- my lsvtec vs k20 integra
- Question about keepers.
- Catch can ?
- Custom set-up, need to know if it will work
- GSR Teggy gots a blown ring on cyl 3 and decided to go ALL MOTOR b20v
- JDM B18C swap questions
- Tuning Help B18C1
- The H vrs K Head Debate Pics INSIDE !!!
- Pulling one of my cars out after around 4+ yrs
- INFO
- ►►March-April | All Motor Classifieds | FS & WTB ◄◄
- cincyb20ek build
- Piston to wall cleaance
- Lighter Rods - Crankshaft Counter Weight
- B series headers ???....
- Adv. Port Theory Discussion: Bias flow and directionality
- Skunk 2 springs and retainers (packaging inquiry)
- Upgrading cams... Have a few questions...
- OPINION ON A CAM
- Help b20b
- new tune for lsv???
- Need help rebuilding my H22A4 Engine!!!
- notched ls pistons
- need help id'ing these cams
- intake valve springs on exhaust side
- Header help.
- B Series Crank Pulley
- Lets build an engine for my hatchy!
- 1.8ltr B16b 222 whp
- Has anyone heard from Donf lately?
- Sleeved block... 2 options... Need opinions
- need help rebuilding my b18c1
- weight of b18c-r oem rods?
- B16A2 Head and Block, OEM HG, CTR P2V Clearance?
- bearing clearance
- Need a shop to install sleeves.
- B18C5 E85 Motor build
- main bearing markings
- Best event in the midwest....
- F2.3 237 whp@7700 rpm stock H22 internals (Cams-pistons)
- balancing rotating assembly
- Would aftermarket pistons give me extra hp
- 13:1 compression what plugs
- b18c TYPe R valves, Springs and Retainers on GSR head
- wats a good setup for lsv?
- HELP! D15b7 mini me tranny questions!
- all motor, non vtec vs vtec tranny
- 07 Si Sedan - 250whp
- TODA CAMSHAFT SPEC SHEETS A-C
- GSR vs LS vs B20
- hondata question/ help
- 84mm 13:1 compression E85
- basic all motor ls going into a very light car
- Bisimoto Level 3 cam timing
- gsr block question
- Staying on top of oil changes lol
- Stock ITR or Omnipower 70mm Throttlebody. That is the question
- Some questions for my build: TB/Injectors/etc.
- B18C5 ITB's + Super Charger Combination
- build help, b18a
- How to tell if a block is sleeved.
- any h22 mahle gold all motor builds????
- Troubleshooting: small damage mark on Crankshaft journal. Is this a big problem?
- What is this part?! No start...
- Parts from Japan
- h22 engine rebuild advice?
- is this easily fixed?
- b18c vs k20a3
- Will this manifold work ok???
- Bisimoto Header
- cam advice
- RLZ engineering or King Motorsports
- 92mm stroker kit
- Removing weight from the rockers?
- NEED HELP WITH B20 ENGINE
- Minimum combined mill of a block and head?
- 200 whp B16
- rebuilding b20vtec questions
- Which to chose Brian crowers Stage 2 or 3?
- 94 civic D16z6 stock, suggestions please.
- Del Sol H22A Dyno video
- Where's SMSP??
- y8 lx block with y8 vtec head, do i need to replace oil pump
- Honda injector compatibility
- vtec on b18b??
- smoking in vtec
- MDX with Compression of 210 PSI for Cylinders
- New Goodie arrived today @ work..
- Compression ratio calculation question
- Toda Cam Gear Timing Belt B18B1 B16 Head 22T water Pump
- Power Steering-HELP
- How true is it that a shaved head would make your valves be heard more
- B18a1 obd0 with gsr obd1 head
- 94gsr head on 96 gsr block....anything?
- Re-Installing Cams (noob)
- CRX K24 build
- JDM B16 crank's BUT wont start.
- injector question for all motor running e85
- H22 Sleeves?
- 11.54@117 at IFO 84x89 stock build (video)
- B18C1 Build help
- B20 vtec getting tuned on the 21st
- Toda spec B vs Skunk2 pro2
- fully built b20v
- 2 layer head gasket question
- My H2B set up.
- first time motor build
- Skunk2 manifold gsr
- Making It Reliabe
- ITB experts, school me...
- oil pressure gauge install on b20
- compression check h22
- J-Series Build
- Question... head gasket / paint / cleaning
- spark plugs and oil for B18c
- EG K26 build
- Another oil squirter thead...
- "Quiet Exhaust"
- h2b header
- first startup b20v not running right. open to try aaanything..
- Engine Mount replacement rubber?
- surprising!
- Zeal Autoworks Calculator Question?
- VTEC supposedly not working on newly built B16A motor
- Power loss help.
- compression help
- B16 itbs
- Head Gasket or Not?
- GSR DRIVER SIDE MOTOR MOUNTS ?'S PLZ HELP
- h2b header question?
- my very first dyno!
- got ?s bout to do a d16a6 p29 slugs
- ls vtec in a crx, crank pully?
- H22 problems would appreciate any and all input
- d16 tb/intakemanifold questions *NOOB*
- Built Type R Head
- water in cylinders 94 honda
- b18c3
- DIY ITB ON MILD BUILD LS-VTEC
- Stock con rod & crank on B18CR 2.0L???
- blown head gasket help
- GSR block with LS crank
- clutch selection for mild b20vtec
- b20 vtec head question
- toga oil pump, any good?
- Block Suggestions?!!!
- Cams-Intake Manifold question
- Does walbro fuel pump change PSI on stock fpr?
- need suggestions on n/a d16a6 build
- rc injectors to big???
- vtec working sometimes
- d15
- 195whp can i get near it?
- integra ls b20b swap problem
- head work done
- Crane cams help
- pr3/p30 pistons with oversized valves
- stroker h22 build
- The E85 All Motor thread.
- Crower or Manley rods?
- wich is faster!? ls-v or gsr?????
- ETD Racing or Full-Race - Quality, Design, Cost...
- Pistons B16a+crank B18C6
- ITR B20 Build
- h22 number 3 rod bearing
- Crower stage 3 cams what oil to use!
- Is it a good idea to change my normal engine oil to fully synthetic engine oil on CRV
- eg hatch engine??????
- stock injectors?
- crazy all motor power on stock internals!
- D16Zc all motors problem
- D16z6 build
- will this work for a good N/a setup?
- cams/springs and retainers
- lsvtec, compression numbers vs. Whp vs. tuning
- CAN I RUN 13s JUST ON A BUILD HEAD???
- Re-Torque head studs?
- GSR EG6 BUILD SUGGESTIONS
- please help on LMA question
- best b series headers
- oil leaking from headgasket?
- Question on Flow Bench & cylinder head Performance
- Whats a good RPM to put launch control on a stock LS/VTEC?
- can someone tell me what this is on the cylinder walls?
- Pretty Little Green CRX
- Hp Gains Suggestions
- high comp gsr
- Valve spring tool
- Am I down grading with my new exhaust?
- endyn fluidampr vs ati race damper
- Carbed b16 build
- b16 intake, intake mani, and header advice
- p2v v2v clearance.
- B18c endyn build
- Fairly stock, anything to be gained with tuning?
- AEM Fuel rail with Victor x manifold
- ITR CAMS VS SKUNK CAMS VS SPOON CAMS
- Max safe RPM for this build, help me chose cams?!?
- B16b CTR build
- Ls/Vtec Stg2 cams FD 4.9 wheel hop and wheel spin... Help!
- 2.0 gsr build advice needed
- Project Prelude
- H23A question
- b16 Race car cams?
- How does the Clutch Slave on bb6 work?
- What does a PS oil cooler Do?
- Fuel Injectors. help please.
- 2.0 all motor cam advice
- Nippon 84mm pistons? do they exist?
- comp. test results?
- Website for Engine Hp numbers?
- Import Auto Pros Cam question
- Porting/ Portmatching questions
- V2v and V2p and degreeing cam question
- Bucks erratically at 1/3 tank of gas...
- Crx HF engine rebuild question
- Is anywhere safe to turn crank with T/belt removed?
- Skunk2 Engineering Vid - How We Design Products
- Pistons and rods questions
- d16z6 ignition timing issues pls help
- my b18c smoking hi revs
- poor mans type r cam setting
- OBX or AEBS
- my b16 isnt able to time what do i do?
- LS DIZZY ON A GSR HEAD?
- D series engine build,, Require help
- D16Z6 N/A Quick Questions.
- need help for crank swapp
- Stupid MSD. 94 GSR distributor cap vs 94 Integra
- Valve adjustment before or after cam degree
- B18a1 build help.
- jhpusa questions???
- Type R Cams
- b16 build
- valve train help
- What seller did you get your 3" inlet ebay intake?
- Need to contact allmotaeg6! Paid for parts and still not received!
- JUN B18C header Advice Good or not?
- can a B16 be bored over to 84.5?
- b16 cam journal problem..
- B20Z2 possible cracks or casting?
- need some help with my ek4
- HELP me milled Head GSr !?!
- Oil burning question...
- needing opinions for my build
- gsr or b16 head
- B series valve guides
- going high compression, any bad/good experiences?
- first B build
- ctr intake cam w/ itr exhaust OR gsr exhaust cam??????
