?
- need help
- ODD Compression numbers, I'm confused!
- Which one for motor Swap B18C1 or B16B ? more torque or more Horsepower?
- Hytech header: Is "heat wrap" actually bad for the header?
- Gapping plugs..
- Toda header on K-series
- ACL race rod bearings
- 87 octane gas in CTR piston NA LS set up
- Best tranny for drag racing?
- Burns Stainless Tri-Y 304 SS Road Race header for a stroked B16
- How to solve piston deck clearance of 2-3mm....help needed..
- Just my luck - ALL MOTOR B20 problem:(
- 250whp DD, All motor. Help
- ITR TWM ITB's. FPR?
- Question on Honda Tall Block.....Help needed!!!
- CTR b16b Head Q's
- Valve Spring Decisions...
- 14 flat with 93 integra
- Swapping Valves - Do I need to redo the head's valve job?
- Finally got my ITR running again and tuned, 243whp graph inside
- HELP NEWBIE WITH ALL MOTOR BUILD UP!! Money to burn need guidence and direction
- internals or bolt ons....
- Help me hit 200whp w/o touching the bottom end!
- b20 vid
- Now, Rod Bearing clearence.
- cams choice need help what to choose
- LS/VTEC DONE!!!11
- Need Help ASAP
- would i gain from this???
- What do I need to make my ITR motor a 2.0 litre?
- What pistons do I have?
- pistons and compression
- Friend Blew a JDM TYpe R. Ideling.
- Will Jg valvetrain withstand skunk2 cams???
- Dyno Numbers?
- 200whp b16?
- Over-rev my motor….. Bent Valves?
- whats the difference if there is any
- bc stage 6?
- New LSVTEC Dyno & Spec Sheet
- Would 84.5mm pistons fit in a 84mm bore?
- Engine builders! I have some???????s
- OEM Starter? When should you start worring about it (i.e. what cylinder psi)?
- Tbone's UNTUNED Skunk Pro-3 cam Dyno
- b18b respond
- eg or ek??
- head identification help!!! PLEAAASE HELP
- I NEED SOME HELP ON WHAT I SHOULD DO
- DOHC ZC ????
- loosing clutch pressure
- ls mount
- Where Did You Mount Your Breather Kits??(Pics Please)
- need some advice ?
- f3000 crate motor b series Toda/Mugen
- will b16a3 pistons fit on ls rods
- stalling help
- Question about zex 59300 cams
- Is this injector still any good?
- NEW 1.8 BUILD
- buddy club spec 4 cams, vafc2 and 550cc injectors?
- need help on parts to use
- To all you guys with custom exhaust, how did you guys go about getting it to be super quiet?
- f20c in a hatch
- Danger running with broken LMA's???
- b16 vtec crackin
- Oil problem(help)
- what mod should i go next ???
- K series Cams
- is this true
- ls water pump question
- gsr engine in ek, any test pipe long to connect to pipping?
- Adding a ECU LED to the dash?
- should i use p30 pistons
- since "bserious" wont answer me.
- All motor or Force fed turbo B20?!?!?!?!
- Finally, our K series Build starts
- SKUNK2 STAGE 2 CAMS
- bc3+ what vtec x-over (only temporary)
- engine surge problem...??
- What would spoon cams be compared to,other cam wise.
- Built LS/VTEC 192whp & 127wtq (with no top end power?)
- ls/vtec good or bad combo?
- ls/vtec why????
- act 4puck ?? bad or good?
- CTR pistons do-able in a b18c1???
- Pictures of my cylinder head
- b20 rods same strength as ls rods???
- Anyone got a some some specs for lsvtec???
- HyTech Headers just received! (1.8L Build Up Cont.)
- Low cam lobe damage...pitting. WTF?
- more horsepower for my sohc zc motor?
- Running lean
- stand alone ems
- I'm Tired of Pushing My Car...Help
- Omni ?
- 86mm b16 with 92mm crank
- Custom intake question?
- what to do...
- vafc mounting pic request or suggestions
- B20 + B16 = ?
- All Motor LS, taking wagers
- have my 98 ex-v6 check engine light on!
- B16 and ITB's
- B20 and B16
- B18C Build...numbers HIGH-LOW-Average?
- 1400mile road trip at 5k constant
- RMF Headers?
- Not sure what to do/what do I need for this compression?
- ls block, 95mm crank, 1.54 r/s ratio?
- all motor is for fuckin pusssssssssies!
- is this head salvagable?
- b18b stroker kit
- skunk2 stage 2 on ITR springs/retainers???
- Does Prelude f23 have thermostat?
- Main bearing clearences.
- squiking itr throttle (power loss)
- please need help i have a 98 civic and my 94 integra motor does not want to turn on
- best compression for daily driver?
- iacv question
- Hey Rocket (or RM rep) - Can I use a Skunk2 Valve Train with the M22xx's?
- whp question
- Why the power loss?
- My RLZ re-worked Head, Flow numbers and Pics, dynos to follow
- TODA spec D cams
- Collector Size?
- 440 or 310???
- Why is my torque dropping off so much above 6000 RPM?
- dohc zc or d16z6 for all motor
- stroker kits
- yo hookups
- what ecu?
- RMF = Randy Monroe's Finest
- "B" OR "H"?
- wooooow!!!
