PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Moved on up, Next gauge install Water temp
  2. doing the impossable
  3. whats better for a n/a build b16a2 b18c1 or poor mans type r
  4. more power from my gsr??
  5. retorque problems .....HELP PLEASE
  6. 1/4 mile run
  7. ctr pistons for ls vtec. need help
  8. Ls vtec problems coolant everywhere
  9. Spark Plug Test (linked from preludepower.com)
  10. B20 vtec project
  11. Hurricane IKE flooded my motor
  12. valve keeper size? (need to verify)
  13. Mount bracket
  14. $20 H/F Balance shaft removal.
  15. header fitment
  16. Velocity Stack dimensions?
  17. Rear Main seal
  18. boring type-r manifold for tb question
  19. B18b1 Cam install
  20. buddy club cams adjustment???
  21. Valves not seating??? HELP
  22. 0.9 is it enough to re-tune??
  23. Timing Chain Help!!!
  24. Should My Oil Pump Gear Look Like This??
  25. What equipment/tool is need to measure cylinder head spring pressure?
  26. ***Porting for Dummies***
  27. b20z??
  28. Build High Milage b16 or buy new JDM b16 and build?
  29. Running rich ruin o2 sensor?
  30. smoke during cold start
  31. H22 high Compression "LOST"..!!
  32. crank, usable or scrap it?
  33. ITB's for an ls
  34. Best way to clean valves? I have them out of the motor already
  35. poorman's type r
  36. DH-Racing Head PICS
  37. port and polish
  38. cracked b-series cylinderheads
  39. will skunk2 pro 2's do me much good?
  40. ITB BUILD?
  41. 84mm Sleeved GSR, But with a Stock Port Head. Stupid?
  42. b20b head swap-b16 or b18???????
  43. Will x manifold and X TB Put my motor flat on its face
  44. What cams are ideal for my setup and goals?
  45. stock gsr tune?
  46. My All Motor Brethren
  47. F23 NA BUILD
  48. need info on sleeves???
  49. are buddy club III+'s much better than CTR cams?
  50. Washed Cylinders -> Zero Compression?
  51. budget all motor d series build????
  52. Thanks DonF!!!!!Actual first engine build!
  53. HELP BUILDING A MOTOR
  54. Thoughts on regrinds
  55. Muffler question
  56. how many ft lbs of torque for a b18a1 head bolts??
  57. Will Integra Type R pistons fit on LS rods?
  58. H22a Crankshaft Turning Torque
  59. distributor & tranny ?
  60. b20vtec pump gas?
  61. 30mm Throttle Body
  62. Help! Buddyclub dualvalve springs with sk2 pro1's!
  63. 11.51@116.14 with 237whp- Street ALL MOTOR K20 EG- Stock block, Stock cast head
  64. Windshield Wipers 96 Honda Accord lx
  65. B16b what i can do?
  66. 94-01 GSR Cylinder Head Differences?
  67. MY CROWER F23 CAM Help me understand specs
  68. SSR / DTR *Street Sweeper* VS Traction bars? Anyone run into fitment issues??
  69. Bad Results with Built Motor. Plz Help!
  70. Block
  71. Question About Valves?
  72. TB/Intake Manifold Combo For My set-up
  73. H22a
  74. integra low idle
  75. mahle frm compatible pistons
  76. Blox Racing Big Tube Tri-Y Header + TSR 85mm B20 VTEC Integra
  77. What plug and what gap
  78. b20/vtec ?'s
  79. Searched: rarely any useful results. Installing oil pressure gauge?
  80. Identifying Cams from a gsr
  81. fuel sytem upgrade?
  82. exhaust help
  83. How much for a k-20
  84. How to measure milled head?
  85. p30 pistons from b16 into gsr block
  86. best all motor LS set up??
  87. How do i find out if i have forged, low compression pistons???? HELP
  88. F20C ITB'S....
  89. what cams are they?
  90. New guy here looking for some input and info
  91. Cylinder Head gurus - Please comment on work performed
  92. tb and intake manny
  93. Lsv fuel problem
  94. GSR cams with B16 cam gears?
  95. All motor and catch cans
  96. cast pistons no oil squirters???
  97. Throttle body question?
  98. NEEDED ASAP: OBD2B INTEGRA GSR VACUUM LINE DIAGRAM
  99. How to adjust AEM tru-time Cam gears HELPP
  100. Post Your All Motor JDM H22 Type S Piston Builds!
  101. GSR build help!
  102. top mount vs. lower mounted injectos dyno and pix?
  103. throttle sprocket and return on individual throttle bodies? two issues i'd like to address
  104. ITR b18C5 swap question....
  105. Changed my route now i have questions
  106. CAR NOT STARTING Need Help
  107. Stock compression height on B18A/B pistons?
  108. 3rd gear pull, spark plugs are brite white!! lean??
  109. ARP Rod Bolts On Stock H22 Rods
  110. jdmb16a hp??
  111. Extrude hone anyone have experienced with it??
  112. best place to assemble my motor
  113. need advice on b20vtec project
  114. jdm d15b w/ y8
  115. Convential vs synthetic hp gains
  116. best big throttle bodies (68-70)
  117. burning oil b20 vtec!
  118. Tranny problems?
  119. Amazing
  120. bent valve
  121. fully buit b20 head on stock bottom help
  122. Help me with my GSR build please.
  123. not sure what parts to get for d16
  124. jdm b18c
  125. b16a problem help please!!!
  126. B16A2
  127. Leakdown Testing help
  128. More power vs. more support for current power?
  129. LS/Vtec Soon to be tuned.... suggestions needed
  130. need some input
  131. Valve spring shims
  132. Honing Question
  133. To increase OR Not to increase RPM range
  134. B18c1 build
  135. the great debate.. P72 vs. PR3 heads
  136. PROPPER HONING OF H22 CYLINDERS??
  137. Fully built motor is it worth it?
  138. B16a VS GSR Tranny
  139. want to know how i will run on my gsr
  140. Ls/vtec torque specs/ built book?
  141. CTR intake cam on stock valvetrain?
  142. timing belt adjustment ?
  143. im upgrading my motor and im want to run straight 110 octane on all motor!!! will i make more power?
  144. 00b18b's LS/Vtec dyno results
  145. How to for n00bs: Gain 20whp for less than $30
  146. problem getting propper type s pistons....
  147. this doesnt sound right. 165whp tuned, on high compression.. mustang dyno
  148. Kind of an odd ball build!!!
  149. Camshaft holder tool
  150. New o2 and still throw code 41, need help asap, dyno is tomorrow.
  151. Need Velocity Stack Socks!!
  152. Will this PCV system work?
  153. engine oil
  154. does anyone know the where to get an oem b18c OIL COOLER? Part #? other questions too
  155. sohc build
  156. Swap
  157. 101 octane tune...
  158. LS VTEC SUGGESTIONS FOR 200 HP
  159. question
  160. All Motor noob, few question
  161. Need help with a daily driven build!
  162. best header
  163. Daily Driver?
  164. block decking question.
  165. compression test results need help noob
  166. passwordjdm chamber intake vs CAI
  167. stroking the b16
  168. b18 help
  169. Rocket Motorsport Cams
  170. Custom Modified PRB manifold vs. RBC
  171. Metel in VTEC solenoid gasket
  172. oil consumption and coolant
  173. b16a pistons in b18a1 block (ls-vtec)
  174. what vtec cams are good at 10000rpm?
  175. Where to buy ITR valvetrain new?
  176. Crower 403's for DD, Stock Retainers or Titanium?
  177. Clearance Issues?
  178. LS/VTEC HELP NEEDED!!!!
  179. 200 whp b16 ctr pistons
  180. need advice...
  181. Lookin for some insight on my build!!?
  182. Help me ID these cams!
  183. usdm itr pistons on ls eagle rods
  184. BOOK RECOMMENDATION NEEDED
  185. Comptech Icebox on a Stock ITR Intake Arm?
  186. intake and exhaust size on 2l LSvtec
  187. Need some input on my BUILD??
  188. jdm b16 build
  189. help with motor swap
  190. MOTOR HELP
  191. 221hp All motor....4.4 or 4.7 fd?
  192. clutch problems...need help asap.
  193. h22 cam choice...
  194. rebuild motor and it wont start !?
  195. needing inputs on compression
  196. Fresh Rebuild-PRO TECHS-Break-In Question/Oil Prime?
  197. Breaking in an engine.
  198. Need help on my setup.
  199. Engine break in.
  200. OBX ITBs?
  201. Site Moving on Monday (Down Time)
  202. valves
  203. stock internal b20vtec spark plug gap
  204. Detonation question
  205. Euro R h2b dyno results.
  206. VICTOR X
  207. Straight GSR ARP head stud torque specs
  208. need opinion on fixing a blown engine
  209. A/F Ratio's on all motor...
  210. all motor b16 with gsr trans?
  211. RACING SPEC VI CAMSHAFTS
  212. Building B16
  213. time in relation to mph
  214. balanced clutch/flywheel ??
  215. Dynojet numbers
  216. (DIY custom air box) cone filter VS. panel filter
  217. new block
  218. ITB gurus, a minute of your time please
  219. GSR w/ LS crank help
  220. how should i build my b18c5
  221. Best pistons and rods?
  222. Tell me what I'm looking at - spun bearing?
  223. All Motor 84.5x89 GSR 230+whp Rocket, Supertech, Dyno, Pics!!
  224. What can i do to get the most out of my motor.
  225. euro r tb question
  226. buddy club spec IV ID help.
  227. cheaper...ls/vtec or b16 swap
  228. Help Please...
  229. My H22 Dyno...........hmmmm
  230. daily driver project -b20 build
  231. People running oem 1-layer headgaskets!!!! 3 quesions
  232. Toda Spec B's + b16a2, Searched but still need answers....
  233. ITBS
  234. B20 vtec w/ B18C5 crank, gridle, oil pick up, and rods????
  235. Anyone running RS MACHINES Vtec Eliminator Cams?
  236. high compression ls (ctr pistons)
  237. need help with rpm/ tach signal for gauge
  238. NA 3inch intake... for UNDER $100??!!
  239. Help me identify this mystery part...
  240. header modification question
  241. JDM b18c gsr throttle response N/A
  242. N/A K20a2 EG TB ?
  243. What B-series engine can Rev the highes???
  244. Difference between B18c R 96 and 98 spec
  245. B16A2 with CTR EK9 Pistons for Daily drive
  246. h22a,h23a,b18 lots of parts for sale taking best offers on all
  247. Cam Choice need some info plz
  248. gsr ecu
  249. How do i change cam gears on the cams
  250. B20 block is it possible to use Ls Crank?
