PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 [129] 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. d16a6 head on d15b7
  2. Need help ASAP. Please Read
  3. Need Help With d16a6
  4. i need help
  5. Hondata Vs. Chrome?
  6. B16A Exhaust Size Dyno Charts (2.25" vs 2.5")
  7. Need Help Cant Find Valve Springs and Retainers!!
  8. swap
  9. 193.5whp 122.5TQ
  10. removing main caps/crank/rods/oil pump
  11. My B18c Build
  12. 12 sec Street D16 engine pics....
  13. stock fuel pressure
  14. just installed new cams now i got a tuning question
  15. CTR pistons VS ITR pistons???
  16. How do you clay a motor?
  17. d16y8 JG port and polished head
  18. Car is idling like crap
  19. looking to make custom header.. need help
  20. My b16a3 burns oil in high rpms in vtec... burns lots! I have good compression no's too, what could
  21. INtake manifold ported and polished now whistles like crazy?!
  22. question ARP head studs..
  23. stuck throttle? Nope....
  24. what 1/4 mile times using BCIII+ cams?
  25. Link to For Sale forum: New B20z with Wiseco 11.5:1 pistons
  26. Street B16 Help
  27. OEM Clutch kit for 200whp+?
  28. b20 vtec???
  29. Need Advise....ITR motor in a 99 civic si
  30. '01 type R mild upgrade ?'s
  31. cams for stock b18c4?
  32. buddy club stg 5
  33. Your opinion is actually desired! Plugs for my NA build setup
  34. deciding what size tire to run 23 or 24.5 low 11sec car
  35. EAGLE OR SCATT CRANKS
  36. So cal tuners...
  37. What is the biggest crank and rods you can fit in a d16y8?
  38. need advice on my upcoming b16 build-up...
  39. How much Power...
  40. What are possible upgrades, but still pass smog in California?
  41. Blox type B camshaft Settings
  42. Compression Test on my motor...sound ok?
  43. why do vtec cams have 3 different lobe sizes?
  44. Took some engine bay pics today.
  45. **H22 Balancer Shaft Belt Quest.**
  46. NEED ADVICE/HELP!!! JDMB18C1 OBD-2
  47. Just did a Compression test on my B17, what do you think?
  48. Crank Pulley Marks...
  49. gauges
  50. ls/vtec b18b/b16b
  51. DIY ITB users only
  52. descent exhaust setup?
  53. Would b18a piston rings work on b16 PR3 pistons?
  54. ssr street sweeper question
  55. I want a torquey b18a1
  56. Headgasket?
  57. Header Question
  58. TYPE R /b16
  59. one of the best combustion articles ive read, of many.
  60. Engine Problem
  61. H22 Busa ITB Project
  62. vtec problemo
  63. question on a 86mmx 89mm build, what block and why. Someone please.
  64. Is 200 whp achievable in a B16 with stock internals?
  65. Crower std. height Steel Retainer with Skunk2 springs...is it safe?
  66. GSR Head w/ B16 Block - WHICH HEADGASKET?
  67. Ha, thought i'd visit all motor fourm again..for all the haters.
  68. Backyard Special Carbon Kevlar Plug Cover
  69. b16 head w/cam caps from a different head
  70. i finished my swap car runs like crap!
  71. lift and duration on all 3 lobes of BC5 cams.....anyone??
  72. honda D15A
  73. Sparkracing header
  74. Skunk 2 stage 3 valve spring recomendation?
  75. Has anyone had experience with this? (JHP enclosed)
  76. What would help make the most power???
  77. my welfare stealth catch can
  78. How high can a Honda ECU read?
  79. question on what block to start from.
  80. Nippon racing Ltd - High performance pistons / HELP NEEDED
  81. mini me questions?
  82. Skunk2 intake mani install issues???
  83. Piston Rings
  84. H22A over 2.0 GSR, worth it?
  85. Vibrant 4-2-1 header. dyno results?
  86. NEED HELP....b20vtec assembly problems
  87. Code issues
  88. HELP > engine dies after skunk2 i/m install
  89. ATTN: Fellow DIY ITB users
  90. just got back from the dyno 06 SI(197WHP)
  91. zex 57200 cam ?
  92. skunk2 pro series or eldobrock victorx intake manifold
  93. My ITB'd Single Cam project is underway! Pics!
  94. pistons size
  95. S2 Pro 2 Cam gear settings?
  96. LS/VTEC, ITR Pistons ... Tuning Question.
  97. V-AFC contoller on OBD0 B16A??
  98. quick k20 Question
  99. b16 tapped how to untapped
  100. An-r Header? Or?
  101. Need Buddy Club III+ cams Urgently!!!
  102. Calling all CTR/in GSR block (owners)
  103. Stock B20B and Dual Pump System thoughts.
  104. DIY throttle bodies!!! quick question.
  105. Need help with VTEC!!!
  106. QUCIK QUESTION!!!!!>inside,click here to open!!!!
  107. So i was looking through Streetfire.com and found a vid of my h22R dyno.
  108. Building My First Lsvtec..Let me know what you think of my setup.
  109. Skunk2 composite fuel rail
  110. b16 hydro trans for sale
  111. will this work
  112. Omni test pipe length
  113. Shim size for 98+ ITR LSD into B16A2 tranny??
  114. dseries numbers
  115. my civic.... any suggestions?
  116. My car idles wierd help me out
  117. y8 dd build
  118. noob question about cam gears but i need to know
  119. exhaust question
  120. 76 mm ??
  121. Post you poor man type r set ups
  122. Just Some Subaru Exhaust Work
  123. Minor build on the B18A LS motor...got a few questions
  124. ARIAS PISTONS k24 RACE PISTONS (High Comp) 11.1! *Cheap!
  125. My friends New H22 Custom Header
  126. I hate "which cams should I go with" threads
  127. EG6 or Ls/Vtec
  128. Is my Build safe?
  129. Fuel Maps
  130. LS Vtec Build what Hp would I be looking at with this set up?
  131. Big thumbs-up to Skunk2, VtecKiDD, Jim Justice, and DonF... Thank You
  132. Do Polyurethane Engine mounts make a difference?
  133. jun 3 cams
  134. h22a or ls/vtec??
  135. All motor D16Y7?
  136. fully built street B20/vtec or stock K20
  137. dyno question
  138. Tuners. What A/F do K Series Motors tend to like? Or like
  139. compression for a stock jdm h22a?
  140. Upgrades plan on B16a2, what u guys think?? !PINOY!
  141. i'm trying to build an ls-vtec for road racing and street use.. i need advise
  142. VTEC switch over point!!!
  143. Header choice for B16
  144. Po mans Type R have some Q's
  145. Anyone Know where you can fin Bearing for JDM ITR 4.785 Final Drive
  146. speed regulator wiring
  147. Shipping $350??
  148. crx ls/vtec
  149. ctr pistons in a b18c5
  150. Will GSR camshaft fit to B16a2??
  151. GSR rod on LS crank
  152. What springs and retainer combo to achieve 100lb seat pressure
  153. Best place to buy a Megan 4-1 header?
  154. lsvtec head gasket
  155. CRVTEC question
  156. compression test results b18c1...........
  157. rod journal, URGENT QUESTION
  158. help please need input
  159. how much power can i expect from my b17 with the following mods???
  160. best bearings to use? acl, oem or what??
  161. Help Please: LSVTEC crx chugging/very hestitant
  162. fatty 5's..
  163. Would a profab header fit a b18 a/b motor in a dc?
  164. need help on compression #'s
  165. Mixing camshafts
  166. how to close the #4 intake valves
  167. xsi head gasket ?
  168. wuddup new here gotta question for sum1
  169. All B18C 5 Zigen Header Users Read on....
  170. nippon pistons
  171. New cams need help
  172. B18c5 Build, need input..
  173. (RS sleeves)
  174. 82mm= 45cc?
  175. what should i do next???
  176. D16Z6 into STD EF plus build advice.
  177. 2.0 L?
  178. Got Dyno'd - Please let me know ..
  179. Im new to this page. So yeah im asking about all motor potenial
  180. GSR main/rod bearings on LS crank/rod
  181. need help finding the right cams
  182. Is it worth the extra money for itr pistons?
  183. Anyone found a solution to Skunk2 throttlebody Sticking??
  184. How Much Power From this setup?
  185. Good Build ? Q `s ?
  186. Good place to port and polish?
  187. Rods and Pistons for D16A6
  188. what kinda of power would i be at with....
  189. Would new valve guides be necessary for 200 whp build?
  190. Question about Skunk2 cams?
  191. Where to buy a B20z motor, in Orlado FL
  192. intake manifold from JDMSHIT.COM
  193. Rocket motorsports cams? What is the comparison...
  194. I do not remember this happeneing before when setting cam timing
  195. Reuse Main Studs?
  196. Vacuum Manifold with ITB's?
  197. pics of my new cams, results and vids of dyno soon...
  198. B18CR Dyno
  199. Piston to Sleeve Clearance
  200. what throttle body and intake manifold should i got
  201. test pipe??
  202. clutch aint grabbing, PLEASE HELP!!!
  203. Hows this look ?
  204. B16A injectors vs GSR injectors
  205. copper spark plugs (itr motor)
  206. cam and valve clearnce issues??
  207. Not really tech related, but its about headers......
  208. Need help with t/b asap
  209. Exhaust piping ?s
  210. H2b With H23 Vtec or H22
  211. 84mm Qs.. reliability
  212. Megan Racing Resonator
  213. What might have caused this?
  214. TWM ITB's, 50mm or 52mm?
  215. Lookin for a decent header...
  216. Exhaust question
  217. OBD2, Forged Pistons, and Knock Sensor
  218. findanza flywheel
  219. Congrats to Hookups - testing in AZ @ NOPI
  220. Went to the track last night...........
  221. CTR cam!!!!!!!!!!!!!!
  222. The FROG - 2.1L Comp4/Street Stock - 92mm Crank B-series buildup - Ready
  223. Any S2000 tuners/engine builders here, share some info with a colleague please..
  224. Stock B20 w/Hondata S300, Header & Intake
  225. Which one is the GSR throttle cable?
  226. where to get my block sleeved for and my 250whp goal
  227. OK why is my valve train clicking like hell after cam swap.
  228. Ppl running AEM ITR CAI (3") in a EG chassis..
  229. What head studs w/ a b16a2 block & GSR head
  230. ACL Race Rod Bearings (std and .001" under sized pair mixing)
  231. 175 whp goal
  232. Toda Cams without the 'A ' stamped at end?
  233. Won't stay on VTEC??? Jdm ITR
  234. 98mm crank
  235. Any adavantage of GSR t/b over LS?
  236. Time for my rebuild but I have some questions first
  237. Sources for engine rebuild parts?
  238. skunk2 stage 3 cams question
  239. Stacking two complete head gaskets? anyone
  240. LSVTEC OR B16A2???
  241. The boring difference
  242. Interesting occurance...Motor seems to lose power in corners...mainly left hand corners
  243. Reuse stock Rod Bolts???
  244. question about redline with this setup
  245. Will a GSR throttle body fit an LS
  246. Why did honda make the d15z1 (vx motor) have a unique 1.62 r/s ratio
  247. Finished Swap, having problems! Car on FIRE!!
  248. piston rod rusted
  249. poor mans type r
  250. b20 crank cap torque specs?? need help
