- Custom ITB, Which are best/easiest to work with
- Taking off flywheel
- all motor b20 vtec, but what exhaust?
- 93 honda civic h22 swap
- dyno graph*da*gsr*stock*itr cams*skunk2 manifold*obd0*search friendly*
- strange grinding noise coming from motor
- ANYONE RUNNING CROWER 63403'S(III) WITH CTR'S/PCT IN A GSR??????
- Any one making over 200 with a similar setup to mine?
- ls vtec
- Eristik head gasket
- seafoam causing knock
- crome FTS help
- Cams in dohc zc
- best cam for setup
- CTR cams for low end?
- Exhaust Advice
- PACE SETTER exhaust.
- Please help with H22a engine swap
- anyone delt with REV VALVES ?????<<<<<<<<<<<<<<<,,
- need thought and opinions on d series buildup...
- anyone know how i can contact MAX HA RACING?
- N1 pulley timing marks different???
- building LS vtec
- Feel the Power
- Flow Testing Results of (4) Catalytic Converters
- cams id plz need help
- what the diff
- TWM ITBs: IACV and IAT sensors
- how well does stock EG airbox flow?
- I need camshafts Jun III
- Crower 402 cams in Stock b16a2 Is it safe?
- ARP head stud install question
- b20 w/ gsr crank and rods
- idle problems
- GSXR Throttle Body Size Listing And Info
- b20z pistons, valve reliefs
- Intake Cam vs. Exhaust Cam
- hey tell me what u think!
- need advice.... b18c5 build....
- SKUNK2 Intake Manifold
- DC race, Jun, or Toda header?
- toda itb's - what are their limitations? displacement/ compression ratio?
- CTR Cams - which cam gears?
- who makes and is selling ITBs gsxITBS
- Ls Vtec? HELP???
- I-VTEC-I....65:1 AIR FUEL RATIO.....FUCKING SIIIICCCKK..
- ACL Bearings? Opinions?
- Field's SFC settings in all motor 2000 SI
- What fluid do I run in my b16 box with a stock LSD?
- Is CTR ECU Tunable?
- aem hyrid cai?
- Stg2 cams + mo goin in. Do i need.. ?
- toda spec c installation help needed...
- STOCK B18C1
- IM Problems... NEED HELP!!
- i need help car smokes
- Sound clips of my catless RS*R exhaust!
- what do i need to tune hondata myself?
- head work
- compression after head milling
- B20 Blpck...Need high compression 84mm OEM pistons!
- Motor swap advice.
- New Guy
- AN-R Header differences
- M24x vs. BC4's....(Tbone/Rocket???)
- Cant Identify these cams
- new here. opinions on my lsvtec ??
- Where to buy 50mm Throttle Body's/Velocity stacks/Filters
- z6 150hp all motor
- No VTEC
- crvtec compression ratio
- Exospeed d-series headwork?
- Header decision?
- Looking for a machine shop in the bay area.
- Aight Need Intake Manifold Decision Help
- chip installation
- 3 Angle Valve question
- 2.2 Vtec Prelude Gots hot with Vtec...please help.
- Help a weak mind decide (clutch/PP setup on high CR DOHC)
- D17 crank in a y8 motor................possible??
- GSR Crank Girdle in LS Problem
- My not so great CBR 954 ITB setup...
- Theory on J's style intake?
- injectors
- quick pistons Q?
- ECU form ITR
- What TODA timing belt for LS/VTEC
- LS tranny gear ratio's after 4.9 final drive.
- B20 rods & JE pistons
- skunk 2 stage 2s
- Header Test: Local Car Needed
- d15b japan motor problem
- Engine setup in relation to Auto-x???
- ITB DO THEY REALLY MAKE A DIFFERENCE
- Motor swap problems, please help me out!
- Recieved my AN-R Standard Header.
- HOW RELIABLE IS SKUNK2 stg2
- Ls/Vtec Help. what am i doing wrong?
- what is a good fuel pump?
- Buddy Club stage 4 and Portflow springs
- itb question?
- attn moderator..
- poor mans type r build
- b16's into gsr block
- CTR CAMS IN B16 VTEC AT 4400 IS THAT GOOD?
- Stage 1 Cams vs CTR on bolt on motor
- b16 head VS GSR head.
- Tuning With Race Gas?
- Low compression pistons...
- Engine gasket rebuild sets - B18 kit work for B20?
- Rods and Bolts Question? For a B18C-R
- Front engine stiffener needed?
- orginal diameter
- Rebuild engine and a swap
- Cam Questioin
- Crank Questions
- bottom end kits
- nitrous with high compression and lots of overlap?
- question on how to set up MSD :thumpup:
- Rare P8R head
- Dyno in Richmond metro area?
- f22b1 fuel problems on 94 accord ex
- Milled head timing belt problems??
- Alot of rattling, need help.
- Best header only drag with exhaust???
- Big cams
- ATTN: LS/VTEC GUYS... SAFC baseline maps?
- 2.0 CRVTEC HEADER INFO AND WTB !!! crx...
- B16 + 10K RPM = Need Block Girdle?
- Bad gas milage after CAI HELP
- help with motor in eg hatch
- dual valve springs?
- B18C Crankshaft
- Whats wrong with my car? Was driving then loud POW now no start?
- Hybrid_vtec's N/A LS Dyno
- IM similarity b16 an d16
- Is my header cracked at the flange/primary? Where is this gunk coming from?
- safe way to hit 9800 rpm
- why has no one used an s2k motor transversley yet
- Head milling?
- cams help!!!!! itr or better...check the specs..
- cometic head gasket question
- B20 comp question
- Opinions on Planned Setup
- B16B DYNO RESULTS IN A 94 HATCH.
- open header question ??????? power!!!
- B16 Head Question
- Pics of my RS*R EXMAG on my EM1 Si + review
- p&p in orlando?
- Help me with my 1986??????????
- Injector ????
- Endyn AIR manifold for NA?
- all motor gsr
- Any b20 builds?
- Best Upgrade for B16 with I/h/e ??!?! help
- b20b b20z
- header again
- k20 or k24????
- Need a turbo for an 04 civic ex
- b16 itb's
- obd1 motors?
- Throttle Body with FITV...need help ASAP!!!
- blown jdm b16a motor
- what is this for??
- valvetrain questions on y8 motor
- www. for honda parts (fuel pump)
- suggestion on a d16y8 set up
- anyone heard of peak performance?
- Throttle body
- Anyone ever have an engine built by z10 Engineering?
- itr piston in my LS motor will work fine?
- ls/vtec motor question...
- diy cold air box
- B16B Fuel Pressure (Don't ask, I searched!)
- MOUNT QUESTION
- AEM Fuel RAIL
- D16 Stroker
- race gas?
- aftermarket keepers for building h22 head?
- 3 inch exhuast (dont give me a lecture, i'm going turbo)
- itb's
- Wierd ticking when im on the gas, bad throttle response
- 5th gear VTEC MALFUNCTION
- Why remove secondaries?
- Camshaft help
- Power gains
- i need to know this CP 84mm COmpression ratio!i run in my b20b wif b16a2 head later!
- skunk2 stage 2 cams versus buddy club 4 cams
- 94 up gsr cams horsepower diff vs stock 88-91 b16a cams.
- Mainstream presents- AEBS Vs SIR1 b16 IM
- H22 headwork help!!!
- Is "ticking" common with test pipes?
- Polyurethane Mounts, would this work?
- Blox Competition Series HSL (High Speed Lift)?
- ALANIZ HEAD!!!!!!!
- after market oil pan??
- Cam gear adjustments
- Damaged CTR cam, repairable?
- Blox GSR IM
- d15 injectors on b16?
- what sensor is this?!
- obd1 engine with obd2 oil pump?
- how much hp?
- Engine Builder's I Need Your Advice: 95mm stroked B-series Block.
- Injector question
- exhaust gasket? Please help.
- ---> a CR-V motor in trouble, need your help.
- Best Swap For My Del Sol
- Looking for a mechanic to install ctr pistons into my gsr!
- 91 integra needs help
- Calling all ITB users....
- OBX Header
- Smelling Fuel with my JDM ITR civic coupe. Help Please.
- Head question, little help.
- ebay flywheel
- Another Cam Inquiry
- JDM B16 with no compression
- Hondata Help!!!
- 2000 SI ECU Tuning
- How much is the VTECb20 SMSP header ?
- Hayabusa fuel injectors VS Stock H22A 345 CC injectors which one is better?
- just purchased blox stg2'
- Help me decide on valves, all motor daily driver
- cam selection and question
- When do dual-valve springs come into nesseccity?
- ls/vtec swap
- All Motor B-series Question (b18 head/b20 block) high comp. pistons????
- Knock Code at wierd times...
- ITR, CTR, or P30 pistons for LS-vtec
- d16z6 camshaft installation
- power increase from 81mm to 85mm bore.
- b16 or ls/vtec need some advice
- ARC induction box
- valvecover internal oil baffle removal
- LsV
- lowering compression...need a head gasket, please help
- b18a into a 92-95 civic
- cryotreating..really necessary?
- CP Pistons need info!this set piston compression ratio i need to know!84mm seller told me wil
- ls/vtec compression and cams
- LS Rods in a Gsr Block
- Need a little
- *Video* 2.0L on ITB's
- high compression?
- _flywheels...._
- Apexi N1
- The official Stoker Kit thread
- CFM #s of Heads
- how many degrees retard and advance ctr intake and itr exhaust cam?
- H23 vs B18c1
