PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Rocket m22x Cam Replacement
  2. whats the advantage of having larger intake valves and stock
  3. b16 valves vs. Aftermarket Valves
  4. ACL Bearings - used for 700 miles, tear down, re-build, can i reuse same bearings?
  5. toss up of 2 headers
  6. s300, can I do this myself?
  7. shifter bushing question
  8. dyno results , b16a2 , what do yall think !!!
  9. Need Help Identifying These camshafts (PICS)
  10. b20vtec
  11. Is 93 good for 12.5:1 compression?
  12. B16 or GSR Cams in B20 Vtec
  13. LS rod bolts
  14. Dyno opinions needed
  15. HONDATA problem...?
  16. Pistons/Wall Clearance/Sleeves/etc...
  17. ctr piston help!
  18. Internal versus External mods on the H22. SMSP + Euro-R vs. Type-S Pistons + Crower 2a Cams
  19. So, is anyone doing or planning any serious B series builds???
  20. Yet Another B18c1 Build
  21. B20 headgasket
  22. Question on ARP main studs...
  23. crankshaft pully B-17
  24. Aftermarket oem replacement valves?
  25. 15000rpm?
  26. Ported Intake Manifolds, Who, Gains, Prices
  27. Need your opinions on which cams for stock block B16A
  28. S2S3 Cam Help
  29. where is randy RMF?
  30. Which rods for k24/k20? *trying to find difference*
  31. B18C1 with CTR pistons trying to figure out compression ratio????
  32. ITR on B16 head
  33. b16 vs b18 theory
  34. quick q, moving piston up out of hole, comp ratio vs headgasket and clearance
  35. B16 head components, cams, gears, etc
  36. How much is it worth??
  37. How strong are OEM rods
  38. can any one tell me what code this is.
  39. Post your high end headers that clear AC
  40. Vtec stoped working
  41. will a VSS code in a obd0 car with no VSS affect my tuning?
  42. B20 Vtec
  43. SIR II cams
  44. few NA dynos. *vid*
  45. cable vs. hydro half shaft
  46. Skunk2 Pro 2 CAMS WITH ROCKET VT???
  47. intake arm and velocity stack...
  48. Clearances
  49. Ever heard of tube seals?
  50. In need of a good basemap!!!
  51. BDL/STR fuel rail fitting
  52. Questions about worn rockers
  53. B18c / GSR Ignition Timing Maps Post Them Up
  54. LS/Vtec in DC2, WHAT POWERSTEERING PUMP and BRACKET?????
  55. d15b vtec in crx distributor problems
  56. skunk2 stage3's VS Pro2's.
  57. poor man ITR
  58. b20 vtec build up!
  59. Ideal Plenum Size for ITBs
  60. searched but no dice. has anyone tried the new sparks 84mm pistons?
  61. advice and guide in building my motor
  62. b20/vtec HELP!!!!!!!!!!!!
  63. k24/k20 or straight k24a2?
  64. Accord sport ?CAM?
  65. Tuning Advice, B18B1 (OBD-0 w/ PR4), built head
  66. getting tuned this week......any precautions
  67. Portflow Head
  68. Please HELP !! B16a2 with M24X Cams
  69. DSM obd1 450cc Injectors...
  70. kms performance?
  71. skunk2stage 2 blox b or blox c or possibly bc3s or others (longgg)
  72. new guy here with some ?????
  73. Want more out of my B20 Vtec
  74. Re-torque ARP head studs.
  75. Rev limit...9200??
  76. axle and lsd question
  77. b20 injectors
  78. Question on clearance?
  79. MT 20-8-14 WHAT PSI
  80. d16a6 pm7 piston and webbers 40
  81. 2.5 in exhaust vs 60 mm
  82. CTR PULLEY WITH BALANCED ROTATING ASSEMBLY
  83. Timing Issue...retard or advance(ignition)
  84. ARP rod bolts for b18c1
  85. No name crank pulley vs STOCK
  86. Boring .20 over to 81.5mm
  87. Need to CC my heads, does anyone know where i can get a kit?
  88. is my throttle body too big?
  89. N/A BUILD...FUTURE MAYBE TURBO?
  90. Buddy Club 3+ and stock B16A valvetrain
  91. buddy club spec 4 cams and smog
  92. What ya thinking?? B20 Vtec build up.....
  93. 2007 Si K20 All Motor Builds
  94. LS/V build, motor sounds too loud? Vids inside.
  95. MAXBORE JORGE anyone know how to contact him??
  96. About 20-30 trq and whp loss on bone stock jdm itr in 1900lbs eg cx hatch?
  97. FERREA valves H22
  98. Rev limit help!!
  99. Question about ITB - e-throttle and MAF (or I want to put ITB on my Exige)
  100. b20z2 vtec build?
  101. Most cost efficient way?
  102. Dyno day
  103. VTEC Controller, USEFULL or NOT????
  104. d16y7 with pm7 pistons and webber40
  105. F1 RACING FLYWHEEL
  106. Could a shaved head w/ the cam gears zero'd out cause positive manifold pressure?
  107. Oil Squirters vs. weisco -- weisco wins
  108. port volume
  109. Poorman's R with GSR Head?
  110. another octane booster poll. but i need it. lol. so help me out
  111. problem with my mains...opinions...pics inside!
  112. F20C exhasut ports vs. K series?
  113. which HEADER vibrant or JGE?
  114. jdm b16 block with gsr head
  115. I got boned at the machine shop, how badly will this hurt me?
  116. h22 for sale
  117. Best Place and Pricing for an RS*R Exmag?
  118. Intake cam seized. Need advice....HELP!
  119. Are skunk2 titanium valves a direct drop in?
  120. Where should i start?
  121. Cam Selection Assistance Please... yep another one.
  122. both front lower mounts?
  123. Help?
  124. New drag car pics( these are actually current)
  125. spark plugs for high compression?
  126. exhaust sound collection anywhere?
  127. valveseats after mileage
  128. exhaust setups
  129. 05 RSX-S Injen Intake Test (CAI vs stock)
  130. how many miles do you have you your build motor?
  131. oem tune ups or napa tune ups.
  132. what would be a good start for a h22 build?
  133. jdm itr stock in eg cx hatch ran 8.5 in 1/8 mile,what mods should i do next?
  134. High Flow Cat suggestions
  135. skunk2 pro2s or pro3s
  136. ITBs on a stock B16?????
  137. How hard should it be for me to turn my cams???
  138. ***HELP***
  139. WTB 22x8x15 slicks
  140. my car smells like gas....
  141. are b16 and ls main bolts the same/compatable?
  142. Phenolic intake manifold gasket
  143. Distributor cap (GSR)
  144. Buddy club stg 5????
  145. Obd 2 to Obd1 do i need crank sensor hooked up
  146. What to do?
  147. B16B buddy club IV's, and some other stuff
  148. JDM B18C help
  149. Race Motor Options
  150. HELP IDENTIFY THESE CAMS ARE THEY ROCKET M24X??
  151. 12.5:1 do I need race gas
  152. Rocket M24X cams dyno graph, results inside!
  153. 18mm wrist pin?
  154. Thanks DonF
  155. cross post: MFactory IM...
  156. lightwight Crankshaft H22A ???
  157. skunk2 pro 2
  158. What sparkplugs are you running?
  159. 87x95 H22a build-up pics
  160. ITB air horn funnel........helP
  161. N/A d16z6 question
  162. Highest CR on 95/96 Octane
  163. 83 mm b18c1 good idea? bad idea?
  164. People with a milled H22A?
  165. does your timing being off make you run rich? timing belt ?
  166. removing remains of graphite head gasket
  167. Blox i/m ?'s
  168. some of the better parts on the market
  169. vibrant header?????
  170. B20 question
  171. How bad is this damage on my head, how to fix??
  172. PISTON REMOVAL and p30's CONTINUED
  173. injectors questions?
  174. oil cooler question
  175. DRAGLS WE HAVE A TRANSACTION ISSUE THAT NEEDS TO BE RESOLVED!!!!
  176. Exploring my options, Wanting a high reving engine with 200-250whp. Input appreciated :)
  177. Crower vs Eagle rods weight?? immediate help please
  178. Z-10 rear block fitting
  179. my b18c build up
  180. LS Valve Spring Tricks??
  181. B20v
  182. SUMMER PLANS
  183. Plug Indexing
  184. My JDM ITR Needs Its Head Build!
  185. What Dual valve springs and retainers are these?
  186. D16Z6 vs D15Z1 vs D15B8 - Fuel economy / Performance
  187. What gap should i go with ?? Help
  188. Your thoughts on my set-up?
  189. need help quick!!!!!!!!!!!
  190. Need Help Fast!!
  191. individual throttle bodies
  192. Estimates for whp for 1995 integra LS
  193. Stock fuel pump limit???
  194. Am I undercammed???
  195. got back from dyno, need input for my #'s
  196. Current GSR SET up What octane to run
  197. Advice needed
  198. Jack from P1 Auto
  199. Walbro 255 info
  200. PCV/black breather box question
  201. Benefits of port welding in the head
  202. skunk2 68 mm TB
  203. b16a head vs. gsr head
  204. Help me pick my CR
  205. stock b18a block/ stock b16 head in DA
  206. B.Crower 0012 stage 2 cam
  207. ctr pistons and bc4's<<
  208. b18c1 all motor setup questions
  209. Torque specs for b16a main caps and con rods
  210. Honda prelude doch v-tech engine mod. Is it posible???
  211. tach jumping and engine sputtering after build/swap
  212. Ls Vtec Build
  213. Who did your sleeving ???
  214. b18c-r oil i should use.....
  215. All motor exhaust question
  216. ARP rod bolts - is rod resizing always necessary?
  217. Help changing piston rings
  218. b18c1 piston ? help
  219. help with catchcan/pcv setup???
  220. b16a2 s4c tranny on my ITR
  221. IM advice...
  222. vid of my all motor civic
  223. *****Help Surging Idle*****
  224. Brian Crower Stage 3 Cams
  225. Skunk 2 intake manifold on a B16a EF
  226. What size injectors should I run...HELP PLEASE!!
  227. what supertech valve springs/titanium retainers you guys recommend for my friend setup
  228. JDM ZC HELP Problems after swap
  229. Help me Identify my OEM B series cams.
  230. Bearings 4 B20
  231. already searched and found nothing. difference in 1.6 and 1.8 liter
  232. POLL: Who did your headwork?
  233. TPS CODE HELP!!!
  234. Seized piston 2 & 3 rings, fuel wash down? HELP!!!
  235. wheel ?
  236. B20
  237. Hondata S300 Engine stalls at 2000 RPM
  238. What are some of the best aftermarket valve springs for the money?
  239. Engine Builders - Is bore honing always recommended ?
  240. Skunk pro stage 3 for H series, Need advise
  241. what size injectors are you running?
  242. need more power out of motor
  243. GOt a question about cams.
  244. LSvtec build
  245. estimates on the power i'll be makin
  246. cam specs?HELP? b16 or 1.8 GSR's
  247. ALL motor itr
  248. A few questions
  249. GSR crank + rods good for B16?
  250. What do you veterans think my LSV will make once it is done?
