- homebrew B20?
- Kenji's ECU chip?
- rod bolts...
- smell a lil gas in my oil
- type R header good for b20vtec?
- Built b16a back from the shop, opinions needed!
- what bore?b18c1
- Got the b16a dyno'd - Mustang Dyno
- O2 sensor question
- cam timing
- What is the Quitest Exhaust??
- Is their a better factory pully for my C5?
- Hesitation / Fuel system problem? (descriptive post)
- best way to tune a b16?
- Spark Plug Newbie Question
- Is this true about resurfacing?
- valve float
- Size of pipe on side exit???
- b20 vtec question....
- b20vtec help...?
- Anyone know any 94+ octane pump spots near Long Beach CA?
- retainers for toda b's, daily driven
- Trade my Toda Spec D's for Skunk 3's?
- b16a2 mani on typeR
- Need help!!!! ASAP....
- Dh-racing.com opinions ?
- Zdyne gold ecu Q's
- time to introduce myself to yall
- 13.0 on street tires in a ek hatch....how hard?
- Cheapest place to get Eagle rods???
- Scuffed Piston
- Has anyone had any luck with this eBay header?
- H22 civic clips?? anyone?
- B20Z with what tranny, GSR or SIR
- strength of GSR rods
- question about injectors
- crank pully
- Why Does Aftermarket Headers Make You Run Lean?
- Where the tools at???
- How to "clean-up" ports and combustion chamber
- Those with deckplates...what headstuds are you using?
- Piston reliability - PR3 vs. P30 vs. ITR vs. CTR
- Lightened or Lightweight axles
- 247WHP/182TQ 12/1 comp H22 on 91octane
- oil squiter
- head porting - MAX CFM..??
- rs dominators cams
- EF-1 cams are reliable
- whaT R THR PROS AND CONS OF A LIGHTEN FLYWHEEL
- where can i find toda,jun cams
- Can i get 200 WHP with this setup?
- tell me what u think of my NEW EQUAL LENGTH RACE HEADER
- Best cams for 14:1 compression l/s vtec
- Do Headers affect Air Fuel readings ?
- B16A1 vs. B16A2 ... differences ...
- Importance of a true 2.5 inch exhaust....
- People with LS/VTEC setups please read(question on ECU tuning)
- anybody have aftermarket h22 camshafts???
- Best stroker kit.
- simple question
- anyone heard of Finish Line in Southern Oregon, Sacramento.
- ls /vtec oil squiter jets..
- all motor gsr lose power to this?
- best intake manifold for a gsr
- Oil catch can for NA motors
- RC 270CC IN GSR
- I just ordered mine and so should you!
- B18C1 vs B18C5
- spoon engine????? or spoon stroker kit
- 2.25" or 2.5" exhaust for b16
- anyone use SMC for fuel tuning?
- building motor from scratch
- ctr pistons on ls vtec use what octane??? who has jerry built # n address?
- Bisimoto New revised B series header
- cylinder head rebuild
- b20 max bore.... did search
- Y1 tranny flywheel removal...
- skunk2 st 2cams work better with portflow or skunk2 valvetrain
- QUESTION FOR ALL OF THE DEL SOL FOLKS
- type s cam part #
- ef-1 valvetrain
- AN-R.com Answer Please
- SMS Products Header
- What do bad valve seals look like..?
- ARP rod bolts nesscarry for mild lsvtec setup?
- Piston- Valve Clearance for Jun 3 Cams
- H/T/E?
- B16/GSR Build Up Vs. ITR Motor
- piston ring gapping
- Here's my Set-up, guess my HP...
- Anyone seen this traction bar?
- Would a fully built B20 12.1 comp. block not be able to work on a stock head w/ stock cams?
- ? on ferrea rockers
- What cams should I get for LS/VTEC setup "I dont want to rev past 8500rpm"
- Opinions on these EF-1 Cams with this setup??
- TB and IM install?
- All K manifold flanges the same??
- 200+whp and somg legal at the same time?
- 2.0L specific headers?
- spoon sport ecu?
- compression noise?
- Reliability of all motor?
- CTR n ITR for b16 n ls vtec set up
- b16 head and gsr block combo in 90 civic SI?
- i need help about LS_VTEC set up n B16!!! help meeh someone
- HELP?? Will this setup need aftermarket cams or
- does anyone have a b20vtec that revs to 8500k-9k rpm?
- 00 si' what should i do next ?
- hondata "type" IM gaskets...how many are there?
- ITR vs. CTR cams/pistons in my GS-R - questions
- I need Help !!!!
- Need a Diagram for MSD Dist. Cap
- Lost Motion Assembly
- Which cams wil work with my crower springs?
- i really need HELP. b16
- what causes pressure leak in fuel rail?
- where to get a JDM 4 to 1 header?
- white smoke coming out of head?
- *dumb question* removing speedo cable on b18a
- anybody ever bought from www.acuraautomotiveparts.org?
- Which all motor engine is the best?
- big bore d16 vs. b18 swap
- Need feed back for rebuild!
- ef-1
- Colder or hotter plugs for a fully built n/a set up?
- Air/Fuel Readings
- Are there any down falls to running stroker kits
- ge vtec oil return kit .... how much does it cost and where can i get
- just some observations of my car...toda reliabilty, daily driving, etc
- Speaking of block girdles...
- shaved b16a heads on a b18c block?
- quarter mile times vs. transmission ratio
- Poor mans Itr setup questions.
- Can anyone rec. a good shop to ceramic-coat headers in LA?
- FJO Wide Banod O2
- Kenji ECU Questions
- 10.1 compression in a stock gsr
- Questions on tranny setup
- Why is the resisitance diff. on my stock LS injector vs. ITR injector?????
- got one for u tech guys
- Problem with my tranny
- OKAY!!!! cRazy cams for cheap... but NOBODY WANTS THEM!!!! why???????
- Build my motor!
- Sgt tunning comes to new england. Tunning spots available.(hondata and more)
- Intake Question?
- Anyone using a 1 layer headgasket?
- will a B16A head fit on a B18C1 block ?
- all motor set up you guys want?
- Question about Dart and block girdles.
- Anyone have a CTR AKA: B16b swap?
- any problems with ARP studs breaking?
- what hp with i get with p30 in b18b
- Head Job!
- All motor gurus, please help. Couple questions..
- which FPR is the best?
- ARP head studs
- Prices on sleeving
- whats the best manifold for n/a
- steps on makin a ls/vtec
- Spoon LSD
- Difference Between B16a and B16b Exhuast Cam
- Advise wanted on engine set up B18C1 for track racing.
- what hatch would be faster?
- What should my new car run?
- best street cam??
- My new all motor beast set-up 230+whp daily driven
- Better header Spoon or Mugen?
- H27Vtec???
- How much more valve lift when VTEC kicks in ?
- does anyone know how to install a skunk2 intake manifold??
- 2.0liter vs 1.8liter? Power difference with same head/cams? Dynos wanted.
- next build up ideas here for intertune tv
- 10K rev'n B18c1 build up... what you think????
- Best Valve Train Parts?
- ALL MOTOR WORK NEEDED
- My NA setup - Fuel ideas anyone?
- How can I messure the Valve clearance on my B18C block ?
- question on stroker kit
- Exhaust piping Question
- GE vtec oil return kit
- Who has experiance with the AN-R.com headers ?
- JG PRO Series Head
- noob question...sorry, i searched.
- tranny ? about LSD>>>>>>>>>>>>>>
- if i put a gsr block on a b16.....
- important checklist for cylinder head rebuild?
- D1.6 non-vtec head swap?
- where is the best place for sleeving
- What is the rod length in a B18C5?
- what bearings? (did search)
- max power w/CTR cams on 2L?
- weird idling? HELP
- attn: all motor junkies
- E.N.D.Y.N intake manifold
- which cam JUN or Skunk2 2 for h22a allmotor
- ITBs & injector placement
- Wondering how the 3" Thermal sounds like on a NA??!! **video**
- jun cams question.
- Question: Rebuild LS motor into VTEC or just buy a VTEC motor ??
- Whats the difference between a gsr crank and a itr crank
- Please rate this set-up...
- problem no one can figure out
- Toda B cams . . . reliability?
- which spark plugs to use?
- help with deltacam 272 on d15b7
- Race engine build up (trackracing) for My 1998 ITR
- Building a B18A all motor
- FPR+Gauge, which ones are you guys using?
- Beat price on Hondata gasket?
- all motor d16a6
- Engine Stands
- Difference in displacement: Gsr block vs. b16 block w/ gsr crank
- A/F ratio
- im looking for a header for good TORQUE...
- individual throttle bodies vs JG intake manifold
- MY BUILT H22 SETUP
- Fuel management question for '00 Si
- how to get ur car light?
- Endyn IM - What's it built for?
- Import Builders. Reliable power. Big Whp. All motor experts needed!!
- Built NA motor+Boost?
- B20B block and 94LS hydro tranny into civic EG3 (with hasport kit)?????
- list your clutch and flywheel
- golden eagle, aebs, or rs machines for 2.0 rebuild
- list your 2.0 liter combos
- 11.1 compression enough for toda c or s2s2?
- IB Spec Super Dupers Wiseco Pistons
- Balanced GSR rods VS ITR rods
- 2L gsr build up -- what pistons/compression?
- does anyone know how??
- H22a- Milling head to raise compresion?
- engine builders and parts finders look!!!
- all motor setup
- Brand name cold air intake vs the no name...
- Piston and Rod quest
- ctr cam tuning question
- What size injectors for my setup??
- Front Body Mods EG to EK
- Is the compression calculator accurate?
- 96-00 Coupes with gsr post times and setup 4 ALL MOTOR
- AEBS intake manifold/Fuel Rail
- Building my 2.0 need suggestions
- ITR Intake Cam: Give Me The Truth!
- DHR New Intake Manifold
- cheapest LS/vtec setup?
- forged pistons or stock ctr cast iron pistons?
- Where are good places to find Spoon Oil pumps
- pistons or just shave?
- gsr motor swap, what cams?
- ITB's on stock motor.....?
