- all motor ls vtec vs. all motor b20 vtec
- 11.5:1 compression pistons slapping...any suggestions?
- What bearings to use?????
- what cams for stock JDM GSR Head
- New cam gear..what do you think??
- B DUB (b20)
- wiseco 84.5mm b20 piston clearence??
- SOME B-SERIES STUFF FOR SALE,MAKE ME SOME OFFERS!
- Exhaust diameter, FI to NA, need a little help.
- who's running carbs?
- NEEDS HELP ON A 93 CIVIC
- Need shop for Tune
- headwork
- boring my gsr block
- power steering brackets the same
- just got my chipped obd1 ecu...
- Endyn Breather : Filter Part #
- B18 head on b16a2 block?
- relationship between Temperature and *Optimal* Ignition Timing?
- jdm b18c not making good power
- # of questions, starting my B20 VTEC build!
- Loss in whp...dynoes included. Please advise! Your feedback is appreciated
- h22a head?????
- undecided on rods ? suggestions?
- b20vtec vs 2.0 ls
- PLEASE HELP all motor build hp #'s or 1/4 mile time's
- Anyone running BRE?
- what cams to get
- timing belt question.
- what/where to get FPR for my caR ?
- K20A2 Auto? Possible(noob Q's)
- Optimal comp for s2s2's
- Exospeed for port and polish. (Did a search, no results.)
- b21a1 frankenstein will it work?
- might have been screwed!!!!
- B20B build with Crower 405, question on valvetrain (Crower vs. Brian Crower vs. Isky)?
- gsr block, jdm itr os pistons, & ls crank???
- itr exhaust inner diameter
- Head porting quest, all motor, crower stage 3 cam, port for .500 ?
- smsp or hytech specs??
- what kind of cams for a 10.8 compression ratio???
- Dyno Tuned and Cam test
- 84mm Sleeves, 81mm Combustion chamber?
- OT: Tesla Motors Electric Roadster
- itr crank pulley any help...
- what kind of power??
- k20a ecu woes
- Please help me... Hunting Idle / Sputtering... I quit argh
- RM M22xx VS BC IV ?
- just want some opinions please
- AEM crank pulley vs CTR crank pulley
- b16a 10 000 miles burns alot off oil...
- what can I use to replace this hole?
- tps
- Signs of bad valve seals guides?
- What kind of lub on crank journals ?
- question about plastigauge
- Did a search and couldn't find anything...
- Question about the Intake Manfiold -_-"
- AllMotor Built ...Power Numbers....?
- piston clearence question
- engine rebuilding
- Ls burning oil
- Best crank and rods to use in B20/VTEC?
- SOHC Build. Input please.
- light throttle check engine light.
- starting and Idle problems
- Who does the best head workon h22 ???
- time to do an inframe re-ring job. help me chose the latest products for the best results
- Best Wheel/Slick combo for All Motor
- TIRE SIZE VS. WHP
- Added some bolt-ons...dynoed and lost power! Damn this N/A Game is Fraustrating...
- hp?
- best way to make PCV/brreather system B20
- neuspeed N2 header? any good?
- Tore down the engine, help diagnose problem here *PICS*
- Need a ride :P
- all motor fit
- IACV Idle Problems HELP!!!
- 450cc injectors????
- best crank for most power
- NA B18c6 85x87mm fully Built Help me with the head work!!
- NA B18c6 85x87mm Help me with the head work!!
- what pistons should i use for my LS Vtec
- Can i reuse a rod that spun a bearing ??? us b18c1 spun rod#3 bearing
- endyn rollerwaves
- 85mm B20B.. is it safe??
- ITB questions
- Kteller magnaflow muffler???
- Standard oi Big tube Tri Y?
- Forged rods and OEM pistons??
- bc3 valve adjustment
- B20 with B16 head--Are GSR cams better due to lower RPMs
- GSR plastic gauge help...
- Symptoms of having the MAP and TPS sensor plugs switched
- help on a build
- 200whp question?????
- ? Building my B18C5 ?
- Some Pics of My RMF Header!
- which size TB
- Stage one clutch
- Itr pistons and rods in a GSR block ????
- Does not accelerate well ?
- Engine cranks, does NOT turn over....
- compression difference pr3 and p30
- Nippon racing pistons any good?
- Can i use devcon to fill in my oem injector holes ?
- clearance issues w/ this set-up ??? searched
- Help with order of build.
- JDM p30 ecu + MSD 998cc
- Need Main Bearing Advice...
- 78mm T bodies for all motor..?
- es oval
- VTEC controllers
- who would you buy a custom basemap from?
- what is the stock bore of b and d series fuel rails?
- ebay N1 catback opinions
- what kind of header should i get for my ALL MOTOR b18a?
- air/fuel ratio????
- How does combustion chamber cc relate to rpm, hp, and compression ?
- Which cams? B16 cam selection poll like no other.
- OIL in Intake Manifold
- ITR header fit a b18a/b?
- Prelude LMAs, which year?
- Specs!
- pistons
- toda vtec killer cams
- Help
- What YOU'D to to an '01 b18c1.
- WILL LS ARP HEAD BOLTS WORK IN A GSR
- sir killing gas
- what springs and retainers for bc3 cams?
- what ecu for ?????
- Bosch platinum 2 plugs
- port and polish
- Questions about B18C5 PCT build I'm considering
- high compression flat pistons?
- My build got put on hold!!
- bearings
- Rebuilding a gsr motor for daily driving
- dyno rip off?
- b16a2 vs b18c1 trans
- Lightweight Eagle crank ??NA build
- Engine builders + Custom Cam grinding
- to b18 or to b20 ls vtec what u think
- Y am I running so rich?
- good price for installing stage 2 cams?
- b16b/b16a experience?
- CTR pistons,stock b16a
- Gsr Question
- COMMENTS NEEDED!!! HEAD WAS DAMAGED AND IS NOW FIXED AND PORTED+POLISHED.....
- anyone heard of this header
- ECU Help
- Spun a bearing...need ideas! Please help...lol
- any 200whp b18a/b or b20 non vtec's out there?
- engine builders
- My SMSP H22 Header came today!!!
- JDM B16b
- 5 Angle valve job nessesary???
- Buddy Club IV 4 Markings?? How do you identify them?
- tuning questions
- Do I need RC injector clips for plug and play on OBDI H22A1?
- question of the day
- chrome p72 odb1 ecu back to stock??
- Help quick question
- Which LSVTEC Aftermarket Pistons - Arias, Wiseco, Other?
- question about eagle h-beam rods
- Place to get motor built in VA?
- BEST PLUGS FOR ALL MOTOR
- what do i need to get to make my d16b7 all motor?
- Hytec question
- what will make more power on a gsr block b16 or gsr
- how much to $ and time to break in motor on the dyno?
- built motor but low compression?!?!
- need oponions on my lsvtec setup
- need help asap please
- Skunk2 K20A cams
- Parts diagrams/fiche for DOHC ZC?
- all head porters
- does anyone in ct tune chrome?
- any recommendation on catch cans?
- 83mm stock B series sleeves?????
- 1 more SMSP header user
- new project for 07 (street car)
- megan headers inlet size?
- HELP!!!!!
- what should i do next??
- Need Help IDLE with SKUNK 2 STAGE 2 CAMS on a B16A2
- My average built motor
- question about eagle rods
- S2P2's? or SMSP?
- import builders rods
- ls/vtec help
- Twin Loop mufflers??
- building a daily driver... starightup b16 or b20 block w/ b16 crank?
- Where did my oil go?
- whats cams to use for my B16 head
- Header and Flywheel Question.
- New Project for 07
- best cams for a stock JDM B16 XSi? CTR/ITR, Skunk2, Blox, BuddyClub?
- heres my first port and polish......
- GSR block?
- blox a or b on a b16a?
- GSR and B16a crank pulley??
- Which cams to run with Omni Valvetrain?
- BONE STOCK 94GSR????
- Help: FAQ about Supertech Valve Springs Lift Specs
- Getting no spark. Please read, just take a peek.
- power output.
- next project!
- New engine technology...
- Skunk2 pro2 Cam degree specs
- REBUILDING MY 01 GSR N/A BUILD PLEASE LEAVE COMMENTS AND INFO
- my stock h22 dyno
- faulty throttle body?
- Gearing effects on a dyno?
- FLY CUT ON HEAD?? yay or nay
- ITR or Blox?
- long block short block
- OBX?Blox Products?
- can someone recomend a shop to send head
- Northwest Dyno Day
- Ferrea Roller Cams
- Mild Built Gsr ....injector size?
- 2.0 L b-series , k20's , h22a's
- engine starts but cuts off
- 2nd gen LS question
- Head bolts
- Hydrolocked motor, rebuilt, and now no start. ANY help here?
- What size Injectors should I run?
- VTEC FOR CHRISTMAS graphs inside
- honing neccesary
- crome ls-vtec
- bearing clearances, questionable..
- anyone run Crower 43402's in a 1.6???
- stock exhaust hurting performace...?
- Help with squeak
- manley all motor rods
- Looking to build my first motor
- hows my mild port job (comments welcome)
- in need of help ASAP. complete obd1 LS swap into a 97EK
- Timing question
- headgasket question
- I need a gsr crank!
- best way to build a ek?
- i need a pole
- looking for a good tuner/shop in gulf coast area
- LMA help
- ls vtec possible?
- valve seats grinded to what specs?!?!?!
