- Any Built DART b20vtecs here?
- ls vtec VS b16a
- ITR intake on GSR EK swap...
- crankshaft help
- kseries header questions
- new motor idling to high
- D16 Build
- h22 injectors in a b18c1
- 85x89 CRX - Some "all motor" fun
- I GOT MASE'D 225whp 1.8L
- eagle stroker kit, oil squirters?
- SKUNK2 MANIFOLD QUES?
- 94 gsr all motor ... i need suggestions or opinions
- Anyone with TRI-Y replica header please read
- oil thickeners???
- Oil flow around 90* turn?
- Notching crossmember to clear header? CRX
- ft b & k series parts (PA +VA)
- Hows this graph look?? 81mm gsr
- lsvtec ?
- grinding valve angles what does it do
- Greddy around oil filter??
- K-series cams
- Quick Question
- engine help
- S2000 AP1 vs AP2 dyno graphs hondata and AFC Neo tuning
- b16 allmotor
- ls-vtec question
- Is this possible?
- 93 octane hp?
- h-motors online h22 buy
- need help with h2b swap!!!!
- Another Skunk2 Cam question
- aftermarket rods necessary?
- skunk2 tuner springs and ctr cam?
- Velocity Stack from Whale Penis
- upgrade to jdm itr intake mani?
- which would give lower ET's?
- My 95mm Stroker build almost running!! Thank You DFE!!!
- Question about rebuilding a b20 block
- help me choose camshafts...
- getting motor tuned/clutch break in
- LS n/a setup? higher comp? anybody
- Getting into the automotive industry.
- Denso Iridium tough model VK22G (5636) For ITR?
- who are your preferred and reputable motor builders
- help on coolant lines in throttle body...!!!!
- Installed Cams, and car feels lacking in power
- if i get jun3 cams....
- How do you install a b series alternator?
- Qustions on S2 Pro2 build
- ek itb install (throttel cable?)
- individual coils on b-series
- Anyone ever use a Performer X on a stockish combo?
- info on buddy club 3+'s on an itr motor
- b17 OBD 1 GSR " breif talk" about whats hot and whats not with this motor
- couple problems here. i need some input please.
- cam to use ? skunk2 pro2+ or 3+ help ..
- RMF header in an EF... Clearance problems?
- enough compression for skunk pro2 ?
- which intake is the best for my setup??
- K20 + jun cams + 15 CR pistons - what valvetrain and valve size?
- Head/Cam setup
- help please!!!!!
- Zero Compression on 3 Cylinders.
- need help with direction (f20b)
- How high?
- engine wiring...?
- D15B7 Bottom end Build ?
- LSV, need help with CAMS!?!?!
- these dont look like crowers??
- Surging idle, check the usual .. wtf?
- Intake System
- Need someone to validate my plan (B18C5??)
- TWM ITB's vs Complete Skunk2 / AEM setup (which to choose, 100 dollar difference????)
- Brian Crower 3's H22
- how to identify a s2 IM?
- confirming my CR.
- can b20 obd2 injectors fit my obd2 b16???
- Post your stroker B series set ups
- Hytech replica header BOLTs ???
- b20b 2-litre - which crank?
- lets try this again.
- 10:1 cr... highest HP? fastest 1/4 mile?
- B20 suggestions....
- SKunk2 Pro series cams
- Breaking timing belts once a month.
- Whats a good b18a1 setup?
- whats best for ls-vtec?
- b20vtec timing belt snapped..help
- B16
- does my '00 jdm B20B have oil squirters?
- rebuild cost?
- wat cams r these?
- All-Motor BIN Tune Directory
- GSR head gasket KO?
- Looking for Cams. Rocket M22x, or Crower 402?
- which flywheel?
- will a Thermal or Hondata heatshield gasket fit on a PerformerX setup
- Gsr
- Whats inside????
- Need help building my lsvtec.
- Is this is a true b16b cylinder head
- race header with a/c compressor??
- cam identification?
- IM and TB porting polishing...ect.. Looking for machinist.. can u answer my questions?
- bearing question-------------------------
- EG h22---------->h2b
- H22 CRX!
- What kind of AFRs you running ?
- Motor build suggestions
- Post DIY ITB set ups!
- B20Vtec stock sleve Usage and Mileage
- who does good D-series head work
- best cams, header & manifold TB combo for b20v stock bottom end
- what cams for my b16 head??
- Cam repair skunk2's can it be done
- Who has experience with Endyn's smaller chambers?
- Thought i'd share some helpful information. Found a true 3'' intake
- Omnimans bearing trick?
- B20/vtec cam help
- what is the best head
- K series i-VTEC Killers?
- Should i run b20b4 with a b16 head all motor or Turbo
- HELP: Identify transmission & final drive
- 90.7 to 97mm stroke - Street motor, bearing clearances
- Larger than OEM B series cranks (>89mm) in street cars....
- Original VS replica 5 zigen border max 304
- Skunk2 Cam Gears Noise Question
- whats the best 4-2-1 header for an ITR??
- OBD1 injector identify?
- Buddy Club Valvetrain in an LS
- exhaust for my setup
- Sparatic VTEC and loss of power - CRX B16
- High idle need help fast!!!!
- need help with head gasket please.
- injector fitting info
- 92 hatch all motor h2b or b20???
- H2b itbs or skunk2 manifold??
- LS NOT LSVTEC!..QUestions
- GSR Skunk2 manifold, what intake?
- doing it
- want opinions on parts
- exhaust smoke question
- fuel rail question
- lsvtec arp head stud question
- Shifting peak power?
- b16 road/race engine
- ls vtec drilling oil feed ?
- LS/VTEC w/GSR head....pistons???
- Help on Throttle Body
- ALLMOTOR LS/VTEC BEAST BUILD help
- 440cc???????????
- question b18 on nitrous
- Overlap ? regarding type-r cams
- I see alot of people who drag using 8-10 lb flywheels, why?
- Finally! 8 o ate + 237.3whp= a car that runs!
- GSR Longblock+LS crank/rods+P30 pistons(.25)=okay?
- what is a B20 vtec???
- When to use Aftermarket timing belt with cams?
- New build, few QUICK questions -b18c1-
- my DIY catch can for Bseries. non turbo
- diff. crank and rods
- Fully built GSR
- 300hp
- want to run old B18(non-Vtec) all motor on pump gas
- what header is better
- Are You Knife Edged????
- A motor for a 1/4 mile
- Check these vids out about the new 07' CTR
- ALL-MOTOR: WHATS BETTER LS/V OR B16 ???
- b20vtec base numbers? (no mods)
- A Question About These Pistons.....
- DET scanners. Who uses them? How did you make it?
- Intake throttle body and Intake manifold...
- BC spec 4 clearence issues
- Stock B16a Dyno results - Tuned by Mase
- help with my NA lsvtec build...
- 6600 vtec point pros and cons
- Aftermarket cams on stock ecu ok?
- XMAS EVE - REVSPEED Reveals all...
- Merry Christmas and Happy New Year to all of Honda-Tech!
- b20vtec roadrace
- my ls/vtec build!
- B16A with CTR pistons
- type r or gsr crank with b20 block..need sleeved?
- Buddy Club Spec 4 cams
- itbs or built b18c
- PISTON PICS WANTED - b16 or similar
- pro's con's b20vtec
- What's your favorite bolt-on?
- valve spring question
- Hondata S300 Users,.... i need a map
- howz holding the highest hp ls vtec??
- ITR PISTONS&WRIST PINS ON EAGLE H BEAM RODS???
- b20vtec??
- where can I find these.....
- help!
- Build up plan for my ITR
- velocity stacks , where does it count (itbs)
- H22 3 angle valve job??
- Porting the TB and IM? Is there any power gains?
- h22a w/ LSD trans swap into integra
- Port match Intake Mani H22
- JE pistons H22???
- whats a good website to order pistons at a decent price?
- HELP WITH 93 CIVIC SOHC D15B VTECH
- high compression pistons in a d motor?
- header temperature?
- H2b 92 hatch
- H22 Skunk2 Pro 2 Cam Specs
- 91 Accord - Trying to replace Fast Idle Control Valve
- Piston to Valve Clearence issues in VTEC
- Finding a crank to fit my rods :S
- blox tuner b cams stock vavletrain help
- Who's air intake is this (pic)?
- New air filter
- head work
- PR3 pistons in a stock b18c1
- Need Expert's Answer About This B16B Cams ASAP
- Forgot to lube release bearing shaft........
- comprossion ratio ?
- b20vtec?
- The Next "BIG DEAL" for HONDA'S
- Type-R Valve Springs Spec's?
- what cams should i put in my lsvtec
- F23 Rod question
- stock retainers with pro1 springs and cams?
- UGR Valves?? WTF?
- Cometic Gasket Alignment on LSV Build
- ATTN: ENGINE BUILDERS what is a good syntethic motor oil for Hot street engines?(tried search No pro
- Water droplets on my cylinder head gasket - normal?
- looking for a dyno tune shop in the Bay area CA.
- Valvetrain for BC3+ cams
- Tuning
- has anyone had cam cap or tower movement? see a use for this?
- What are you K series guys doing manifoldly speaking?
- 86mm gives how many HP over stock 81mm's
- Best shop for custom pistons??
- Looking for I beam Rods
- need a little help
- new to the import builder world ...need some help
- what kind of metal are the oem b series valves?
- . H22 help
- ANR compact vs. hytech replica
- B16
- ls vtec bearings?
- b20vtec..rs machine pistons..clearance
- exhaust question
- is a y8 obd1 or obd2...NEED HELP WITH MINI-ME...Head SWAP..
