PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 [188] 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Here's what I have... which clutch should I go for ?
  2. Non Vtec vs. Vtec
  3. Ayone useing M22 cams
  4. what B series motor is best for an all motor set up
  5. scat rods
  6. transmission issues on my all motor car
  7. Ls Vtec all motor , what will my compression be
  8. B20 piston question.
  9. Swap Info for a 97 B18C Type R into an EK
  10. Explain how this works
  11. Compression Question
  12. JUN Cams
  13. Help major buel problem
  14. Injector Question
  15. BC racing condenser
  16. Throttle body question
  17. What should i buy
  18. Omni valve springs
  19. skunk 3 cams
  20. what kind of h22 cams have s10 engraved?
  21. Honda 25 HP Industrial diesel enginetingst
  22. code 21 searched n need help
  23. toda independent throttle bodies
  24. Is it possible to install the oil pump inner rotor wrong?
  25. oh god..wat is header's collector and header's outlet?
  26. import tunner shoot out
  27. low hanging header help
  28. Crower camshaft 402 users... are yall using crower specs or different specs?
  29. skunk2 valvetrain overkill for s1's?
  30. ls/vtec crower stg 3 cammed dyno...
  31. Cleaning a ported head.
  32. whats a good exaust?
  33. Pro Fab custom header
  34. AEM management
  35. arp 2000 bolts tightening torque??.. b20
  36. crvtec piston ring gap?? whats the spec!
  37. what exuast? for Gsr or B20?
  38. how much would a b20vtec cost?
  39. BUILT LS/VTEC- BEST TRANNY
  40. toda sports fuel injection kit
  41. Price for getting a block honed or bored
  42. help with my dyno sheet numbers???
  43. ctr ex. cam identification?
  44. ok... jdm itr pistons vs usdm itr pistons??? what you think is be better for a b18c1?
  45. How important are higher rev limits?
  46. Catless with test pipe or cat converter with test pipe?
  47. CTR in. cam, GSR ex. cam. What EX. Valve springs?
  48. J's racing CF intake in DA Integra?
  49. Just got back from the track... dont know what to think...
  50. LS VTEC QUESTION?
  51. Thinner headgasket or Flat bottom Valves??
  52. b18b w/ eagle rods?
  53. intake selection need help
  54. Acell DFI good for NA?
  55. gsr all motor setup
  56. 1990 honda civic starting problem
  57. What do you think about this allmotor setup??
  58. droping an engine in my 97 civic
  59. does my setup need a wideband o2? SOHC
  60. what ITBs do i have?
  61. Need Help Please
  62. LS vtec question.............oil pump
  63. Help Wanted:NY JDM Sales/Warehouse Manager
  64. Looking for feedback on JG Engine Dynamics sleeved blocks...
  65. SKunk stage 2 in a STock compression JDM GSR
  66. b16a2 setup
  67. 10k+ redline possible?
  68. 94' B18B and a 98' B18B parts question?
  69. speed govener?
  70. J's intake only CarbonFiber?
  71. Is it ok to grind off the valve guide to make it flush with the port?
  72. Best Piston Compression for All Motor
  73. Hey guys what do think of this build plan?
  74. Want speed
  75. Pulleys
  76. Tranny question for the motor.
  77. All motor Civic Fast
  78. Looking for DTR, AN-R header Dynos
  79. What is more likely to WARP, the Piston or the Cylinder???
  80. ctr or itr pistons for gsr
  81. big cam question please help!!!!
  82. d16a6 block
  83. header question need help on deciding.
  84. RLZ site down??? Is he still overflowed with heads??
  85. JDM H22 4door Baseline Dyno VIDEO!!
  86. tool for measuring cylinder bore?
  87. Need help with my setup!!!
  88. Pulleys and kits>>
  89. Cam gears?
  90. 320cc injectors sufficent for built crvtec?
  91. LS Throttle Body Suggestions
  92. Jet Performance ECU upgrade
  93. Need help with lubrication
  94. On to a new Project!
  95. lets talk about sea foam it works? to clean you motor??
  96. ls/vtec question
  97. gsr was flooded, need to know what i can salvage off my car...
  98. dont know whats wrong with my setup
  99. Power Rev Racing
  100. ctr pistons in my gsr HELP!!! Burnt 2 pistons in 56 miles
  101. Would DC Headers for a B16a fit a B18b LS motor?
  102. H23/Vtec DYNO
  103. questions about block im picking up.. need opinion !
  104. Are just upgraded valve springs fine for Buddy Club 3+ in my b18c?
  105. Anyone running 1mm oversized valves with cams that have at least 12.4mm of lift (H22)???
  106. Pictures of my H22 head ported and polished and welded chambers(56k warning)
  107. valve clearance
  108. all-motor upgrades for 2k d16y8?
  109. H and F series valve info needed...
  110. B18C Build - Questions
  111. Sleeved without bore?
  112. motor options
  113. My H22A1 a-m build.
  114. Pulleys...good idea or not?
  115. Ls in an Eg-6, settings for Apex'i S-AFC
  116. Looking for a few of the "BEST" Tuner's in the Midwest region.
  117. Did i burn my exhaust valves?
  118. single cam piston/rod question...
  119. 7 day ALL MOTOR monster build-up!!! pics inside!!! GSR integra DC2
  120. What is resleeving
  121. Interesting - Oval Throttle Bodies
  122. N/A LS Setup
  123. Skunk2 SOHC IM dyno?
  124. Type R Intake manifold
  125. Suggestions needed for mildly built b16.
  126. New to all motor
  127. best place for JDM DC 4-1
  128. NEED PACMAN CRX street vid
  129. OT: free 27" TV
  130. what does it take to run 14 sec with a b18b?
  131. K20/K24 All Motor - Parts List
  132. Blox Racing needs your help! Please help answer this survey...
  133. Benson Sleeved/ Import Builders pistons/ Toda C charts
  134. why does my car sound like it has stock cams/////
  135. how to tell i have stage 3 crower cams//////
  136. custom shops in so cal to make custom piping?
  137. What to do...
  138. Compression check results on a fresh built B20VTEC
  139. Whats involved with "tuning"
  140. WTB: Jun H22a Exhaust cam HELP
  141. Where to buy exhaust bypass valve?
  142. Car Hesitate while driving. Help ...............................................
  143. Check engine light check obd1 no instrument cluster?
  144. Yet another Mobil 1 thread
  145. HELP ME identify this Aftermarket H22A cam PLEASE
  146. How can I figure out what my comp. ratio is???
  147. Is this worth the money
  148. all motor build to hit a goal... help?
  149. stroked b16 vs. b18
  150. h22a in 92 accord PROBLEMS
  151. Where's the best place to buy a CTR intake cam?
  152. How to gain CR without Pistons or Mill head
  153. QUESTION ABOUT TECH 43 racing piston kits
  154. AN-R Header
  155. B20 Vtec oil line question
  156. what happened with the GREAT CAM TEST???
  157. b16 bare block build up
  158. All motor LSVTEC Question
  159. Leakdown test results 3.2 Acura Type S
  160. How much time do you spend on your Integra
  161. Distance between Cat Conveter to Resonator?
  162. Cat converter how far away resonator should it be?
  163. need dyno around bay area
  164. Crankcase pressure real high - would it affect Top end performance?
  165. RSX pistons in B20?
  166. Re-routing valve cover breather tube from intake to exhaust ????
  167. I HAVE QUESTIONS ABOUT THE BUILDING OF A POOR MAN'S TYPE R! WHY DOES A B18B1 MAKE MORE.....
  168. NEED HELP ON A d16y6 SWAP I AM DOING TO MY EG HATCH HELP!!!!!!
  169. Calling anyone that can help me asap
  170. Stuck Head Studs
  171. Untuned B20VTEC makes crazy numbers
  172. crvtec gap settings?
  173. question about valve adjustment
  174. Upgrade Fuel pump with my setup?
  175. b20z piston and valve clearance?????help
  176. Cam Timing in relation to Ignition Timing
  177. prelude PLEASE HELP
  178. Recently aquired a B16B- How would you build it?
  179. GSXR Throttle Bodies (a thread continuation)
  180. VSS Sensor ( Variable Speed Sensor)
  181. ls cams...
  182. Mugen ECU, whats so special about them?
  183. Where to buy b18c5
  184. bored k24
  185. d16a6 camshaft
  186. Crower Stage 2 All motor Intake Camshaft doesn't lay evenly... is it okay?
  187. Legitimate question... looking for legitimate answers regarding intake manifolds
  188. Throttle body
  189. Begining Stages of My N/A Setup...
  190. where can my boy buy a built h22 from?
  191. Stock GSR Block - Best Cams?
  192. Reground Camshafts?
  193. Weak/no spark???
  194. do i have bent valves or is the shop tryin to get money from me?
  195. quick question,valve adjustment
  196. UK HONDA OWNERS?
  197. LSVTEC owners,just about finished with lsvtec '95block '91head(extra coolant lines coming out of thr
  198. Vision R spec 4-1
  199. Single slammers in the 13's
  200. Mini Me SOHC build up... (what to do next)
  201. Has anyone used his before????
  202. Anyone know what jojo callos times are?
  203. Honda-tech is gay like rj.
  204. Intake manifold question?
  205. What should I tune my car with?
  206. dump valve
  207. buddy club spec 3 or jdm type r cams
  208. Guys give me a hand.
  209. valve spring question
  210. best air filter?
  211. Where to get a good deal on ats 4.9 final drive?
  212. swap guide link needed ?
  213. inquiry: ITR vs CTR cams ??
  214. Comp/ZEX cams - any good?
  215. Oh dann OBX header......discussion
  216. changin from JG eldelbrock mani to skunk 2 manifold
  217. Acceleration stuttering Please Help
  218. D16Z6 RPM withstand
  219. best air intakes for an allmotor
  220. Got a ge lsvtec kit it came with a b16 head gasket???????pls she's tor down rightnow
  221. Need advice on blown motor
  222. Piston Selection
  223. SKUNK2 RSX 9.86 @140mph BOTI
  224. gsr axles
  225. Video's
  226. new to the all motor side.....
  227. how much timing are you runing with 14/1cr or higher
  228. which bearings?
  229. Cams
  230. how can i get more power
  231. Thread size and pitch for head bolts?
  232. jdm b18c1 Running rich all of a sudden.?
  233. Transpro aluminium radiators
  234. supertech valves?
  235. Skunk2 stage 2 Cams
  236. thinking about vtec cam upgrade
  237. type r pistons
  238. Cam Identification - Civic Si Cam?
  239. My H22A1 all motor setup.
  240. lets talk high compression, and under cam'ing
  241. itr valve train!
  242. My build is over, install time
  243. Hesitation during acceleration????????need HELP!!!!!!!
  244. itb's new or used anyone?
  245. ---I need advice on B16B motor!!!---
  246. ---I need advice on B16B motor!!!---
  247. Where do I contact DTR FAB?
  248. Quick question will the type r dual springs fit on the GSR retainers?
  249. Motor building thread, calling out all the pro's and racebuilders
  250. How to achieve 11.1-11.5 CR on a Stock GSR head
