PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Header question about JASMA Headers!!
  2. budget build questions
  3. quick H23 O2 sensor question
  4. j37a4 swap
  5. wont idle lower than 1700?
  6. 93 civic problems
  7. Way too loud
  8. BPi stack and whale penis intake
  9. K Series worth it?
  10. NEED HELP ASAP! HORRIBLE GAS MILEAGE IN K20Z1 SWAPPED EJ8
  11. Why Does my fuel pump fuse keep popping cant figure it out? 15a fuse
  12. stock ls rods w/ arp bolts vs. eagle h-beams
  13. dirt in b16 head
  14. Drag Cartel Drop in Cam Test - K20Z1
  15. blox cams
  16. who can shortening a Skunk2 IM??
  17. Timing Belt getting shred up somehow. H22A motor in Del Sol
  18. K20a ITB's
  19. The OEM Honda JDM P73 .25mm oversize pistons that were "discontinued" = false
  20. How do I remove a cosmetic headgasket lead residue?
  21. crank position sensor
  22. H22A crank in F22
  23. what happened to these bearings?
  24. Blox Max flo or OEM ITR header
  25. K20z3: Pump Gas Dyno Tune
  26. B20B vtec with B16 cams.
  27. h22 dyno graph question
  28. Headers for b16a
  29. GSR head flow #'s
  30. itr 4-1 header fit on b16???
  31. looking for a budget build that will pass CA smog
  32. B16A head question....
  33. Walbro 255 Fuel pump On stock B20b ok??
  34. Fuel Injector size for all motor setup??
  35. Any Experience with Bisimoto's Rods?
  36. Valve spring replacement troubles...Help please.
  37. Is ACT dropping their socks???
  38. What's my next mod, b16a2??
  39. LSVTEC Rod Bolt Question
  40. LSvtec to B20vtec Questions
  41. Did I messed up my rod bearings?
  42. gsr tranny problems
  43. oil burning issues
  44. Old Dyno, New Dyno, tune on sat
  45. s2s3 tuner vs pro1 vs 98 type r cams
  46. Timing belt got owned again? H22A
  47. opinion on b16 build
  48. jdm b16 and need an exhaust
  49. 2000 accord v6 tranny or engine swap question
  50. b16a2 with gsr head?
  51. not sure witch swap to go with!!! a lil help please
  52. Please help me identify ITR valvespring
  53. NEED SERIOUS LS VTEC HELP
  54. ls vtec allmotor advise
  55. B16a Build Help/Tips
  56. Omni man Build
  57. HELP!!LS-VTEC BUILD 13.1 COMP. ISSUES
  58. h2k?
  59. NEED HELP w B16A in 92 Hatch
  60. LS/VTEC help
  61. pro fab headers???
  62. B18c compression?
  63. B16a crank angle problem (not wiring)
  64. where would i find?
  65. Jeez! anyone ever try this?
  66. max hp for a built b16!?
  67. valve guide clearance...
  68. SRP pistons?
  69. wats highest compression streetable?
  70. pistons and vavles quick question...
  71. all motor b18c1 with 3inch or 2.5?
  72. diferences between dual valve springs?
  73. Gsr Build Questions
  74. Any mismatched valvetrain horror stories?
  75. Where to buy built bottom ends??
  76. pistons on connecting rods B18B motor
  77. Which rod bearing set do I get when buying oem? confused
  78. Jdm h22a what piston rings do i use?
  79. RS PISTON RING GAP??
  80. (I Need Advice)Frankenstein Motors B-Series(which combos make the most power ?)
  81. lsv cooling issues
  82. question about upgrading injector size for b16a
  83. REAL SKUNK2 STAGE 3 TUNER CAMS??? HELP
  84. Build advice
  85. Manley Pistons in Oem C.Rods
  86. Rocker arm installation?
  87. valve angles debate here!!!
  88. Oil filling up Endyn breather too fast!!
  89. head work done and run stock ecu?
  90. WANT TO BUILD A NA B16
  91. FS JUN 4 prototype B series camshafts
  92. Pressure in the valve cover. HELP Whats causing this????
  93. aftermarket wrist pins quick question
  94. LS.....WHAT??????????
  95. 91 civic hatchback
  96. MSD ignition and Blaster 2 coil - stock cap and rotor - bottleneck?
  97. recs for oil pan gasket?
  98. My B18C Build - Input Appreciated
  99. Big loss between 2.36"(Apexi Noir) and 2.50"?
  100. Short vs. Long Intake Length
  101. Stock ls flow bench results!!!
  102. Camshaft Upgrade Dilemma....
  103. Built B20 Vtec Idle problem... HELP!
  104. identity of CP pistons dome
  105. LIKE TO HEAR WHAT YOU THINK
  106. ACCORD RWD
  107. Header too big for exhaust? FCUK!
  108. Block swap question
  109. Exhaust Decisions?
  110. can anyone identify this header? shoud i use it?
  111. faster in DC integra... b16a or b20z?
  112. Skunk Pro3 clearances
  113. torque specs for the cam covers/ b16 head gsr cams
  114. running rich + spark plug question
  115. Buddy Club Cams Spec III or IV ???
  116. need buddy club spec 4's!!
  117. k20a3 head
  118. question about cams
  119. Tach issues and miss fire (2 different issues)
  120. My new build! for a little while anyways...
  121. d16y8 problems, can you guys help me out
  122. B18C1 build
  123. 2.0L ITR swap 246hp/155tq
  124. b17 and p30 pistons
  125. Bizzare issue: Low power output
  126. how to make my header looking clean again
  127. 95 integra gsr tune and dyno
  128. fully built ls vtec
  129. h22a type b cams
  130. Oil getting dirty in 1500 miles?
  131. Need help asap! blow-by problems!!
  132. GSR Help
  133. What the hell?!?!?!
  134. help with my gsr
  135. B SERIES N/A CATCH CAN PICS REQUEST
  136. 550cc Injectors to big?
  137. Oil ring expander
  138. D16Z6 Build
  139. d15 crank in d16 block
  140. Energy Suspension Motor mount inserts
  141. H22 HEADER AND CAT QUESTION!!
  142. list your ls/vtec set up
  143. Hytech authentication
  144. engine stiffeners
  145. B16 with 75 shot of nitrous video
  146. ALL MOTOR JDM GSR CATCH CAN QUESTION
  147. blox a cams. lets hear them reviews
  148. head gasket size question
  149. anyone here port their own intake manifold?
  150. SK2 Pro1s vs. SK2 Pro2s for my build?
  151. identifying cams
  152. B16A N/A help...Cams, lma's, etc.
  153. New block from Blueprint Racing!
  154. Looking for the best Cams that make more power for my built B20Vtec?
  155. Help deciding on cams for my setup plz
  156. throttle body ?'s for b18c1 with b16 head
  157. Anyone run PCT/CTR pistons before?
  158. b16a2 Need advise please
  159. Another bearing clearances help thread....
  160. B20Z Questions
  161. sohc help
  162. need help
  163. quick question about professional products tb
  164. Help with d16 build
  165. INJECTORS!!!
  166. do connecting rods have a specific order
  167. what are the differences between the b series oil pans ?
  168. plz help ground issues
  169. LSVtec 12.5 cr with Skunk Pro1?
  170. Bottom end help
  171. lsvtec
  172. CP Piston 11.5:1 piston to deck height.
  173. B16 crank Pulley on GSR? Need help!
  174. problems with my first h22a...
  175. WeaponR throttle rotor
  176. The ever re-occuring "ls/vtec build thread"
  177. dyno'd my b16a yesterday
  178. b16 build! what should i do now??? any advice???
  179. Alaniz Competition Head Work..anyone?
  180. GSR Intake Manifold question
  181. Magnetic Drain plugs
  182. 270hp stock cam k24!!
  183. quick piston question
  184. Aftermarket Throttle-body to Support Cruise Control?
  185. aebs headstuds
  186. Burning Oil Smell coming from Engine Bay...
  187. b18a1 N/A 200whp?
  188. my ls vtec will i make 200hp?? will i hit 12 sec or low??
  189. Trouble choosing fuel injectors
  190. H22A1 NA Fully built tuning/ecu isues
  191. B20- Vtec build help.
  192. sk2 pro2 cams
  193. injector and tuning Q
  194. B-Series Piston Opinion.
  195. LS/VTEC
  196. Going all motor, I need header/exhaust advice for DB8
  197. 2.1L BUILT MOTOR.
  198. Just bought a lsvtec and there is no oil feed line to the head!!!
  199. leakiy B16A.. SPRAY OFF??
  200. Is there a best tranny for an H23 to put an LSD in?
  201. YOUR OPINION AND ADVICE.
  202. sk2 pro2 cams
  203. lets see those b18c5/b18c numbers!!!
  204. daily drag car project
  205. b20 rod bolts , acl rob bearings .
  206. need help guys!
  207. Lsvtec oil plug in head
  208. Head codes?
  209. H23 CEL 7, WTF is throttle angle?!?
  210. Future plans for my 98 DC2 advice please!
  211. help with block specs *searched
  212. Best Cam for 11.6:1 b20v daily driver?
  213. QUICK HELP
  214. How soon is too soon?
  215. wanna build my d15b
  216. 2.0 LS V-TEC build
  217. Opionis on this motor I plan on buying
  218. is 13.2 compression to much for pump gas??
  219. Intake VS Intake Question????
  220. H2B without kit!!!!!
  221. vtec valve spring seats
  222. Fully Builting H22
  223. Clutch....ive searched and searched and searched
  224. b16 head typer cams
  225. Help with Header
  226. About the Zex cams...
  227. whats the best intake manifold
  228. how to adjust fuelpressure!!!!
  229. blox type c
  230. b20 vtec 84.5mm 11.5.1 oversize? (reliable or not?)
  231. Late night victory
  232. tune? w/dyno graph
  233. need help verifying tuner1's
  234. Predicted HP Numbers?
  235. Help choosing intake system for B16
  236. Valve clearances with M22x and Supertech valvetrain
  237. Is a Port n Polish worth it for this setup?
  238. are these type r cams????
  239. Modded B18C1 Doesnt run right.
  240. I'm a dousch, what order do the wires go on the rotor?
  241. water pump question
  242. Wrong section, please delete
  243. God's of Greddy, may your hammer be mighty
  244. my new ported head
  245. Lesson learned, now I need some advice on where to go from here (LONG)
  246. From turbo to ALL MOTOR BABY!!
  247. b18C5 all motor circuit racing engine specs.
  248. 176whp B16 looking for next stage..
  249. B16 Timing belt alignment questions
  250. B20/Vtec guys please chim in...
