PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 [175] 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. injectors for b20
  2. valve train question...
  3. Hondata w/ boost option on NA???
  4. All motor LS project!
  5. B18C-R mods
  6. Question about Eagle H beams
  7. All motor B20VTEC ***200WHP 135ft/tq BUDGET TYPE R KILLER*** 56k killer
  8. exhaust manifold
  9. max rev on a h23vtec
  10. BUDDY CLUB spec 3+ cam gear settings?
  11. Cons of hot tanking a Sleeved Block
  12. Need Help!!!! Freshly rebuilt z6 runs BAD!!!!
  13. Best valvetrain for LS?
  14. wanting to go all SOHCmotor
  15. GSXR 600 ITB's?
  16. Skunk2 valvespring
  17. Skunk2 Stage 2 owners
  18. Why is revlimiter at 6500????
  19. ctr type r pulley alt. belt??
  20. Built B16b header choice (already searched)
  21. Honda Engines Codes...
  22. Omni valvetrain
  23. Welding Combustion chambers on b16 Head!
  24. Difference between b18b/b18c/b20 blocks?
  25. Cheap ITB's??
  26. Cam Gears!!!!what will they do?
  27. My Stock B16B CTR Dyno
  28. B18C OR B20/VTEC????ON CRX
  29. EG6 Spoon header
  30. B20/VTEC ??????????
  31. 99 Accord AUTO
  32. Maybe you ALL_MOTOR guys can help me?
  33. b18a LS...will ctr pistons fit into a LS?
  34. Any Advise For b20 vtec
  35. Chip maps
  36. pistons from B16B
  37. who all makes 4-1 headers?
  38. N/A tuners prepare for the New Honda engine
  39. f20c rod bolt torque spec?
  40. building gsr block
  41. b16 dyno test @ method motor works in fresno,ca PART 2
  42. Whats an SAFC hack
  43. Just sharing some dyno info....RedZone Performance
  44. which side is rich?
  45. Omni or RM valvespring retainer?
  46. I Have a B18B........
  47. 96 rs daily driver, is 200bhp a reality??
  48. gsr head with dual valve springs?
  49. CTR transmission mated to b18c1 platform?
  50. T-belt belt too loose.
  51. unorthodox crank pulley
  52. gsr cranked b20/vtec ?'s that i need opinions on
  53. whats next on the b16a2
  54. Port and Polish
  55. b20vtec?
  56. crower stroker kit for b18c?
  57. Rocket Motorsports H22 Regrinds???
  58. **200 WHP Stock Block GSR-Part2:Retuned**
  59. Rebuilding a hydrolocked engine?
  60. Headgasket help....
  61. Pics of porting work
  62. modifying a header for deckplate/ talldeck motor?
  63. ls vtec question\ctr pistons/ctr cam shaft
  64. Best D16Z6 cam
  65. Transmision for Lsvtec
  66. LS/VTEC Dyno's
  67. your knowlege of sohc d16 tolerances
  68. what vtec head sould i use??
  69. compression test results
  70. Used Hondata ???
  71. VAFC question, some1 must know about it
  72. need HELP finalzing motor project (my first build)...lsvtec
  73. how much HP/ TQ increase will i see in PCT/CTR pistons????
  74. Pump Gas
  75. idol air control
  76. Rods?
  77. Engine build question
  78. help! jsut got hondata back for h22a in 94 hatch... detonation
  79. Pyrometer vs Wideband o2
  80. I bearm Vs H beam Vs X beam, benfits and downsides?
  81. DIY valveseal removal on d16?
  82. FIGHT IT OUT
  83. I need 1 .25mm Oversize CTR Piston
  84. TODA spec B cams w/ OMNI power valvetrain?
  85. mid 13 sec ls?
  86. Valvetrain chatter!!
  87. Engine Builder in the Northeast (search didn't give me any help)
  88. another crvtec! ?
  89. Ever Heard of Timing Being so Far off That You Get ZERO CR When Testing?
  90. Cams,Cams,Cams so many choices?
  91. diff. intake/exhaust side cams?
  92. Bogging b18c 2k-5k vtec..please help
  93. B16 Dyno
  94. DYI: How to lock your rockers for claying your motor
  95. crower stage 2's...grind down rocker arm's this true???
  96. single cam itb's
  97. what type of gains with blox type A cams
  98. Automatic SiR Project
  99. help finding pistons
  100. need advice on wht to do
  101. when you first start a car, why does water come out the exhaust?
  102. All motor ITR setup
  103. Oil Pump Crank Trigger Sensor
  104. Valvespring rate/camshaft consideration?
  105. which block b18c or b20b?
  106. what intake manifold to use with my hi-comp set-up?
  107. Installation Headwork
  108. Question about fuel stuff, FPR, Fuel Rail and Gauge? What else do I need?
  109. reving my gsr to 8400 on stock valvtrain
  110. d-series setups.
  111. B18A block, B16A head & CTR pistons - safe with a chipped ecu??? RACE GAS ONLY
  112. OBX Iridiums = NGK or Denso?
  113. Bubby club camshafts
  114. Attention Crome/Uberdata users, should i use p72 or p30 base map for ITR engine.
  115. B18C5 vs B16A head question
  116. ls/vtec slow?
  117. Am I idling to high??
  118. Does anyone have an opinion on Aeroturbine Exhaust System?
  119. What Air fuel ratio is best for NA?
  120. need help with Main Bearing selection
  121. my ls/vtec=171.9hp & 136.2tq
  122. hmm... well i got a b18a for free...
  123. header final choice
  124. Headgasket
  125. jdm itr smog test
  126. jun cam for h22a, yes or no?
  127. b20vtec what should my fuel pressure be??
  128. alternator belt for 94 hatch with h22a? what do i get?
  129. 90 Accord - Electric problems?
  130. Civic Type R Crank Pulley!!!!!
  131. ZC Dyno
  132. couple of Q's about the b17
  133. head work
  134. anyone here take itr valvetrain to 9k?
  135. I just want to have fun
  136. twin disk clutch question, bolts? check out the pics.
  137. oil pump?
  138. opinion on ACL bearings??? reliability??? installation??? B18C
  139. Buddy Club Cam degree ? HELP !!!
  140. d16y8
  141. are the .40 over jdm itr replica pistons reliable on stock sleeves??????
  142. CTR P30 or PR3 in an LS
  143. better exaust for gsr
  144. Flatslide thottle body
  145. Arias Pistons or JE?
  146. //////////FOR SALE SEMI BUILT GSR SOCAL//////////
  147. any Kseries putting down over 200 lb-ft of torque @ the wheel?
  148. data logger ?
  149. Whats the best kind of cams to use with stock valvetrain?
  150. B16 gears in ls tranny?
  151. where to get individual throttle bodies?
  152. long tube dc header
  153. an-r header group buy
  154. Golden Eagle Ls/Vtec Conversion kit?
  155. Darton Open Deck Sleeves and Max Bore Size
  156. NEED ADVICE ON A HEADER, PLEASE HELP!!!!
  157. CBR 954's?
  158. I thought 3" exhausts were only for boost but....
  159. Profab header fitment pics (56k=owned ya heard)
  160. type r cams r stage 2
  161. aftermarket / overbored throttle body - gasket question
  162. Safe Fuel PSI for 11.0:1 Compression GSR?
  163. 1st all motor build
  164. FYI leading edge oil
  165. BC's 3+ or BC's 4
  166. hope for the 7th gen civic?
  167. New to B-series: ITR cams upgrade?
  168. i want to make power but i dont really want to turbo or noss i want to na with out port and polish
  169. stock gsr+methodmotor works=151 whp
  170. anyone use the rocket m25 cams?
  171. 87Civic W/d15a2 carb, rebuild or swap?
  172. Are you supposed to replace LMA's with bigger cams?
  173. i wana add nos to my.....
  174. where can i get a typr R Tranny???????
  175. low cost GSR rebuild?
  176. D16A6 minime need help
  177. p73 pistons in a b18b
  178. Building All motor jdm ITR in 99 civic si
  179. Throttle Body for ITR
  180. what to do to type r b18c and keep stock block
  181. ARP Headstuds
  182. any H22 with Y1 track times??
  183. XSI Vtec?
  184. best h22 header for the money?
  185. DC Sports 4-1 Ceramic Header - Any good?
  186. which header for my setup
  187. Haha Skunk2 Dyno
  188. timing itr cams in a stock b16
  189. suld I hhhhmmmmmm????????
  190. Congrats Charles madrid & skunk2 team
  191. Anyone know anything about these ITB's
  192. H-T, help me decide! BC 3+ or S2S2 cams?
  193. D16a6 valve springs
  194. Forged cranks vs billet cranks vs oem honda vs ???
  195. Car not starting? Please Help...
  196. whtas your choice??????
  197. quick queston. will a gsr oil pan work on a B20 block?
  198. Fuel Pump prob? Please Help!
  199. finally put the car on the dyno
  200. ls/vtec
  201. Gutting the Si for the track
  202. White smoke at start up
  203. NA SOHC 154.85 whp
  204. B18c5, B16A, and B18c1.... which one to choose??
  205. high power cam?
  206. B20 VTEC Help!
  207. Valve Spring Rates / Specs
  208. Tensioner broke...looking for experience/advice...
  209. ITB's Yay Or Nay?!?!?
  210. mased! headertech vs comptech race header
  211. pr3-3 head???Help
  212. shop around pittsburgh for ls vtec
  213. h22 type-s in dx coup
  214. wtb gsr itbs twm jenvey etc
  215. Mase Tuning@ Modacar 211whp 1.8 b-series
  216. Skunk2 stage 3's rough on valvatrain?
  217. What Compression are you guys running on your "STREET" motor??!??
  218. cam gears adjustment.
  219. ls/vtec ? compression and octane
  220. NEW SKUNK CAMS
  221. LS Vtec
  222. NA ls/vtec build .... comments & suggestions needed
  223. f20b dynoed
  224. what type of wire everyone is running?
  225. 310cc inj. + jdm p30 yes or no?
  226. B21 A1
  227. Milling
  228. b16 dyno test @ method motor works in fresno,ca
  229. robearracing FPR?
  230. Spoon Pistons...
  231. m22 cams....where can i get some 4 a good price?
  232. CTR cams in a B16 + port/skim
  233. CTR cams in a B16 + port/skim
  234. b20 block or build what i have
  235. Home made Throttle Bodies videos.
  236. Nice 262hp Allmotor setup ... very simple; very clean !!!
  237. What is the most N/A HP that someone has made out of a B Series?
  238. skunk2 Mani fitment
  239. b16 all motor video, loud vtec - open header
  240. Help me out with my plugs they look lean
  241. 200whp daily driver b16?
  242. Best sleeves for high rpm /high compression motors
  243. which skunk 2 cams do the bc 3+ cams compare to?
  244. WTB Mini-Me
  245. anyone have an n/a ls/vtec bin?
  246. ALL MOTOR b20 builts
  247. anyOne Know of a Cheap illegal smog place? (So Cal)
  248. k20 cams question
  249. water pump/timing belt change on LS/vtec
  250. k series tuners (looking for the most competent tuner)
