PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. B20
  2. skunk2 cam gears?
  3. Civic Type RX
  4. b16 pistons in b18c5 block??
  5. Snapped timing belt, 92 accord
  6. car wont start...ls vtec
  7. Skunk2 stage2 cams vs Toda Spec C!
  8. ls vtec...help
  9. Cool video of what happens inside a combustion chamber (not animation)
  10. planned to build a poorman's ITR engine
  11. >>03 Type-s With K20a Tuned At Churchautomotive<<
  12. TB coolant bypass, quick question...
  13. Buying a EG4 with B18C4 block and head with b20 crank. Opinions?
  14. b18c5
  15. Lsvtec build...
  16. milling head/ block ls/vtec
  17. pcts in b16A ?
  18. WOW! MY girlfriend just ordered me a scat 92mm crank for my build,
  19. b series tranny help
  20. itb's rsx?
  21. 81mm lsvtec with pro2 cams
  22. Head torque, and torquing bolts in general
  23. pr3's in a LS
  24. B18C5 engine with B16B ECU?
  25. need help on smog =T
  26. who would you recomend to get your head done around (nor cal) or (so cal)
  27. gsr build
  28. Mild build and Mugen Twin Loop
  29. JVT Racing Header?
  30. LS V Head Gasket
  31. which NON vtec cam for stock vavle train?
  32. Hondata IM gasket, where to buy?
  33. serial number on the motor??
  34. Power prediction anyone? (1834cc B18C4 + mods)
  35. Need a stock GSR .bin ASAP PLEASE
  36. gsr block b16 head what pistons
  37. My TWM ITBs need to breath better!
  38. Benefits of using a GSR crank in a B20 block?
  39. Civic Type R pulley...what belt??
  40. why obd0 better that obd1?
  41. first time rebuilding engine... need some help
  42. witch is better? f23 crank or h23?
  43. TB coolant bypassed? Insulated Gaskets? Under hood tempratures? Looking for 10 HP
  44. k24/k20 pan baffle or no baffle?
  45. Omni Titanium Retainers and dual valve springs with
  46. TWM ITB modification
  47. JDM D15B non-Vtec
  48. CR for daily driver
  49. Will this setup net me close to 140whp
  50. In need or SERIOUS help...
  51. LS flat faced valves?
  52. Idle problem HELP!!!
  53. Best Cams for LS V
  54. YSK-1 tranny
  55. Valve adjustment?
  56. GSR Mild Build
  57. wht is best for na in a delslo?
  58. b16 head question
  59. OMNI throttle body???
  60. D16A6 Raising Compression
  61. endyn cams
  62. bored
  63. Where to buy portflow inners?
  64. my na oem lsvtec build dyno
  65. My new H22 manifold courtesy of Lovefab
  66. Anyone know if all K24 Cranks are the same?
  67. Getting Tuned and Passing Inspection/Emissions
  68. Too much RICE BURNER sound...!!
  69. h23 manual tensioner
  70. b18a mild head work help
  71. question on possibly a future build
  72. fully floating or press fit wrist pins?
  73. temp gauge problem
  74. b20 vs b18
  75. "Official" All Motor LS B18a, B18b - DOHC NONvtec
  76. Anyone had this problem after an align hone....
  77. Ls/vtec balancing question
  78. My Build Up Not getting The Track Times I hoped For
  79. dc- 4-1 2.5" mod?
  80. Rebuilt B18B
  81. Skunk2 stage2 cams (B18c)
  82. Tail user???????
  83. GSR whp
  84. building a poormans type r.....what do you think.........
  85. 98' Spec JDM ITR Dyno result
  86. JDM d15b
  87. high fuel pressure = bad mileage?
  88. ZC swap in 91 SI: Idle problem... All out of idea's
  89. My b20 non-vtec build
  90. retainers
  91. Help! What Kind Of Headers Do I Get?
  92. which injector size do i get??
  93. h22 build need help with arp rod bolts for f23 rods
  94. How to build B16A2
  95. crower 403's or 404's?
  96. what ecu should i use
  97. supertech valve springs w/ stock retainers???
  98. b20 vtec
  99. ls vtec build
  100. What cams
  101. CTR piston ques
  102. GSR build ques
  103. Whats the differenece between AEM short ram, AEM cold air?
  104. ported b16a head vs. ported b18c head?
  105. Where to buy 3" piping Cold Air Intake?
  106. as far as clearances is this to tight?
  107. NEW CTR PISTONS
  108. ls vtec build ( what type of tranny and clutch)
  109. m24x is too much?
  110. Where to purchase valve seat cutters for Honda/Acura heads
  111. Crank no start ????? Have no idea at this point
  112. what would u rather do? take a look.
  113. Opinion's on Mugen Ek Intake vs DC Mugen Intake
  114. Reading Spark plugs
  115. Aftermarket Fans
  116. 9CivicHatch3's Stock Type R with BPI and Rage/Hytech Copy Makes 186WHP
  117. b16 all motor?
  118. Do you guys run A/C or P/S (or both) with your all motor builds?
  119. middle rocker arm wear?
  120. GSR block, P30 pistons, resurfaced GSR head. Claying necessary?
  121. difference between a short block and long block b18/b20
  122. Tighter v2p clearance?
  123. how much of a clearance diff do o/s valves make?
  124. Anyone know what happened to Underground Racing USA????
  125. D16Z6 valve springs
  126. need some help cams and injectors
  127. h22a timing
  128. camshaft installation question
  129. Shhoting for 180WHP??? Need Help!!!
  130. K24A4 Head Swap K20A?
  131. VTEC = Black/Grey Smoke :S
  132. LS cam choice?
  133. any cams
  134. Where to buy a new motor
  135. Standard or oversized engine bearings for LS/Vtec build
  136. BIG PROBLEMS... LOTS OF SMOKE
  137. Upgrading pistons
  138. Manifold to head bolt torque specs for B18C5- not in manual -what are they?
  139. Start help
  140. itb air filters.. itb pros need help
  141. d16y8/d15b7 build
  142. poll for d-series headers
  143. motor swappin
  144. cam degree
  145. Good Info from team-integra.net
  146. Enogh to get to 200whp?
  147. spark plugs
  148. Skunk
  149. ITR motor not hitting VTEC
  150. My Build Thread + a question (What clutch are you mildly built ls/vtec guys using?)
  151. OEM b-series retainer to guide clearance
  152. Total Timing 20 ????
  153. Rocket Motorsports
  154. RS*R vs Edelbrock - Headers
  155. B20vtec dynoed... not that great results.
  156. JGE header any Comments on its design
  157. ~220whp ls/vtec in 94' ex good for 12s?
  158. Vafc settings HELP
  159. whats up with the light
  160. header compatibility???
  161. Edelbrock Pro Flow Header #6737
  162. Best motor to get 300hp with itb???
  163. smsp b20vtec header vs toda racing header
  164. LS VTEC CAM ?
  165. spark plugs for lsvtec?
  166. all motor LS
  167. Custom B16 piston on an LS / B18 rod?
  168. what intake and header for b16?
  169. B18C burning oil
  170. runnning very rich
  171. im running on a h swap help!!!!!
  172. HELP! Whats Best Spark Plugs?
  173. HELP! I need new distributor!
  174. Which Cams is the best??
  175. 1998 Honda CRV Upgrade
  176. B18 non vtec/b16 pistons...i need settings opinions
  177. b18c built head question..
  178. pro fab header problem
  179. Tuning question
  180. hmmmm pistons?
  181. Anything Knows these intake manifold?
  182. Compression calculator?
  183. buddy club cam gears springs
  184. blox hsl?
  185. B16B to 1.8 conversion what pistons
  186. Engine surging in combination with overheat - 93 Accord
  187. si vs gsr head
  188. help problems with gearbox or clutch?? help please
  189. boring?
  190. WTB: b-series header
  191. WTB: B16 header
  192. bseries header: mugen or dc
  193. Piston to Valve clearence
  194. WHAT CAMS ARE BETTER?
  195. cam timing issues
  196. Best Performance Honda Motor? ? ?
  197. My eg h22
  198. what is to high of a compression?
  199. s2s2 ideal compresion
  200. Question about spools
  201. aftermarket rods on b16 pistons?
  202. maximum performance on Type R
  203. head question
  204. cam selection
  205. automatic power
  206. DH Racing
  207. Ls Vtec Clearance issues
  208. eCtune on my build QUICK QUESTION
  209. B series head builder?
  210. Using a Variable length intake manifold to produce boost.
  211. prologger
  212. simple oem gsr build dyno numbers
  213. gsr rods in ls???
  214. d15b7 help !!!
  215. Cylinder wall chip. GSR block.
  216. Just wanted to say thanks!!!
  217. buddy club spec III cams or spec iv
  218. civic type-r vs. teg type-r cams
  219. EG build ... anyone got opinions???
  220. B16 head and B18C1 Block Help!
  221. Vtec Help
  222. LS Rod Dimensions vs. c1/c5 Rods
  223. Chamfered Bearings
  224. Ls-Vtec
  225. Help! got my car tuned last year and a/f is off...
  226. Question? From having Cam Specs, Finding degree settings to use..
  227. .25 OS which head gasket?
  228. b18a1 motor
  229. do DH racing throttle bodies still suck???
  230. Good price?
  231. My First Ls/Vtec Build
  232. ffffff
  233. hayward ITBs
  234. Ls/Vtec Comp?
  235. ROD LENGTHS?
  236. Allmotor.. Transmission Help H22
  237. Ls/vtec idling issues?
  238. what clearances everybody using? help appreciated
  239. Will P30s fit on LS rods With no machining????
  240. i got a fully built JG type r head, what block should i use?
  241. skunk2 pro3's with 12.5:1 compression pistons, valves hitting pistons. need info
  242. Rm M23?
  243. B16 swap issues???
  244. pistons hitting (gsr problem 911)
  245. Clutch install, now got some problems
  246. easy question
  247. what rods??
  248. Stock JDM H22A CrankShaft Limits
  249. F22B2 Honda Challenge Build
  250. My LS Vtec Build
