PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. ARE YOU KIDDING ME?!? Please help, I don't know what the frack this is......
  2. b18b wont start oil in spk plugs
  3. tb edelbrock 70 cuestion
  4. ITR cams in b16 head
  5. blox valve springs question?
  6. Lets talk spark for a second...
  7. H23 VTEC PROBLEM
  8. **** Lsvtec 201hp stock cams****
  9. rs machine piston ring gap
  10. rs machine piston ring gap
  11. Cam?
  12. Cam ?
  13. what spark plugs???
  14. GSR block w/ LS crank
  15. b20vtec fuel pump and fuel injectors
  16. UPGRADE PISTONS?????????????
  17. How does this budget motor setup sound!
  18. itr/ctr valvetrain limits
  19. F22 rebuild- where to get parts.
  20. s2s2 cams vs Jun stg 2
  21. Valve stem installed height measured from where exactly?
  22. CTR pistons
  23. b20v problem 2nd...
  24. which college or trade school???
  25. rs machine 84mm ITR pistons
  26. b series stroker guys come in
  27. B Series Simple budget recipe for 11's, daily driven
  28. skunk2 pro3 cam Questions!
  29. B18C-R rebuild advice please
  30. are these skunk2 pro3's ? b16,b17,b18 cams
  31. B16 Idles real high
  32. Easy question about B16 retainers???????
  33. Header decision
  34. What pistons should i use?
  35. B18C build questions
  36. rebuilding gsr
  37. Rocket motor sports cams
  38. reccommend a muffler???
  39. Built type r motor is running rich. Help please
  40. ID Please
  41. What did I just break? 83" Accord, EK1 Motor
  42. lsvtec all motor help... cams etc
  43. b16 all motor question
  44. How are you guys gasket matching your t-bodies?
  45. comp cams in b series
  46. b16 build issue... need some sound advice
  47. installing skunk2 valve train
  48. regular gas...87octane
  49. K24 Crank in H22...kit?
  50. NA LS oem build questions
  51. What is considered to be a "normal" oil pressure on a B-series engine?
  52. switching fuels
  53. GSR swap Cutting off suddenly more than once ?!?!?!?
  54. !!My lil All Motor build!!
  55. Type R block with gsr head or ls/vtec??
  56. h22a clearances
  57. vafc question
  58. Skunk2 Stage 2 Or Pro 2 Cams?
  59. Difference between ITR/GSR exhaust cams??
  60. $ Money & Decisions: LSD or Mods?
  61. FOR SALEE!!!!
  62. B18C 2.2L Stroker Build Questions/Input
  63. LS/VTEC smokes.. ready more.. need answers
  64. Who sells b series supertech steel retainers?
  65. Want to build my LSVTEC.... advice suggestions plz?
  66. imput on my build
  67. Are these real TDM tri-y replica headers??
  68. obd1 - obd2 questions please help
  69. H23 IAB removal
  70. MSD super conductor 8.5mm wires good?
  71. 20 mpg in N/A B16
  72. Which Gasket?
  73. Loud Valves?
  74. Identifying Spoon B-Series Cams???
  75. b17a
  76. Pump gas build question
  77. Not getting compression in Brand New rebuilt D16 Engine
  78. what head setup to go with?
  79. p30 pistons in my b18
  80. Advice:quiet exhausts?
  81. D15B & D15B2 question
  82. LS/vtec igniter offset
  83. Integra GSR b18c Build Up Need some Advice!
  84. Which build for pump gas?
  85. Does Compression go Down with Bigger Bores?
  86. B20v build what header intake manifold TB, cam choice and oversized valves?
  87. gx pistons specs.
  88. Basic upgrades for reliability for JDM B20 set up.
  89. Meth Injection for N/A??
  90. Need Help.. b18c timing setup
  91. H22 Stock Bore & Stroke 245 Whp 11.5.1 Compresion
  92. b20 with high compression pistons almost 11
  93. H22 with ITR Intake??
  94. Future GSR or ITR build would like pointers.
  95. ls-vtec high idle issue?
  96. ALL MOTOR HELP GSR
  97. Will Valves Clear Pistons on B20B Block with GSR Head?
  98. ls/vtec arp bolts work with gsr block b16 head?
  99. Vehicle scale
  100. ls vtec priming oil system for the first time
  101. Help with poor mans type R build!!!!!
  102. DIY-how to check your compression ratio without opening your engine
  103. integra all motor
  104. anybody know what an a1 transmission is?
  105. My N/A LS Vtec Build
  106. lookin for more torque
  107. What arp head studs do I need?
  108. Help with switching block on B20B with GSR Head
  109. Toda Headgasket
  110. Would Should my setup make? (Horsepower)
  111. Any F series love?
  112. Tri-y hytech replica header and stock cat possible?
  113. engine swap for a 95 civic dx worth it?
  114. Which inline fuel filter?
  115. 1999 GSR Starter advise please
  116. H23 intake manifolds
  117. Distributor compatability question.
  118. your experience of CP pistons?
  119. engine clearances
  120. CODE 15.....PLEASE HELP!!!!
  121. D15b2 build (dpfi) some doubts :|
  122. high comp. tuning
  123. lsv head gasket
  124. Help: How to make 200whp with LS-V
  125. help with head gasket 85:5
  126. My Build. all input appreciated GSR motor
  127. What's the difference between a ls motor and a gsr motor?
  128. Few H23 part identifications please...
  129. OEM obd0 b16 Intake Manifold vs OBD1 B16 Intake Manifold - HP Increase?
  130. b20 vtec build
  131. My CRX HF: cast TypeR vs. VtecKidd RMF narrow replica header back to back dyno result
  132. B16A piston into ITR motor?
  133. Need Help Selecting Exhaust Size for my Build
  134. GSR block - LS crank/rods w/ 84mm bore
  135. need help
  136. any good how-to's on sizing bearings,pistons, and rings?
  137. LS Cam Holder Bolts Torque ????
  138. anywone tried this pistons
  139. 89 b16a with 99 b16a2 crank?
  140. My Build
  141. tb port vs im port
  142. aftermarket lifters
  143. Engine shot!
  144. Pics of why my timing belt got screwed up.
  145. FPR compensation?
  146. My 2.4 h series build
  147. aebs intake mani vs stock itr mani???
  148. Stock airbox vs Cold air/shortram
  149. Crx EE8 build b16/b18
  150. new to the honda world
  151. Possible engine damage?
  152. 90 EF D15B6 NEED HELP
  153. Distributor question/issue
  154. 12.5:1 LS vs 9.5:1 B20
  155. input on password jdm powerchamber.
  156. how to tell the difference between cams
  157. thermostat doesnt open?!?!?!
  158. HELP B20/vtec vs LS/vtec
  159. Timing issue
  160. Edelbrock or Skunk 2 Intake Manifold for GSR
  161. MY TIMING BELT AFTER 72 MILES ON REBUILD
  162. timing belt to tight?? help??
  163. what did i do wrong
  164. need advice on skunk2 tuner 1 cams on 1.8 LSvtec pr3 pistons
  165. Oil on spark plug thread
  166. Is there a difference between 240cc and 290cc
  167. Excessive Smoke From Breather
  168. Will ITR Cams make more than 210whp with 2.0L high comp Engine?
  169. Do vtec motors cause air motion in the block?
  170. Tuning itb's?
  171. B16B Crankshaft on B18b1 works??
  172. compressin numbers after rebuild
  173. OIL PAN QUESTION
  174. exhaust question
  175. Diameter of the 4 cyl Accord 2008 Throttle Body?
  176. Torco mpz engine assembly lube HP
  177. I NEED A OBDll GSR HEAD.....AND GSR ECU
  178. skunk2/blox tuner 1 or tuner 2? stock bottem end
  179. rmf or hytech header
  180. piston notch????
  181. What battery do you use?
  182. MIDWEST BUILD AND TUNE>?
  183. oil in intake manifold ?
  184. Experience with gude's head package?
  185. Brian Crower vs. Eagle Stroker Kit
  186. 281whp/210tq - AV Tuning & Development NA Stroker
  187. NA d15b7 build
  188. good block for ITR head
  189. Cam Question
  190. Built B Serious that needs good ECU, info needed
  191. H22, H23 head differences... few easy questions...
  192. itr cams on stock b16 valvetrain??
  193. h23a1 head swap.
  194. Ignitor?? Where is it?
  195. What Head Bolts/Studs Should I Be Using For This Combo ?
  196. Cam choices... Which one?
  197. Need help with chosing parts for B20Vtec.
  198. Take a look at my LS valves....eww nasty!
  199. gsr head on b16 block
  200. help oil leak from??
  201. All Motor EG ITR swapped. ? about ITBs Opinions Welcome!
  202. Want-To-Know. Should buy or not?
  203. all motor 84mm b16
  204. need help bad before i go broke!
  205. 92 civic si
  206. N/A Build plans for 2010 92 B17A1
  207. Build plans for B17A1
  208. Zinc oil additive?
  209. what headgasket to get on poor mans r??
  210. B20B P8R nonvtec Ported head flow result
  211. how can i tell if i have a b16 head or itr??
  212. Intermittenly, idle goes up and down, 900-1400rpms
  213. 2.0 LSV FULLY BUILT...WHP?
  214. H22A Oil Pressure
  215. b18c5 /b16a2 valve lash question
  216. jdmb18c question
  217. B20 or B18c1
  218. Whos Running the Hytech Replica B-series Header
  219. b16 head gasket on an Ls-v setup??
  220. ITR Camshaft question.
  221. the better buy????
  222. Another topic about bad LMA's HELP!
  223. 3.5" Intake??
  224. SEMOTORSPORTS All Motor CRX -VIDEO-
  225. any rare f20b sir-t builds..
  226. edelbrock tb help!
  227. B16B Crankshaft in B16A2 Block
  228. Next LSV build...shooting for 190 - 200whp, possible w/the setup listed?
  229. probe industries forged b20 pistons
  230. my compression low and is all even
  231. What do I need for E85?
  232. throttle body help???
  233. B20 Bottom End Build
  234. whining noise from manifold
  235. DIY Throttle body calibration
  236. D16a6 head on d16y7 block need info on build
  237. 20 Thou Bearings ??
  238. 2 layer head gasket????
  239. how sould I clean my stock gsr pistons with???
  240. will my eg tech maual work for my 01 crv?
  241. gsr head gasket
  242. what cams should i run. 12.5-1 b20vtec asap
  243. how much do you think it will make???
  244. grinding in valves
  245. Edelbrock Cams
  246. itr vs skunk2
  247. Is the B20Z oil pump the same part as the P72 GS-R/Type R?
  248. Pistons for 97 Gsr B18C
  249. pr3 head build
  250. B20 help
