PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 [132] 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. need some cam specs
  2. level of hardness ls/vtec swap?
  3. Stainless RMF to top off the big block
  4. 55mm or 60mm exhaust
  5. Impressive H22 All Motor Dyno *inside*
  6. Buddy club Spec 3+ cams ?s
  7. new stats on the new motor
  8. Question about installing Type R cams in GSR...
  9. Password JDM/J's Racing intake
  10. Extra Clearance Bearings?
  11. stock b16 head gasket thickness vs. mugen thickness
  12. I just ordered my TURBONATOR!! Time to prove them wrong! 35hp GAIN!!
  13. Inlet manifold, short or long?
  14. Keep 2.25 inch or go 2.5 exhaust piping on a mildly built B16A?
  15. Those w/ 85mm bore, what headgasket are you using?
  16. pistons?
  17. what can i do to my b16a block before i put it on besides machine work and ctr pistons?
  18. colder spark plugs dseries turbo
  19. all motor h22 dyno chart
  20. another ls vtec ?
  21. Thread pitch on cam cap bolts?
  22. Bullfrog Cams taplets adjustment
  23. yet another cam question
  24. head gasket question
  25. Which oil pump?
  26. i need help it a 1987 porsche carrera
  27. Piston removal question.
  28. Compression vs cam timing
  29. Wondering
  30. ls/gsr fuel systen
  31. header decision???
  32. TWM ITB Injector seals??????????????
  33. RMF Narrow header and exhaust fitment
  34. best all motor set up
  35. B16B pistons in b16a block..in our out of hole???
  36. are my itb's two small
  37. a ctr pulley on a b16
  38. B18C1 not starting.
  39. Valvetrain suggestions for JUN Cams in H22A?!
  40. Raxels Question
  41. Swapping F22 for H22 rods for higher compression?
  42. Aftermarket air intake manifolds jg engine dynamics,skunk2,aebs,golden eagle
  43. b18c5 shortblock - with 00 Si ecu?
  44. What engine management system options for a 03 CL Type S V6 w/ 6sp trans?
  45. steps/procedures to changing gsr pistons? tools?
  46. bad to run open header?
  47. DIY Busa ITBs on an H22...do they make power?
  48. Painting Header, Gold/Bronze Etc
  49. timing belt installation
  50. head question
  51. BC Spec III Pro Spec Racing Spec Exhaust - Should I? - Pls read
  52. DONF In Jacksonville FL DFE DFE DFE
  53. recommendations on an LS/VTEC
  54. rings not seating? re-hone AND rings too?
  55. Writing my paper on Honda-tech
  56. new dyno results
  57. Head coming off, looking for 200whp in the future
  58. civic killed!
  59. E-manage Ultimate Questions / Issues
  60. jun3s vs skunk pro series
  61. <<WHAT IS REQUIRED to have your vehicle tuned on CROME-PRO>>
  62. injector size?
  63. D16z6 pistons/rods and mods. oh yeah and a question.
  64. back from the land of boost....
  65. PCT pistons, Skunk2 pro 1 camshaft, B18C5
  66. B16A with Skunk Pro1
  67. Ghetto stroker
  68. What's faster?
  69. Looking for a GSR or TYPE R COMPLETE swap for an eg(93 civic hatchback)
  70. Whats the best LS VTEC Kit to buy?
  71. ticking
  72. b20vtec ?
  73. ARP head stud and rod bolts
  74. bisi hooked me up with my rs machine cams
  75. quick question.
  76. B20/VTEC sleeves strong enough for high cr pistons?
  77. Assembling GSR short block, crank won't sit flat...help
  78. gsr compression
  79. d16z6 head question, what is this!?
  80. TWM sticking ?? solutions ??
  81. ctr intake cams on my c5?
  82. B16A3 with CTR pistons Question!
  83. What Exhaust System R you Running????
  84. cam gear 0 ?
  85. JG engine Head work?
  86. cam polls Toda Spec C or Skunk2 Pro2
  87. k20a2 dyno
  88. Omni test pipe?
  89. y8 Block/ZC Pistons/z6 head
  90. 93.5mm offset Bore K20 race engine
  91. ls/vtec question
  92. Header Test Repost (RMF,SMSP,Hytech,ANR, DTR, DC)
  93. want to use 1 layer hg.....
  94. gains from an SAFCII
  95. groung wires
  96. Head Gasket thikness?
  97. b20 want more power
  98. who makes the lightest flywheels
  99. rebuilding ls motor
  100. Good tune/flat curve = reliability?
  101. new aem ignition coil. Twin-Fire Capacitive Digital Ignition Module
  102. ITR valve spring install. I need a Q answered.
  103. B20/VTEC, what spark advance should i run it
  104. Mugen chip or Hondata?
  105. fuel injector question...
  106. JDM Shit products?
  107. ls-v keeps shuttin off
  108. ls/vtec oil line conversion?
  109. WTD :INFO: H22 Flywheels
  110. K24 Dyno, DTR, TWM, KPro
  111. bay area mechanics
  112. Got A Question About LS
  113. Build Advice Wanted!
  114. LSvtec spitting code 4? need help!!
  115. buddy club spec 3 timing??
  116. skunk2 mani + itr tb won't match up
  117. which flows better, JDM ITR Intake manifold or the AEBS Intake manifold
  118. N/A Map sensor going crazy.. which route?
  119. Blox B or BC3+ cams for my setup?
  120. greedy header
  121. how soon should i change out the oil after rebuild?
  122. HELP!!!...oil pressure very low....is it normal???
  123. 96 ex SOHC VTEC BUILD, smogable.
  124. tech43 b16 stroker
  125. Low Compression in Cyl. 4. . .Head gasket, Rings, Valves?? Need Help!!
  126. SKunk2 manifold install on 01 GSR
  127. cost of engine swap
  128. cam polls on 86.5x87 13:5.1 setup
  129. k20 in a dc2 instead of ek?
  130. Running 91 octane Bad?????
  131. got it all together, need a little help
  132. Relocating fuel injectors makes more power???
  133. Nology Hot Wires y8 spark plug wires on a Z6
  134. anyway to tell about skunk 2 LS cams
  135. Question A Deal On Ls/Vtec Or No?
  136. all motor building tutorials
  137. vtec problems on GSR
  138. best bang for the $$
  139. Looking for 11 to 11.5:1 comp pistons for lsvtec
  140. itr cam with cam sproket
  141. need tips for good dyno results tomorrow
  142. H22 NA project went bad (blown engine)...advices needed for 250whp.
  143. recomend spark plugs please.
  144. Some feedback for an ls/vtec
  145. 96 ex 2dr parts
  146. carb problems on 2nd gen prelude
  147. where would i?
  148. gsr cam question??
  149. where can i buy a b18b 98+
  150. sohc non-vtec high CP pistons question
  151. gsr block b16a head questions HELP!!
  152. skunk2 ecu
  153. Help my determine CR with this setup?
  154. b16 piston's in a gsr engine
  155. ITB's/ running without filters
  156. P30 piston GSR Blox B
  157. ls/vtec swap with gsr head butterflies question??
  158. itb's
  159. Honda main bearing?
  160. 2.5 inch collector stock cat
  161. fluidyne radiator? fan question with rmf narrow-link to pic
  162. dtr narrow- fluydine radiator? clearence? - link to pics
  163. eagle lighten crank..good or bad??
  164. H22 Idle Probs....
  165. Difference in CR with ITR rods/LS rods?
  166. 403s revving to 7100-7200, valvesprings needed?
  167. B16 a tuuning/mods
  168. Toda C, Buddy Club Spec IV, or JUN 3 cams on 12.1 compression sheets?
  169. oil pan question!
  170. Endyn or CP pistons
  171. getting more power out of a zc
  172. B16 Head Shaved How Much?? How can I tell??
  173. piston CR question
  174. How strong is an ITR crank? Crank gurus chime in...
  175. Fibertuned Carbon intake manifold. (AIR typre clone)
  176. JDM B18C5 Question
  177. HKS 268 Camshafts for ZC? what HP?
  178. blew my motor, what are my options?
  179. 17 lbs broke a cam
  180. ITB'S
  181. Jdm B16A Bolt-ons?
  182. D16a all motor build up
  183. D-Series Builds
  184. intake cam wont spin
  185. ARP or EAGLE head studs
  186. Buddy Club Cam Gears BREAKING?
  187. what kind of numbers will i see
  188. ITB MPG
  189. OE Type R injector size?
  190. Question about dynographs...
  191. AEM V2 OR REG. COLD AIR?!
  192. header choice? Cam choice?
  193. Valve Clearance?
  194. CTR cams, how to be sure? and, stock springs?
  195. H22 Balance Shafts and Fluidampr
  196. b20 modifacations
  197. need help for gsr setup
  198. Timing belt
  199. gsr engine
  200. Bunch of B20 questions.
  201. trouble with cam timing
  202. some questions
  203. Ls/Vtec with ctr pistons
  204. Head stud Question... Custom... or is it ?
  205. Hitting the Dyno for tuning soon...What #'s should I expect?
  206. rage header
  207. ITB's & Hondata stage 2 (obd0) possible?
  208. b20/vtec questions....searched
  209. Tsudo N1 Exhaust
  210. Stock Motor is getting some internal love....questions for All-motor guys inside..
  211. is there any way to test out a msd blaster coil with out actually hooking it up to the dizzy?
  212. H22 Axle popping out of tranny I searched hours need help asap
  213. which header for me???
  214. 82MM Q's
  215. 94 vx b16a2 ?'s
  216. an-r header question
  217. What rods with 92mm crower crank??
  218. new h22 all motor dyno
  219. Which cam is the best "drop in and go" cam?
  220. RM M22's, Toda Spec C's, or Buddy Club Spec 4
  221. SKUNK2 PRO SERIES! H22?
  222. ctr pistons?? timing ??
  223. 28" resonator...
  224. What power from this setup - bought complete engine, approx power? ITB's etc
  225. How's this setup sound? Help a newb out.
  226. Thinning Center divider (head port) good or bad... opinions and suggestions...
  227. Finally Done LS/VTEC
  228. want higher compression
  229. Buddyclub spec 3 + or Skunk2 stage 1??
  230. B18b to obd 0 HELP!!!
  231. building a B18C4 for race what size ITBs to use ??
  232. 3 Angle Valve Job...
  233. different between the engine of integra 96 type r and 98 type r
  234. Do I need to upgrade my fuel system?
  235. C-speed compression calc correct?
  236. is this normal ? Maxing out 240CC on B20vtec on "Vtec" ? "see inside"
  237. 200hp pass emmisions?
  238. can i run rc 550 injectors in a 1.8 allmotor build
  239. Blox HSL cam
  240. Well guys im back to NA no more boost for me. ?'s on new build-up
  241. Q on changing pistons
  242. Exhaust question --> 2.5 inch too big and too loud?
  243. wut itbs?
  244. How quick do you think I will be?
  245. where can I find a Mugen N1 ECU for the ITR for a good price?
  246. Combustion chamber work... What should this run me?
  247. Dh Racing
  248. Topline rings are sucking really bad. Oil being burnt like a MOFO.
  249. 0-60 and quarter mile times
  250. take a layer off oem HG?
