- new king racing bearings..
- twms itbs, k20r, what injectors to use. dsm?
- for b20v guys, what 2.5" exhaust do you have?
- Cam experts needed jdm b18c/crower
- Do I need valvesprings for stock redline? (B18B1)
- What kind of cams this are?
- stock b16b
- skunk 2 stage 2 cams help
- h22 arp rod bolts?
- Ls-vtec build questions?
- Identifying Crower LS Cams?
- spark plugs
- Stock ITR cams with cam gears timing help!
- need big help please read thanks
- are ti. retainers really nesseary?
- Head Clearances
- my first all motor build.. a few questions..
- Cat? Goerlich/Thunderbolt
- b20/vtec: possible to use b20 pistons?
- B16a piston question
- inputs on tri-y vs hytech rep for h22????
- Torque Damper GSR Install Help
- On car valve spring tool
- help buildin a h22
- your experience with BLOX camshafts?
- built B16 header ? similar to toda ?
- h22 help
- 11.8:1 with toda cams
- Please Help Will My pistons fit?
- oil leak on new engine!?
- all motor/nitrous gsr dyno
- ? on MSD VTEC Distributor
- My final B16A dyno run.
- pistons
- exhaust vs intake cam
- RMF Replica Replica Header?
- 95 gsr trans on 92 ls precautions?
- Cost to pay a shop to rebuild LS motor?
- 13.5.1 comp motor 93 octane or race gas?
- b16a head
- ls internals in a gsr engine?
- header question
- best bang for $$ header under $400..
- dizzy
- DC Sports JDM 4-1 header pipe size?
- Air fuel ratio
- Flushing motoroil
- help identify pistons
- B20Vtec Headgasket
- Valve Train Question
- Which ARP Head Studs???
- gsr swap help....
- fidanza flywheel
- Congrats to Chunky- 3 Years in the making............
- ctr camshaft question 00 em1
- h22 type s pistons one f22 rods
- s80 (gsr) transmission acting up???
- Eldebrook Victor X 70mm tb on skunk2 im (GSR)
- performerx over blox
- Vtec kicking in....
- Deciding on what rim/tire combo to run
- question on how to port n polish
- CTR valvetrain
- need help w/ parts order on LS motor build...pics
- knife edge crank?
- The best bang for my buck...4k to be exact
- gsr head problem
- rear breather ports for oil catch can on a b18a block
- Question on GSR swap
- Will a lightened flywheel show hp on dyno
- merge collector on old header, tell me what u think
- AZ RAGE mounts
- GSR Girdle on B20 block
- B20 done... Feedback please *pic's*
- help with camshaft identification
- Can't get a straight answer from ARP
- k-series headers spec???
- Mini me pros !!!!!
- Strup Header
- **Side Exit Headers Pics**
- Ls what pump
- Those RMF narrow-looking headers that people are selling now....
- what ever happened to mike belben
- p30 SIR ecu with d16z6
- car doesnt pull til 7200????
- Some quick questions on changing pistons and break-in!
- low compression
- Finally my H build up.
- Stockish B16a2 All motor Cam ??'s
- Motor rebuild problem any help would be great
- New TB won´t adjust to factory tps setting???
- smoking bad
- WD-40 B Series Shootout
- Another Ls/vtec build or not?
- Which head gasket IE manufacturer
- stock gsr + 450cc injectors?
- h22 all motor with dyno...take a look
- Help with camshaft selection
- Ls Vtec Help!! first timer!
- Oil leak on ls block. HELP!!!
- V-Stack Size?
- E manage or AFC?
- Am i going in the right direction b20v build
- Opinions on Aluminum Exhaust Piping...
- final drive swap question
- Best N/A street motor
- need help bearing oil clearance and ring gap,crank end play
- How to recognize vtec cam: SIR CTR GSR ETC..
- OEM vs Autozone
- Whats the best approach here?
- Opinion on my Ls V build
- can i reuse my oil pump
- b18c stage 2 cams, best exhaust?
- Looking to build all motor set up... For street/strip on a budget...
- Ls/vtec
- gsr bearings ? help`
- sk2 stg2 degree
- Timing belt split in half!
- Question about my transmission *Help PlEaSe*
- LS swap in ef
- real redline for sohc zc!
- Need Help ARP Head Bolts?
- almost done wit allmotor build few things still needed tho!
- Just got tuned and I'm making poop for power. Need new cams.
- What does Whistling mean. .. ..
- h22 manual tensioner problem
- piston to valve clearance?
- Making 3.5" intake what bend to use?
- De-Buring a block...
- B20V Pointers
- Question on blox B cams
- fly wheel weight
- Plans for an all motor build
- Parts that i buy for my b20vtec
- New pistons what rods to get
- 2000 1.6 vtec same as 99?
- Minor Build
- oil catch can installation on b20 vtec
- Kinda disappointed in my build...
- Ls vtec wont run, help
- JDM ITR on usdm b16 ecu
- Crank offset grind price
- b series flywheel ?
- Want to raise my compression??
- My First Build - B18C
- Looking to tune my car need some suggestions
- motor questions
- Stuck on exhaust
- What would you add or change?
- what length header?
- cam guys - i need help
- Cold air or Short ram intake
- Blox rating thread locked...? WTF?
- Cutting Valves (30 degree angle question)
- Daily Driver setup
- T-Bolt Clamps
- exhaust help
- h22 blox b cams harsh vtec transition???
- b18a bottom end b18b top end
- Car wont stay on help please!
- new to HT requesting some info?
- ZERG industries headgasket any good??
- how do i change alt. on 90 accord?
- Skunk 2 Valvetrain Rating
- B16 b18
- D16z6 Build
- 4 grand?
- ILR presents ls/vtec simple build, dyno graph
- SR-S Exhaust, Has anyone experienced with those?
- Rebuilding a streetable gsr
- Which Knock Sensor for B20 vtec
- What pistons do you recommend?
- Blox rating
- Back cutting stock valves
- SKUNK2 PRO SERIES(seat locators)what to USE?HELP
- 2.5in header to ws2??help!
- cams stock or aftermarket???
- Problem with b18 stroker motor (aluminum flywheel)
- Which intake manifold for my setup? (B16 setup inside) Valve Springs needed?
- Why VTEC killer cams and not LS?
- H23A where can i find a manual? haynes dont do one
- 12:5.1 GSR block/b16 head S2 Pro2's a good a good cam to run?
- h22 bisi headers
- LS/Vtec Build
- quick AND reliable
- Endyn bumpstix camshafts
- Compression problems ~'`PLEASE Help`'~
- F23 block, h22A head, K24 pistons
- HELP! : Poor Man's Type-R, Harness?
- what are the best cams for a b18c
- how much would it cost to re-build a h23 engine?
- My dyno results.
- d15b2 question
- cel need help
- intake piping vs throttle body
- Good Tuning Shop in Southeast
- Help Squeezing Some Hp Out My Stock H22...
- all motor gurus chime in
- h22a whp
- gsr dual valve springs...
- How far can it rev ? 9K SOHC ? HWO MUCH POWER ? HELP
- Just got a d16z6! I have some questions!
- Nice Cams Question?
- what cams to use on my bild
- Identifying Intake Manifolds
- D16Z6 p29 pistons
- B20Vtec Compression(GSR head)
- Throttle body question
- Anybody knows bout these JVT tr-Y headers?
- 82mm bore without sleeving?
- swapping b18c and ls engine components
- ssr header for built b16?
- What is the great benefit?
- Ok, fess up
- timing advance
- New head bolts?
- b20 vtec 4dr integra...help
- what are some good rods for 280whp
- Need help with a build. GSR/B20
- C16, Q16, C12, E85...13.5:1 CR. For All motor, what is the better option?
- noobi build questions?
- Noobie Build Questions?/
- Need help.. Knock sensor problem
- Oversized H22 Type S Pistons
- B16A approved for SCCA Formula Atlantic
- hastin rings b18 os
- Intake On b16a2
- few cams measured, interesting results
- Pulled motor. Looking for any advice on my parts list
- ls/vtec build need help
- T25 1st or 2nd gen for D16a6 200hp goal
- re-using forged rods..
- Car dying? is it my cams
- POST YOUR ALL MOTOR h22-H2B DYNO
- how high are you revving your H22
- f23 build N/A
- b16 header..old toda?
- skunk2 intake manifold question
- all motor h22 build and dyno graph
- 94 accord f22b2 swap to f23a. Help
- P2V V2V is it NECESSARY?!
- a20 crank
- NEED HELP! B20/Vtec
- Got my oil return plugs for G series build
- Flat faced valves flow characterisics
- Exhaust Resonators - Two Better than One?
- crankcase breather question...
- all motor h2b build 350whp? possible?
- 2.0 narrow headers???
- 440cc injectors
