- ALL MOTOR / Money Spent / 1/4 times / specs Vids / timeslips would be good..
- b18 head
- Help with my transmission please
- TB Spacer
- ITR Cat going on a NA build...anybody know the dimensions of it?
- 220 WHP set up, what cams/header
- GSR block with P30's, how much can I deck?
- Anyone else besides ENDYN...........
- what are you all motor gsr crx guys running?
- Valve Lash
- Toda B's Vs. Pro 2's
- b20b/b16a head in eg with itb's
- b17 connecting rods question
- 4-1 or 4-2-1
- civic si 2005 what can i do ?
- oem bearing part numbers
- p30 pistons or ctr pistons
- any ideas on this set up
- Injector Question
- dc header
- What is the lift
- How can I maximize the Hp without Turbo charging a d16??
- dyno of 94 gsr tuned by Eugene from prostreet import
- any ideas on a all b16a2 build up
- HELP PLEASE THERES ANTI FREEZE IN MY OIL!!!!
- Another D16A6 build
- Primary lobe differences on Skunk2 S2 vs. JUN III
- B16B Dyno Plot
- Any problems running single layer head gasket
- mugen intake vs. comptech icebox
- 200whp with bolt ons
- Milled head TDC
- roller rocker/ roller cam setup
- loss of power with the A/C
- Whats the deal with my plugs & wires? Pics attached.
- B20VTEC experiences with stock block
- is it possible
- Question about mixing a stock ECU + bigger injectors
- fuel pressure drops quick once car is shut off..
- Tbone's Dart build TEARDOWN. pics inside
- Header Fitment problem....Please Help AM guys!
- SOHC BUILDERS
- which block for my fully built head
- header?
- Swap Question
- timing belt problem help!!!!!!!
- 97 type r tranny. What axles?
- Kind of a silly question about cams
- Clutch and Flywheel Question
- brand new...
- Mustang Throttle Bodies
- Cam Seal Question
- just got back from the dyno, what do you guys think?
- Motor Specs B18B1 B18A1
- 5w-40 oil
- HYTECH, SMSP, DTR header. Where to buy?
- low 12's!
- 12sec civic cx
- All problems with Dart Tall Deck block.....
- expected whp?
- Problem fouling plugs! running ITR pistons in stock rebuilt B18C1 HELP!!
- Torquing down headgasket.
- Greddy DT muffler
- Putting a 2.0 header in a 1.8? possible problems?
- daily driving on Buddy Club spec 4's?
- my friend needs help with ls/vtec
- Who makes the best allmotor header
- YAAAA! got my new RMF narrow for my 2.0L gsr!!! (pics)
- Do I need aftermarket valves?
- NEw here important question
- New Project: All Motor B16
- ls/vtec question
- Hondata?
- Clutch Problems for LS, NEED HELP
- line boreing ?
- b series tranny casings interchangeable?
- itb's tuning
- K-series: DRT simple build K24
- clutch ??? what kind do u guys recommend ???
- what trans are u guys running...
- ITB specs + motor set up ----- post it!
- bad lsvtec track times need help
- a lil help
- !ll W!ll's B16 All-Gerbil dyno results w/ ITB's
- need suggestion for motor selection
- another ctr build
- b16 head/ gsr block
- hot tanking parts for a rebuild
- poorman's type arrrgh.
- apexi header?
- gsr all motor
- Point me in the right direction.
- anyone running Scat crank/rods?
- 2 gen b18 swap
- stock b17 with Blox Type B cams
- build a d15 or d16?
- OBD2A in a 2000 Civic EX(OBD2B)
- Valve adjustment H22a Question
- Need opinion on timing belt
- HELP!!! CTR or Oversized ITR Pistons Pass CA Emissions?
- b16 Stoker kit
- Jeff Evans and JE Import for engine build
- 2.0L Integra Type R Dyno Sheet 223.2whp / 162.2tq + video
- Skunk2 Pro Series 1 cams in B18C5
- buddy club spec 3 (NON PLUS) cam specs
- jdm shit header?
- Vtec Killer Cams
- gsr secondary bufferflies, why is it so bad?
- Buliding my Motor, JDM B16, Help Needed
- Will an ITR Throttle body make a difference?
- Obd1 in a ob2 car?
- Read Me: repost of phenolic
- Help with cam choice and setup choices.
- diagram for re arranging the clutch pack for KAAZ
- mx22 with toda springs??
- anybody have a apexi V-afc controller ???
- ITB dynos--filtered vs air horn
- B16a head build... What do you think?
- B18A1 84mm Bore Headgasket
- B16/gsr intake bolt pattern same/different...................?
- Break Engine running Rich? DRiving for tuning day - guru's help this guy out...!
- intake mani
- OEM Honda/Acura Valve Springs Questions...need confirm.
- To test pipe or not to test pipe, that is my question!?!?!?
- stock muffler??
- Where can I find the instruction manual for this?
- do I need a block girdle
- prepping ecu for hondata s200?
- jdm b20b vtec question???
- can you tell a type r cam just by looking?
- LSVTEC sep up!!!!
- what intake manifold for built b18b
- b16a on engine stand??
- Ignition Issue *Vid*
- Flange Difference, GSR vs b16/ITR
- My LSVTEC on the dyno, video coming! 11,000+ RPM!
- Bought a new header...
- DC 4-2-1 header
- Help with cams
- LS/VTEC Help
- B or K series: Most competitive setup for Honda Challenge H1 in ITR shell?
- CTR pistons & B18C1 or B18C5 bottom??
- GO!!!!
- LOW IDEL ON MY 2.0 ALL MOTOR
- Toda Header with a/c?
- What size itb for my na d16z6 (have research)
- Password JDM IM gasket larger than holes on Sk2
- Odyssey with f22b guzzles fuel??? Heeellp!!!
- Oil leakage after head job...
- F22a4 Compression?
- Toda Headers
- b16 or itr pistons???
- Best B18?
- what cams are these??? :S
- anyone with 200whp have a 68mm throttle body?
- My Daily 82 mm GSR build up
- problem! just installed my s2s2 cams and camshafts
- Cam Caps
- skunk2 stage 2 PRO VS stage 2 no PRO
- head assembly
- ATTN:hookups, Rage,RMF, SMSP, Rocket,REvolt,DonF,Sheepey, etcetc
- SEARCHED-HOW TO IDENTIFY B16 TRANNY?
- clutch decision for ls vtec
- JDM GSR stock bottom build
- Height of the Honda Dart Tall Deck block....HELP!!!
- Ls/vtec headgasket?
- First time JDM B16A swap??? anyone please???
- Is 68mm tb too big for B16a???
- AN-R side exit header
- What is needed to install LSD in cable tranny?
- p06 Ecu in a B18c1/b16a2
- how can you tell if it's skunk2 cams??
- b16 idels loww on cold start....
- Exhaust manifold studs?
- My NA GSR Setup
- Skunk2 Stage2 idle question
- wiseco or oem pistons cspeed calculator????????
- All Motor Integra's DC's
- For you homemade ITB guys....
- P30(JDM B16A) Pistons do they fit B18C rods?
- Engine stored, time for assembly .. q's (ring seat etc).
- Aftermarket steel retainers?
- Small cam and high compression
- kaaz vs. quaife vs. stock
- head gasket help?
- high compression b20 ?
- pully kits
- 00 civic ex. next swap/build obd2 to 1 deluma
- in need of input on camshafts and other
- need higher compression
- ECU for a ITR
- Zero Compression in Cyl#1.
- b20 first move to make
- b16 build up plans
- OBD-2 and modifications
- Motorcycle oil?
- EXEDY HYPER SINGLE CLUTH KIT stage 3
- Are all aftermarket throttle bodies the same?
- LSvtec stalling?
- What length resonator should i run? 14 or 18 inch?
- mild build 211whp
- cams
- Camshaft and a micrometer
- **PlEASE READ** Wierd request
- High Reving motor 11k +
- When building an NA motor...is there an ideal intake manifold----stock/aftermarket?
- Ls/vtec rod knocking
- will b16 head studs fit gsr
- what cams should i use in my lsvtec swap
- quick question about keepers
- CTR TB vs 64 MM JG TB?
- HYTECH K-SWAP HEADER VS RCREW K-SWAP HEADER
- Need help choosing b18 vs B20
- Can i Use Stock headbolts?
- ITR Cams
- 200 whp on oem parts b20/vtec?
- N/A BUILD UP.REAL WORLD EXPERIENCE/CAMSHAFT INFORMATION
- first header
- Gauges, gauges, gauges
- b20 with b18c head
- cam timing
- JDM vs USDM p30 Pistons
- Can anyone ID a TD-48U distributor?
- I have a gearbox problem, please help me
- Low voltage to O2 sensor
- going all motor
- Civic Type-R pistons and rods, how much horsepower can they withstand.
- Compression Too High??
- LS VTEC what kind of ecu should i use
- what is up with that Rcrew swap header for civic. ????????????????????
- Mistaken rod knock for something else?
- what combination for gsr motor rebuild
- Check Engine light@ High rpm?? Need help ASAP
- auto tranny swaped to a 5spd
- which ecu ???
- B20 Sleeving?
- Is a high-flow cat worth it?
- Skunk2 pro dynos???? post them up
- which cams junIII or skunk pro1or2
- Best Price with Best Quality O2 Wide band ??
- type r header vs comptech header
- A taste of my latest street build....
- Sneak Peak - ranta18's H22 All-Motor Build
- Is the Vic. X to much for my set up?
- can itr rods fit ls motor?
- anyone know what skunk2 pro3s make rpms up to
- quick ls/vtec sensor question
- which sms header multi piece or welded
- what do u guys think of my setup?
- LOOKING FOR LSD!!!
