PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Micro-Budget D16 Build
  2. Which bolts do i use?
  3. Looking for tech in Wisconsin! Anyone?
  4. how to find out if its a type r crank
  5. 1996 civic ex
  6. B18 eagle rods and srp piston help
  7. b16a head rocker arm inspection??
  8. H22A4 Motor Swap Problem !
  9. B17A1 Advice
  10. cilinder wall with chip safe or not safe? help pls
  11. need help with my ls vtec build
  12. B16A Intaking knocking.
  13. Suddenly can't rev past 7200rpms
  14. Header recomendation?
  15. Injector vacuum leak help please
  16. DHPS camshafts
  17. *Need Help* 90 Honda civic EF Wont start (Read Please)
  18. ARP Stud question
  19. 00 b16a2 motors parts
  20. b18 c1
  21. average dyno results for B16A?
  22. sonic boom!
  23. stock LSvtec
  24. High Compression
  25. ? best all motor cams
  26. Pro3 cam dyno and build
  27. B16A With gsr stroke
  28. H22...Euro-R vs. Skunk2 Manifold???
  29. Compression Test
  30. hybrid b16,more q's
  31. no power to injectors
  32. ls vtec question
  33. need to change fuel pump?
  34. d series injector work on b16?
  35. obd0 dpfi to obd1 mpfi
  36. torque specs
  37. Machining wrist pin lock grooves into CTR pistons for forged rods?
  38. plz delete this...found answer
  39. LSVTEC WIRING HELP PLZ
  40. b18c1 block b16a head
  41. 84.5MM 12.8CR pro2ed B20vtec daily driver :)
  42. apexi ws1?
  43. skunk2 pro2 cam timing
  44. obd2 ecu start and ond1 motor
  45. My attempt at using a velocity stack....
  46. Anoying low rpm/light throttle hesitation problem... O2 related??
  47. Help with choosing intake manifold and TB !
  48. B16 ticking during idle only!?
  49. obd1 b16 does not start
  50. adjusted cam gear affects compression test?
  51. ls fuel rail on b16 engine
  52. LSVtec wanting a little more hp. 205 WHP....wanting more 215-220whp or more?!
  53. question...
  54. Blown Gsr Head Pics
  55. B18C1----Hesitation/Dying
  56. ITB's with air filter?
  57. Crank angle sensor
  58. gsr with itr pistons
  59. compression ratio
  60. What size Injectors should be used?
  61. D Series Questions
  62. THINKiNG ABOUT GOIN F HELP!!
  63. Buying GSR block w/ CTR pistons, need advice on what else need
  64. I need help dealing with RLZ
  65. Timing issue on new swap..maybe?
  66. my b16 build
  67. What size ARP rod bolts for B16?
  68. messin with the d16z6
  69. b20 vtec itb setup
  70. BCS3 drop in??
  71. B20 84.5mm ITR with PRO1's...
  72. LS vtec newbie here, got a overheating problem.
  73. what injectors?
  74. what would i have to do to put a b16 or b18 in my 88 civic?
  75. Ls/Vtec or turbo
  76. What is your advice to run 11.0-11.1 sec. in this all motor?
  77. stock gsr pistons or not
  78. Mystery cams....help
  79. GSR Block on b16 head?
  80. Camshaft questions for BC's and Skunk2s
  81. 2.0 LS/Vtec Video
  82. ITR cams in stock piston B20z
  83. CEL code 9 CYP - cylinder sensor
  84. anyone running this?? greddy alumin upper rad hose
  85. na build piston question
  86. Engine knocking only when warm up
  87. b18c deck height?
  88. help idenfitying cams
  89. Wiseco Pistons H22A
  90. All Motor ZC.
  91. compression ratio help
  92. d16 head milled
  93. what HG are you using for 87mm bore bseries?
  94. Whats My Built B18c1 worth?
  95. Best Way to make 400WHP?
  96. crank 95mm.
  97. ehxaust rasp
  98. Post your stock sleeve H22 builds!!!
  99. EG tb heater bypass
  100. Driverside Oil Leak: Headgasket or Cam Seals?
  101. only gained 15 hp
  102. 94-95 GSR/Type-R oil cooler install on a 97 GSR
  103. need 5-10whp more!!
  104. ORD Massive GSR Intake Works for B16 Head and ORD Custom Header (2.2L All Motor)
  105. OS H22A Type S Piston Availability
  106. My Ported H22a Dyno
  107. .
  108. Build my A6 or build a Z6 Minime
  109. what pistons to use
  110. B18c with CTR pistons 81.75
  111. Bore, or stroke a B18C?
  112. B20 Vtech All Motor with Nitrous Injection Question?
  113. my ebay clutch that could
  114. stock LS rod strength...
  115. ignition wires
  116. thick headgasket?
  117. B20 Vtec ignition timing?
  118. Confused on wat clutch to run!
  119. need advice on gsr rebuild
  120. my setup, your thoughts?
  121. After Rebuild Antifreez in the Oil.
  122. Estimated HP out of built LS/Vtec
  123. Blox B-Series VTEC High Compression Valve Set
  124. gsr/ls deck height??? need help asap!
  125. LS/Vtec
  126. High comp lsv stage 3 cams 196whp on basemap
  127. b20/vtec or ls/vtec?
  128. Gsr B18c1 Build query
  129. b18a1 bearing question
  130. old skool ZC builds? DUAL CARBS
  131. GSR HP intake mani vs. victor X mani
  132. p72 Head On B16a2 Block Questions??
  133. Broke B16, now what??
  134. Motor running hot after build. Whats wrong??
  135. All motor b series setup question
  136. ITR Bottom End, RDR Head, S2S2's, 221whp/151wtq
  137. normal looking wear on pistons?
  138. A sneak peak...
  139. B16a3 rebuild with ctr pistons recommendations?
  140. sk2 s2 cam gears tune
  141. B18C with b16a2 Head Questions and help.
  142. building a beater ls/vtec piston question
  143. Shaft Problem
  144. Does SMS still make headers?
  145. Twisted Sisters...3 All motor sleepers..
  146. skunk2 pro series i.m. vs oem type r (retro fit for non-vtec motors)
  147. looking to purchase cams, need assistance
  148. B18b Swap Surging Problem
  149. Dizzy Question, B Swap
  150. Blown engine
  151. Anyone Wanna Guess My Compression For Me?
  152. HELP HELP HELP..... HELP!
  153. just replaced my main bearings and rod bearings now engine wont move
  154. Ported GSR head Part II , The chambers.
  155. VTEC will not work on aftermarket catback system?
  156. header question
  157. how high of compression can you make a stock pistoned ls motor
  158. valve lash and compression?
  159. My TACHOMETER is spazzing out!
  160. stroker motor question
  161. B18a obd1 valve cover on 98 b18b, pcv valve question.
  162. head swap problem
  163. B20 VTEC BUILD ALL MOTOR QUESTIONS
  164. coolant issue!
  165. How much longer is the tri y header & rmf header
  166. Rear Main oil seal?
  167. valve releifs?
  168. b20v all motor build
  169. MY CRX LSVTEC BUILD SO FAR!!!!
  170. Most efficent Ls Vtec build Need Suggestions
  171. Fresh Rebuilt Motor Runs like Crap!
  172. RCautoworks goes to the drag strip( all motor h22 )
  173. Where can I find washers for prelude lma's to put in b16
  174. lsvtec .. running on ls dizzy
  175. b20v adjustable cams?
  176. LS/VTEC WIRING PLEASE NEED HELP
  177. what oil for new stock rebuild
  178. How many Horses?!?
  179. head resurfacing question
  180. d16z6 high compression question
  181. Fully built on type R engine or CR VTEC
  182. b18cr build questions
  183. fully built head cam problem
  184. hondata s300...cold start...hot start...idle issue help!
  185. TPS & throttle cable Q
  186. The best way to build my LS CRX(All Motor)
  187. Valve Questions
  188. aem itr cai vs injen itr cai
  189. innovative vs hasport
  190. B18A with CTR(pct) pistons 11.77cr or 12.81cr??
  191. FORGED LS VTEC BUILD ISSUE.
  192. pic request please
  193. B18b Running Rich
  194. Need Help Please!!! B20/VTEC possible dropped valve
  195. D16Z6 Swap
  196. Skunk2 Manifold vs. EURO R Manifold H22A engine??
  197. Skunk2 IM vs AEBS IM
  198. jdm B16a with 12:1 compression. bigger injectors???
  199. Surging at 1500rpm
  200. cam selection
  201. Eagle H-Beams/CTR's
  202. b17 start up question
  203. H22 vtec/oil pressure issue
  204. I Have a Rare Oiling Problem
  205. Reverse Rotation Engines
  206. Need Help with new rebuild
  207. valve clearance (b16a3). someone set my mind at ease
  208. spun bearing? bent valve?
  209. All Motor forum [FAQ]
  210. do i need a radiator fan?
  211. Are engine swaps always trustable?
  212. b16a block w/ 87mm crank
  213. my new b20 build.
  214. Arp 9mm 8740 bolts
  215. Hastings 81mm rings on 82mm pistons
  216. Possible Torque...
  217. oil or wd40 rings?
  218. size of freeze plug
  219. obd1 p28 on obd0 b16
  220. B16 producing white smoke?
  221. is a 72mm tb and port matched intake mani to big!
  222. Fresh Rebuild, runs but will not Idle...
  223. Header and Radiator clearance.
  224. How would you know if your car has aftermarket cams?
  225. CTR's on b16 Rods?
  226. bone stock 207whp 160tq h2b swap eg
  227. Vid of Bisimoto F22A 9sec passes..all motor
  228. My first dyno. B18C1 - 201 WHP / 133 TQ
  229. vtec
  230. h22 hatch new dyno numbers
  231. b20 crank
  232. I have a slight hiccup on idle
  233. k20a intake manifold on k24a1, fit?
  234. HELP! Need the real information about block girdles!?
  235. gsr dizzy on b16 head
  236. Supertech Light Weight Aluminum Retainers
  237. machine shops in MD?
  238. ls build
  239. D16Y8 oil pump. Can you swap in a D16Z6 pump?
  240. cant decide.... oppinions please!!
  241. GSR Skunk2 IM / Skunk 2 TB in a EK(4dr) HELP !!
  242. turbo guy going N/A
  243. post your intake manifold
  244. My AM GSR Died - Help Needed ASAP
  245. B18B LS Help!!!
  246. Am I choking my motor?
  247. Skunk 2 Pro 2 Cam Degreeing follow up question
  248. What is a 3 angle valve job?
  249. Cant identify these camshafts
  250. Shift Linkage/Tranny Problem
