PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. k20 swap
  2. Skunk2 Pro-series camgear failure
  3. S2k retainers
  4. HELP! 2 radiators BLOWN in ONE day!! PLEASE HELP ME!
  5. 125hp and 130hp. what do you think?
  6. 1st--->2nd---->1st= Broke!
  7. can i tell before tearing down if it's a cylinder wall or head gasket?
  8. Help!! with b16a built
  9. 2.0L ls/v questions
  10. gsr vs itr crankshaft
  11. ctr header with 2.5 collector
  12. Camshaft for B20V (Toda B, Jun 3, BC 4?)
  13. What Should I Run ?
  14. B16a2 JDM Rebuild - Opinions?
  15. Does a pr-3 "integra ls" throttle body and intake manifold fit a d16z6?
  16. vtec controller killerb thoughts
  17. ITBS OBX (Map Sensor?)
  18. machining rods to accept larger rod bolts?
  19. b20b 7300 rpm redline?
  20. New Bisimoto Dynos Charts
  21. 98 prelude automatic circle track
  22. heading to the dyno soon.
  23. b18 gsr to b20 vtec
  24. b18c build
  25. Questions about all motor LS set up
  26. D15b7 Block with a D16a6 head
  27. all motor b17 or all motor b18b1
  28. Rev Limiter
  29. Blown Head Gasket? help me diagnose (pics inside)
  30. itb questions
  31. Delirium Motorsports (Luis Curredors Civic Si) DYNO and Track vid
  32. I have what appears to be 2 small hairline cracks in one of my sleeves.
  33. solution to dented feel's twin cam 4-2-1
  34. stock rebuild with lean air/fuel
  35. My Nonvtec B22b frankenstein
  36. 81m LSVtec w/ Blox C cams - new numbers
  37. H22 help
  38. Looking for best h22 engine builder
  39. 1.9L ITR motor?
  40. anyone with with experience on crower stage 2 cams???
  41. Mugen F3 engine
  42. Help B20vtec build Guidance and suggestions
  43. HELP!!!! Having Problems with my B20vtec
  44. What should I gap my spark plugs to for my all motor d16z6
  45. ring suggestions
  46. 200whp OEM build
  47. b20vtec dyno then and now 2 years later
  48. What are GE Oil Squiter Blockoffs?
  49. All motor b18c in civic 97
  50. Why is my d16z6 keep hesistating and backfiring before it goes
  51. First build, need some input!
  52. Blox B cams Advice? HELP
  53. Decisions decisions decisions... built all motor or supercharge
  54. high compression gsr questions
  55. loss of power!
  56. To buddy club spec IV 4 camshaft ppl, dialing question
  57. b20 block sleeving
  58. b18b1 all motor
  59. stock valve springs mixed up (LS head), help identify
  60. BC5 ID marks
  61. Are High compression valves worth it?
  62. B17 cam question
  63. 2 liter pro 2 cams looking for advice
  64. 2 liter B16B
  65. Rookie questions
  66. Piston clearance question
  67. ls vtec????
  68. just got the ek tuned
  69. b16a2 problem
  70. lookin to build a high rev b series
  71. help deciding on valves and valvetrain
  72. All motor B20vtec, UK.
  73. Pointers, Advice, with my NA B20vtec build?
  74. Piston ring end gap (b20)
  75. spoon engines??
  76. MY LS VTEC DYNO #...
  77. need help
  78. Blox test pipe, what size is this? 2.5" or 2.25"?
  79. All motor 81mm GSR pro2 carnage pics
  80. where to buy OEM and what machine shop??
  81. spark plug gap and tuning question
  82. manul Transmission Fit?????
  83. 12.5:1 compression in factory civic.
  84. VENTURI effect TB
  85. Please advise my h22 build
  86. MY 1st ALL MOTOR BUILD.. I NEED HELP!
  87. I need your advice on an H22a
  88. d15b7 Compression Ratio
  89. Need Help with Smog...failed
  90. B20/VTEC loose timing belt!
  91. Simple cat question
  92. Haters rejoice (A20) content
  93. b16b vs b16a2
  94. Best blox cam ffor 12.0:1 comp?
  95. NEED COMPRESSION HELP PLEASED
  96. maxbore b16 throttle body be enough for this setup???
  97. Header design question
  98. s2s1 tuner series
  99. What's the Compression Formula????
  100. Best header for the money????
  101. white smoke out my oil cap
  102. What Header Is This?
  103. "Spark Plugs" Jobs in a motor.
  104. Buddy Club Spec II Question...
  105. eagle rods bore size
  106. Wiseco XX ring set markings
  107. detonation fully built ls/vtec
  108. Poor mans R, with ls crank? HELP!!!!
  109. "Oils" Jobs in a motor.
  110. NOOB here, how do i Torque rods?
  111. Crankcase/valve cover venting question
  112. HX Build!? Single Slammer Economy ;)
  113. looking to build my LS V need you help
  114. Skunk Mega Power Header?
  115. feels like i lose power in 3rd gear when i hit vtec
  116. Thoughts on B16A setup?
  117. I/M comparison
  118. crank's scratched up a tiny bit
  119. What intake manifold should I choose??
  120. high compression ls/vtec exhuast setup question
  121. B18A header Fit a B18B
  122. type r engine parts
  123. need help. does someone have a list of all the seals/gaskets for b16a2 engine
  124. What kind of oil should I use for my motor d16z6 142 whp e85
  125. New pistons
  126. B18c(r) All Motor Build...Need input
  127. All Motor GSR??????
  128. mpfi question
  129. fuel injector OR ecu problem!
  130. Skunk2 Pro2 H22 cams HELP
  131. cylinder head milling??
  132. Best/most important gauges for all motor
  133. B16a Mild NA Build - Just a feeler w/ Questions
  134. skunk2 tuner sping seat pressure
  135. b16b?
  136. are they ok to use
  137. A1 block with type r pistons question
  138. b20vtec pistons
  139. H23/Blacktrax on F23?
  140. Why is my car missing after I checked the spark plugs PLEASE HELP
  141. what injector size should i be running???
  142. Help me I.D. these rods and pistons
  143. TWM ITB PROBLEM
  144. throttle body size, 1.8 high compression
  145. timing issue!??
  146. who makes 101mm crank for B-series?
  147. bc4 vs pro1 on 12.0 b20
  148. What is the compression (psi) of a obd1gsr (on a compression test)
  149. Cruising while holding at vtec crossover
  150. 12.0:1 n/a build best cams?
  151. BAD CLUTCH!????
  152. D16Z6 Build Q's?
  153. gsr loose timing belt
  154. B16 build help
  155. 84.7mm B16a build
  156. difference between old and new pro2?
  157. Civic EG B20 tuned 215whp
  158. BloxC cmas dyno numbers 11.5 lsvtec
  159. BDl Cam Gears and V2V questions
  160. 96 vs. 98 spec itr cams
  161. all motor gsr hatch 1/4 mile runs
  162. offroad h22a unlimited class 5 BAJA
  163. Experienced Opinions Needed on Bearing Clearances....
  164. skunk2 pro 1s
  165. obd1 b16 idles high
  166. B20 Vtec Oil Pressure HELP!!!!
  167. timing off?
  168. Nitrous build ???'s
  169. b20 swap confused
  170. supertech inner spring
  171. Recomendations for my N/A setup (what IM I should use)
  172. Question for b20vtec guys
  173. b16a head reassembly
  174. Catch Can Setup on OBD1 B18a1 Block/ITR head
  175. h22 build ?
  176. Want to build NA B series
  177. b18c4 help
  178. b16 balance shaft, aluminum crank pulley
  179. B20 VTEC oil leak !!!! HELP
  180. CYP Sensor problems- cant fix
  181. gsr block b16 head
  182. stuck head bolts! help!
  183. Help With CAM Identification!!
  184. Help with tuning a B20Vtec
  185. GSR 2001
  186. piston rings???
  187. Tri-Y Header data collection and Results
  188. Blox Velocity Stack and Filter ~DYNO COMPARISON~
  189. Stock b20 w/arp bolts..?
  190. CRX?
  191. 178whp is this about right?
  192. which headers to use
  193. can someone help me figure out which correct ACL race bearings to use?
  194. N/A H22 Build - Dyno Results
  195. CTR Pistons in a B17?
  196. Which cams SHOULD I use?
  197. b17 with wavy torque plot
  198. B20 Vtec blow by PLEASE HELP.
  199. How much does a hone take off?
  200. takin a leap...into k24 world
  201. Need help
  202. B20B swap Help
  203. Leakdown Test Results, Compression Test...opinions?
  204. D16Y7 Build
  205. arp bolts on rods
  206. Piston to valve clearance questions.
  207. No VTEC!! Code 6
  208. pro1's w/ buddy club valvetrain
  209. JDM B20B block question
  210. jdm b16 vs 98 jdm itr throttle body & intake manifold on stock jdm b16a
  211. stock b16 block vs ls block with srp 11.1 pistons.
  212. b18a question
  213. 360 infinite usa???
  214. Rings: JE proseal vs Wiseco vs Supertech
  215. CYP Code on b16
  216. Blox C versus Blox A
  217. 11:1 compression, ok with 91 octane?
  218. Need some help, smoke
  219. 1st GEAR vtec FOR 96 ACURA INtegra GSR is not working
  220. Cylinders 1 and 2 do not fire at idle
  221. question for the tuner's?
  222. Greddy sandwich plate fittings
  223. F22B1 head questions
  224. Nyce1's TGR Talking Smack About Cali Heads
  225. blox tuner type c cams. anyone heard of them
  226. Highest Compression Ratio for Pump Gas??
  227. high compression build questions
  228. Which Is Faster > h22a vtec with h22 tranny/h23/f22 tranny
  229. Buddy Club camshafts spec 3 plus w/ ITR valvesprings?
  230. skunk pro 2"S
  231. GE lsvtec dowel pin location
  232. Bisimoto V2 header tested!
  233. b20vtec head gasket ??? ASAP
  234. Bad LMA's? Video inside
  235. Anyone ever done b18a bottom,ls rods,ctr pistons,b16 head combo on a stock ecu?
  236. building a mild b18b1
  237. CEL for tps sensor...but not when motor is warmed up!? HELPPPP
  238. b16 head vs b18c head
  239. B18 Block Questions
  240. Gasket sets HELP!
  241. are these bc4 cams?
  242. GSR and ITR rods
  243. burning oil after rebuild....
  244. Supertech Valvetrain Questions
  245. Preluded Injector Question
  246. h22 pro 3 cam question....
  247. Car Stalling/ oil light problem...
  248. what pistons for over 81.5
  249. stock gsr skunk2 pro 1s
  250. 95mm stroke + 9,000 RPM = Fun
