- Degreeing Question (Skunk2 Pro2)
- 94 teg ls to gsr
- buddy club valve train question.
- cylinder hone question
- should i stay poorman's or go b20vtec?
- <h2b build> Questions
- B20V stock/just tuned
- best compression for 240whp+ b20v??
- h23 blue top ef h2b track vids. opinions needed
- b20vtec or poorman's?
- Valvoline VR1 Oil?
- help with chosing throttle body size
- spun a bearing yesterday
- Frustrating dyno day
- Mild B20z non-vtec daily driver build... looking for input.
- B16 Idle Problems
- would ex harness work with my lx ecu
- Will p29 pistons fit on aftermarket manley rods?
- WTB Tuner or ITR cams
- Is $350 good for tuner cams?
- The Plagued Belt Squeal
- Help Me !!!!!!!!!
- Exhaust cam locking up!
- k series chain tensioner issues
- all motor B18c build advice?
- Quick question: JDM ITR B18c 96 GSR Header on B16a2
- need help with lsvtec build its a budget build
- H Series Build (Few Questions)
- Who can machine 14mm domestic delphi injectors down to 11mm import size?
- O-ring for RC 310 Injectors.
- Crane cams.. Help me !!!!
- ATTN: people who are rebuilding GSRs / Hate CTR Pistons
- help with b18c 84mm build
- B20 VTEC pricing question
- catch can set up
- Ebay Turbo Kit
- oem retainers wear !
- Crankshaft Help
- Help me find a suitable catch can
- ls/vtec oiling problem.
- F20B header build
- Anyone have a Built motor using stock header?
- B16 header questions...to many chocies
- valve guide porting.
- ►►May-June | All Motor Classifieds | FS & WTB ◄◄
- balance the b16a crank or not? and other suggestions.
- RSX-S Retainers in bseries head, Which keepers do I need?
- MAX 75psi oil pressure
- gsr mild build
- ARP head stud install question
- PAINTING INSIDE YOUR ENGINE BLOCK
- anyone know what retainers these are? (bseries)
- ruined gsr head?
- pros an cons on regrinding cams????
- Official List of Things to Check When "My VTEC isn't Working"
- I need help with piston rings please
- B16A sensor help!!
- B20 vtec question
- Damaged Camshaft?
- Impact of using B16 Crank in B18C
- Build help k20z3 motor
- 84.5mm gsr all motor
- EG B20?
- :Question: How does vibration effect horsepower?
- Where to mount oil pressure sending unit
- Lets talk about flat faced valves and dished valves.
- gsr sleeves
- No Vtec.. confused...
- d15b2 tranny on zc dohc
- I want to know about the feasibility of a motor design stated below?
- "How would you do it" build!!!
- lsvtec messed up need help asap
- Question regarding buddy club cam gears
- Ls vtec. Need help on vaccum lines!!!
- MAin bearing help
- do i need a knock sensor for my lsv
- ITR cams into b16a difference???
- Gsr Motor Build
- Over heating when system is pressurized
- r2vs issues
- B Series Head Work PNP
- b18c5 intake/exhaust questions
- NGK Spark Plug Selection: All Motor Application
- ****B20 WONT GO INTO GEAR****:(
- Blox HSL Competition Cam.
- Please HELP. Puzzling Problem?!
- Need shop for hot tank/pnp/head assembly
- 97 itr help
- **b16a2 mild build questions (noob) kinda**
- street tuning vs dyno tuning
- B20 build with new rings, should I hone or not?
- residue in B18C cylinders, deck scratch, problem? (pics)
- Check out my plugs!!!!!!!!
- Ls/vtec build suggestions?
- Weird B16 High RMP problem
- crx with ls vtec. HELP!
- GSR Block prices??
- LS Block w GSR pistons
- What injectors should i use and at what psi?
- After Market Exhaust!!!
- Made it to the Dyno Finally
- B18C-R Build...Any suggestions??
- RBC on my F20B
- B18C1" ALL MOTOR "
- JUN3 cam id
- Has anyone heard of G-Oil?
- EF My crappy vtakk box
- Advise on my GSR build
- D15b2 all motor build
- Need to buy individual JUN valvesprings and retainers... where do I start looking?
- H23A blue top?
- valvespring question
- Oil Filter Holder B18B
- B16A n/a build questions
- Brand new to the Honda scene...need advice.
- Header Cylinder Pairing
- B18b Lifter Nuts PLEASE HELP
- Noob's All Motor LS/Vtec build
- Fuel Setup for B20vtec
- 440cc injectors not enough for this 81mm lsvtec?
- Multiple port sandwich plate.
- last minute b16 opinions
- B16 Headgasket leaks oil after switching heads
- STROKER NODUALR CAST IRON CRANKS (B SERIES)
- Ferrea Pac Alloy Bee Hive Valve Springs.?.?
- supertech valvesprings
- d16z6 Question
- b20v exhaust
- Pro-Jay ITB's
- which smsp header is this?
- my b18c build
- Thoughts & opinions on motor issues
- how to make higfh compression Y8
- Need help with piston selection
- My 1st Event WIN at Honda Day, ATCO
- ProFunction Dyno Testing Report - Headers and Intake Manifolds on a 85X89 Bseries
- help deleting the big charcoal/ Vapor Canister box
- need D15B help
- Is there a Difference Between Accord and Prelude rear t braket's??
- Another Cam ID Thread :(
- Which header?? help plz
- b20 with b16 head (clearance problems)?
- b16a running problems!!!
- b18c5 clutch question
- Finding Velocity Stacks for ITB's
- Ls-vtec compression+whp question.
- rusty cylinder walls rebuild question
- What cams are these!?
- LS/VTEC Headstud ?
- vtec problem
- Dimple effect inside velocity stack?
- want to build a na b16a
- How to improve my B16 setup? (Header and IM)
- question on rebuilding shortblock
- "built heads, stock blocks"- were is that thread?
- ITR valvesprings just drop in GSR? blox IM only 62mm opening?
- ARP HEAD STUDS???????
- Smoke and idling on ls vtec. HELP ME:/
- Checking my settings if it sounds about right.
- wiring questions
- mugen intake dyno
- D15B7 Head resurfacing (shocker huh?)
- Identify this crank
- Advice on my all motor build
- Which header to choose for road racing,
- fully built/sleeved/ls-vtec questions help???
- CNC Head Porting
- Best camshafts for my build ?
- getting a gsr head fixed
- itr b20vtec all motor DD
- 2 fuel pumps???
- how to wire up vtec
- fully built/sleeved/ls-vtec,how high should or can i rev?
- what CAI for use with 70mm throttle body
- ILL GARAGE'S N/A Project JUNK
- Johnson_Racing's All Motor EG Build
- built all motor on E85. oil changed every 2 months?
- Budget B20V build, polish+port or manifold?
- PR3-3 Cylinder Head Issue
- All Motor LS Build Questions???
- NGk plugs for b16a? nappa gave me ZFR5F-11
- B18b1 pistons question, naturally aspirated
- Crower Valve train with skunk2 pro 1 cams
- need guidance another b20vtec DD
- what are the limits of phk (b20z2) pistons
- Help with 1.8L LSV Valvetrain Set up (Supertech duel springs w/ crower chromolys?)
- catch can / PCV / vapor canister, school me plz
- All Motor GSR Questions
- Big tube H2B drag header
- Plug for pvc black box (breather setup)
- LS-V idle problem
- D16A6 piston question
- WAY too much Fuel Pressure, regulator all the way down
- advice on my build
- why is my motor knocking???????????????
- B20: P8R Cams vs P75 Cams
- help: low fuel presure and no start after installing walbro fuel pump.
- Rocket Motorsports cams
- B16 stroker or B20 ?
- d16a1 head on a6 shortblock?
- Finally made it to the dyno
- h22 coolant circulation
- Top feed Secondary Injectors on itb's help cool intake?
- Having some issues B18c1
- b20b build questions.
- YCP 84mm ITR spec , ring problem
- Finally Tuned, A Few Questions.
- rmf header
- Need help with search
- Question about my Build!Civic Si 99..new member!
- cam question
- Can you still swap in AZ and pass smog???
- IAC Valve Question
- Stock (used) GSR valves
- Yay or Nay EK motor build
- BigBlock22's Daily Driver Build
- What Compression do I have?
- Anybody talked to DonF lately?
- B series piston question (bore size)
- B20 build eg coupe :newb:
- Catch Can Question
- Camshafts another option.
- Time for a rebuild.... Need suggestions
- For those with a b18c swap??
- building a b18c5 to bet chevy cobaltss and srt 4
- B16 ITB's, coolant bypass hose question
- NEW - Coil On Plug for Hondata s300 users is finally here!!!
- need advice on my build
- 3 inch Blox Velocity Stack and Filter?
- cp pistons in a b16a
- B18c + ITB + toda killer
- dip stick question
- 86mm gsr rebuild. what over bore is safe?
- nah2b(randy) contact info?
- Need Advice Building a Daily Driver All-Motor car
- CODES!!
- Skunk2 PRO Series 70mm Throttle Body - design problem.
- b20vtec and y1 vs ys1 questions
- Valve keepers / valve locks / valve cotter
- Fresh rebuild first oil change slight problem
- Current LSVTEC BUILD
- Wrist Pin Offset?
- EXTREME Gas Fumes in Warmer Weather
- Topic about stock DC2 airbox mods with dyno's
- Difference in ITR Cams and Skunk 2 Tuner Cams
- Bolt ons, advice welcome
- b20 vtev timing belt
- tech: differences between a ls head and b16 head
- Crower dual valvespring height and pressure?
- LSv type r help
